, including all inherited members.
add_facet(CubitFacet *facet) | ImprintPointData | [virtual] |
add_match_data(ImprintMatchData *match_data) | ImprintPointData | |
add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
adjacent_points(CubitPoint **adj_points, int &num_adj_points) | CubitPoint | |
adjacent_points(DLIList< CubitPoint * > &result_list) | CubitPoint | |
attachedFacets | ImprintPointData | [private] |
bounding_box() | CubitPoint | |
check_inverted_facets(const CubitVector &new_position) | CubitPoint | |
coef_vector() | CubitPoint | [inline, virtual] |
coef_vector(const CubitMatrix &coef) | CubitPoint | [inline, virtual] |
coefVector | CubitPoint | [protected] |
compute_avg_normal() | ImprintPointData | |
coordinates() const | ImprintPointData | [inline, virtual] |
coordinates(double point_array[3]) | ImprintPointData | [virtual] |
coords | ImprintPointData | [private] |
CubitPoint() | CubitPoint | |
d_coef(const double d_coefficient) | CubitPoint | [inline, virtual] |
d_coef() | CubitPoint | [inline, virtual] |
dCoef | CubitPoint | [protected] |
debug_draw(int color=-1, int flush=1, int draw_uv=0) | CubitPoint | [virtual] |
define_tangent_vectors() | CubitPoint | |
delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
delete_TD(ToolData *td) | ToolDataUser | [virtual] |
du(CubitVector &duvec) | CubitPoint | [inline, virtual] |
du() | CubitPoint | [inline, virtual] |
dv(CubitVector &dvvec) | CubitPoint | [inline, virtual] |
dv() | CubitPoint | [inline, virtual] |
edges(DLIList< CubitFacetEdge * > &edge_list) | ImprintPointData | [virtual] |
endPartition | ImprintPointData | [private] |
entityId | ImprintPointData | [private] |
FacetEntity() | FacetEntity | |
facets(DLIList< CubitFacet * > &facet_list) | ImprintPointData | [inline, virtual] |
facets_on_surf(int surf_id, DLIList< CubitFacet * > &facet_list, CubitBoolean &on_internal_boundary) | CubitPoint | |
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_edge(CubitPoint *other_point) | CubitPoint | |
get_end_partition() | ImprintPointData | [inline] |
get_list_loop_pos() | ImprintPointData | [inline] |
get_loop_pos() | ImprintPointData | [inline] |
get_loop_size() | ImprintPointData | [inline] |
get_match_list(DLIList< ImprintMatchData * > &match_data_list) | ImprintPointData | |
get_matching_point() | ImprintPointData | [inline] |
get_next_seg() | ImprintPointData | [inline] |
get_parents(DLIList< FacetEntity * > &facet_list) | CubitPoint | [virtual] |
get_point_type() | ImprintPointData | [inline] |
get_prev_seg() | ImprintPointData | [inline] |
get_start_partition() | ImprintPointData | [inline] |
get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
get_uv(CubitFacet *facet, double &u, double &v) | CubitPoint | [virtual] |
get_uvs(CubitFacet *facet, double &u, double &v, double &s) | CubitPoint | [virtual] |
id()=0 | CubitPoint | [pure virtual] |
ImprintPointData(double x_val, double y_val, double z_val) | ImprintPointData | |
ImprintPointData(const CubitVector &new_point) | ImprintPointData | |
ImprintPointData(ImprintPointData *copy, CubitVector &new_coords) | ImprintPointData | |
initialize_imprint_data() | ImprintPointData | [private] |
is_feature() | CubitPoint | [inline] |
is_matched() | ImprintPointData | [inline] |
is_owner_vertex() | ImprintPointData | [inline] |
isFeature | CubitPoint | [protected] |
isMatched | ImprintPointData | [private] |
listLoopPos | ImprintPointData | [private] |
loopPos | ImprintPointData | [private] |
loopSize | ImprintPointData | [private] |
marked(int marked) | ImprintPointData | [inline, virtual] |
marked() | ImprintPointData | [inline, virtual] |
markedFlag | CubitPoint | [protected] |
matchingPoint | ImprintPointData | [private] |
memoryManager | ImprintPointData | [private, static] |
merge_points(CubitPoint *cp, CubitBoolean keep_point=CUBIT_FALSE) | CubitPoint | [virtual] |
myOwner | ImprintPointData | [private] |
myPointType | ImprintPointData | [private] |
next_feature_edges(CubitFacetEdge *this_edge_ptr, DLIList< CubitFacetEdge * > feature_edge_list) | CubitPoint | |
nextSeg | ImprintPointData | [private] |
normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
normal() | CubitPoint | [inline, virtual] |
normal(CubitFacet *facet_ptr) | CubitPoint | |
normal(CubitQuadFacet *qfacet_ptr) | CubitPoint | |
normal(CubitFacetEdge *edge_ptr) | CubitPoint | |
normal_ptr() | CubitPoint | [inline, virtual] |
num_adj_facets() | ImprintPointData | [virtual] |
owner(RefEntity *my_owner) | ImprintPointData | [inline] |
owner() | ImprintPointData | [inline] |
ownerRefVertex | ImprintPointData | [private] |
pointMatches | ImprintPointData | [private] |
points(DLIList< CubitPoint * > &point_list) | ImprintPointData | [inline, virtual] |
prevSeg | ImprintPointData | [private] |
project_to_tangent_plane(CubitVector &pt) | CubitPoint | |
remove_facet(CubitFacet *facet) | ImprintPointData | [virtual] |
remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
remove_TD(ToolData *td) | ToolDataUser | [virtual] |
reset_normal() | CubitPoint | [inline, virtual] |
rotate_normal(CubitTransformMatrix &rotmat) | CubitPoint | |
set(const CubitVector &pos) | ImprintPointData | [inline, virtual] |
set_as_feature() | CubitPoint | [inline] |
set_box_tol(double tol) | CubitPoint | [inline, static] |
set_end_partition() | ImprintPointData | [inline] |
set_id(int) | CubitPoint | [inline, virtual] |
set_loop_pos(int ii, int jj, int loop_size) | ImprintPointData | [inline] |
set_matched(ImprintMatchData *match_data) | ImprintPointData | |
set_matching_point(ImprintPointData *other) | ImprintPointData | |
set_next_seg(ImprintLineSegment *next_seg) | ImprintPointData | [inline] |
set_normal(CubitVector &surf_norm) | CubitPoint | [inline, virtual] |
set_point_type(PointType type) | ImprintPointData | [inline] |
set_prev_seg(ImprintLineSegment *prev_seg) | ImprintPointData | [inline] |
set_start_partition() | ImprintPointData | [inline] |
set_unmatched() | ImprintPointData | |
set_uv(double u, double v) | CubitPoint | [inline, virtual] |
set_uvs(double u, double v, double s) | CubitPoint | [inline, virtual] |
SetDynamicMemoryAllocation(memoryManager) int id() | ImprintPointData | [inline] |
shared_edge(CubitPoint *other_point) | CubitPoint | |
shared_facets(CubitPoint *other_point, CubitFacet *&facet1, CubitFacet *&facet2) | CubitPoint | |
shared_facets(CubitPoint *other_point, DLIList< CubitFacet * > &result_list) | CubitPoint | |
size() | CubitPoint | [inline, virtual] |
sizeVal | CubitPoint | [protected] |
startPartition | ImprintPointData | [private] |
surfNormal | CubitPoint | [protected] |
surfU | CubitPoint | [protected] |
surfV | CubitPoint | [protected] |
tangent(CubitFacetEdge *edge_ptr, double mindot) | CubitPoint | |
ToolDataUser() | ToolDataUser | [inline] |
transform(CubitTransformMatrix &tfmat) | CubitPoint | |
transform_to_global(CubitVector &loc_vec, CubitVector &glob_vec) | CubitPoint | |
transform_to_local(CubitVector &glob_vec, CubitVector &loc_vec) | CubitPoint | |
tris(DLIList< CubitFacet * > &facet_list) | CubitPoint | [inline, virtual] |
uVal | CubitPoint | [protected] |
vVal | CubitPoint | [protected] |
x() | ImprintPointData | [inline, virtual] |
y() | ImprintPointData | [inline, virtual] |
z() | ImprintPointData | [inline, virtual] |
~CubitPoint() | CubitPoint | [virtual] |
~FacetEntity() | FacetEntity | [virtual] |
~ImprintPointData() | ImprintPointData | |
~ToolDataUser() | ToolDataUser | [virtual] |
