cgma
MergeTool Member List
This is the complete list of members for MergeTool, including all inherited members.
about_spatially_equal(Surface *surf_1, Surface *surf_2, double tolerance_factor)MergeTool
about_spatially_equal(LoopSM *loop_1, LoopSM *loop_2, CubitSense relative_sense, double tolerance_factor)MergeTool
about_spatially_equal(CoEdgeSM *coedge_1, CoEdgeSM *coedge_2, CubitSense relative_sense, double tolerance_factor)MergeTool
about_spatially_equal(Curve *curve_1, Curve *curve_2, CubitSense &relative_sense, double tolerance_factor)MergeTool
about_spatially_equal(TBPoint *point_1, TBPoint *point_2, double tolerance_factor)MergeTool
add_merge_tool_assistant(MergeToolAssistant *mta_ptr)MergeTool
assistant_list_MergeTool [private]
CAMergePartner classMergeTool [friend]
can_separate(DLIList< TopologyBridge * > &bridge_list, bool check_parents)MergeTool [protected]
check_saved_id(BasicTopologyEntity *bte)MergeTool [protected]
cleanup_unmerge()MergeTool [protected]
compare_and_merge(CubitBoolean merge_flag, GroupingEntity *keeper_entity, GroupingEntity *dead_entity)MergeTool [private]
compare_BTE(BasicTopologyEntity *keeper_entity, BasicTopologyEntity *dead_entity) const MergeTool [private]
compare_GE(GroupingEntity *keeper_entity, GroupingEntity *dead_entity)MergeTool [private]
compare_notify(RefEntity *entity)MergeTool
compare_SE(SenseEntity *keeper_entity, SenseEntity *dead_entity)MergeTool [private]
compareEntityListMergeTool [private]
complete_merge()MergeTool [private]
contains_merged_children(Body *body, DLIList< RefEntity * > &merged_children)MergeTool
contains_merged_entities(DLIList< Body * > &bodies)MergeTool
contains_merged_entities(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > *merged_ref_ents=NULL)MergeTool
delete_instance()MergeTool [inline, static]
destroy_dead_geometry(CubitBoolean yes_no)MergeTool [inline, static]
destroyDeadGeometryMergeTool [private, static]
displayProgressMergeTool
end_unmerge(CubitBoolean top)MergeTool [inline, private]
entity_merged(TopologyEntity *entity)MergeTool
find_merge_tool_assistant(const std::type_info &type)MergeTool
find_mergeable_refedges(DLIList< RefEntity * > &entities, DLIList< DLIList< RefEdge * > * > &lists_of_mergeable_ref_edges, bool clean_up_compare_data=true)MergeTool
find_mergeable_refentities(DLIList< RefEntity * > &entities, DLIList< DLIList< RefFace * > * > &lists_of_mergeable_ref_faces, DLIList< DLIList< RefEdge * > * > &lists_of_mergeable_ref_edges, DLIList< DLIList< RefVertex * > * > &lists_of_mergeable_ref_vertices)MergeTool
find_mergeable_reffaces(DLIList< RefEntity * > &entities, DLIList< DLIList< RefFace * > * > &lists_of_mergeable_ref_faces, bool clean_up_compare_data=true)MergeTool
find_mergeable_refvertices(DLIList< RefEntity * > &entities, DLIList< DLIList< RefVertex * > * > &lists_of_mergeable_ref_vertices, bool clean_up_compare_data=true)MergeTool
find_only_mergeable_curves(DLIList< Surface * > &surf_list, DLIList< DLIList< Curve * > * > &lists_of_mergeable_curves, double input_tol=-1.0)MergeTool
find_only_mergeable_curves(DLIList< Curve * > &all_curves, DLIList< DLIList< Curve * > * > &lists_of_mergeable_curves, double input_tol=-1.0)MergeTool
find_only_mergeable_curves(DLIList< BodySM * > &body_list, DLIList< DLIList< Curve * > * > &lists_of_mergeable_curves, double input_tol=-1.0)MergeTool
find_only_mergeable_refedges(DLIList< Body * > &body_list, DLIList< DLIList< RefEdge * > * > &lists_of_mergeable_ref_edges)MergeTool
find_only_mergeable_surfaces(DLIList< BodySM * > &body_list, DLIList< DLIList< Surface * > * > &lists_of_mergeable_surfaces)MergeTool
find_only_mergeable_surfaces(DLIList< BodySM * > &body_list, DLIList< DLIList< Surface * > * > &lists_of_mergeable_surfaces, const double tol)MergeTool
force_merge(RefFace *face1, RefFace *face2)MergeTool
force_merge(RefEdge *edge1, RefEdge *edge2)MergeTool
force_merge(RefVertex *vtx1, RefVertex *vtx2)MergeTool
force_merge(RefEntity *ent1, RefEntity *ent2)MergeTool
force_merge(const DLIList< RefEntity * > &list)MergeTool
get_group_last_merged_curvs()MergeTool [inline]
get_group_last_merged_surfs()MergeTool [inline]
get_group_last_merged_verts()MergeTool [inline]
get_new_ids_on_unmerge()MergeTool [static]
group_results(CubitBoolean t_or_f)MergeTool [inline, static]
groupResultsMergeTool [private, static]
imprint_merge_solutions_for_overlapping_surfaces(RefFace *face1, RefFace *face2, bool execute, DLIList< CubitString > &display_strings, DLIList< CubitString > &command_strings, DLIList< CubitString > &preview_strings)MergeTool
initialize_settings()MergeTool [static]
instance()MergeTool [static]
instance_MergeTool [private, static]
lastCurvsMergedMergeTool [private]
lastSurfsMergedMergeTool [private]
lastVertsMergedMergeTool [private]
merge_all_bodies()MergeTool
merge_all_refedges()MergeTool
merge_all_reffaces()MergeTool
merge_all_refvertices()MergeTool
merge_bodies(DLIList< Body * > &refbody_list)MergeTool
merge_BTE(BasicTopologyEntity *keeper_entity, BasicTopologyEntity *dead_entity)MergeTool [private]
merge_entities(DLIList< RefEntity * > &entity_list, CubitBoolean should_clean_out=CUBIT_TRUE, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_GE(GroupingEntity *keeper_entity, GroupingEntity *dead_entity)MergeTool [private]
merge_refedges(DLIList< RefEdge * > &refedge_list, CubitBoolean should_clean_out=CUBIT_TRUE, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_reffaces(DLIList< RefFace * > &refface_list, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_reffaces_old(DLIList< RefFace * > &refface_list, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_refvertices(DLIList< RefVertex * > &refvertex_list, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_SE(SenseEntity *keeper_entity, SenseEntity *dead_entity)MergeTool [private]
merge_volumes(DLIList< RefVolume * > &vol_list, CubitBoolean print_info=CUBIT_TRUE)MergeTool
merge_with_auto_imprint(RefFace *surf1, RefFace *surf2)MergeTool
mergeSurvivorEntityListMergeTool [private]
MergeTool()MergeTool [private]
new_unmergedMergeTool [private]
old_merge_refedges(DLIList< RefEdge * > &refedge_list, CubitBoolean should_clean_out=CUBIT_TRUE, CubitBoolean print_info=CUBIT_TRUE)MergeTool
old_merge_refvertices(DLIList< RefVertex * > &refvertex_list, CubitBoolean print_info=CUBIT_TRUE)MergeTool
old_unmergedMergeTool [private]
OldUnmergeCode classMergeTool [friend]
parents_contain_merged_entities(DLIList< RefEntity * > &ref_entities)MergeTool
remove_compare_data()MergeTool
remove_merge_tool_assistant(MergeToolAssistant *mta_ptr)MergeTool
separate_bodies(DLIList< Body * > &separate_list, DLIList< Body * > *from_list=NULL)MergeTool
separate_edge(DLIList< Curve * > &bridges, bool descend)MergeTool [protected]
separate_edges(DLIList< RefEdge * > &separate_list, DLIList< RefEdge * > *from_list=NULL)MergeTool
separate_entities(DLIList< TopologyEntity * > &separate_list, DLIList< TopologyEntity * > *from_list=NULL)MergeTool [protected]
separate_face(DLIList< Surface * > &bridges, bool descend)MergeTool [protected]
separate_faces(DLIList< RefFace * > &separate_list, DLIList< RefFace * > *from_list=NULL)MergeTool
separate_vertex(DLIList< TBPoint * > &bridges)MergeTool [protected]
separate_volumes(DLIList< RefVolume * > &separate_list, DLIList< RefVolume * > *from_list=NULL)MergeTool
set_new_ids_on_unmerge(CubitBoolean value)MergeTool [static]
start_unmerge()MergeTool [inline, private]
test_no_tree(DLIList< RefFace * > &refface_list)MergeTool [private]
test_r_star_tree(DLIList< RefFace * > &refface_list)MergeTool [private]
test_r_tree(DLIList< RefFace * > &refface_list)MergeTool [private]
unmerge(DLIList< RefEntity * > &entity_list, CubitBoolean descend=CUBIT_TRUE)MergeTool
unmerge(RefEntity *entity_ptr, CubitBoolean descend=CUBIT_TRUE)MergeTool
unmerge(RefFace *face_ptr, CubitBoolean descend=CUBIT_TRUE, DLIList< RefFace * > *new_faces=NULL)MergeTool
unmerge(RefEdge *edge_ptr, CubitBoolean descend=CUBIT_TRUE, DLIList< RefEdge * > *new_curves=NULL)MergeTool
unmerge(Body *body_ptr)MergeTool
unmerge(RefVolume *vol_ptr)MergeTool
unmerge(RefVertex *vertex_ptr, DLIList< RefVertex * > *new_verts=NULL)MergeTool
unmerge_all()MergeTool
unmerged_entities(DLIList< RefEntity * > *entities=NULL) const MergeTool
unmerged_list_in_useMergeTool [private]
warn_about_refface_sense(RefFace *face_ptr_1, RefFace *face_ptr_2, bool faces_reversed)MergeTool [private, static]
~MergeTool()MergeTool
