about_spatially_equal(RefFace *ref_face_ptr_2, double tolerance_factor=1.0, CubitBoolean notify_refEntity=CUBIT_FALSE, CubitBoolean test_bbox=CUBIT_TRUE, int test_internal=0) | RefFace | |
actuate_cubit_attrib(int attrib_type) | CubitAttribUser | |
actuate_cubit_attrib(DLIList< RefEntity * >, int) | CubitAttribUser | [static] |
add_compare_data(RefEntity *partner) | RefEntity | |
add_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
add_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
add_hard_point(RefVertex *ref_vertex_ptr) | RefFace | |
add_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
add_sense_entity(SenseEntity *) | BasicTopologyEntity | |
add_TD(ToolData *new_td) | ToolDataUser | [virtual] |
adjoins(RefFace *input_face_ptr) | RefFace | |
append_attrib_internal(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
append_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
area() | RefFace | |
assign_default_name(CubitBoolean user_setting=CUBIT_FALSE) | RefEntity | |
auto_actuate_cubit_attrib(CubitBoolean from_constructor=CUBIT_TRUE, CubitBoolean after_geom_changes=CUBIT_FALSE) | CubitAttribUser | |
auto_read_cubit_attrib() | CubitAttribUser | |
auto_update_cubit_attrib() | CubitAttribUser | |
auto_update_cubit_attrib(DLIList< RefEntity * > &entity_list, CubitBoolean write_too=CUBIT_TRUE) | CubitAttribUser | [static] |
autoMergeStatus | RefEntity | [protected] |
BasicTopologyEntity() | BasicTopologyEntity | [inline] |
bodies(DLIList< Body * > &body_list) | TopologyEntity | |
body() | TopologyEntity | |
bounding_box() | BasicTopologyEntity | [virtual] |
bridge_manager() const | TopologyEntity | [inline] |
bridge_manager() | TopologyEntity | [inline] |
can_modify() | RefEntity | [virtual] |
center_point() | RefFace | [virtual] |
chains(DLIList< Chain * > &chain_list) | TopologyEntity | |
change_to_parent_ref_entities(DLIList< RefEntity * > &ancestors) | RefEntity | [static] |
children_mergeable() | RefEntity | [virtual] |
ChildType typedef | RefFace | |
class_name() const | RefFace | [inline, virtual] |
clear_all_simple_attrib(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
clear_all_simple_attrib_set_to_actuate(DLIList< RefEntity * > &entity_list) | CubitAttribUser | [static] |
clear_simple_attribs() | CubitAttribUser | |
clear_simple_attribs_set_to_actuate() | CubitAttribUser | |
co_edge() | TopologyEntity | |
co_edge_loops(DLIList< DLIList< CoEdge * > > &co_edge_loops) | RefFace | |
co_edges(DLIList< CoEdge * > &co_edge_list) | TopologyEntity | |
co_faces(DLIList< CoFace * > &co_face_list) | TopologyEntity | |
co_vertices(DLIList< CoVertex * > &co_vertex_list) | TopologyEntity | |
co_volumes(DLIList< CoVolume * > &co_volume_list) | TopologyEntity | |
color(int value) | RefEntity | [virtual] |
color() const | RefEntity | [virtual] |
common_ref_edge(RefFace *input_face_ptr) | RefFace | |
common_ref_edges(RefFace *input_face_ptr, DLIList< RefEdge * > &common_edge_list) | RefFace | |
common_ref_volume(RefFace *input_face_ptr) | RefFace | |
compare_alignment(RefFace *second_ref_face_ptr) | RefFace | |
comparison_found(RefEntity *partner) | RefEntity | |
CubitAttribUser(CubitAttrib *=NULL) | CubitAttribUser | |
CubitEntity() | CubitEntity | [inline] |
CubitEventDispatcher class | CubitObservable | [friend] |
CubitObservable() | CubitObservable | |
CubitObservable(const CubitObservable &) | CubitObservable | [protected] |
CubitObserver class | CubitObservable | [friend] |
dag_type() const | RefFace | [inline, virtual] |
RefEntity::dag_type(const std::type_info &) | RefEntity | [static] |
RefEntity::dag_type(const char *cli_type_name) | RefEntity | [static] |
deactivated(CubitBoolean flag) | TopologyEntity | |
deactivated() const | TopologyEntity | |
deactivatedStatus_ | TopologyEntity | [protected] |
delete_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
delete_TD(ToolData *td) | ToolDataUser | [virtual] |
dimension() const | RefFace | [virtual] |
disconnect_all_children(DLIList< TopologyEntity * > *children=0) | BasicTopologyEntity | [protected, virtual] |
disconnect_all_parents(DLIList< TopologyEntity * > *parents=0) | BasicTopologyEntity | [protected, virtual] |
disconnect_from_DAG() | TopologyEntity | |
encountered_ | TopologyEntity | [protected] |
entity_name() const | RefEntity | [virtual] |
entity_name(CubitString name) | RefEntity | |
entity_names(DLIList< CubitString > &names) const | RefEntity | |
entity_type_info() const | RefFace | [inline, virtual] |
entityId | CubitEntity | [protected] |
evaluate(double u, double v, CubitVector *position, CubitVector *normal, CubitVector *curvature1, CubitVector *curvature2) | RefFace | |
find_closest_point_trimmed(CubitVector from_point, CubitVector &point_on_surface) | RefFace | |
find_closest_points_trimmed(std::vector< CubitVector > &from_points, std::vector< CubitVector > &points_on_surface) | RefFace | |
find_cubit_attrib_type(int, DLIList< CubitAttrib * > &) const | CubitAttribUser | |
find_sense_entity(GroupingEntity *gpe) const | BasicTopologyEntity | |
find_sense_entity(BasicTopologyEntity *bte) const | BasicTopologyEntity | |
gather_bdy_entities(DLIList< RefEntity * > &entity_list, DLIList< RefEntity * > &bdy_list) | RefEntity | [static] |
generate_default_name(CubitString &name) | RefEntity | |
genus() | RefFace | |
geometry_type() const | BasicTopologyEntity | |
get_all_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | |
get_all_child_ref_entities(DLIList< RefEntity * > &input_list, DLIList< RefEntity * > &output_list) | RefEntity | [static] |
get_all_parent_ref_entities(DLIList< RefEntity * > &entity_list, const int get_bodies=CUBIT_FALSE) | RefEntity | |
get_all_TDs(IdentityFn specified_type, DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_all_TDs(DLIList< ToolData * > *all_tds) const | ToolDataUser | [virtual] |
get_by_name(const CubitString &name) | RefEntity | [static] |
get_child_ref_entities(DLIList< RefEntity * > &entity_list) | RefEntity | [virtual] |
get_child_ref_entity_type() const | RefEntity | |
get_child_ref_entity_type(DagType parent_type) | RefEntity | [static] |
get_children(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
get_class_name() | RefFace | [inline, static] |
get_co_faces(DLIList< CoFace * > &co_faces_found_list, RefVolume *input_ref_volume_ptr) | RefFace | |
get_compare_partner() | RefEntity | |
get_crack_length() | RefFace | |
get_cubit_attrib(int attrib_type, CubitBoolean create_if_missing=CUBIT_TRUE) | CubitAttribUser | |
get_cubit_attrib_list(DLIList< CubitAttrib * > &) | CubitAttribUser | |
get_entity_type_info(const char *entity_type) | RefEntity | [static] |
get_first_grouping_entity_ptr() const | BasicTopologyEntity | [inline] |
get_first_sense_entity_ptr() const | BasicTopologyEntity | [inline] |
get_geometry_entity_ptr() const | BasicTopologyEntity | |
get_geometry_query_engine() const | TopologyEntity | |
get_geometry_sense() | RefFace | |
get_graphics(GMem &results, unsigned short normal_tolerance=15, double distance_tolerance=0.0, double longest_edge=0.0) | RefFace | |
get_grouping_entity_list(DLIList< GroupingEntity * > &groupingEntityList) const | BasicTopologyEntity | |
get_matching_CoFace(RefVolume *ref_volume_ptr) | RefFace | |
get_observer_list(DLIList< CubitObserver * > &observers) | CubitObservable | |
get_param_range_U(double &lower_bound, double &upper_bound) | RefFace | |
get_param_range_V(double &lower_bound, double &upper_bound) | RefFace | |
get_parent_ref_entities(DLIList< RefEntity * > &entity_list) | RefFace | [virtual] |
get_parent_ref_entity_type() const | RefEntity | |
get_parent_ref_entity_type(DagType child_type) | RefEntity | [static] |
get_parents(DLIList< TopologyEntity * > *list=0) const | BasicTopologyEntity | [virtual] |
get_point_normal(CubitVector &origin, CubitVector &normal) | RefFace | |
get_principal_curvatures(const CubitVector &point, double &curvature1, double &curvature2, RefVolume *ref_volume_ptr=NULL) | RefFace | |
get_projected_distance_on_surface(CubitVector *pos1, CubitVector *pos2, double &distance) | RefFace | |
get_ref_class_name(const std::type_info &ref_type) | RefEntity | [static] |
get_related_entity_list(const std::type_info &related_entity_type, DLIList< RefEntity * > &entity_list) | RefEntity | |
get_sense_entities(DLIList< SenseEntity * > &result, GroupingEntity *in_this) | BasicTopologyEntity | |
get_sense_entities(DLIList< SenseEntity * > &result, BasicTopologyEntity *in_this) | BasicTopologyEntity | |
get_sense_entity_list(DLIList< SenseEntity * > &senseEntityList) const | BasicTopologyEntity | |
get_surface_ptr() | RefFace | |
get_surface_ptr() const | RefFace | |
get_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
get_TD(IdentityFn specified_type) const | ToolDataUser | [virtual] |
hard_points(DLIList< RefVertex * > &new_hard_point_list) | RefFace | |
hardPointColor | RefFace | [private] |
hardPointList | RefFace | [protected] |
headAttrib | CubitAttribUser | [protected] |
id() const | CubitEntity | [virtual] |
initialize() | RefFace | [private] |
is_child(RefEntity *entity) | RefEntity | [virtual] |
is_closed_in_U() | RefFace | |
is_closed_in_V() | RefFace | |
is_cylindrical() | RefFace | |
is_directly_related(TopologyEntity *entity) | TopologyEntity | |
is_mergeable(AutoMergeStatus val) | RefEntity | [virtual] |
is_mergeable() | RefEntity | |
is_merged() | RefEntity | |
is_nonmanifold(GroupingEntity *in_this_parent) | BasicTopologyEntity | |
is_parametric() | RefFace | |
is_parent(RefEntity *entity) | RefEntity | [virtual] |
is_periodic() | RefFace | |
is_periodic_in_U(double &period) | RefFace | |
is_periodic_in_V(double &period) | RefFace | |
is_planar() | RefFace | |
is_singular_in_U(double u_param) | RefFace | |
is_singular_in_V(double v_param) | RefFace | |
is_transparent(int flag) | CubitEntity | [virtual] |
is_transparent() const | CubitEntity | [virtual] |
is_visible(int flag) | CubitEntity | [virtual] |
is_visible() const | CubitEntity | [virtual] |
join(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
join(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
listFlag | RefEntity | [protected] |
local_tolerance(double value) | RefEntity | [inline] |
local_tolerance(void) | RefEntity | [inline] |
loops(DLIList< Loop * > &loop_list) | TopologyEntity | |
marked(int value) | RefEntity | [inline, virtual] |
marked() | RefEntity | [inline, virtual] |
markedFlag | RefEntity | [protected] |
maxPositionDeviation | RefFace | [private] |
mColor | RefEntity | [protected] |
measure() | RefFace | [virtual] |
measure_label() | RefFace | [virtual] |
meet(RefEntity *ref_entity_2, DLIList< RefEntity * > &join_set) | RefEntity | |
meet(DLIList< RefEntity * > &ref_entities, DLIList< RefEntity * > &join_set) | RefEntity | [static] |
merge_entity_names(RefEntity *dead_entity) | RefEntity | |
merge_owner(RefEntity *deletable_entity) | CubitAttribUser | |
merge_status() const | RefEntity | |
ModelQueryEngine class | TopologyEntity | [friend] |
move_to_surface(CubitVector &location, double *u_guess=NULL, double *v_guess=NULL) | RefFace | [virtual] |
move_to_surface(CubitVector &location, CubitVector &along_vec) | RefFace | [virtual] |
normal_at(const CubitVector &location, RefVolume *volume=NULL, double *u_guess=NULL, double *v_guess=NULL) | RefFace | |
notify_observers(const CubitEvent *event) | CubitObservable | |
notify_sub_all_observers(const GeometryEvent::Type &event) | RefEntity | |
num_cubit_attrib() | CubitAttribUser | |
num_loops() | TopologyEntity | |
num_names() const | RefEntity | |
num_parent_ref_entities() | RefEntity | |
num_poles() | RefFace | |
num_ref_edges() | TopologyEntity | |
num_ref_faces() | TopologyEntity | |
num_ref_vertices() | TopologyEntity | |
num_ref_volumes() | TopologyEntity | |
number_of_Loops() | RefFace | |
observerList | CubitObservable | [protected] |
operator=(const RefFace &) | RefFace | [private] |
CubitObservable::operator=(const CubitObservable &) | CubitObservable | [protected] |
ordered_loops(DLIList< Loop * > &loop_list) | RefFace | |
ParentType typedef | RefFace | |
point_containment(const CubitVector &point) | RefFace | |
point_containment(double u, double v) | RefFace | |
position_from_u_v(double u, double v) | RefFace | |
query_append_children(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
query_append_parents(DLIList< TopologyEntity * > &list) | BasicTopologyEntity | [protected, virtual] |
read_cubit_attrib(int attrib_type) | CubitAttribUser | |
ref_edge() | TopologyEntity | |
ref_edge_loops(DLIList< DLIList< RefEdge * > > &ref_edge_loops) | RefFace | |
ref_edges(DLIList< RefEdge * > &ref_edge_list) | TopologyEntity | |
ref_face() | TopologyEntity | |
ref_faces(DLIList< RefFace * > &ref_face_list) | TopologyEntity | |
ref_vertex() | TopologyEntity | |
ref_vertex_loops(DLIList< DLIList< RefVertex * > > &ref_vert_loop_list) | RefFace | |
ref_vertices(DLIList< RefVertex * > &ref_vertex_list) | TopologyEntity | |
ref_volume() | RefFace | |
ref_volumes(DLIList< RefVolume * > &ref_volume_list) | TopologyEntity | |
RefEntity() | RefEntity | |
RefEntityFactory class | RefFace | [friend] |
RefFace(Surface *surfacePtr) | RefFace | [protected] |
RefFace(const RefFace &) | RefFace | [private] |
remove_all_simple_attribute(TopologyBridge *bridge) | CubitAttribUser | |
remove_attrib_geometry_entity(CubitAttrib *) | CubitAttribUser | |
remove_child_link(TopologyEntity *entity_ptr) | BasicTopologyEntity | [protected, virtual] |
remove_compare_data() | RefEntity | |
remove_cubit_attrib(int attrib_type) | CubitAttribUser | |
remove_cubit_attrib(CubitAttrib *) | CubitAttribUser | |
remove_entity_name(CubitString const &name) | RefEntity | |
remove_entity_names() | RefEntity | |
remove_from_DAG(CubitBoolean recursive_flag=CUBIT_FALSE) | TopologyEntity | |
remove_from_observers() | CubitObservable | [protected] |
remove_grouping_entity(GroupingEntity *) | BasicTopologyEntity | |
remove_observer(CubitObserver *observer) | CubitObservable | [protected, virtual] |
remove_sense_entity(SenseEntity *) | BasicTopologyEntity | |
remove_simple_attribute(TopologyBridge *bridge, const CubitSimpleAttrib &attrib_ptr) | CubitAttribUser | |
remove_TD(IdentityFn specified_type) | ToolDataUser | [virtual] |
remove_TD(ToolData *td) | ToolDataUser | [virtual] |
reverse_normal() | RefFace | |
reverse_topology() | RefFace | [virtual] |
sense(RefVolume *volume) | RefFace | |
sense(RefFace *face_ptr) | RefFace | |
set_geometry_entity_ptr(GeometryEntity *geometryEntityPtr) | BasicTopologyEntity | |
set_grouping_entity_list(DLIList< GroupingEntity * > &new_list, DLIList< GroupingEntity * > &removed_list) | BasicTopologyEntity | |
set_id(int i) | RefEntity | [virtual] |
set_id(int i, CubitBoolean emit_event) | RefEntity | |
set_outward_normal(RefVolume *volume) | RefFace | |
set_topology_bridge(TopologyBridge *TB_ptr) | TopologyEntity | [protected] |
set_updated_flag(CubitBoolean flag) | CubitAttribUser | |
set_written_flag(CubitBoolean flag) | CubitAttribUser | |
shells(DLIList< Shell * > &shell_list) | TopologyEntity | |
split_owner(DLIList< CubitSimpleAttrib > &csa_list) | CubitAttribUser | |
switch_entity_names(RefEntity *other_entity) | RefEntity | |
ToolDataUser() | ToolDataUser | [inline] |
TopologyEntity() | TopologyEntity | |
transf_owner(const CubitVector &matrow1, const CubitVector &matrow2, const CubitVector &matrow3, const CubitVector &translate_vec, const double scale_factor) | CubitAttribUser | |
u_v_from_position(CubitVector const &location, double &u, double &v, CubitVector *closest_location=NULL) | RefFace | |
unmerged_bounding_box() | BasicTopologyEntity | [virtual] |
update_auto_merge_state() | RefEntity | |
update_cubit_attrib(int) | CubitAttribUser | |
uv_derivitives(double u_param, double v_param, CubitVector &du, CubitVector &dv) | RefFace | |
valence(RefEntity *parent=NULL) | RefEntity | |
validate() | RefFace | [virtual] |
write_cubit_attrib_by_type(int attrib_type) | CubitAttribUser | |
write_cubit_attrib_list(DLIList< CubitAttrib * > attrib_list) | CubitAttribUser | |
write_cubit_attribs() | CubitAttribUser | |
write_specific_cubit_attrib(CubitAttrib *cubit_attrib_ptr) | CubitAttribUser | |
~BasicTopologyEntity() | BasicTopologyEntity | [virtual] |
~CubitAttribUser() | CubitAttribUser | [virtual] |
~CubitEntity() | CubitEntity | [virtual] |
~CubitObservable() | CubitObservable | [virtual] |
~RefEntity() | RefEntity | [virtual] |
~RefFace() | RefFace | [virtual] |
~ToolDataUser() | ToolDataUser | [virtual] |
~TopologyEntity() | TopologyEntity | [virtual] |
