add_facet_boundary_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [static] |
add_facet_boundary_point(CubitPoint *point_ptr, CubitFacet *facet_ptr, CubitVector &normal) | TDFacetBoundaryPoint | [static] |
add_facet_boundary_point(CubitPoint *point_ptr, CubitQuadFacet *qfacet_ptr, CubitVector &normal) | TDFacetBoundaryPoint | [static] |
add_surf(int new_id) | TDFacetBoundaryPoint | |
add_surf_facets(DLIList< CubitFacet * > adj_facet_list) | TDFacetBoundaryPoint | |
destroy_memory() | TDFacetBoundaryPoint | [inline, static] |
get_boundary_point_data(int *int_data, double *double_data, int &iidx, int &didx) | TDFacetBoundaryPoint | |
get_boundary_point_data_size(int &size_int_data, int &size_double_data) | TDFacetBoundaryPoint | |
get_bpd(CubitFacet *facet) | TDFacetBoundaryPoint | [private] |
get_facet_boundary_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [static] |
get_normal(int surf_id, CubitVector &normal) | TDFacetBoundaryPoint | |
get_normal(CubitFacet *adj_facet, CubitVector &normal) | TDFacetBoundaryPoint | |
get_normal(CubitFacetEdge *edge_ptr, CubitVector &normal) | TDFacetBoundaryPoint | |
get_point() | TDFacetBoundaryPoint | [inline] |
get_uv(CubitFacet *adj_facet, double &u, double &v) | TDFacetBoundaryPoint | |
get_uvs(CubitFacet *adj_facet, double &u, double &v, double &s) | TDFacetBoundaryPoint | |
init_normal(BoundaryPointData *bpd_ptr) | TDFacetBoundaryPoint | [private] |
initialize(CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) | TDFacetBoundaryPoint | |
is_facet_boundary_point(const ToolData *td) | TDFacetBoundaryPoint | [inline, static] |
memoryManager | TDFacetBoundaryPoint | [private, static] |
merge(ToolDataUser *other_td_user) | ToolData | [virtual] |
merge_normals(CubitFacet *facet0, CubitFacet *facet1) | TDFacetBoundaryPoint | |
new_facet_boundary_point(CubitPoint **points, CubitFacet **facets, int &iidx, int &didx, int *int_data, double *double_data) | TDFacetBoundaryPoint | [static] |
next_tool_data() | ToolData | [inline] |
next_tool_data(ToolData *data) | ToolData | [inline] |
pointDataList | TDFacetBoundaryPoint | [private] |
pointPtr | TDFacetBoundaryPoint | [private] |
propogate(ToolDataUser *new_td_user) | ToolData | [virtual] |
reset_normals() | TDFacetBoundaryPoint | |
rotate_normal(CubitTransformMatrix &rotmat) | TDFacetBoundaryPoint | |
s(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
set_normal(int surf_id, CubitVector &normal) | TDFacetBoundaryPoint | |
set_point(CubitPoint *point_ptr) | TDFacetBoundaryPoint | [inline] |
set_surf_id(CubitFacet *facet_ptr, int surf_id) | TDFacetBoundaryPoint | |
set_uv(CubitFacet *adj_facet, double u, double v) | TDFacetBoundaryPoint | |
set_uvs(CubitFacet *adj_facet, double u, double v, double s) | TDFacetBoundaryPoint | |
SetDynamicMemoryAllocation(memoryManager) static void set_memory_allocation_increment(int increment=0) | TDFacetBoundaryPoint | [inline, pure virtual] |
TDFacetBoundaryPoint() | TDFacetBoundaryPoint | |
ToolData() | ToolData | [inline, protected] |
u(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
v(CubitFacet *adj_facet) | TDFacetBoundaryPoint | |
~TDFacetBoundaryPoint() | TDFacetBoundaryPoint | |
~ToolData() | ToolData | [virtual] |
