cgma
VirtualQueryEngine Member List
This is the complete list of members for VirtualQueryEngine, including all inherited members.
associate_curves(DLIList< Curve * > &target_set, RefEdge *edge_ptr, DLIList< Curve * > &reset_set)VirtualQueryEngine [static]
bodies_overlap(BodySM *body_ptr_1, BodySM *body_ptr_2) const VirtualQueryEngine [virtual]
curve_is_on_ignored_surface(Curve *curve, Surface *surf)VirtualQueryEngine [virtual]
default_error_message(const char callers_name[]) const VirtualQueryEngine [private]
delete_instance()VirtualQueryEngine [static]
delete_solid_model_entities(DLIList< BodySM * > &) const VirtualQueryEngine [protected, virtual]
delete_solid_model_entities(BodySM *body_ptr) const VirtualQueryEngine [protected, virtual]
delete_solid_model_entities(Surface *surf_ptr) const VirtualQueryEngine [protected, virtual]
delete_solid_model_entities(Curve *curve_ptr) const VirtualQueryEngine [protected, virtual]
delete_solid_model_entities(TBPoint *point_ptr) const VirtualQueryEngine [protected, virtual]
GeometryQueryEngine::delete_solid_model_entities(GeometryEntity *ref_entity_ptr) const GeometryQueryEngine [virtual]
delete_topology_bridge(TopologyBridge *bridge) const GeometryQueryEngine [virtual]
entity_entity_distance(GeometryEntity *ref_entity_ptr1, GeometryEntity *ref_entity_ptr2, CubitVector &pos1, CubitVector &pos2, double &distance)VirtualQueryEngine [virtual]
entity_extrema(DLIList< GeometryEntity * > &ref_entity_list, const CubitVector *dir1, const CubitVector *dir2, const CubitVector *dir3, CubitVector &extrema, GeometryEntity *&extrema_entity_ptr)VirtualQueryEngine [virtual]
entity_type_info() const VirtualQueryEngine [inline, virtual]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, const char *file_name, Model_File_Type file_type, const CubitString &cubit_version, ModelExportOptions &export_options)VirtualQueryEngine [protected, virtual]
export_solid_model(DLIList< TopologyBridge * > &bridge_list, char *&p_buffer, int &n_buffer_size, bool b_export_buffer)VirtualQueryEngine [inline, protected, virtual]
fire_ray(CubitVector &origin, CubitVector &direction, DLIList< TopologyBridge * > &at_entity_list, DLIList< double > &ray_params, int max_hits, double ray_radius, DLIList< TopologyBridge * > *hit_entity_list=0) const VirtualQueryEngine [protected, virtual]
get_allint_version()GeometryQueryEngine [virtual]
get_composite_curve_facetting(CompositeCurve *ccurve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const VirtualQueryEngine [protected]
get_composite_surface_facetting(CompositeSurface *surf_ptr, GMem *gMem, std::vector< TopologyBridge * > *vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > *facet_edges_on_curves, unsigned short normal_tol, double absolute_tol, double longest_edge) const VirtualQueryEngine [protected]
get_engine_version_string()VirtualQueryEngine [virtual]
get_graphics(Surface *surface_ptr, GMem *gmem, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const VirtualQueryEngine [virtual]
get_graphics(Surface *surface_ptr, GMem *gMem, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const VirtualQueryEngine [virtual]
get_graphics(Curve *curve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const VirtualQueryEngine [virtual]
GeometryQueryEngine::get_graphics(BodySM *bodysm, GMem *g_mem, std::vector< Surface * > &surface_to_facets_vector, std::vector< TopologyBridge * > &vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > &facet_edges_on_curves, unsigned short normal_tolerance, double distance_tolerance, double max_edge_length) const GeometryQueryEngine [virtual]
get_intersections(Curve *curve, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, CubitBoolean bounded, CubitBoolean closest)VirtualQueryEngine [virtual]
get_intersections(Curve *ref_edge1, Curve *ref_edge2, DLIList< CubitVector > &intersection_list, bool bounded=CUBIT_FALSE, bool closest=CUBIT_FALSE)VirtualQueryEngine [virtual]
get_intersections(Curve *ref_edge, Surface *ref_face, DLIList< CubitVector > &intersection_list, bool bounded=CUBIT_FALSE)VirtualQueryEngine [virtual]
GeometryQueryEngine::get_intersections(Curve *ref_edge1, CubitVector &point1, CubitVector &point2, DLIList< CubitVector > &intersection_list, bool bounded=false, bool closest=false)=0GeometryQueryEngine [pure virtual]
get_isoparametric_points(Surface *ref_face_ptr, int &nu, int &nv, GMem *&gMem) const VirtualQueryEngine [virtual]
get_major_version()VirtualQueryEngine [virtual]
get_minor_version()VirtualQueryEngine [virtual]
get_ordered_loops(RefFace *, DLIList< Loop * > &) const GeometryQueryEngine [inline, virtual]
get_partition_curve_facetting(PartitionCurve *pcurve_ptr, GMem *gMem, double angle_tolerance=0, double distance_tolerance=0, double max_edge_length=0) const VirtualQueryEngine [protected]
get_partition_surface_facetting(PartitionSurface *surf_ptr, GMem *gMem, std::vector< TopologyBridge * > *vertex_edge_to_point_vector, std::vector< std::pair< TopologyBridge *, std::pair< int, int > > > *facet_edges_on_curves, unsigned short normal_tol, double absolute_tol, double longest_edge) const VirtualQueryEngine [protected]
get_point_containment(DLIList< BodySM * > &body_list, DLIList< CubitVector > &point_list, double tolerance, bool allow_pts_in_multiple_bodies, std::vector< std::pair< BodySM *, std::vector< int > > > &bodysm_to_pt_indices)GeometryQueryEngine [virtual]
get_sister_partitions(RefEntity *ref_entity, DLIList< RefEntity * > &sisters)VirtualQueryEngine
get_sme_resabs_tolerance() const VirtualQueryEngine [protected, virtual]
get_subminor_version()VirtualQueryEngine [virtual]
get_u_isoparametric_points(Surface *ref_face_ptr, double v, int &n, GMem *&gMem) const VirtualQueryEngine [virtual]
get_underlying_bridges(TopologyBridge *bridge_ptr, DLIList< TopologyBridge * > &bridge_list)VirtualQueryEngine [virtual]
get_underlying_curves(Curve *curve_ptr, DLIList< TopologyBridge * > &curve_list)VirtualQueryEngine [virtual]
get_underlying_surfaces(Surface *surf_ptr, DLIList< TopologyBridge * > &surf_list)VirtualQueryEngine [virtual]
get_v_isoparametric_points(Surface *ref_face_ptr, double u, int &n, GMem *&gMem) const VirtualQueryEngine [virtual]
get_VEs(RefVolume *volume_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE)VirtualQueryEngine [static]
get_VEs(RefFace *face_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE)VirtualQueryEngine [static]
get_VEs(RefEdge *edge_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE)VirtualQueryEngine [static]
get_VEs(RefVertex *vertex_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE)VirtualQueryEngine [static]
get_VEs(TopologyEntity *te_ptr, DLIList< TopologyBridge * > &ve_list, CubitBoolean visible=CUBIT_FALSE, const CubitBoolean children_too=CUBIT_TRUE)VirtualQueryEngine [static]
get_visible_entities(TopologyBridge *hidden_tb, DLIList< TopologyBridge * > &real_tbs)VirtualQueryEngine [virtual]
get_visible_entity_at_point(TopologyBridge *hidden_tb, CubitVector *point)VirtualQueryEngine [virtual]
has_virtual(TopologyEntity *entity)VirtualQueryEngine [static]
import_solid_model(const char *file_name, Model_File_Type file_type, DLIList< TopologyBridge * > &imported_entities, ModelImportOptions &import_options)VirtualQueryEngine [protected, virtual]
import_solid_model(DLIList< TopologyBridge * > &imported_entities, const char *pBuffer, const int n_buffer_size)VirtualQueryEngine [inline, protected, virtual]
instance()VirtualQueryEngine [inline, static]
instance_VirtualQueryEngine [protected, static]
is_intermediate_engine()VirtualQueryEngine [inline, virtual]
is_partition(RefEntity *ref_entity)VirtualQueryEngine
is_virtual(TopologyEntity *entity, const CubitBoolean children_too=CUBIT_FALSE)VirtualQueryEngine [static]
is_virtual(DLIList< Body * > &entity_list, const CubitBoolean children_too=CUBIT_FALSE)VirtualQueryEngine [static]
is_virtual(DLIList< RefEntity * > &entity_list, const CubitBoolean children_too=CUBIT_FALSE)VirtualQueryEngine [static]
list_engine_versions(CubitString &versions)GeometryQueryEngine [virtual]
modeler_type()VirtualQueryEngine [inline, virtual]
param_epsilon_fractionVirtualQueryEngine [static]
reflect(BodySM *body, const CubitVector &axis)VirtualQueryEngine [virtual]
reflect(GeometryEntity *ent, const CubitVector &axis)VirtualQueryEngine [virtual]
register_attributes()VirtualQueryEngine
remove_virtual_geometry(RefEntity *entity_ptr, CubitBoolean all_children)VirtualQueryEngine
remove_virtual_geometry(Body *body, bool all_children)VirtualQueryEngine
remove_virtual_geometry(RefVolume *vol, bool all_children)VirtualQueryEngine
remove_virtual_geometry(RefFace *face)VirtualQueryEngine
restore_transform(BodySM *body)VirtualQueryEngine [virtual]
rotate(BodySM *body, const CubitVector &axis, double angle)VirtualQueryEngine [virtual]
rotate(GeometryEntity *ent, const CubitVector &axis, double degrees)VirtualQueryEngine [virtual]
save_temp_geom_file(DLIList< TopologyBridge * > &bridge_list, const char *file_name, const CubitString &cubit_version, CubitString &created_file, CubitString &created_file_type)VirtualQueryEngine [protected, virtual]
scale(BodySM *body, double factor)VirtualQueryEngine [virtual]
scale(BodySM *body, const CubitVector &factors)VirtualQueryEngine [virtual]
scale(GeometryEntity *ent, double factor)VirtualQueryEngine [virtual]
scale(GeometryEntity *ent, const CubitVector &factors)VirtualQueryEngine [virtual]
set_dbl_option(const char *opt_name, double val)VirtualQueryEngine [protected, virtual]
set_export_allint_version(const int version)GeometryQueryEngine [virtual]
set_export_version(const int major, const int minor)GeometryQueryEngine [virtual]
set_int_option(const char *opt_name, int val)VirtualQueryEngine [protected, virtual]
set_sme_resabs_tolerance(double new_resabs)VirtualQueryEngine [protected, virtual]
set_str_option(const char *opt_name, const char *val)VirtualQueryEngine [protected, virtual]
sort_edges(DLIList< RefEdge * > &edge_list) const VirtualQueryEngine
transform_vec_position(CubitVector const &position_vector, BodySM *OSME_ptr, CubitVector &transformed_vector) const VirtualQueryEngine [virtual]
translate(BodySM *body, const CubitVector &offset)VirtualQueryEngine [virtual]
translate(GeometryEntity *ent, const CubitVector &offset)VirtualQueryEngine [virtual]
validate_geometry_database() const GeometryQueryEngine [inline, virtual]
VGE_MAJOR_VERSIONVirtualQueryEngine [private, static]
VGE_MINOR_VERSIONVirtualQueryEngine [private, static]
VGE_SUBMINOR_VERSIONVirtualQueryEngine [private, static]
VirtualQueryEngine()VirtualQueryEngine [protected]
virtuals_created() const VirtualQueryEngine
volumes_overlap(Lump *lump1, Lump *lump2) const VirtualQueryEngine [virtual]
~GeometryQueryEngine()GeometryQueryEngine [inline, virtual]
~VirtualQueryEngine()VirtualQueryEngine
