MeshKit
1.0
00001 #include "meshkit/EBMesher.hpp" 00002 #include "meshkit/SCDMesh.hpp" 00003 #include "meshkit/MKCore.hpp" 00004 #include "meshkit/ModelEnt.hpp" 00005 #include "meshkit/SizingFunction.hpp" 00006 #include "moab/ReadUtilIface.hpp" 00007 #include "meshkit/iGeom.hpp" 00008 #include "meshkit/RegisterMeshOp.hpp" 00009 00010 #include "moab/Core.hpp" 00011 #include "moab/Range.hpp" 00012 #include "moab/CartVect.hpp" 00013 #include "moab/EntityType.hpp" 00014 #include "moab/HomXform.hpp" 00015 #include "moab/GeomTopoTool.hpp" 00016 00017 #include <time.h> 00018 00019 #ifdef HAVE_CGM 00020 #include "CubitDefines.h" 00021 #include "GeometryQueryTool.hpp" 00022 #include "RefFace.hpp" 00023 #endif 00024 00025 #define PI 3.14159265 00026 #define ERRORRF(a) {if (iBase_SUCCESS != err) {std::cerr << a << std::endl; return false;}} 00027 00028 double rayDir[3][3] = {{1., 0., 0.}, {0., 1., 0.}, {0., 0., 1.}}; 00029 00030 const bool debug_ebmesh = false; 00031 inline bool less_intersect(const IntersectDist d1, const IntersectDist d2) { 00032 return d1.distance < d2.distance; 00033 } 00034 00035 inline bool equal_intersect(const IntersectDist d1, const IntersectDist d2) { 00036 return std::abs(d1.distance - d2.distance) < 10e-7; 00037 } 00038 00039 namespace MeshKit 00040 { 00041 // static registration of this mesh scheme 00042 moab::EntityType EBMesher_tps[] = {moab::MBVERTEX, moab::MBHEX, moab::MBMAXTYPE}; 00043 const moab::EntityType* EBMesher::output_types() 00044 { return EBMesher_tps; } 00045 00046 EBMesher::EBMesher(MKCore *mkcore, const MEntVector &me_vec, 00047 double size, bool use_geom, int add_layer) 00048 : MeshScheme(mkcore, me_vec), m_nAddLayer(add_layer), m_dInputSize(size), m_bUseGeom(use_geom) 00049 { 00050 m_mesh = mkcore->imesh_instance()->instance(); 00051 m_hRootSet = mkcore->imesh_instance()->getRootSet(); 00052 m_nStatus = OUTSIDE; 00053 m_iStartHex = 0; 00054 m_hObbTree = NULL; 00055 m_hTreeRoot = 0; 00056 00057 // create tags with MOAB for dense tags 00058 int outside = 1; 00059 const void *out = &outside; 00060 m_elemStatusTag = get_tag("ELEM_STATUS_TAG", 1, 00061 moab::MB_TAG_DENSE, moab::MB_TYPE_INTEGER, out); 00062 00063 int length = 1; 00064 const void *leng = &length; 00065 m_edgeCutFracLengthTag = get_tag("EDGE_CUT_FRAC_LENGTH_TAG", // # of fractions 00066 3, 00067 //moab::MB_TAG_SPARSE, // using dense for hdf5 exporting performance 00068 moab::MB_TAG_DENSE, 00069 moab::MB_TYPE_INTEGER, leng); 00070 00071 m_edgeCutFracTag = get_various_length_tag("EDGE_CUT_FRAC_TAG", 00072 //moab::MB_TAG_SPARSE, 00073 moab::MB_TAG_DENSE, 00074 moab::MB_TYPE_DOUBLE); 00075 00076 int m_id = 1; 00077 const void *id = &m_id; 00078 m_volFracLengthTag = get_tag("VOL_FRAC_LENGTH_TAG", 1, 00079 moab::MB_TAG_SPARSE, moab::MB_TYPE_INTEGER, id); 00080 00081 m_volFracHandleTag = get_various_length_tag("VOL_FRAC_HANDLE_TAG", 00082 moab::MB_TAG_SPARSE, moab::MB_TYPE_INTEGER); 00083 00084 m_volFracTag = get_various_length_tag("VOL_FRAC_TAG", 00085 moab::MB_TAG_SPARSE, moab::MB_TYPE_DOUBLE); 00086 00087 // set bounding box size tag 00088 double bb_default[6] = { 0., 0., 0., 0., 0., 0. }; 00089 m_bbTag = get_tag("BOUNDING_BOX_SIZE", 6, 00090 moab::MB_TAG_SPARSE, moab::MB_TYPE_DOUBLE, bb_default); 00091 00092 m_GeomTopoTool = new moab::GeomTopoTool( moab_instance() ); 00093 } 00094 00095 EBMesher::~EBMesher() 00096 { 00097 delete m_GeomTopoTool; 00098 } 00099 00100 bool EBMesher::can_mesh(ModelEnt *me) 00101 { 00102 if (me->dimension() == 3) return true; 00103 else return false; 00104 } 00105 00106 bool EBMesher::add_modelent(ModelEnt *model_ent) 00107 { 00108 // make sure this represents geometric volumes 00109 if (3 != model_ent->dimension()) 00110 throw Error(MK_WRONG_DIMENSION, "Wrong dimension entity added to EBMesher."); 00111 00112 return MeshOp::add_modelent(model_ent); 00113 } 00114 00115 MeshOp *EBMesher::get_scd_mesher() 00116 { 00117 MeshOpProxy* proxy = NULL; 00118 proxy = MKCore::meshop_proxy("SCDMesh"); 00119 if (proxy == NULL) throw Error(MK_FAILURE, "Couldn't find a MeshOp capable of producing the given mesh type."); 00120 return mk_core()->construct_meshop(proxy); 00121 } 00122 00123 void EBMesher::setup_this() 00124 { 00125 MeshOp *scd_mesher = NULL; 00126 std::vector<MeshOp*> meshops; 00127 bool inserted = false; 00128 00129 for (MEntSelection::iterator sit = mentSelection.begin(); sit != mentSelection.end(); sit++) { 00130 ModelEnt *me = (*sit).first; 00131 bool found = false; 00132 if (!scd_mesher) scd_mesher = get_scd_mesher(); 00133 meshops.clear(); 00134 me->get_meshops(meshops); 00135 int n_meshops = meshops.size(); 00136 00137 if (n_meshops > 0) { 00138 for (int i = 0; i < n_meshops; i++) { 00139 if (meshops[i] == scd_mesher) { 00140 found = true; 00141 break; 00142 } 00143 } 00144 } 00145 00146 if (!found) { // if no scd meshop 00147 // add this entity to it, and if first, make sure it's added upstream 00148 scd_mesher->add_modelent(me); 00149 if (!inserted) { 00150 mk_core()->insert_node(scd_mesher, this); 00151 inserted = true; 00152 } 00153 } 00154 00155 // no need to traverse all geometry for using whole geometry 00156 if (m_bUseWholeGeom) break; 00157 } 00158 00159 SCDMesh *sm = (SCDMesh*) scd_mesher; 00160 sm->set_interface_scheme(SCDMesh::full); 00161 sm->set_grid_scheme(SCDMesh::cfMesh); 00162 00163 sm->set_axis_scheme(SCDMesh::cartesian); 00164 sm->set_box_increase_ratio(m_boxIncrease); // add some extra layer to box 00165 00166 if (m_bUseWholeGeom) sm->set_geometry_scheme(SCDMesh::all); 00167 else sm->set_geometry_scheme(SCDMesh::individual); 00168 00169 // use mesh based geometry in SCDMesh and make tree to get box dimension 00170 if (m_bUseMeshGeom) { 00171 sm->use_mesh_geometry(true); 00172 sm->set_cart_box_min_max(m_minCoord, m_maxCoord, m_boxIncrease); 00173 } 00174 00175 // set # of intervals for 3 directions 00176 std::vector<int> fine_i (m_nDiv[0], 1); 00177 sm->set_coarse_i_grid(m_nDiv[0]); 00178 sm->set_fine_i_grid(fine_i); 00179 std::vector<int> fine_j (m_nDiv[1], 1); 00180 sm->set_coarse_j_grid(m_nDiv[1]); 00181 sm->set_fine_j_grid(fine_j); 00182 std::vector<int> fine_k (m_nDiv[2], 1); 00183 sm->set_coarse_k_grid(m_nDiv[2]); 00184 sm->set_fine_k_grid(fine_k); 00185 } 00186 00187 void EBMesher::execute_this() 00188 { 00189 iBase_ErrorType err; 00190 GraphNode *scd_node = other_node(in_arcs()); 00191 00192 double obb_time = .0; 00193 double intersection_time = .0; 00194 double set_info_time = .0; 00195 time_t time1, time2, time3, time4; 00196 unsigned long long mem1, mem3, mem4; 00197 moab_instance()->estimated_memory_use(0, 0, 0, &mem1); 00198 moab::ErrorCode rval; 00199 00200 if (debug_ebmesh) { 00201 rval = mk_core()->moab_instance()->write_mesh("input.vtk"); 00202 MBERRCHK(rval, mk_core()->moab_instance()); 00203 } 00204 00205 time(&time1); 00206 if (m_bUseGeom && !m_bUseMeshGeom) { // construct obb tree for geometry surfaces and volumes by GeomTopoTool 00207 rval = m_GeomTopoTool->construct_obb_trees(m_bUseWholeGeom); 00208 MBERRCHK(rval, mk_core()->moab_instance()); 00209 } 00210 time(&time2); 00211 obb_time += difftime(time2, time1); 00212 00213 for (MEntSelection::iterator sit = mentSelection.begin(); sit != mentSelection.end(); sit++) { 00214 // 1. set division 00215 double box_min_max[6]; 00216 if (m_bUseWholeGeom) { 00217 static_cast<SCDMesh*> (scd_node)->get_box_dimension(box_min_max, &box_min_max[3]); 00218 } 00219 else { 00220 err = mk_core()->imesh_instance()->getData(reinterpret_cast< iBase_EntityHandle > 00221 (sit ->first->mesh_handle()), m_bbTag, &box_min_max[0]); 00222 IBERRCHK(err, "Failed to get hexes.\n"); 00223 } 00224 set_division(box_min_max, &box_min_max[3]); 00225 00226 // 2. set or construct obb tree 00227 time(&time1); 00228 set_tree_root(sit->first); 00229 time(&time2); 00230 obb_time += difftime(time2, time1); 00231 00232 // 3. find intersected geometry surfaces by rays 00233 find_intersections(); 00234 time(&time3); 00235 intersection_time += difftime(time3, time2); 00236 moab_instance()->estimated_memory_use(0, 0, 0, &mem3); 00237 00238 // 4. set hex status and boundary hex cut fraction info 00239 set_tag_info(); 00240 time(&time4); 00241 set_info_time += difftime(time4, time3); 00242 moab_instance()->estimated_memory_use(0, 0, 0, &mem4); 00243 00244 if (m_bUseWholeGeom) break; 00245 } 00246 if (debug_ebmesh) { 00247 std::cout << "OBB_tree_construct_time: " << obb_time 00248 << ", intersection_time: " << intersection_time 00249 << ", set_info_time: " << set_info_time << std::endl; 00250 std::cout << "start_memory: " << mem1 00251 //<< ", OBB_tree_construct_moemory: " << mem2 00252 << ", intersection_memory: " << mem3 00253 << ", set_info_memory: " << mem4 00254 << std::endl; 00255 } 00256 } 00257 00258 void EBMesher::set_num_interval(int* n_interval) 00259 { 00260 for (int i = 0; i < 3; i++) { 00261 m_nDiv[i] = n_interval[i]; 00262 } 00263 } 00264 00265 void EBMesher::set_tree_root(ModelEnt* me) 00266 { 00267 moab::ErrorCode rval; 00268 if (m_bUseGeom) { 00269 if (m_hObbTree == NULL) { 00270 m_hObbTree = m_GeomTopoTool->obb_tree(); 00271 } 00272 if (m_bUseWholeGeom) { 00273 if (!m_bUseMeshGeom) m_hTreeRoot = m_GeomTopoTool->get_one_vol_root(); 00274 } 00275 else { 00276 rval = m_GeomTopoTool->get_root(me->mesh_handle(), m_hTreeRoot); 00277 MBERRCHK(rval, mk_core()->moab_instance()); 00278 } 00279 } 00280 else { // facet data input case 00281 moab::EntityHandle meshset; 00282 if (m_bUseWholeGeom) meshset = 0; 00283 else meshset = me->mesh_handle(); 00284 00285 // get triangles 00286 moab::Range tris; 00287 rval = moab_instance()->get_entities_by_dimension(meshset, 2, tris); 00288 MBERRCHK(rval, mk_core()->moab_instance()); 00289 00290 // make tree 00291 if (m_hObbTree == NULL) { 00292 m_hObbTree = new moab::OrientedBoxTreeTool( moab_instance() ); 00293 } 00294 rval = m_hObbTree->build(tris, m_hTreeRoot); 00295 MBERRCHK(rval, mk_core()->moab_instance()); 00296 } 00297 } 00298 00299 void EBMesher::find_intersections() 00300 { 00301 std::cout << "starting to find intersections." << std::endl; 00302 int i; 00303 //m_vnHexStatus.resize(m_nHex, 1); // initialize all hex as outside 00304 m_vnHexStatus.resize(m_nHex, 0); // initialize all hex as inside 00305 00306 // fire rays to 3 directions 00307 for (i = 0; i < 3; i++) { 00308 //m_vnEdgeStatus[i].resize(m_nDiv[i]*m_nDiv[(i + 1)%3]*m_nDiv[(i + 2)%3], OUTSIDE); 00309 m_vnEdgeStatus[i].resize(m_nDiv[i]*m_nDiv[(i + 1)%3]*m_nDiv[(i + 2)%3], INSIDE); 00310 fire_rays(i); 00311 } 00312 std::cout << "finished to find intersections." << std::endl; 00313 } 00314 00315 void EBMesher::export_mesh(const char* file_name, bool separate) 00316 { 00317 // get all hexes 00318 time_t time1, time2, time3; 00319 time(&time1); 00320 int i; 00321 iBase_ErrorType err; 00322 std::vector<iBase_EntityHandle> hex_handles; 00323 err = mk_core()->imesh_instance()->getEntities(m_hRootSet, iBase_REGION, 00324 iMesh_HEXAHEDRON, hex_handles); 00325 IBERRCHK(err, "Failed to get hexes.\n"); 00326 /* 00327 int hex_size = hex_handles.size(); 00328 int* hex_status = new int[hex_size]; 00329 int* hex_status = NULL; 00330 std::vector<int> hex_status(hex_size); 00331 err = mk_core()->imesh_instance()->getIntArrData(&hex_handles[0], hex_size, 00332 m_elemStatusTag, &hex_status[0]);*/ 00333 00334 int error; 00335 int hex_size = hex_handles.size(); 00336 int* hex_status = new int[hex_size]; 00337 int hex_status_alloc = sizeof(int)*hex_size; 00338 int hex_status_size = 0; 00339 iMesh_getIntArrData(m_mesh, &hex_handles[0], 00340 hex_size, m_elemStatusTag, 00341 &hex_status, &hex_status_alloc, 00342 &hex_status_size, &error); 00343 IBERRCHK(error, "Failed to get hex status.\n"); 00344 time(&time2); 00345 00346 if (separate) { 00347 int n_inside_hex = 0; 00348 int n_outside_hex = 0; 00349 int n_boundary_hex = 0; 00350 int hex_stat; 00351 (void) hex_stat; 00352 std::vector<iBase_EntityHandle> insideHex, outsideHex, bndrHex; 00353 for (i = 0; i < hex_size; i++) { 00354 if (hex_status[i] == 0) { 00355 n_inside_hex++; 00356 hex_stat = 0; 00357 insideHex.push_back(hex_handles[i]); 00358 } 00359 else if (hex_status[i] == 1) { 00360 n_outside_hex++; 00361 hex_stat = 1; 00362 outsideHex.push_back(hex_handles[i]); 00363 } 00364 else if (hex_status[i] == 2) { 00365 n_boundary_hex++; 00366 hex_stat = 2; 00367 bndrHex.push_back(hex_handles[i]); 00368 } 00369 else { 00370 throw Error(MK_FAILURE, "Hex element status should be inside/outside/boundary."); 00371 } 00372 } 00373 00374 std::cout << "# of exported inside hex:" << n_inside_hex 00375 << ", # of exported outside hex:" << n_outside_hex 00376 << ", # of exported boundary hex:" << n_boundary_hex 00377 << ", geom vol:" 00378 << n_inside_hex*m_dIntervalSize[0]*m_dIntervalSize[1]*m_dIntervalSize[2] 00379 << ", vox vol:" << hex_size*m_dIntervalSize[0]*m_dIntervalSize[1]*m_dIntervalSize[2] 00380 << std::endl; 00381 time(&time3); 00382 00383 // save inside/outside/boundary elements separately 00384 if (n_inside_hex > 0) { 00385 write_mesh(file_name, 0, &insideHex[0], n_inside_hex); 00386 } 00387 if (n_boundary_hex > 0) { 00388 write_mesh(file_name, 2, &bndrHex[0], n_boundary_hex); 00389 } 00390 if (n_outside_hex > 0) { 00391 write_mesh(file_name, 1, &outsideHex[0], n_outside_hex); 00392 } 00393 00394 if (debug_ebmesh) { 00395 std::cout << "hex_handle_get_time: " 00396 << difftime(time2, time1) 00397 << ", separate_write_time: " 00398 << difftime(time3, time2) 00399 << std::endl; 00400 } 00401 } 00402 else { 00403 write_mesh(file_name, 3, &hex_handles[0], hex_size); 00404 time3 = clock(); 00405 if (debug_ebmesh) { 00406 std::cout << "hex_handle_get_time: " 00407 << difftime(time2, time1) 00408 << ", actual_write_time: " 00409 << difftime(time3, time2) 00410 << std::endl; 00411 } 00412 } 00413 delete [] hex_status; 00414 } 00415 00416 void EBMesher::write_mesh(const char* file_name, int type, 00417 iBase_EntityHandle* handles, int& n_elem) 00418 { 00419 time_t time1, time2, time3; 00420 time(&time1); 00421 int is_list = 1; 00422 moab::ErrorCode rval; 00423 iBase_EntitySetHandle set; 00424 iBase_ErrorType err; 00425 00426 err = mk_core()->imesh_instance()->createEntSet(is_list, set); 00427 IBERRCHK(err, "Couldn't create set."); 00428 00429 err = mk_core()->imesh_instance()->addEntArrToSet(handles, n_elem, set); 00430 IBERRCHK(err, "Couldn't add hexes to set."); 00431 time(&time2); 00432 00433 std::string out_name; 00434 std::stringstream ss; 00435 if (type == 0) ss << "inside_"; 00436 else if (type == 1) ss << "outside_"; 00437 else if (type == 2) ss << "boundary_"; 00438 ss << file_name; 00439 ss >> out_name; 00440 00441 rval = moab_instance()->write_mesh(out_name.c_str(), 00442 (const moab::EntityHandle*) &set, 1); 00443 MBERRCHK(rval, mk_core()->moab_instance()); 00444 00445 std::cout << "Elements are exported." << std::endl; 00446 time(&time3); 00447 00448 if (debug_ebmesh) { 00449 std::cout << "set_creation_time: " 00450 << difftime(time2, time1) 00451 << ", write_time: " 00452 << difftime(time3, time2) 00453 << std::endl; 00454 } 00455 } 00456 00457 EdgeStatus EBMesher::get_edge_status(const double dP, int& iSkip) 00458 { 00459 if (m_nStatus == INSIDE) { // previous inside 00460 if (dP < m_dSecondP) { 00461 m_nMove = 0; 00462 iSkip = m_iSecondP; 00463 return INSIDE; 00464 } 00465 else { 00466 if (is_shared_overlapped_surf(m_iInter - 1)) m_nMove = 1; 00467 else m_nMove = 2; 00468 00469 // skip shared and overlapped interesections 00470 while (m_vIntersection[m_iInter].distance - 00471 m_vIntersection[m_iInter - 1].distance < 1e-7 && 00472 (unsigned int) (m_iInter + 1) < m_vIntersection.size()) m_iInter++; 00473 00474 return BOUNDARY; 00475 } 00476 } 00477 else if (m_nStatus == OUTSIDE) { // previous outside 00478 if (dP < m_dFirstP) { 00479 m_nMove = 0; 00480 return OUTSIDE; 00481 } 00482 else { 00483 if (dP < m_dSecondP) m_nMove = 0; 00484 else if (is_shared_overlapped_surf(m_iInter - 1)) m_nMove = 1; 00485 else m_nMove = 2; 00486 00487 // skip shared and overlapped interesections 00488 while (m_vIntersection[m_iInter].distance - 00489 m_vIntersection[m_iInter - 1].distance < 1e-7 && 00490 (unsigned int) (m_iInter + 1) < m_vIntersection.size()) m_iInter++; 00491 00492 return BOUNDARY; 00493 } 00494 } 00495 else if (m_nStatus == BOUNDARY) { // previous boundary 00496 if (dP < m_dFirstP) { 00497 m_nMove = 0; 00498 iSkip = m_iFirstP; 00499 return OUTSIDE; 00500 } 00501 else { 00502 if (dP < m_dSecondP) { 00503 m_nMove = 0; 00504 if (m_prevPnt < m_dFirstP) return BOUNDARY; 00505 else { 00506 iSkip = m_iSecondP; 00507 return INSIDE; 00508 } 00509 } 00510 else { 00511 if (is_shared_overlapped_surf(m_iInter - 1)) m_nMove = 1; 00512 else m_nMove = 2; 00513 00514 // skip shared and overlapped interesections 00515 while (m_vIntersection[m_iInter].distance - 00516 m_vIntersection[m_iInter - 1].distance < 1e-7 && 00517 (unsigned int) (m_iInter + 1) < m_vIntersection.size()) m_iInter++; 00518 00519 if (m_prevPnt < m_dSecondP) return BOUNDARY; 00520 else return OUTSIDE; 00521 } 00522 } 00523 } 00524 else { 00525 std::cerr << "Couldn't get edge status." << std::endl; 00526 return INSIDE; 00527 } 00528 } 00529 00530 bool EBMesher::set_neighbor_hex_status(int dir, int i, int j, int k) 00531 { 00532 int iElem; 00533 int otherDir1 = (dir + 1)%3; 00534 int otherDir2 = (dir + 2)%3; 00535 00536 if (dir == 0) { // x coordinate ray 00537 m_iElem = j*m_nDiv[0]*m_nDiv[1] + i*m_nDiv[0] + k; 00538 if (!set_hex_status(m_iElem, m_nStatus, dir)) return false; 00539 iElem = m_iElem - m_nDiv[dir]; 00540 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00541 iElem -= m_nDiv[dir]*m_nDiv[otherDir1]; 00542 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00543 iElem += m_nDiv[dir]; 00544 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00545 } 00546 else if (dir == 1) { // y coordinate ray 00547 m_iElem = i*m_nDiv[1]*m_nDiv[0] + k*m_nDiv[0] + j; 00548 if (!set_hex_status(m_iElem, m_nStatus, dir)) return false; 00549 iElem = m_iElem - 1; 00550 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00551 iElem -= m_nDiv[dir]*m_nDiv[otherDir2]; 00552 if (!set_hex_status(iElem++, m_nStatus, dir)) return false; 00553 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00554 } 00555 else if (dir == 2) { // z coordinate ray 00556 m_iElem = k*m_nDiv[0]*m_nDiv[1] + j*m_nDiv[0] + i; 00557 if (!set_hex_status(m_iElem, m_nStatus, dir)) return false; 00558 iElem = m_iElem - 1; 00559 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00560 iElem -= m_nDiv[otherDir1]; 00561 if (!set_hex_status(iElem++, m_nStatus, dir)) return false; 00562 if (!set_hex_status(iElem, m_nStatus, dir)) return false; 00563 } 00564 00565 return true; 00566 } 00567 00568 bool EBMesher::set_hex_status(int index, EdgeStatus value, int dir) 00569 { 00570 if (index < 0 || index > m_nHex - 1) { 00571 return false; 00572 } 00573 00574 if (m_vnHexStatus[index] != 2) { 00575 if (value == INSIDE) { 00576 m_vnHexStatus[index] = 0; 00577 } 00578 else if (value == OUTSIDE) { 00579 m_vnHexStatus[index] = 1; 00580 } 00581 else if (value == BOUNDARY) { 00582 m_vnHexStatus[index] = 2; 00583 } 00584 } 00585 00586 return true; 00587 } 00588 00589 bool EBMesher::set_edge_status(int dir) 00590 { 00591 // set boundary cut information to edge 00592 std::vector<double> vdCutFraction; 00593 if (m_nMove == 0) vdCutFraction.push_back((m_curPnt - m_dFirstP)/m_dIntervalSize[dir] - 1.); 00594 else if (m_nMove == 1) vdCutFraction.push_back(1. - (m_curPnt - m_dSecondP)/m_dIntervalSize[dir]); 00595 else if (m_nMove == 2) { 00596 vdCutFraction.push_back(1. - (m_curPnt - m_dSecondP)/m_dIntervalSize[dir]); 00597 if (m_dFirstP < m_curPnt) { 00598 vdCutFraction.push_back((m_curPnt - m_dFirstP)/m_dIntervalSize[dir] - 1.); 00599 } 00600 } 00601 00602 std::map<int, CutFraction>::iterator iter = m_mdCutFraction.find(m_iElem); 00603 if (iter == m_mdCutFraction.end()) { // not exist 00604 CutFraction cFraction(dir, vdCutFraction); 00605 m_mdCutFraction[m_iElem] = cFraction; 00606 } 00607 else { // exist 00608 iter->second.add(dir, vdCutFraction); 00609 } 00610 00611 //m_nFraction += vdCutFraction.size(); 00612 00613 return true; 00614 } 00615 00616 void EBMesher::set_division() 00617 { 00618 int i, j; 00619 moab::CartVect box_center, box_axis1, box_axis2, box_axis3, 00620 min_cart_box(HUGE_VAL, HUGE_VAL, HUGE_VAL), 00621 max_cart_box(0., 0., 0.); 00622 00623 moab::ErrorCode rval = m_hObbTree->box(m_hTreeRoot, box_center.array(), 00624 box_axis1.array(), box_axis2.array(), 00625 box_axis3.array()); 00626 MBERRCHK(rval, mk_core()->moab_instance()); 00627 00628 // cartesian box corners 00629 moab::CartVect corners[8] = {box_center + box_axis1 + box_axis2 + box_axis3, 00630 box_center + box_axis1 + box_axis2 - box_axis3, 00631 box_center + box_axis1 - box_axis2 + box_axis3, 00632 box_center + box_axis1 - box_axis2 - box_axis3, 00633 box_center - box_axis1 + box_axis2 + box_axis3, 00634 box_center - box_axis1 + box_axis2 - box_axis3, 00635 box_center - box_axis1 - box_axis2 + box_axis3, 00636 box_center - box_axis1 - box_axis2 - box_axis3}; 00637 00638 // get the max, min cartesian box corners 00639 for (i = 0; i < 8; i++) { 00640 for (j = 0; j < 3; j++) { 00641 if (corners[i][j] < min_cart_box[j]) min_cart_box[j] = corners[i][j]; 00642 if (corners[i][j] > max_cart_box[j]) max_cart_box[j] = corners[i][j]; 00643 } 00644 } 00645 moab::CartVect length = max_cart_box - min_cart_box; 00646 00647 // default value is adjusted to large geometry file 00648 // interval_size_estimate : 2*L*sqrt(2*PI*sqrt(2)/# of tris) 00649 if (m_dInputSize < 0.) { 00650 int n_tri; 00651 rval = moab_instance()-> 00652 get_number_entities_by_dimension(reinterpret_cast<moab::EntityHandle>(m_hRootSet), 00653 2, n_tri); 00654 MBERRCHK(rval, mk_core()->moab_instance()); 00655 00656 double box_length_ave = (length[0] + length[1] + length[2])/3.; 00657 m_dInputSize = 2.*box_length_ave*sqrt(8.886/n_tri); 00658 } 00659 00660 for (i = 0; i < 3; i++) { 00661 m_nDiv[i] = length[i]/m_dInputSize; 00662 if (m_nDiv[i] < m_nAddLayer) m_nDiv[i] = m_nAddLayer; // make "m_nAddLayer" elements larger than bounding box 00663 m_dIntervalSize[i] = m_dInputSize; 00664 //if (m_nDiv[i]*.07 > m_nAddLayer) m_nDiv[i] += m_nDiv[i]*.07; 00665 //else m_nDiv[i] += m_nAddLayer; 00666 m_nDiv[i] += m_nAddLayer; 00667 m_nNode[i] = m_nDiv[i] + 1; 00668 m_origin_coords[i] = box_center[i] - .5*m_nDiv[i]*m_dIntervalSize[i]; 00669 } 00670 00671 m_nHex = m_nDiv[0]*m_nDiv[1]*m_nDiv[2]; 00672 00673 std::cout << "# of hex: " << m_nHex << ", interval size: " 00674 << m_dInputSize << std::endl; 00675 00676 std::cout << "# of division: " << m_nDiv[0] << "," 00677 << m_nDiv[1] << "," << m_nDiv[2] << std::endl; 00678 } 00679 00680 int EBMesher::set_division(double* min, double* max) 00681 { 00682 for (int i = 0; i < 3; i++) { 00683 m_dIntervalSize[i] = (max[i] - min[i])/m_nDiv[i]; 00684 m_nNode[i] = m_nDiv[i] + 1; 00685 m_origin_coords[i] = min[i]; 00686 } 00687 00688 m_nHex = m_nDiv[0]*m_nDiv[1]*m_nDiv[2]; 00689 00690 std::cout << "# of hex: " << m_nHex << ", interval_size: " 00691 << m_dIntervalSize[0] << ", " << m_dIntervalSize[1] << ", " 00692 << m_dIntervalSize[2] << std::endl; 00693 00694 std::cout << "# of division: " << m_nDiv[0] << "," 00695 << m_nDiv[1] << "," << m_nDiv[2] << std::endl; 00696 00697 return iBase_SUCCESS; 00698 } 00699 00700 int EBMesher::make_scd_hexes() 00701 { 00702 // create vertex and hex sequences 00703 int i; 00704 double max_coords[3]; 00705 (void) max_coords; 00706 for (i = 0; i < 3; i++) { 00707 max_coords[i] = m_origin_coords[i] + m_nDiv[i]*m_dIntervalSize[i]; 00708 } 00709 00710 moab::HomCoord coord_min(0, 0, 0); 00711 moab::HomCoord coord_max(m_nDiv[0], m_nDiv[1], m_nDiv[2]); 00712 moab::EntitySequence* vertex_seq = NULL; 00713 moab::EntitySequence* cell_seq = NULL; 00714 moab::EntityHandle vs, cs; 00715 moab::Core *mbcore = dynamic_cast<moab::Core*>(moab_instance()); 00716 00717 moab::ErrorCode rval = mbcore->create_scd_sequence(coord_min, coord_max, moab::MBVERTEX, 1, vs, vertex_seq); 00718 MBERRCHK(rval, mk_core()->moab_instance()); 00719 00720 mbcore->create_scd_sequence(coord_min, coord_max, moab::MBHEX, 1, cs, cell_seq); 00721 MBERRCHK(rval, mk_core()->moab_instance()); 00722 00723 moab::HomCoord p2(coord_max.i(), coord_min.j(), coord_min.k()); 00724 moab::HomCoord p3(coord_min.i(), coord_max.j(), coord_min.k()); 00725 00726 rval = mbcore->add_vsequence(vertex_seq, cell_seq, coord_min, coord_min, 00727 p2, p2, p3, p3); 00728 MBERRCHK(rval, mk_core()->moab_instance()); 00729 00730 int nTotNode = m_nNode[0]*m_nNode[1]*m_nNode[2]; 00731 int ii, jj, kk; 00732 moab::EntityHandle handle; 00733 double dumv[3]; 00734 for (i = 0, handle = vs; i < nTotNode; i++, handle++) { 00735 ii = (i%(m_nNode[0]*m_nNode[1]))%m_nNode[0]; 00736 jj = (i%(m_nNode[0]*m_nNode[1]))/m_nNode[0]; 00737 kk = i/m_nNode[0]/m_nNode[1]; 00738 dumv[0] = m_origin_coords[0] + ii*m_dIntervalSize[0]; 00739 dumv[1] = m_origin_coords[1] + jj*m_dIntervalSize[1]; 00740 dumv[2] = m_origin_coords[2] + kk*m_dIntervalSize[2]; 00741 rval = moab_instance()->set_coords(&handle, 1, dumv); 00742 MBERRCHK(rval, mk_core()->moab_instance()); 00743 } 00744 00745 m_iStartHex = moab_instance()->id_from_handle(cs); 00746 00747 return iBase_SUCCESS; 00748 } 00749 00750 iBase_TagHandle EBMesher::get_tag(const char* name, int size, 00751 unsigned store, moab::DataType type, 00752 const void* def_value, 00753 bool create_if_missing) 00754 { 00755 moab::Tag retval = 0; 00756 /*moab::ErrorCode result = moab_instance()->tag_create(name, size, store, type, 00757 retval, def_value, 00758 create_if_missing);*/ 00759 store = store | moab::MB_TAG_CREAT; 00760 if(!create_if_missing) 00761 store = store | moab::MB_TAG_EXCL; 00762 moab::ErrorCode result = moab_instance()->tag_get_handle(name, size, type, retval, store, 00763 def_value); 00764 if (create_if_missing && moab::MB_SUCCESS != result) { 00765 std::cerr << "Couldn't find nor create tag named " << name << std::endl; 00766 } 00767 00768 return (iBase_TagHandle) retval; 00769 } 00770 00771 iBase_TagHandle EBMesher::get_various_length_tag(const char* name, 00772 unsigned store, moab::DataType type) 00773 { 00774 moab::Tag retval = 0; 00775 store = store | moab::MB_TAG_VARLEN | moab::MB_TAG_CREAT; 00776 moab::ErrorCode result = moab_instance()-> 00777 tag_get_handle( name, 1, type, retval, store); 00778 if (moab::MB_SUCCESS != result) { 00779 std::cerr << "Couldn't find nor create tag named " << name << std::endl; 00780 } 00781 00782 return (iBase_TagHandle) retval; 00783 } 00784 00785 void EBMesher::set_tag_info() 00786 { 00787 // get all hexes 00788 int i, j, k; 00789 iBase_ErrorType err; 00790 std::vector<iBase_EntityHandle> hex_handles; 00791 err = mk_core()->imesh_instance()->getEntities(m_hRootSet, iBase_REGION, 00792 iMesh_HEXAHEDRON, hex_handles); 00793 IBERRCHK(err, "Failed to get hexes.\n"); 00794 00795 err = mk_core()->imesh_instance()->setIntArrData(&hex_handles[0], m_nHex, 00796 m_elemStatusTag, 00797 &m_vnHexStatus[0]); 00798 IBERRCHK(err, "Failed to set hex element status data."); 00799 00800 // set cut fraction info to boundary hexes 00801 int nBndrHex = m_mdCutFraction.size(); 00802 std::vector<iBase_EntityHandle> hvBndrHex(nBndrHex); 00803 int* frac_size = new int[nBndrHex]; 00804 int* frac_leng = new int[3*nBndrHex]; 00805 int nFracSize, nTempSize, iHex, nTolFrac = 0; 00806 int nDoubleSize = sizeof(double); 00807 std::map<int, CutFraction>::iterator iter = m_mdCutFraction.begin(); 00808 std::map<int, CutFraction>::iterator end_iter = m_mdCutFraction.end(); 00809 for (i = 0; iter != end_iter; iter++, i++) { 00810 iHex = iter->first; 00811 hvBndrHex[i] = hex_handles[iHex]; 00812 00813 nFracSize = 0; 00814 for (j = 0; j < 3; j++) { 00815 nTempSize = iter->second.fraction[j].size(); 00816 nFracSize += nTempSize; 00817 frac_leng[3*i + j] = nTempSize; 00818 } 00819 frac_size[i] = nDoubleSize*nFracSize; // sizeof(double)* 00820 nTolFrac += nFracSize; 00821 } 00822 00823 int iFrac = 0; 00824 double* fractions = new double[nTolFrac]; 00825 std::vector<const void*> frac_data_pointer(nBndrHex); 00826 iter = m_mdCutFraction.begin(); 00827 for (i = 0; iter != end_iter; iter++, i++) { 00828 for (j = 0; j < 3; j++) { 00829 nFracSize = iter->second.fraction[j].size(); 00830 frac_data_pointer[i] = &fractions[iFrac]; 00831 for (k = 0; k < nFracSize; k++) { 00832 fractions[iFrac++] = iter->second.fraction[j][k]; 00833 } 00834 } 00835 } 00836 00837 err = mk_core()->imesh_instance()->setIntArrData(&hvBndrHex[0], nBndrHex, 00838 m_edgeCutFracLengthTag, 00839 frac_leng); 00840 IBERRCHK(err, "Failed to set cut fraction sizes to hex."); 00841 00842 moab::ErrorCode rval = moab_instance()->tag_set_by_ptr(reinterpret_cast<moab::Tag> (m_edgeCutFracTag), 00843 reinterpret_cast<moab::EntityHandle*> (&hvBndrHex[0]), 00844 nBndrHex, &frac_data_pointer[0], frac_size); 00845 MBERRCHK(rval, mk_core()->moab_instance()); 00846 00847 delete [] frac_size; 00848 delete [] frac_leng; 00849 delete [] fractions; 00850 } 00851 00852 void EBMesher::fire_rays(int dir) 00853 { 00854 // ray fire 00855 int i, j, k, l, index[3]; 00856 double tolerance = 1e-12; 00857 double rayLength = m_nDiv[dir]*m_dIntervalSize[dir]; 00858 int iNodeStart, iNodeEnd, nIntersect, nNodeSlice; 00859 double startPnt[3], endPnt[3]; 00860 int otherDir1 = (dir + 1)%3; 00861 int otherDir2 = (dir + 2)%3; 00862 // harmless as this expression (does nothing) so that a compiler sees it is used. 00863 (void) iNodeEnd; 00864 (void) nNodeSlice; 00865 00866 for (j = 1; j < m_nNode[otherDir2] - 1; j++) { 00867 for (i = 1; i < m_nNode[otherDir1] - 1; i++) { 00868 00869 // get ray start and end points 00870 if (dir == 0) { // x coordinate ray 00871 iNodeStart = j*m_nNode[dir]*m_nNode[otherDir1] + i*m_nNode[dir]; 00872 iNodeEnd = iNodeStart + m_nNode[dir] - 1; 00873 nNodeSlice = 1; 00874 index[0] = 0; 00875 index[1] = i; 00876 index[2] = j; 00877 } 00878 else if (dir == 1) { // y coordinate ray 00879 iNodeStart = i*m_nNode[otherDir2]*m_nNode[dir] + j; 00880 iNodeEnd = iNodeStart + m_nNode[otherDir2]*(m_nNode[dir] - 1); 00881 nNodeSlice = m_nNode[otherDir2]; 00882 index[0] = j; 00883 index[1] = 0; 00884 index[2] = i; 00885 } 00886 else if (dir == 2) { // z coordinate ray 00887 iNodeStart = j*m_nNode[otherDir1] + i; 00888 iNodeEnd = iNodeStart + m_nNode[otherDir1]*m_nNode[otherDir2]*(m_nNode[dir] - 1); 00889 nNodeSlice = m_nNode[otherDir1]*m_nNode[otherDir2]; 00890 index[0] = i; 00891 index[1] = j; 00892 index[2] = 0; 00893 } 00894 else IBERRCHK(iBase_FAILURE, "Ray direction should be 0 to 2."); 00895 00896 for (l = 0; l < 3; l++) { 00897 if (l == dir) { 00898 startPnt[l] = m_origin_coords[l]; 00899 endPnt[l] = m_origin_coords[l] + m_nDiv[dir]*m_dIntervalSize[l]; 00900 } 00901 else { 00902 startPnt[l] = m_origin_coords[l] + index[l]*m_dIntervalSize[l]; 00903 endPnt[l] = startPnt[l]; 00904 } 00905 } 00906 00907 k = 0; 00908 m_iInter = 0; 00909 if (!fire_ray(nIntersect, startPnt, endPnt, tolerance, dir, rayLength)) { 00910 IBERRCHK(iBase_FAILURE, "Couldn't fire ray."); 00911 } 00912 00913 if (nIntersect > 0) { 00914 m_iFirstP = m_vIntersection[m_iInter].distance/m_dIntervalSize[dir]; 00915 m_dFirstP = startPnt[dir] + m_vIntersection[m_iInter++].distance; 00916 m_iSecondP = m_vIntersection[m_iInter].distance/m_dIntervalSize[dir]; 00917 m_dSecondP = startPnt[dir] + m_vIntersection[m_iInter++].distance; 00918 00919 // set outside before the first hit 00920 for (k = 0; k < m_iFirstP; k++) { 00921 m_nStatus = OUTSIDE; 00922 00923 if (!set_neighbor_hex_status(dir, i, j, k)) { 00924 IBERRCHK(iBase_FAILURE, "Couldn't set neighbor hex status."); 00925 } 00926 } 00927 00928 for (; k < m_nNode[dir] - 1;) { 00929 int i_skip = 0; 00930 m_curPnt = startPnt[dir] + (k + 1)*m_dIntervalSize[dir]; 00931 EdgeStatus preStat = m_nStatus; 00932 m_nStatus = get_edge_status(m_curPnt, i_skip); 00933 m_vnEdgeStatus[dir][i*m_nDiv[dir] + j*m_nDiv[dir]*m_nDiv[otherDir1] + k] = m_nStatus; 00934 00935 // set status of all hexes sharing the edge 00936 if (!set_neighbor_hex_status(dir, i, j, k)) { 00937 IBERRCHK(iBase_FAILURE, "Couldn't set neighbor hex status."); 00938 } 00939 00940 if (m_nMove > 0) { 00941 if (m_iInter < nIntersect) { 00942 if (!move_intersections(dir, nIntersect, startPnt)) { 00943 IBERRCHK(iBase_FAILURE, "Couldn't move intersections."); 00944 } 00945 } 00946 else { 00947 m_nMove = 1; 00948 if (m_nStatus == BOUNDARY && !set_edge_status(dir)) { 00949 IBERRCHK(iBase_FAILURE, "Couldn't set edge status."); 00950 } 00951 k++; 00952 break; // rest is all outside 00953 } 00954 } 00955 else if (m_nStatus == BOUNDARY && !set_edge_status(dir)) { 00956 IBERRCHK(iBase_FAILURE, "Couldn't set edge status."); 00957 } 00958 else if (m_nStatus == OUTSIDE && preStat == BOUNDARY) { // set outside until next hit 00959 k++; 00960 for (; k < i_skip; k++) { 00961 m_nStatus = OUTSIDE; 00962 if (!set_neighbor_hex_status(dir, i, j, k)) { 00963 IBERRCHK(iBase_FAILURE, "Couldn't set neighbor hex status."); 00964 } 00965 } 00966 } 00967 00968 // set cut-cell edge status 00969 if (i_skip > 0) { 00970 m_prevPnt = startPnt[dir] + i_skip*m_dIntervalSize[dir]; 00971 k = i_skip; 00972 } 00973 else { 00974 m_prevPnt = m_curPnt; 00975 k++; 00976 } 00977 } 00978 } 00979 00980 // the rest are all outside 00981 for (; k < m_nNode[dir] - 1; k++) { 00982 m_nStatus = OUTSIDE; 00983 if (!set_neighbor_hex_status(dir, i, j, k)) { 00984 IBERRCHK(iBase_FAILURE, "Couldn't set neighbor hex status."); 00985 } 00986 } 00987 } 00988 } 00989 } 00990 00991 bool EBMesher::fire_ray(int& nIntersect, double startPnt[3], 00992 double endPnt[3], double tol, int dir, 00993 double rayLength) 00994 { 00995 m_vIntersection.clear(); 00996 m_vhInterSurf.clear(); 00997 m_vhInterFacet.clear(); 00998 m_mhOverlappedSurf.clear(); 00999 std::vector<double> temp_intersects; 01000 moab::ErrorCode rVal; 01001 moab::OrientedBoxTreeTool::TrvStats stats; 01002 if (m_bUseGeom) { // geometry input 01003 rVal = m_hObbTree->ray_intersect_sets(temp_intersects, m_vhInterSurf, 01004 m_vhInterFacet, m_hTreeRoot, tol, 01005 startPnt, rayDir[dir], &rayLength, 01006 &stats); 01007 } 01008 else { // facet input 01009 std::vector<moab::EntityHandle> dum_facets_out; 01010 rVal = m_hObbTree->ray_intersect_triangles(temp_intersects, dum_facets_out, 01011 m_hTreeRoot, tol, 01012 startPnt, rayDir[dir], &rayLength, 01013 &stats); 01014 } 01015 01016 nIntersect = temp_intersects.size(); 01017 if (moab::MB_SUCCESS != rVal) { 01018 std::cerr << "Failed : ray-triangle intersection." << std::endl; 01019 return false; 01020 } 01021 01022 if (nIntersect > 0) { 01023 m_vIntersection.resize(nIntersect); 01024 01025 for (int l = 0; l < nIntersect; l++) { 01026 IntersectDist temp_inter_dist(temp_intersects[l], l); 01027 m_vIntersection[l] = temp_inter_dist; 01028 } 01029 std::sort(m_vIntersection.begin(), m_vIntersection.end(), less_intersect); 01030 01031 if (nIntersect > 1) { 01032 bool bMoveOnce; 01033 m_nIteration = 0; 01034 m_iOverlap = 0; 01035 01036 if (m_bUseGeom) { // if there are geometry info 01037 remove_intersection_duplicates(); 01038 } 01039 else if (is_ray_move_and_set_overlap_surf(bMoveOnce)) { // facet geom case 01040 if (!move_ray(nIntersect, startPnt, endPnt, tol, dir, bMoveOnce)) { 01041 std::cerr << "Number of Intersection between edges and ray should be even." << std::endl; 01042 return false; 01043 } 01044 } 01045 nIntersect = m_vIntersection.size(); 01046 } 01047 } 01048 01049 return true; 01050 } 01051 01052 bool EBMesher::move_intersections(int n_dir, int n_inter, double start_pnt[3]) 01053 { 01054 if (m_nMove > 0) { 01055 if (m_iInter < n_inter) { 01056 if (m_nMove == 1) { 01057 do { 01058 if (m_nStatus == BOUNDARY && !set_edge_status(n_dir)) return false; 01059 m_iFirstP = m_iSecondP; 01060 m_dFirstP = m_dSecondP; 01061 m_iSecondP = m_vIntersection[m_iInter].distance/m_dIntervalSize[n_dir]; 01062 m_dSecondP = start_pnt[n_dir] + m_vIntersection[m_iInter++].distance; 01063 } 01064 while (m_dSecondP < m_curPnt && m_iInter < n_inter); 01065 } 01066 else if (m_nMove == 2) { 01067 do { 01068 m_iFirstP = m_vIntersection[m_iInter].distance/m_dIntervalSize[n_dir]; 01069 m_dFirstP = start_pnt[n_dir] + m_vIntersection[m_iInter++].distance; 01070 if (m_nStatus == BOUNDARY && !set_edge_status(n_dir)) return false; 01071 if (m_iInter < n_inter) { 01072 m_iSecondP = m_vIntersection[m_iInter].distance/m_dIntervalSize[n_dir]; 01073 m_dSecondP = start_pnt[n_dir] + m_vIntersection[m_iInter++].distance; 01074 } 01075 else { 01076 m_iSecondP = m_iFirstP; 01077 m_dSecondP = m_dFirstP; 01078 } 01079 } 01080 while (m_dSecondP < m_curPnt && m_iInter < n_inter); 01081 } 01082 } 01083 } 01084 01085 return true; 01086 } 01087 01088 bool EBMesher::is_shared_overlapped_surf(int index) 01089 { 01090 int nParent; 01091 iBase_ErrorType err; 01092 moab::EntityHandle hSurf; 01093 if (m_bUseGeom) { 01094 hSurf = m_vhInterSurf[m_vIntersection[index].index]; 01095 err = mk_core()->imesh_instance()->getNumPrnt(reinterpret_cast<iBase_EntitySetHandle> (hSurf), 01096 1, nParent); 01097 IBERRCHK(err, "Failed to get number of surface parents.\n"); 01098 01099 if (nParent > 1) return true; 01100 } 01101 else hSurf = m_vIntersection[index].index; 01102 01103 return m_mhOverlappedSurf.count(hSurf) > 0; 01104 } 01105 01106 void EBMesher::get_grid_and_edges_techX(double* boxMin, double* boxMax, int* nDiv, 01107 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& rmdCutCellSurfEdge, 01108 std::vector<int>& rvnInsideCell, bool isCornerExterior) 01109 { 01110 int i, j, err, ii, jj, kk, iHex; 01111 for (i = 0; i < 3; i++) { 01112 boxMin[i] = m_origin_coords[i]; 01113 boxMax[i] = m_origin_coords[i] + m_dIntervalSize[i]*m_nDiv[i]; 01114 nDiv[i] = m_nDiv[i]; 01115 } 01116 01117 // get all hexes 01118 std::vector<iBase_EntityHandle> hex_handles; 01119 err = mk_core()->imesh_instance()->getEntities(m_hRootSet, iBase_REGION, 01120 iMesh_HEXAHEDRON, hex_handles); 01121 IBERRCHK(err, "Failed to get hexes.\n"); 01122 01123 // get hex status 01124 int hex_size = hex_handles.size(); 01125 /* 01126 //int* hex_status = new int[hex_size]; 01127 //int* hex_status; 01128 //std::vector<int> hex_status(hex_size); 01129 int temp = 0; 01130 int* hex_status = &temp; 01131 err = mk_core()->imesh_instance()->getIntArrData(&hex_handles[0], hex_size, 01132 m_elemStatusTag, hex_status); 01133 */ 01134 int error; 01135 int* hex_status = new int[hex_size]; 01136 int hex_status_alloc = sizeof(int)*hex_size; 01137 int hex_status_size = 0; 01138 iMesh_getIntArrData(m_mesh, &hex_handles[0], 01139 hex_size, m_elemStatusTag, 01140 &hex_status, &hex_status_alloc, 01141 &hex_status_size, &error); 01142 IBERRCHK(error, "Failed to get hex status."); 01143 01144 // get inside and boundary hexes 01145 int nInside = 0; 01146 int nOutside = 0; 01147 int nBoundary = 0; 01148 rvnInsideCell.clear(); 01149 for (i = 0; i < hex_size; i++) { 01150 if (hex_status[i] == 0) { // if inside 01151 iHex = moab_instance()->id_from_handle(reinterpret_cast<moab::EntityHandle> 01152 (hex_handles[i])) - m_iStartHex; 01153 rvnInsideCell.push_back((iHex%(m_nDiv[0]*m_nDiv[1]))%m_nDiv[0]); 01154 rvnInsideCell.push_back((iHex%(m_nDiv[0]*m_nDiv[1]))/m_nDiv[0]); 01155 rvnInsideCell.push_back(iHex/m_nDiv[0]/m_nDiv[1]); 01156 nInside++; 01157 } 01158 else if (hex_status[i] == 1) nOutside++; 01159 else if (hex_status[i] == 2) nBoundary++; 01160 else IBERRCHK(err, "Element status should be one of inside/outside/boundary."); 01161 } 01162 std::cout << "# of inside, outside, boundary elem: " << nInside 01163 << ", " << nOutside << ", " << nBoundary << std::endl; 01164 delete [] hex_status; 01165 01166 // get cut-cell fractions 01167 double dFrac[4]; 01168 std::map<int, CutFraction>::iterator iter = m_mdCutFraction.begin(); 01169 std::map<int, CutFraction>::iterator end_iter = m_mdCutFraction.end(); 01170 01171 for (; iter != end_iter; iter++) { // for each cut-cell 01172 // get i, j, k index from handle 01173 iHex = iter->first; 01174 ii = (iHex%(m_nDiv[0]*m_nDiv[1]))%m_nDiv[0]; 01175 jj = (iHex%(m_nDiv[0]*m_nDiv[1]))/m_nDiv[0]; 01176 kk = iHex/m_nDiv[0]/m_nDiv[1]; 01177 01178 // surface 1 01179 CutFraction cutFrac = iter->second; 01180 if (cutFrac.fraction[1].size() > 0) { 01181 dFrac[0] = cutFrac.fraction[1][0]; 01182 if (dFrac[0] < 0.) dFrac[0] *= -1.; 01183 } 01184 else dFrac[0] = -1.; 01185 if (cutFrac.fraction[2].size() > 0) { 01186 dFrac[3] = cutFrac.fraction[2][0]; 01187 if (dFrac[3] < 0.) dFrac[3] *= -1.; 01188 } 01189 else dFrac[3] = -1.; 01190 dFrac[1] = get_edge_fraction(iHex + m_nDiv[0], 2); 01191 dFrac[2] = get_edge_fraction(iHex + m_nDiv[0]*m_nDiv[1], 1); 01192 01193 if (dFrac[0] > 0. || dFrac[1] > 0. || dFrac[2] > 0. || dFrac[3] > 0.) { // if surface is cut 01194 CutCellSurfEdgeKey surfKey(ii, jj, kk, 0); 01195 std::vector<double> edges; 01196 if (dFrac[0] < 0.) dFrac[0] = get_uncut_edge_fraction(ii, jj, kk, 1); 01197 if (dFrac[1] < 0.) dFrac[1] = get_uncut_edge_fraction(ii, jj + 1, kk, 2); 01198 if (dFrac[2] < 0.) dFrac[2] = get_uncut_edge_fraction(ii, jj, kk + 1, 1); 01199 if (dFrac[3] < 0.) dFrac[3] = get_uncut_edge_fraction(ii, jj, kk, 2); 01200 for (j = 0; j < 4; j++) edges.push_back(dFrac[j]); 01201 rmdCutCellSurfEdge[surfKey] = edges; 01202 } 01203 01204 // surface 2 01205 cutFrac = iter->second; 01206 if (cutFrac.fraction[0].size() > 0) { 01207 dFrac[0] = cutFrac.fraction[0][0]; 01208 if (dFrac[0] < 0.) dFrac[0] *= -1.; 01209 } 01210 else dFrac[0] = -1.; 01211 if (cutFrac.fraction[1].size() > 0) { 01212 dFrac[3] = cutFrac.fraction[1][0]; 01213 if (dFrac[3] < 0.) dFrac[3] *= -1.; 01214 } 01215 else dFrac[3] = -1.; 01216 dFrac[1] = get_edge_fraction(iHex + 1, 2); 01217 dFrac[2] = get_edge_fraction(iHex + m_nDiv[0]*m_nDiv[1], 0); 01218 01219 if (dFrac[0] > 0. || dFrac[1] > 0. || dFrac[2] > 0. || dFrac[3] > 0.) { // if surface is cut 01220 CutCellSurfEdgeKey surfKey(ii, jj, kk, 1); 01221 std::vector<double> edges; 01222 if (dFrac[0] < 0.) dFrac[0] = get_uncut_edge_fraction(ii, jj, kk, 0); 01223 if (dFrac[1] < 0.) dFrac[1] = get_uncut_edge_fraction(ii + 1, jj, kk, 2); 01224 if (dFrac[2] < 0.) dFrac[2] = get_uncut_edge_fraction(ii, jj, kk + 1, 0); 01225 if (dFrac[3] < 0.) dFrac[3] = get_uncut_edge_fraction(ii, jj, kk, 2); 01226 for (j = 0; j < 4; j++) edges.push_back(dFrac[j]); 01227 rmdCutCellSurfEdge[surfKey] = edges; 01228 } 01229 01230 // surface 3 01231 cutFrac = iter->second; 01232 if (cutFrac.fraction[0].size() > 0) { 01233 dFrac[0] = cutFrac.fraction[0][0]; 01234 if (dFrac[0] < 0.) dFrac[0] *= -1.; 01235 } 01236 else dFrac[0] = -1.; 01237 if (cutFrac.fraction[1].size() > 0) { 01238 dFrac[3] = cutFrac.fraction[1][0]; 01239 if (dFrac[3] < 0.) dFrac[3] *= -1.; 01240 } 01241 else dFrac[3] = -1.; 01242 dFrac[1] = get_edge_fraction(iHex + 1, 1); 01243 dFrac[2] = get_edge_fraction(iHex + m_nDiv[0], 0); 01244 01245 if (dFrac[0] > 0. || dFrac[1] > 0. || dFrac[2] > 0. || dFrac[3] > 0.) { // if surface is cut 01246 CutCellSurfEdgeKey surfKey(ii, jj, kk, 2); 01247 std::vector<double> edges; 01248 if (dFrac[0] < 0.) dFrac[0] = get_uncut_edge_fraction(ii, jj, kk, 0); 01249 if (dFrac[1] < 0.) dFrac[1] = get_uncut_edge_fraction(ii + 1, jj, kk, 1); 01250 if (dFrac[2] < 0.) dFrac[2] = get_uncut_edge_fraction(ii, jj + 1, kk, 0); 01251 if (dFrac[3] < 0.) dFrac[3] = get_uncut_edge_fraction(ii, jj, kk, 1); 01252 for (j = 0; j < 4; j++) edges.push_back(dFrac[j]); 01253 rmdCutCellSurfEdge[surfKey] = edges; 01254 } 01255 } 01256 01257 if (debug_ebmesh) export_fraction_edges(rmdCutCellSurfEdge); 01258 } 01259 01260 bool EBMesher::get_grid_and_edges(double* boxMin, double* boxMax, int* nDiv, 01261 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& rmdCutCellEdge, 01262 std::vector<int>& rvnInsideCell, bool isCornerExterior) 01263 { 01264 int i, ii, jj, kk, iHex; 01265 for (i = 0; i < 3; i++) { 01266 boxMin[i] = m_origin_coords[i]; 01267 boxMax[i] = m_origin_coords[i] + m_dIntervalSize[i]*m_nDiv[i]; 01268 nDiv[i] = m_nDiv[i]; 01269 } 01270 01271 if (!get_inside_hex(rvnInsideCell)) return false; 01272 01273 // get cut-cell fractions 01274 std::map<int, CutFraction>::iterator iter = m_mdCutFraction.begin(); 01275 std::map<int, CutFraction>::iterator end_iter = m_mdCutFraction.end(); 01276 01277 for (; iter != end_iter; iter++) { // for each cut-cell 01278 // get i, j, k index from handle 01279 iHex = iter->first; 01280 ii = (iHex%(m_nDiv[0]*m_nDiv[1]))%m_nDiv[0]; 01281 jj = (iHex%(m_nDiv[0]*m_nDiv[1]))/m_nDiv[0]; 01282 kk = iHex/m_nDiv[0]/m_nDiv[1]; 01283 01284 for (i = 0; i < 3; i++) { 01285 std::vector<double> fractions(iter->second.fraction[i]); 01286 CutCellSurfEdgeKey edgeKey(ii, jj, kk, i); 01287 rmdCutCellEdge[edgeKey] = fractions; 01288 } 01289 } 01290 01291 if (debug_ebmesh) return export_fraction_points(rmdCutCellEdge); 01292 01293 return true; 01294 } 01295 01296 bool EBMesher::get_inside_hex(std::vector<int>& rvnInsideCell) 01297 { 01298 int i, err, iHex; 01299 01300 // get all hexes 01301 std::vector<iBase_EntityHandle> hex_handles; 01302 err = mk_core()->imesh_instance()->getEntities(m_hRootSet, iBase_REGION, 01303 iMesh_HEXAHEDRON, hex_handles); 01304 IBERRCHK(err, "Failed to get hexes.\n"); 01305 01306 // get hex status 01307 int hex_size = hex_handles.size(); 01308 /* 01309 //int* hex_status = new int[hex_size]; 01310 //int* hex_status; 01311 std::vector<int> hex_status(hex_size); 01312 err = mk_core()->imesh_instance()->getIntArrData(&hex_handles[0], hex_size, 01313 m_elemStatusTag, &hex_status[0]); 01314 */ 01315 int error; 01316 int* hex_status = new int[hex_size]; 01317 int hex_status_alloc = sizeof(int)*hex_size; 01318 int hex_status_size = 0; 01319 iMesh_getIntArrData(m_mesh, &hex_handles[0], 01320 hex_size, m_elemStatusTag, 01321 &hex_status, &hex_status_alloc, 01322 &hex_status_size, &error); 01323 ERRORRF("Failed to get hex status.\n"); 01324 01325 // get inside and boundary hexes 01326 int nInside = 0; 01327 int nOutside = 0; 01328 int nBoundary = 0; 01329 rvnInsideCell.clear(); 01330 for (i = 0; i < hex_size; i++) { 01331 if (hex_status[i] == 0) { // if inside 01332 iHex = moab_instance()->id_from_handle(reinterpret_cast<moab::EntityHandle> 01333 (hex_handles[i])) - m_iStartHex; 01334 rvnInsideCell.push_back((iHex%(m_nDiv[0]*m_nDiv[1]))%m_nDiv[0]); 01335 rvnInsideCell.push_back((iHex%(m_nDiv[0]*m_nDiv[1]))/m_nDiv[0]); 01336 rvnInsideCell.push_back(iHex/m_nDiv[0]/m_nDiv[1]); 01337 nInside++; 01338 } 01339 else if (hex_status[i] == 1) nOutside++; 01340 else if (hex_status[i] == 2) nBoundary++; 01341 else ERRORRF("Element status should be one of inside/outside/boundary.\n"); 01342 } 01343 std::cout << "# of inside, outside, boundary elem: " << nInside 01344 << ", " << nOutside << ", " << nBoundary << std::endl; 01345 01346 delete [] hex_status; 01347 return true; 01348 } 01349 01350 bool EBMesher::export_fraction_edges(std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& mdCutCellSurfEdge) 01351 { 01352 // export fractions as edge 01353 double curPnt[3], ePnt[6]; 01354 std::vector<iBase_EntityHandle> edge_handles; 01355 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >::iterator itr = mdCutCellSurfEdge.begin(); 01356 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >::iterator e_itr = mdCutCellSurfEdge.end(); 01357 for (; itr != e_itr; itr++) { 01358 curPnt[0] = m_origin_coords[0] + itr->first.i*m_dIntervalSize[0]; 01359 curPnt[1] = m_origin_coords[1] + itr->first.j*m_dIntervalSize[1]; 01360 curPnt[2] = m_origin_coords[2] + itr->first.k*m_dIntervalSize[2]; 01361 std::vector<double> edges = itr->second; 01362 01363 if (itr->first.l == 0) { 01364 if (edges[0] > 0. && edges[0] < 1.) { 01365 ePnt[0] = curPnt[0]; 01366 ePnt[1] = curPnt[1]; 01367 ePnt[2] = curPnt[2]; 01368 ePnt[3] = ePnt[0]; 01369 ePnt[4] = ePnt[1] + edges[0]*m_dIntervalSize[1]; 01370 ePnt[5] = ePnt[2]; 01371 if (!make_edge(ePnt, edge_handles)) return false; 01372 } 01373 if (edges[1] > 0. && edges[1] < 1.) { 01374 ePnt[0] = curPnt[0]; 01375 ePnt[1] = curPnt[1] + m_dIntervalSize[1]; 01376 ePnt[2] = curPnt[2]; 01377 ePnt[3] = ePnt[0]; 01378 ePnt[4] = ePnt[1]; 01379 ePnt[5] = ePnt[2] + edges[1]*m_dIntervalSize[2]; 01380 if (!make_edge(ePnt, edge_handles)) return false; 01381 } 01382 if (edges[2] > 0. && edges[2] < 1.) { 01383 ePnt[0] = curPnt[0]; 01384 ePnt[1] = curPnt[1]; 01385 ePnt[2] = curPnt[2] + m_dIntervalSize[2]; 01386 ePnt[3] = ePnt[0]; 01387 ePnt[4] = ePnt[1] + edges[2]*m_dIntervalSize[1]; 01388 ePnt[5] = ePnt[2]; 01389 if (!make_edge(ePnt, edge_handles)) return false; 01390 } 01391 if (edges[3] > 0. && edges[3] < 1.) { 01392 ePnt[0] = curPnt[0]; 01393 ePnt[1] = curPnt[1]; 01394 ePnt[2] = curPnt[2]; 01395 ePnt[3] = ePnt[0]; 01396 ePnt[4] = ePnt[1]; 01397 ePnt[5] = ePnt[2] + edges[3]*m_dIntervalSize[2]; 01398 if (!make_edge(ePnt, edge_handles)) return false; 01399 } 01400 } 01401 if (itr->first.l == 1) { 01402 if (edges[0] > 0. && edges[0] < 1.) { 01403 ePnt[0] = curPnt[0]; 01404 ePnt[1] = curPnt[1]; 01405 ePnt[2] = curPnt[2]; 01406 ePnt[3] = ePnt[0] + edges[0]*m_dIntervalSize[0]; 01407 ePnt[4] = ePnt[1]; 01408 ePnt[5] = ePnt[2]; 01409 if (!make_edge(ePnt, edge_handles)) return false; 01410 } 01411 if (edges[1] > 0. && edges[1] < 1.) { 01412 ePnt[0] = curPnt[0] + m_dIntervalSize[0]; 01413 ePnt[1] = curPnt[1]; 01414 ePnt[2] = curPnt[2]; 01415 ePnt[3] = ePnt[0]; 01416 ePnt[4] = ePnt[1]; 01417 ePnt[5] = ePnt[2] + edges[1]*m_dIntervalSize[2]; 01418 if (!make_edge(ePnt, edge_handles)) return false; 01419 } 01420 if (edges[2] > 0. && edges[2] < 1.) { 01421 ePnt[0] = curPnt[0]; 01422 ePnt[1] = curPnt[1]; 01423 ePnt[2] = curPnt[2] + m_dIntervalSize[2]; 01424 ePnt[3] = ePnt[0] + edges[2]*m_dIntervalSize[0]; 01425 ePnt[4] = ePnt[1]; 01426 ePnt[5] = ePnt[2]; 01427 if (!make_edge(ePnt, edge_handles)) return false; 01428 } 01429 if (edges[3] > 0. && edges[3] < 1.) { 01430 ePnt[0] = curPnt[0]; 01431 ePnt[1] = curPnt[1]; 01432 ePnt[2] = curPnt[2]; 01433 ePnt[3] = ePnt[0]; 01434 ePnt[4] = ePnt[1]; 01435 ePnt[5] = ePnt[2] + edges[3]*m_dIntervalSize[2]; 01436 if (!make_edge(ePnt, edge_handles)) return false; 01437 } 01438 } 01439 if (itr->first.l == 2) { 01440 if (edges[0] > 0. && edges[0] < 1.) { 01441 ePnt[0] = curPnt[0]; 01442 ePnt[1] = curPnt[1]; 01443 ePnt[2] = curPnt[2]; 01444 ePnt[3] = ePnt[0] + edges[0]*m_dIntervalSize[0]; 01445 ePnt[4] = ePnt[1]; 01446 ePnt[5] = ePnt[2]; 01447 if (!make_edge(ePnt, edge_handles)) return false; 01448 } 01449 if (edges[1] > 0. && edges[1] < 1.) { 01450 ePnt[0] = curPnt[0] + m_dIntervalSize[0]; 01451 ePnt[1] = curPnt[1]; 01452 ePnt[2] = curPnt[2]; 01453 ePnt[3] = ePnt[0]; 01454 ePnt[4] = ePnt[1] + edges[1]*m_dIntervalSize[1]; 01455 ePnt[5] = ePnt[2]; 01456 if (!make_edge(ePnt, edge_handles)) return false; 01457 } 01458 if (edges[2] > 0. && edges[2] < 1.) { 01459 ePnt[0] = curPnt[0]; 01460 ePnt[1] = curPnt[1] + m_dIntervalSize[2]; 01461 ePnt[2] = curPnt[2]; 01462 ePnt[3] = ePnt[0] + edges[2]*m_dIntervalSize[0]; 01463 ePnt[4] = ePnt[1]; 01464 ePnt[5] = ePnt[2]; 01465 if (!make_edge(ePnt, edge_handles)) return false; 01466 } 01467 if (edges[3] > 0. && edges[3] < 1.) { 01468 ePnt[0] = curPnt[0]; 01469 ePnt[1] = curPnt[1]; 01470 ePnt[2] = curPnt[2]; 01471 ePnt[3] = ePnt[0]; 01472 ePnt[4] = ePnt[1] + edges[3]*m_dIntervalSize[1]; 01473 ePnt[5] = ePnt[2]; 01474 if (!make_edge(ePnt, edge_handles)) return false; 01475 } 01476 } 01477 } 01478 01479 int is_list = 1; 01480 iBase_EntitySetHandle set; 01481 iBase_ErrorType err; 01482 err = mk_core()->imesh_instance()->createEntSet(is_list, set); 01483 IBERRCHK(err, "Couldn't create set."); 01484 01485 err = mk_core()->imesh_instance()->addEntArrToSet(&edge_handles[0], 01486 edge_handles.size(), set); 01487 IBERRCHK(err, "Couldn't add edges to set."); 01488 01489 moab::ErrorCode rval = moab_instance()->write_mesh("edges.vtk", 01490 (const moab::EntityHandle*) &set, 1); 01491 MBERRCHK(rval, mk_core()->moab_instance()); 01492 01493 return true; 01494 } 01495 01496 bool EBMesher::export_fraction_points(std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >& mdCutCellEdge) 01497 { 01498 // export fractions as edge 01499 int i, j, dir, nFrc; 01500 iBase_ErrorType err; 01501 double curPnt[3], fracPnt[3], frac; 01502 iBase_EntityHandle v_handle; 01503 std::vector<iBase_EntityHandle> vertex_handles; 01504 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >::iterator itr = mdCutCellEdge.begin(); 01505 std::map< CutCellSurfEdgeKey, std::vector<double>, LessThan >::iterator e_itr = mdCutCellEdge.end(); 01506 for (; itr != e_itr; itr++) { 01507 curPnt[0] = m_origin_coords[0] + itr->first.i*m_dIntervalSize[0]; 01508 curPnt[1] = m_origin_coords[1] + itr->first.j*m_dIntervalSize[1]; 01509 curPnt[2] = m_origin_coords[2] + itr->first.k*m_dIntervalSize[2]; 01510 dir = itr->first.l; 01511 nFrc = itr->second.size(); 01512 01513 for (i = 0; i < nFrc; i++) { 01514 frac = itr->second[i]; 01515 if (frac > 0. && frac < 1.) { 01516 for (j = 0; j < 3; j++) { 01517 if (j == dir) fracPnt[j] = curPnt[j] + frac*m_dIntervalSize[j]; 01518 else fracPnt[j] = curPnt[j]; 01519 } 01520 err = mk_core()->imesh_instance()->createVtx(fracPnt[0], fracPnt[1], 01521 fracPnt[2], v_handle); 01522 IBERRCHK(err, "Couldn't create vertex."); 01523 vertex_handles.push_back(v_handle); 01524 } 01525 } 01526 } 01527 01528 int is_list = 1; 01529 moab::ErrorCode result; 01530 iBase_EntitySetHandle set; 01531 err = mk_core()->imesh_instance()->createEntSet(is_list, set); 01532 IBERRCHK(err, "Couldn't create set."); 01533 01534 err = mk_core()->imesh_instance()->addEntArrToSet(&vertex_handles[0], 01535 vertex_handles.size(), set); 01536 IBERRCHK(err, "Couldn't add vertices to set."); 01537 01538 result = moab_instance()->write_mesh("frac_vertices.vtk", 01539 (const moab::EntityHandle*) &set, 1); 01540 if (moab::MB_SUCCESS != result) { 01541 std::cerr << "Failed to write fraction vertices." << std::endl; 01542 return false; 01543 } 01544 01545 return true; 01546 } 01547 01548 bool EBMesher::make_edge(double ePnt[6], std::vector<iBase_EntityHandle>& edge_handles) 01549 { 01550 iBase_ErrorType err; 01551 iBase_EntityHandle vertex_handle[2], edge_handle; 01552 iBase_EntityHandle* pVertexHandle = &vertex_handle[0]; 01553 err = mk_core()->imesh_instance()->createVtxArr(2, iBase_INTERLEAVED, 01554 ePnt, pVertexHandle); 01555 IBERRCHK(err, "Failed to create vertices.\n"); 01556 01557 err = mk_core()->imesh_instance()->createEnt(iMesh_LINE_SEGMENT, 01558 &vertex_handle[0], 2, 01559 edge_handle); 01560 IBERRCHK(err, "Failed to create edge.\n"); 01561 01562 edge_handles.push_back(edge_handle); 01563 01564 return true; 01565 } 01566 01567 double EBMesher::get_edge_fraction(int idHex, int dir) 01568 { 01569 std::map<int, CutFraction>::iterator end_iter = m_mdCutFraction.end(); 01570 std::map<int, CutFraction>::iterator iter = m_mdCutFraction.find(idHex); 01571 if (iter != end_iter && iter->second.fraction[dir].size() > 0) { 01572 double frac = iter->second.fraction[dir][0]; 01573 if (frac < 0.) frac *= -1.; 01574 return frac; 01575 } 01576 else return -1.; 01577 } 01578 01579 double EBMesher::get_uncut_edge_fraction(int i, int j, int k, int dir) 01580 { 01581 int iEdge; 01582 01583 if (dir == 0) { 01584 if (j == m_nDiv[1] || k == m_nDiv[2]) return 0.; // return outside 01585 iEdge = k*m_nDiv[0]*m_nDiv[1] + j*m_nDiv[0] + i; 01586 } 01587 else if (dir == 1) { 01588 if (i == m_nDiv[0] || k == m_nDiv[2]) return 0.; // return outside 01589 iEdge = i*m_nDiv[1]*m_nDiv[2] + k*m_nDiv[1] + j; 01590 } 01591 else if (dir == 2) { 01592 if (i == m_nDiv[0] || j == m_nDiv[1]) return 0.; // return outside 01593 iEdge = j*m_nDiv[0]*m_nDiv[2] + i*m_nDiv[2] + k; 01594 } 01595 else return -1.; 01596 01597 EdgeStatus edgeStatus = m_vnEdgeStatus[dir][iEdge]; 01598 if (edgeStatus == INSIDE) return 1.; 01599 else if (edgeStatus == OUTSIDE) return 0.; 01600 else return -1.; 01601 } 01602 01603 bool EBMesher::move_ray(int& nIntersect, double* startPnt, double* endPnt, 01604 double tol, int dir, bool bSpecialCase) 01605 { 01606 //int i, nIteration; 01607 int i; 01608 bool bMove = true; 01609 01610 if (bSpecialCase) m_iOverlap = 0; 01611 01612 while (bMove) { 01613 if (m_nIteration > 10) { 01614 if (bSpecialCase) return true; // special case 01615 else if (m_bUseGeom) { // shared/overlapped, faceting case 01616 m_mhOverlappedSurf[m_iOverlap] = 0; 01617 m_mhOverlappedSurf[m_iOverlap + 1] = 0; 01618 return true; 01619 } 01620 else { 01621 return false; 01622 } 01623 } 01624 01625 for (i = 0; i < 3; i++) { 01626 if (i != dir) { 01627 startPnt[i] += tol; 01628 endPnt[i] += tol; 01629 } 01630 } 01631 01632 moab::CartVect ray(endPnt[0] - startPnt[0], endPnt[1] - startPnt[1], endPnt[2] - startPnt[2]); 01633 double rayLength = ray.length(); 01634 moab::ErrorCode rVal; 01635 ray.normalize(); 01636 m_vIntersection.clear(); 01637 m_vhInterSurf.clear(); 01638 m_vhInterFacet.clear(); 01639 01640 std::vector<double> temp_intersects; 01641 moab::OrientedBoxTreeTool::TrvStats stats; 01642 if (m_bUseGeom) { 01643 rVal = m_hObbTree->ray_intersect_sets(temp_intersects, m_vhInterSurf, 01644 m_vhInterFacet, m_hTreeRoot, tol, 01645 startPnt, ray.array(), &rayLength, 01646 &stats); 01647 } 01648 else { // facet input 01649 std::vector<moab::EntityHandle> dum_facets_out; 01650 rVal = m_hObbTree->ray_intersect_triangles(temp_intersects, dum_facets_out, 01651 m_hTreeRoot, tol, 01652 startPnt, ray.array(), &rayLength, 01653 &stats); 01654 m_vhInterSurf.resize(temp_intersects.size()); 01655 } 01656 01657 if (moab::MB_SUCCESS != rVal) { 01658 std::cerr << "Failed : ray-triangle intersection." << std::endl; 01659 return false; 01660 } 01661 01662 nIntersect = temp_intersects.size(); 01663 m_vIntersection.resize(nIntersect); 01664 for (i = 0; i < nIntersect; i++) { 01665 IntersectDist temp_inter_dist(temp_intersects[i], i); 01666 m_vIntersection[i] = temp_inter_dist; 01667 } 01668 std::sort(m_vIntersection.begin(), m_vIntersection.end(), less_intersect); 01669 bMove = is_ray_move_and_set_overlap_surf(bSpecialCase); 01670 m_nIteration++; 01671 } 01672 01673 std::cout << "ray is moved successfully." << std::endl; 01674 01675 return true; 01676 } 01677 01678 bool EBMesher::is_ray_move_and_set_overlap_surf(bool& bSpecialCase) 01679 { 01680 int nInter = m_vIntersection.size() - 1; 01681 01682 while (m_iOverlap < nInter) { 01683 if (m_vIntersection[m_iOverlap + 1].distance - m_vIntersection[m_iOverlap].distance < 1e-7) { 01684 if (m_bUseGeom) { 01685 moab::EntityHandle h1 = m_vhInterSurf[m_vIntersection[m_iOverlap].index]; 01686 moab::EntityHandle h2 = m_vhInterSurf[m_vIntersection[m_iOverlap + 1].index]; 01687 01688 if (h1 == h2) { // remove too close case 01689 bSpecialCase = false; 01690 return true; 01691 } 01692 else if (m_nIteration < 10) { // when ray intesect shared edge by 2 triangles 01693 bSpecialCase = true; 01694 return true; 01695 } 01696 else { // overlapped surfaces 01697 m_mhOverlappedSurf[h1] = 0; 01698 m_mhOverlappedSurf[h2] = 0; 01699 m_nIteration = 0; 01700 m_iOverlap++; 01701 } 01702 } 01703 else { 01704 if (m_nIteration < 10) { // when ray intesect shared edge by 2 triangles 01705 bSpecialCase = true; 01706 return true; 01707 } 01708 else { // overlapped surfaces 01709 //bSpecialCase = false; 01710 //m_nIteration = 0; 01711 //m_iOverlap++; 01712 m_vIntersection.erase(m_vIntersection.begin() + m_iOverlap + 1); 01713 nInter = m_vIntersection.size(); 01714 m_vhInterSurf.resize(nInter); 01715 //m_nIteration = 0; 01716 } 01717 } 01718 } 01719 else m_iOverlap++; 01720 } 01721 01722 return false; 01723 } 01724 01725 void EBMesher::remove_intersection_duplicates() 01726 { 01727 int ind = 0; 01728 int nInter = m_vIntersection.size() - 1; 01729 01730 while (ind < nInter) { 01731 if (m_vIntersection[ind + 1].distance - m_vIntersection[ind].distance < 1e-7) { 01732 moab::EntityHandle h1 = m_vhInterSurf[m_vIntersection[ind].index]; 01733 moab::EntityHandle h2 = m_vhInterSurf[m_vIntersection[ind + 1].index]; 01734 01735 if (h1 != h2) { // overlapped/shared surfaces 01736 std::vector<iBase_EntitySetHandle> parents_out1, parents_out2; 01737 int err = mk_core()->imesh_instance()->getPrnts(reinterpret_cast<iBase_EntitySetHandle> (h1), 1, parents_out1); 01738 IBERRCHK(err, "Failed to get number of surface parents.\n"); 01739 err = mk_core()->imesh_instance()->getPrnts(reinterpret_cast<iBase_EntitySetHandle> (h2), 1, parents_out2); 01740 IBERRCHK(err, "Failed to get number of surface parents.\n"); 01741 if (parents_out1.size() == 1 && parents_out2.size() == 1) { 01742 if (parents_out1[0] != parents_out2[0]) { // parent volues are also different 01743 m_mhOverlappedSurf[h1] = 0; 01744 m_mhOverlappedSurf[h2] = 0; 01745 } 01746 } 01747 } 01748 m_vIntersection.erase(m_vIntersection.begin() + ind + 1); 01749 nInter--; 01750 } 01751 else ind++; 01752 } 01753 } 01754 01755 bool EBMesher::get_volume_fraction(int vol_frac_div) 01756 { 01757 std::cout << "starting get_volume_fraction." << std::endl; 01758 int i, j, k, l, n, iHex, dir, nIntersect, rayIndex[3], index[3], 01759 otherDir1, otherDir2, err, nParent; 01760 (void) otherDir1; 01761 (void) otherDir2; 01762 double tolerance = 1e-12, dDistance, elem_origin[3], 01763 elem_interval_size[3], startPnt[3], endPnt[3], rayMaxEnd[3]; 01764 moab::ErrorCode rval; 01765 bool bOverlapSecond, bClosed = true; 01766 std::vector<iBase_EntityHandle> edge_handles; 01767 01768 double dTotEdgeElem = 0.; 01769 for (i = 0; i < 3; i++) { 01770 rayMaxEnd[i] = m_origin_coords[i] + m_nDiv[i]*m_dIntervalSize[i]; 01771 dTotEdgeElem += m_dIntervalSize[i]*(vol_frac_div + 1)*(vol_frac_div + 1); 01772 } 01773 01774 // get all hexes 01775 std::vector<iBase_EntityHandle> hex_handles; 01776 err = mk_core()->imesh_instance()->getEntities(m_hRootSet, iBase_REGION, 01777 iMesh_HEXAHEDRON, hex_handles); 01778 IBERRCHK(err, "Failed to get hexes.\n"); 01779 01780 int hex_size = hex_handles.size(); 01781 /* 01782 std::vector<int> hex_status(hex_size); 01783 //int* hex_status = NULL; 01784 err = mk_core()->imesh_instance()->getIntArrData(&hex_handles[0], hex_size, 01785 m_elemStatusTag, &hex_status[0]); 01786 */ 01787 int error; 01788 std::vector<int> frac_length; 01789 int* hex_status = new int[hex_size]; 01790 int hex_status_alloc = sizeof(int)*hex_size; 01791 int hex_status_size = 0; 01792 iMesh_getIntArrData(m_mesh, &hex_handles[0], 01793 hex_size, m_elemStatusTag, 01794 &hex_status, &hex_status_alloc, 01795 &hex_status_size, &error); 01796 ERRORRF("Failed to get hex status.\n"); 01797 01798 for (n = 0; n < hex_size; n++) { 01799 if (hex_status[n] == 2) { // just boundary 01800 std::map<moab::EntityHandle, VolFrac> vol_fraction; 01801 std::map<moab::EntityHandle, VolFrac>::iterator vf_iter; 01802 std::map<moab::EntityHandle, VolFrac>::iterator vf_end_iter; 01803 iHex = moab_instance()->id_from_handle(reinterpret_cast<moab::EntityHandle> 01804 (hex_handles[n])) - m_iStartHex; 01805 index[0] = (iHex%(m_nDiv[0]*m_nDiv[1]))%m_nDiv[0]; 01806 index[1] = (iHex%(m_nDiv[0]*m_nDiv[1]))/m_nDiv[0]; 01807 index[2] = iHex/m_nDiv[0]/m_nDiv[1]; 01808 01809 for (i = 0; i < 3; i++) { 01810 elem_origin[i] = m_origin_coords[i] + index[i]*m_dIntervalSize[i]; 01811 elem_interval_size[i] = m_dIntervalSize[i]/vol_frac_div; 01812 } 01813 01814 for (dir = 0; dir < 3; dir++) { // x, y, z directions 01815 otherDir1 = (dir + 1)%3; 01816 otherDir2 = (dir + 2)%3; 01817 01818 for (j = 0; j < vol_frac_div + 1; j++) { 01819 for (i = 0; i < vol_frac_div + 1; i++) { 01820 // get ray start and end points 01821 if (dir == 0) { // x coordinate ray 01822 rayIndex[0] = 0; 01823 rayIndex[1] = i; 01824 rayIndex[2] = j; 01825 } 01826 else if (dir == 1) { // y coordinate ray 01827 rayIndex[0] = j; 01828 rayIndex[1] = 0; 01829 rayIndex[2] = i; 01830 } 01831 else if (dir == 2) { // z coordinate ray 01832 rayIndex[0] = i; 01833 rayIndex[1] = j; 01834 rayIndex[2] = 0; 01835 } 01836 else IBERRCHK(iBase_FAILURE, "Ray direction should be from 0 to 2."); 01837 01838 for (k = 0; k < 3; k++) { 01839 if (k == dir) { 01840 startPnt[k] = elem_origin[k]; 01841 endPnt[k] = startPnt[k] + m_dIntervalSize[k]; 01842 } 01843 else { 01844 startPnt[k] = elem_origin[k] + rayIndex[k]*elem_interval_size[k]; 01845 endPnt[k] = startPnt[k]; 01846 } 01847 } 01848 01849 // ray-tracing 01850 if (!fire_ray(nIntersect, startPnt, endPnt, 01851 tolerance, dir, m_dIntervalSize[dir])) return iBase_FAILURE; 01852 01853 if (nIntersect > 0) { // ray is intersected 01854 bOverlapSecond = false; 01855 bClosed = true; 01856 for (k = 0; k < nIntersect; k++) { 01857 std::vector<moab::EntityHandle> parents; 01858 //moab::Range parents; 01859 rval = moab_instance()->get_parent_meshsets(m_vhInterSurf[m_vIntersection[k].index], 01860 parents); 01861 if (rval != moab::MB_SUCCESS) { 01862 std::cerr << "Couldn't get parents." << std::endl; 01863 return false; 01864 } 01865 01866 nParent = parents.size(); 01867 dDistance = m_vIntersection[k].distance; 01868 01869 if (is_shared_overlapped_surf(k)) { 01870 if (nParent == 2) { // shared surface 01871 for (l = 0; l < 2; l++) { 01872 if (l == 1) { 01873 dDistance *= -1.; 01874 bClosed = false; 01875 } 01876 else bClosed = true; 01877 01878 vf_iter = vol_fraction.find(parents[l]); 01879 if (vf_iter == vol_fraction.end()) { 01880 VolFrac temp_vf(dDistance, bClosed); 01881 vol_fraction[parents[l]] = temp_vf; 01882 //std::cout << "iHex=" << iHex << ", vh=" 01883 // << parents[l] << ", dir=" << dir << ", dDistance1=" 01884 // << dDistance << ", vol=" 01885 // << temp_vf.vol << std::endl; 01886 } 01887 else { 01888 vf_iter->second.vol += dDistance; 01889 vf_iter->second.closed = bClosed; 01890 //std::cout << "iHex=" << iHex << ", vh=" 01891 // << vf_iter->first << ", dir=" << dir << ", dDistance1=" 01892 // << dDistance << ", vol=" 01893 // << vf_iter->second.vol << std::endl; 01894 } 01895 } 01896 } 01897 else if (nParent == 1) { // overlapped surface 01898 if (bOverlapSecond) { // second intersection 01899 /* 01900 for (int m = 0; m < 3; m++) { 01901 ePnt[m] = startPnt[m]; 01902 } 01903 ePnt[dir] += dDistance; 01904 */ 01905 dDistance *= -1.; 01906 bClosed = false; 01907 bOverlapSecond = false; 01908 } 01909 else { 01910 /* 01911 // make edge 01912 for (int m = 0; m < 3; m++) { 01913 if (bClosed) ePnt[m] = startPnt[m]; 01914 ePnt[m + 3] = ePnt[m]; 01915 } 01916 ePnt[dir + 3] += dDistance; 01917 if (!make_edge(ePnt, edge_handles)) return iBase_FAILURE; 01918 */ 01919 bOverlapSecond = true;// first intersection 01920 bClosed = true; 01921 } 01922 01923 vf_iter = vol_fraction.find(parents[0]); 01924 if (vf_iter == vol_fraction.end()) { 01925 VolFrac temp_vf(dDistance, bClosed); 01926 vol_fraction[parents[0]] = temp_vf; 01927 //std::cout << "iHex=" << iHex << ", vh=" 01928 // << parents[0] << ", dDistance2=" 01929 // << dDistance << ", vol=" 01930 // << temp_vf.vol << std::endl; 01931 } 01932 else { 01933 vf_iter->second.vol += dDistance; 01934 vf_iter->second.closed = bClosed; 01935 //std::cout << "iHex=" << iHex << ", vh=" 01936 // << vf_iter->first << ", dir=" << dir << ", dDistance2=" 01937 // << dDistance << ", vol=" 01938 // << vf_iter->second.vol << std::endl; 01939 } 01940 } 01941 else return iBase_FAILURE; 01942 } 01943 else { // normal case 01944 if (nParent != 1) return iBase_FAILURE; 01945 01946 if (!is_same_direct_to_ray(k, dir)) { 01947 dDistance *= -1.; // outside 01948 bClosed = false; 01949 } 01950 else bClosed = true; 01951 01952 vf_iter = vol_fraction.find(parents[0]); 01953 if (vf_iter == vol_fraction.end()) { 01954 VolFrac temp_vf(dDistance, bClosed); 01955 vol_fraction[parents[0]] = temp_vf; 01956 //std::cout << "iHex=" << iHex << ", vh=" 01957 // << parents[0] << ", dir=" << dir << ", dDistance3=" 01958 // << dDistance << ", vol=" 01959 // << temp_vf.vol << std::endl; 01960 } 01961 else { 01962 vf_iter->second.vol += dDistance; 01963 vf_iter->second.closed = bClosed; 01964 //std::cout << "iHex=" << iHex << ", vh=" 01965 // << vf_iter->first << ", dir=" << dir << ", dDistance3=" 01966 // << dDistance << ", vol=" 01967 // << vf_iter->second.vol << std::endl; 01968 } 01969 } 01970 } 01971 01972 // if fraction is not closed, add interval size to close 01973 vf_iter = vol_fraction.begin(); 01974 vf_end_iter = vol_fraction.end(); 01975 for (; vf_iter != vf_end_iter; vf_iter++) { 01976 if (!vf_iter->second.closed) { 01977 vf_iter->second.vol += m_dIntervalSize[dir]; 01978 vf_iter->second.closed = true; 01979 /* 01980 for (int m = 0; m < 3; m++) { 01981 ePnt[m + 3] = startPnt[m]; 01982 } 01983 ePnt[dir + 3] += m_dIntervalSize[dir]; 01984 if (!make_edge(ePnt, edge_handles)) return iBase_FAILURE; 01985 */ 01986 //std::cout << "iHex=" << iHex << ", vh=" 01987 // << vf_iter->first << ", dir=" << dir << ", dDistance4=" 01988 // << m_dIntervalSize[dir] << ", vol=" 01989 // << vf_iter->second.vol << std::endl; 01990 } 01991 } 01992 } 01993 else { // decide if it is fully inside 01994 if (!fire_ray(nIntersect, startPnt, rayMaxEnd, 01995 tolerance, dir, m_nDiv[dir]*m_dIntervalSize[dir])) return iBase_FAILURE; 01996 01997 if (nIntersect > 0) { // fully inside 01998 if (is_shared_overlapped_surf(0) || // shared or overlapped 01999 is_same_direct_to_ray(0, dir)) { // other inside case 02000 moab::Range parents; 02001 rval = moab_instance()->get_parent_meshsets(m_vhInterSurf[m_vIntersection[0].index], 02002 parents); 02003 if (rval != moab::MB_SUCCESS) { 02004 std::cerr << "Couldn't get parents." << std::endl; 02005 return false; 02006 } 02007 02008 moab::EntityHandle parent_entity = parents.pop_front(); 02009 vf_iter = vol_fraction.find(parent_entity); 02010 if (vf_iter == vf_end_iter) { 02011 VolFrac temp_vf(m_dIntervalSize[dir], true); 02012 vol_fraction[parent_entity] = temp_vf; 02013 //std::cout << "iHex=" << iHex << ", vh=" 02014 // << parents[0] << ", dir=" << dir << ", dDistance5=" 02015 // << dDistance << ", vol=" 02016 // << temp_vf.vol << std::endl; 02017 } 02018 else { 02019 vf_iter->second.vol += m_dIntervalSize[dir]; 02020 vf_iter->second.closed = bClosed; 02021 //std::cout << "iHex=" << iHex << ", vh=" 02022 // << vf_iter->first << ", dir=" << dir << ", dDistance5=" 02023 // << dDistance << ", vol=" 02024 // << vf_iter->second.vol << std::endl; 02025 } 02026 } 02027 } 02028 } 02029 } 02030 } 02031 } 02032 02033 int vol_frac_length = vol_fraction.size(); 02034 std::vector<int> vol_frac_id(vol_frac_length); 02035 std::vector<double> vol_frac(vol_frac_length); 02036 int vol_frac_id_size = vol_frac_length*sizeof(int); 02037 int vol_frac_size = vol_frac_length*sizeof(double); 02038 vf_iter = vol_fraction.begin(); 02039 vf_end_iter = vol_fraction.end(); 02040 for (int m = 0; vf_iter != vf_end_iter; vf_iter++, m++) { 02041 vol_frac_id[m] = vf_iter->first; 02042 vol_frac[m] = vf_iter->second.vol/dTotEdgeElem; 02043 //std::cout << "iHex=" << iHex << ", i=" << index[0] 02044 // << ", j=" << index[1] << ", k=" << index[2] 02045 // << ", vol_handle=" << vf_iter->first 02046 // << ", vol=" << vf_iter->second.vol 02047 // << ", vol_fraction=" << vf_iter->second.vol/dTotEdgeElem 02048 // << std::endl; 02049 } 02050 const void* vol_frac_ids = &vol_frac_id[0]; 02051 const void* vol_fracs = &vol_frac[0]; 02052 02053 // set volume fraction information as tag 02054 rval = moab_instance()->tag_set_data(reinterpret_cast<moab::Tag> (m_volFracLengthTag), 02055 reinterpret_cast<moab::EntityHandle*> (&hex_handles[n]), 02056 1, &vol_frac_length); 02057 MBERRCHK(rval, mk_core()->moab_instance()); 02058 02059 rval = moab_instance()->tag_set_by_ptr(reinterpret_cast<moab::Tag> (m_volFracHandleTag), 02060 reinterpret_cast<moab::EntityHandle*> (&hex_handles[n]), 02061 1, &vol_frac_ids, &vol_frac_id_size); 02062 MBERRCHK(rval, mk_core()->moab_instance()); 02063 02064 rval = moab_instance()->tag_set_by_ptr(reinterpret_cast<moab::Tag> (m_volFracTag), 02065 reinterpret_cast<moab::EntityHandle*> (&hex_handles[n]), 02066 1, &vol_fracs, &vol_frac_size); 02067 MBERRCHK(rval, mk_core()->moab_instance()); 02068 02069 if (debug_ebmesh) { 02070 for (int v = 0; v < vol_frac_length; v++) { 02071 std::cout << "#_boundary_hex_handles=" << hex_handles[n] 02072 << ",vol_frac_handle[" << v << "]=" << vol_frac_id[v] 02073 << ",vol_fracs[" << v << "]=" << vol_frac[v] 02074 << std::endl; 02075 } 02076 } 02077 } 02078 } 02079 02080 std::cout << "end get_volume_fraction." << std::endl; 02081 delete [] hex_status; 02082 02083 return true; 02084 } 02085 02086 bool EBMesher::is_same_direct_to_ray(int i, int dir) 02087 { 02088 moab::CartVect coords[3], normal(0.0), ray_dir(rayDir[dir]); 02089 const moab::EntityHandle *conn; 02090 int len; 02091 02092 // get triangle normal vector 02093 moab::ErrorCode rval = moab_instance()->get_connectivity(m_vhInterFacet[m_vIntersection[i].index], 02094 conn, len); 02095 assert(moab::MB_SUCCESS == rval && 3 == len); 02096 02097 rval = moab_instance()->get_coords(conn, 3, coords[0].array()); 02098 (void) rval; 02099 assert(moab::MB_SUCCESS == rval); 02100 02101 coords[1] -= coords[0]; 02102 coords[2] -= coords[0]; 02103 normal += coords[1] * coords[2]; 02104 normal.normalize(); 02105 02106 return angle(normal, ray_dir) < .5*PI; 02107 } 02108 02109 void EBMesher::set_obb_tree_box_dimension() 02110 { 02111 std::cout << "starting to construct obb tree." << std::endl; 02112 moab::ErrorCode rval = m_GeomTopoTool->construct_obb_trees(m_bUseWholeGeom); 02113 MBERRCHK(rval, mk_core()->moab_instance()); 02114 02115 m_hObbTree = m_GeomTopoTool->obb_tree(); 02116 m_hTreeRoot = m_GeomTopoTool->get_one_vol_root(); 02117 02118 moab::CartVect box_center, box_axis1, box_axis2, box_axis3; 02119 for (int i = 0; i < 3; i++) { 02120 m_minCoord[i] = HUGE_VAL; 02121 m_maxCoord[i] = 0.; 02122 } 02123 rval = m_hObbTree->box(m_hTreeRoot, box_center.array(), 02124 box_axis1.array(), box_axis2.array(), 02125 box_axis3.array()); 02126 MBERRCHK(rval, mk_core()->moab_instance()); 02127 02128 // cartesian box corners 02129 moab::CartVect corners[8] = {box_center + box_axis1 + box_axis2 + box_axis3, 02130 box_center + box_axis1 + box_axis2 - box_axis3, 02131 box_center + box_axis1 - box_axis2 + box_axis3, 02132 box_center + box_axis1 - box_axis2 - box_axis3, 02133 box_center - box_axis1 + box_axis2 + box_axis3, 02134 box_center - box_axis1 + box_axis2 - box_axis3, 02135 box_center - box_axis1 - box_axis2 + box_axis3, 02136 box_center - box_axis1 - box_axis2 - box_axis3}; 02137 02138 // get the max, min cartesian box corners 02139 for (int i = 0; i < 8; i++) { 02140 for (int j = 0; j < 3; j++) { 02141 if (corners[i][j] < m_minCoord[j]) m_minCoord[j] = corners[i][j]; 02142 if (corners[i][j] > m_maxCoord[j]) m_maxCoord[j] = corners[i][j]; 02143 } 02144 } 02145 std::cout << "finished to construct obb tree." << std::endl; 02146 } 02147 } // namespace MeshKit
