cgma
00001 //- File: CAEntityTol.cpp 00002 //- Owner: W. Roshan Quadros 00003 //- Description: Cubit Attribute for entity ids. 00004 //- Checked By: 00005 //- Version: 00006 00007 00008 #include "CAEntityTol.hpp" 00009 #include "CAMergePartner.hpp" 00010 #include "TDUniqueId.hpp" 00011 #include "TopologyBridge.hpp" 00012 #include "RefEntity.hpp" 00013 #include "RefVertex.hpp" 00014 #include "RefEdge.hpp" 00015 #include "RefFace.hpp" 00016 #include "CastTo.hpp" 00017 #include "MergeTool.hpp" 00018 #include "RefEntityFactory.hpp" 00019 #include "GeometryQueryTool.hpp" 00020 #include "GSaveOpen.hpp" 00021 #include "CADeferredAttrib.hpp" 00022 #include "BasicTopologyEntity.hpp" 00023 #include "GeometryEntity.hpp" 00024 00025 CubitAttrib* CAEntityTol_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa) 00026 { 00027 return new CAEntityTol(entity, p_csa); 00028 } 00029 00030 CAEntityTol::CAEntityTol(RefEntity* new_attrib_owner, 00031 const CubitSimpleAttrib &csa_ptr) 00032 : CubitAttrib(new_attrib_owner) 00033 { 00034 entityTol = 0.0; 00035 if(!csa_ptr.isEmpty()) 00036 { 00037 PRINT_DEBUG_95( "Creating ENTITY_TOL attribute from CSA for %s %d\n", 00038 (attribOwnerEntity ? attribOwnerEntity->class_name() : "(none)"), 00039 (attribOwnerEntity ? attribOwnerEntity->id() : 0)); 00040 00041 const std::vector<double>& d_list = csa_ptr.double_data_list(); 00042 00043 assert(d_list.size() == 1); 00044 entityTol = d_list[0]; 00045 } 00046 } 00047 00048 CAEntityTol::CAEntityTol(RefEntity* new_attrib_owner) 00049 : CubitAttrib(new_attrib_owner) 00050 { 00051 entityTol = 0.0; 00052 00053 PRINT_DEBUG_95( "Creating ENTITY_TOL attribute for %s %d\n", 00054 (attribOwnerEntity ? attribOwnerEntity->class_name() : "(none)"), 00055 (attribOwnerEntity ? attribOwnerEntity->id() : 0)); 00056 } 00057 00058 CAEntityTol::~CAEntityTol() 00059 { 00060 } 00061 00062 CubitStatus CAEntityTol::reset() 00063 { 00064 00065 return CUBIT_SUCCESS; 00066 } 00067 00068 CubitStatus CAEntityTol::actuate() 00069 { 00070 if ( hasActuated) 00071 return CUBIT_SUCCESS; 00072 00073 if ( !attribOwnerEntity ) 00074 return CUBIT_FAILURE; 00075 00076 deleteAttrib = CUBIT_FALSE; 00077 00078 //- If actuating after import, change the tol. Else (auto actuated) tol is already changed... 00079 if( attribOwnerEntity->local_tolerance() == 0.0 ) 00080 { 00081 attribOwnerEntity->local_tolerance(entityTol); 00082 } 00083 00084 hasActuated = CUBIT_TRUE; 00085 return CUBIT_SUCCESS; 00086 } 00087 00088 CubitStatus CAEntityTol::update() 00089 { 00090 //delete_attrib(CUBIT_TRUE); 00091 //return CUBIT_SUCCESS; 00092 00093 if (hasUpdated) return CUBIT_SUCCESS; 00094 00095 PRINT_DEBUG_95( "Updating ENTITY_TOL attribute for %s %d\n", 00096 attribOwnerEntity->class_name(), attribOwnerEntity->id()); 00097 00098 // set the updated flag 00099 hasUpdated = CUBIT_TRUE; 00100 00101 // first, remove this attrib in its old form from the geometry entity 00102 if (hasWritten == CUBIT_TRUE) 00103 { 00104 attribOwnerEntity->remove_attrib_geometry_entity(this); 00105 hasWritten = CUBIT_FALSE; 00106 } 00107 00108 double local_tol = attribOwnerEntity->local_tolerance(); 00109 if( local_tol == 0.0) 00110 { 00111 delete_attrib(CUBIT_TRUE); 00112 return CUBIT_SUCCESS; 00113 } 00114 else 00115 { 00116 00117 // reset the delete flag if it was set before 00118 delete_attrib(CUBIT_FALSE); 00119 00120 // now, write to geometry entity 00121 entityTol = local_tol; 00122 attribOwnerEntity->write_specific_cubit_attrib(this); 00123 } 00124 return CUBIT_SUCCESS; 00125 } 00126 00127 void CAEntityTol::merge_owner(CubitAttrib *deletable_attrib) 00128 { 00129 // take the id with the lowest value 00130 CAEntityTol *other_ca_tol = CAST_TO(deletable_attrib, CAEntityTol); 00131 00132 if (other_ca_tol && ( entityTol == 0.0 || entityTol < other_ca_tol->tolerance() )) 00133 entityTol = other_ca_tol->tolerance(); 00134 } 00135 00136 CubitSimpleAttrib CAEntityTol::cubit_simple_attrib() 00137 { 00138 std::vector<CubitString> cs_list; 00139 std::vector<double> d_list; 00140 std::vector<int, std::allocator<int> > i_list; 00141 00142 d_list.push_back ( entityTol ); 00143 00144 cs_list.push_back(att_internal_name()); 00145 00146 CubitSimpleAttrib csattrib_ptr(&cs_list, &d_list, &i_list); 00147 00148 return csattrib_ptr; 00149 } 00150 00151 void CAEntityTol::print() 00152 { 00153 // print info on this attribute 00154 00155 PRINT_INFO("CAEntityTol: owner = %s %d: tolerance =%f\n", 00156 attribOwnerEntity->class_name(), attribOwnerEntity->id(), 00157 entityTol); 00158 } 00159 00160 00161 CubitSimpleAttrib CAEntityTol::split_owner() 00162 { 00163 // if this entity is to be split, pass back a simple attribute with 00164 // duplicate tol data to be put on new entity 00165 PRINT_DEBUG_95("CAEntityName::split_owner()\n"); 00166 update(); 00167 return cubit_simple_attrib(); 00168 } 00169
