cgma
00001 //- Class: CAEntityTol 00002 //- Owner: W. Roshan Quadros 00003 //- Description: Cubit attribute for tolerance at entity 00004 //- Checked by: 00005 //- Version: 00006 00007 #ifndef CA_ENTITY_TOL_HPP 00008 #define CA_ENTITY_TOL_HPP 00009 00010 #include <typeinfo> 00011 #if !defined(_WIN32) 00012 using std::type_info; 00013 #endif 00014 00015 #include "CubitAttrib.hpp" 00016 #include "CubitDefines.h" 00017 #include "CADefines.hpp" 00018 00019 class RefEntity; 00020 00021 class CUBIT_GEOM_EXPORT CAEntityTol : public CubitAttrib 00022 { 00023 private: 00024 00025 double entityTol; 00026 //- entity tolerance 00027 00028 public: 00029 00030 virtual ~CAEntityTol(); 00031 00032 CAEntityTol (RefEntity*); 00033 00034 CAEntityTol (RefEntity*, const CubitSimpleAttrib &); 00035 //- create a CAEID from a simple attribute 00036 00037 //HEADER- RTTI and safe casting functions. 00038 virtual const type_info& entity_type_info() const 00039 { return typeid(CAEntityTol);} 00040 //R- The geometric modeler type 00041 //- This function returns the type of the geometric modeler. 00042 00043 CubitStatus actuate(); 00044 00045 CubitStatus update(); 00046 00047 CubitStatus reset(); 00048 //- don't need an active reset function since there aren't any 00049 //- lists on this CA 00050 00051 void merge_owner(CubitAttrib *deletable_attrib); 00052 CubitSimpleAttrib split_owner(); 00053 00054 CubitSimpleAttrib cubit_simple_attrib(); 00055 00056 int int_attrib_type() {return CA_ENTITY_TOL;} 00057 00058 double tolerance() {return entityTol;} 00059 00060 void print(); 00061 00062 }; 00063 00064 CubitAttrib* CAEntityTol_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa); 00065 00066 #endif 00067
