cgma
00001 // CAVirtualVG class 00002 00003 #include "CAVirtualVG.hpp" 00004 #include "CubitSimpleAttrib.hpp" 00005 #include "TopologyEntity.hpp" 00006 #include "RefEntity.hpp" 00007 #include "BasicTopologyEntity.hpp" 00008 #include "RefEdge.hpp" 00009 #include "RefVertex.hpp" 00010 #include "TDUniqueId.hpp" 00011 #include "CADeferredAttrib.hpp" 00012 00013 CubitAttrib* CAVirtualVG_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa) 00014 { 00015 return new CAVirtualVG(entity, p_csa); 00016 } 00017 00018 00019 CAVirtualVG::CAVirtualVG(RefEntity *owner, const CubitSimpleAttrib &simple_attrib) 00020 : CubitAttrib(owner) 00021 { 00022 numVC = 0; 00023 numVV = 0; 00024 00025 if(!simple_attrib.isEmpty()) 00026 { 00027 // generate a simple attribute containing the data in this CA 00028 const std::vector<double> &d_list = simple_attrib.double_data_list(); 00029 const std::vector<int> &i_list = simple_attrib.int_data_list(); 00030 00031 // (no string) 00032 00033 // now the integers 00034 // numVV, numVC 00035 int offset = 0; 00036 numVV = i_list[offset++]; 00037 numVC = i_list[offset++]; 00038 00039 // vgUIDs 00040 int i; 00041 for (i = numVV+(3*numVC); i > 0; i--) 00042 vgUIDs.append(i_list[offset++]); 00043 00044 // numVCPoints 00045 int sum = 0; 00046 for (i = numVC; i > 0; i--) { 00047 int temp_int = i_list[offset++]; 00048 numVCPoints.append(temp_int); 00049 sum += temp_int; 00050 } 00051 00052 offset = 0; 00053 // pointUIDList 00054 for (i = numVV+sum; i > 0; i--) { 00055 double x = d_list[offset++]; 00056 double y = d_list[offset++]; 00057 double z = d_list[offset++]; 00058 posVector.append(new CubitVector( x, y, z ) ); 00059 } 00060 00061 // If we are constructing from a CubitSimpleAttrib, 00062 // then this attrib is already written 00063 has_written(CUBIT_TRUE); 00064 } 00065 } 00066 00067 CubitStatus CAVirtualVG::update() 00068 { 00069 00070 // the owner entity is virtual; put a CAVirtualVG on the underlying entity to represent 00071 // this entity 00072 00073 if (hasUpdated) return CUBIT_SUCCESS; 00074 /* 00075 assert(attrib_owner() != 0); 00076 00077 TopologyEntity *topo_entity = CAST_TO(attrib_owner(), TopologyEntity); 00078 assert(topo_entity != 0); 00079 00080 DLIList<VirtualEntity*> ve_list; 00081 VirtualGeometryEngine::instance()->get_VEs(topo_entity, ve_list, CUBIT_FALSE, CUBIT_FALSE); 00082 00083 for( int i = ve_list.size(); i--; ) 00084 { 00085 ParasiteEntity *vge = dynamic_cast<ParasiteEntity*>(ve_list.get_and_step()); 00086 00087 if (vge == NULL) { 00088 // this entity isn't a virtual entity - if this entity doesn't have any virtual 00089 // entities registered, set delete flag, then exit 00090 if (numVV == 0 && numVC == 0) 00091 delete_attrib(CUBIT_TRUE); 00092 else { 00093 PRINT_DEBUG_90("Keeping CA_VIRTUAL_VG for %s %d\n", 00094 attrib_owner()->class_name(), attrib_owner()->id()); 00095 hasUpdated = CUBIT_TRUE; 00096 } 00097 00098 continue; 00099 } 00100 00101 // ok, we have a virtual entity; first get the underlying entity, and a CAVVG for that 00102 // entity 00103 BasicTopologyEntity* bte_ptr = vge->bte_bound_to(); 00104 00105 if (!bte_ptr) { 00106 PRINT_ERROR("Couldn't find underlying BTE for virtual entity %s %d.\n", 00107 attrib_owner()->class_name(), attrib_owner()->id()); 00108 return CUBIT_FAILURE; 00109 } 00110 00111 CAVirtualVG *other_CAVVG = (CAVirtualVG *) bte_ptr->get_cubit_attrib(CA_VIRTUAL_VG); 00112 00113 // if that other CAPVG's written flag is set, it's an old one from a 00114 // previous write and needs to be reset 00115 if (other_CAVVG->has_written() == CUBIT_TRUE) { 00116 other_CAVVG->reset(); 00117 other_CAVVG->has_written(CUBIT_FALSE); 00118 } 00119 00120 // now put virtual geometry-specific data on the attribute 00121 ParasitePoint *vvertex = CAST_TO(vge, ParasitePoint); 00122 ParasiteCurve *vcurve = CAST_TO(vge, ParasiteCurve); 00123 if (vvertex != NULL) { 00124 // put uids and position on ca 00125 other_CAVVG->add_vvertex(vvertex); 00126 other_CAVVG->delete_attrib(CUBIT_FALSE); 00127 } 00128 00129 else if (vcurve != NULL) { 00130 other_CAVVG->add_vcurve(vcurve); 00131 other_CAVVG->delete_attrib(CUBIT_FALSE); 00132 } 00133 00134 else { 00135 PRINT_ERROR("Shouldn't get here in CAVirtualVG::update.\n"); 00136 return CUBIT_FAILURE; 00137 } 00138 } 00139 00140 hasUpdated = CUBIT_TRUE; 00141 if (numVV == 0 && numVV == 0) delete_attrib(CUBIT_TRUE); 00142 00143 return CUBIT_SUCCESS; 00144 */ 00145 00146 delete_attrib(CUBIT_TRUE); 00147 return CUBIT_SUCCESS; 00148 } 00149 00150 00151 CubitStatus CAVirtualVG::reset() 00152 { 00153 //- reset info; called from CAU and also from update! 00154 numVV = 0; 00155 numVC = 0; 00156 //- the number of virtual points and curves contained in this attr 00157 00158 vgUIDs.clean_out(); 00159 //- unique ids of virtual points and curves contained in this attr 00160 00161 posVector.clean_out(); 00162 //- position vectors for virtual curves 00163 00164 numVCPoints.clean_out(); 00165 //- for each virtual curve, the number of virtual points in that curve 00166 00167 return CUBIT_SUCCESS; 00168 } 00169 00170 CubitSimpleAttrib CAVirtualVG::cubit_simple_attrib() 00171 { 00172 // generate a simple attribute containing the data in this CA 00173 std::vector<CubitString> cs_list; 00174 std::vector<double> d_list; 00175 std::vector<int> i_list; 00176 00177 // first the string 00178 cs_list.push_back(att_internal_name()); 00179 00180 // now the integers 00181 // numVV, numVC 00182 i_list.push_back(numVV); 00183 i_list.push_back(numVC); 00184 00185 // vgUIDs 00186 int i; 00187 vgUIDs.reset(); 00188 for (i = vgUIDs.size(); i > 0; i--) 00189 i_list.push_back(vgUIDs.get_and_step()); 00190 00191 // numVCPoints 00192 numVCPoints.reset(); 00193 for (i = numVCPoints.size(); i > 0; i--) 00194 i_list.push_back(numVCPoints.get_and_step()); 00195 00196 // now the doubles 00197 posVector.reset(); 00198 for (i = posVector.size(); i > 0; i--) { 00199 d_list.push_back(posVector.get()->x()); 00200 d_list.push_back(posVector.get()->y()); 00201 d_list.push_back(posVector.get_and_step()->z()); 00202 } 00203 00204 return CubitSimpleAttrib(&cs_list, &d_list, &i_list); 00205 } 00206 00207 CubitStatus CAVirtualVG::actuate() 00208 { 00209 // actuate this CA 00210 /* 00211 // first, actuate the points, with this CA's owner as their owners 00212 int i, j; 00213 vgUIDs.reset(); 00214 posVector.reset(); 00215 00216 DLIList<int> leftover_uids, leftover_vcpoints; 00217 DLIList<CubitVector*> leftover_posvector; 00218 int leftover_vvs = 0, leftover_vcs = 0; 00219 00220 DLIList<ParasitePoint*> vpoint_list; 00221 for (i = 0; i < numVV; i++) { 00222 CubitVector pos_vec(*posVector.get_and_step()); 00223 // make the virtual vertex 00224 BasicTopologyEntity *bte_ptr = CAST_TO(attrib_owner(), BasicTopologyEntity); 00225 RefVertex *new_vertex = 00226 VirtualGeometryEngine::instance()->create_VirtualVertex(pos_vec, bte_ptr); 00227 // add a unique id to it, for referencing later 00228 TDUniqueId *uid_ptr = new TDUniqueId(new_vertex, vgUIDs.get()); 00229 CADeferredAttrib::owner_created( new_vertex, vgUIDs.get_and_step() ); 00230 00231 if (new_vertex == NULL) { 00232 PRINT_WARNING("Problems making new vertex with uid = %d.\n", vgUIDs.prev()); 00233 leftover_uids.append(vgUIDs.prev()); 00234 leftover_posvector.append(posVector.prev()); 00235 leftover_vvs++; 00236 } 00237 } 00238 00239 // now actuate CAVVG's on lower order entities 00240 DLIList<RefEntity*> children; 00241 attrib_owner()->get_child_ref_entities(children); 00242 for (i = children.size(); i > 0; i--) { 00243 children.get_and_step()->actuate_cubit_attrib(CA_VIRTUAL_VG); 00244 } 00245 00246 // now handle creating virtual curves 00247 numVCPoints.reset(); 00248 DLIList<RefEdge*> vcurve_list; 00249 for (i = 0; i < numVC; i++) { 00250 // start by grabbing all the stuff off the attribute's lists 00251 00252 int start_uid = vgUIDs.get_and_step(), 00253 end_uid = vgUIDs.get_and_step(); 00254 00255 // now get the intermediate points; these should all be virtual, and should 00256 // be in this entity's virtual point list 00257 DLIList<CubitVector*> vec_list; 00258 // get the number of virtual points in the list 00259 int num_points = numVCPoints.get_and_step(); 00260 for (j = 0; j < num_points; j++) 00261 vec_list.append(posVector.get_and_step()); 00262 00263 int virtual_curve_uid = vgUIDs.get_and_step(); 00264 00265 // the first two are start and end points, and may not be virtual 00266 ToolDataUser *tdu = TDUniqueId::find_td_unique_id(start_uid); 00267 RefVertex *start_vertex = CAST_TO(tdu, RefVertex); 00268 tdu = TDUniqueId::find_td_unique_id(end_uid); 00269 RefVertex *end_vertex = CAST_TO(tdu, RefVertex); 00270 00271 if (!start_vertex || !end_vertex) { 00272 PRINT_DEBUG_90("Couldn't restore virtual curve with uid = %d.\n", 00273 virtual_curve_uid); 00274 // cache leftover data for restoring later 00275 leftover_uids.append(start_uid); 00276 leftover_uids.append(end_uid); 00277 leftover_uids.append(virtual_curve_uid); 00278 leftover_vcpoints.append(num_points); 00279 leftover_posvector += vec_list; 00280 leftover_vcs++; 00281 continue; 00282 } 00283 00284 // make the virtual curve 00285 RefEdge *virtual_edge = 00286 VirtualGeometryEngine::instance()->create_VirtualEdge(start_vertex, 00287 end_vertex, 00288 vec_list); 00289 if (!virtual_edge) { 00290 PRINT_DEBUG_90("Couldn't restore virtual curve with uid = %d.\n", 00291 virtual_curve_uid); 00292 // cache leftover data for restoring later 00293 leftover_uids.append(start_uid); 00294 leftover_uids.append(end_uid); 00295 leftover_uids.append(virtual_curve_uid); 00296 leftover_vcpoints.append(num_points); 00297 leftover_posvector += vec_list; 00298 leftover_vcs++; 00299 continue; 00300 } 00301 00302 ParasiteEntity* curve = 00303 dynamic_cast<ParasiteEntity*>(virtual_edge->get_geometry_entity_ptr()); 00304 assert(curve != NULL); 00305 curve->bind_to( dynamic_cast<BasicTopologyEntity*>(attrib_owner()) 00306 ->get_geometry_entity_ptr()); 00307 00308 // save the curve's unique id 00309 TDUniqueId *uid_ptr = new TDUniqueId(virtual_edge, virtual_curve_uid); 00310 00311 CADeferredAttrib::owner_created( virtual_edge, virtual_curve_uid ); 00312 //virtual_edge->actuate_cubit_attrib(CA_VIRTUAL_VG); 00313 //virtual_edge->actuate_cubit_attrib(CA_PARTITION_VG); 00314 } 00315 00316 if (0 == leftover_vvs && 0 == leftover_vcs) 00317 hasActuated = CUBIT_TRUE; 00318 else { 00319 // have some leftover data - reset data in this attribute 00320 numVV = leftover_vvs; 00321 numVC = leftover_vcs; 00322 vgUIDs = leftover_uids; 00323 numVCPoints = leftover_vcpoints; 00324 posVector = leftover_posvector; 00325 hasActuated = CUBIT_FALSE; 00326 00327 // now add this attribute to the unactuated list in CADA 00328 CADeferredAttrib::add_unactuated_ca(this); 00329 } 00330 00331 // we're done 00332 return (CUBIT_FALSE == hasActuated ? 00333 CUBIT_FAILURE : CUBIT_SUCCESS); 00334 */ return CUBIT_FAILURE; 00335 } 00336 00337 /* 00338 void CAVirtualVG::add_vvertex(ParasitePoint *vpoint) 00339 { 00340 00341 TopologyEntity *vpoint_topo_entity = vpoint->topology_entity(); 00342 RefVertex *owning_vertex = CAST_TO(vpoint_topo_entity, RefVertex); 00343 assert(owning_vertex != 0); 00344 int vvertex_uid = TDUniqueId::get_unique_id(owning_vertex); 00345 00346 //- adds data for this vpoint to this CA 00347 numVV++; 00348 vgUIDs.insert_first(vvertex_uid); 00349 posVector.insert_first(new CubitVector(vpoint->coordinates())); 00350 } 00351 */ 00352 /* 00353 void CAVirtualVG::add_vcurve(ParasiteCurve *vcurve) 00354 { 00355 // need to get list of vpoint uids defining the virtual curve 00356 // the owner should be a RefEdge 00357 TopologyEntity *vcurve_topo_entity = vcurve->topology_entity(); 00358 RefEdge *virtual_edge = CAST_TO(vcurve_topo_entity, RefEdge); 00359 assert(virtual_edge != 0); 00360 00361 // first get start and end points, and their uids 00362 DLIList<int> uid_list; 00363 RefVertex *temp_vertex = virtual_edge->start_vertex(); 00364 int start_uid = TDUniqueId::get_unique_id(temp_vertex); 00365 vgUIDs.append(start_uid); 00366 temp_vertex = virtual_edge->end_vertex(); 00367 int end_uid = TDUniqueId::get_unique_id(temp_vertex); 00368 vgUIDs.append(end_uid); 00369 00370 // now get the other points and their uids 00371 DLIList<ParasitePoint*> vpoint_list; 00372 vcurve->getSegments(vpoint_list); 00373 vpoint_list.reset(); 00374 00375 for (int i = vpoint_list.size(); i > 0; i--) { 00376 ParasitePoint *temp_point = vpoint_list.get_and_step(); 00377 posVector.append(new CubitVector(temp_point->coordinates())); 00378 } 00379 00380 int owner_uid = TDUniqueId::get_unique_id(virtual_edge); 00381 00382 //- adds data for this vcurve to this CA 00383 vgUIDs.append(owner_uid); 00384 numVCPoints.append(vpoint_list.size()); 00385 numVC++; 00386 } 00387 00388 */ 00389
