cgma
00001 /******************************************************************************* 00002 COPYRIGHT 2002 CATERPILLAR INC. ALL RIGHTS RESERVED 00003 00004 This program is the property of Caterpillar Inc., includes Caterpillar's 00005 confidential and trade secret information, and is maintained as an 00006 unpublished copyrighted work. It is not to be copied or used by others 00007 except under license from Caterpillar. This program is also protected as an 00008 unpublished work in accordance with the copyright act of 1976. In the event 00009 of either inadvertent or deliberate publication, Caterpillar Inc. intends to 00010 maintain copyright protection for this work under the relevant copyright 00011 laws pertaining to published works. The inclusion of a copyright notice 00012 hereon is precautionary only, and does not imply publication or disclosure. 00013 00014 00015 Filename : CCubitFile.hpp 00016 00017 Purpose : Declares an interface for reading and writing data in the 00018 Cubit (*.cub) file format. 00019 00020 Special Notes : 00021 00022 Creator : Will A. Helden 00023 00024 Creation Date : 02/15/02 00025 00026 Owner : Will A. Helden 00027 00028 *******************************************************************************/ 00029 00030 #ifndef CCubitFile_HPP 00031 #define CCubitFile_HPP 00032 00033 #include <stdio.h> 00034 #include <cstdio> 00035 #include <memory.h> 00036 #include "CGMUtilConfigure.h" 00037 #include <vector> 00038 #include "CubitFile.hpp" 00039 00040 namespace NCubitFile { 00041 00042 class CMetaData; 00043 class CFEModel; 00044 class CSimModel; 00045 00046 typedef unsigned int UnsignedInt32; // This must always be a 32 bit integer!!! 00047 typedef const char* ConstCharPtr; 00048 00049 struct SModelData { 00050 UnsignedInt32 mintModelHandle; 00051 UnsignedInt32 mintModelType; 00052 UnsignedInt32 mintModelOwner; 00053 }; 00054 struct SElemData { 00055 UnsignedInt32 mintElemType; 00056 UnsignedInt32 mintElemOrder; 00057 UnsignedInt32 mintElemCount; 00058 UnsignedInt32* mpaElemIDs; 00059 UnsignedInt32* mpaElemGlobalIDs; 00060 UnsignedInt32* mpaElemConnect; 00061 }; 00062 struct SGroupData { 00063 UnsignedInt32 mintMemberType; 00064 UnsignedInt32 mintMemberCount; 00065 UnsignedInt32* mpaMemberIDs; 00066 }; 00067 typedef SGroupData SBlockData; 00068 typedef SGroupData SNodeSetData; 00069 typedef SGroupData SBCSetData; 00070 typedef SGroupData SConstraintData; 00071 00072 // first edition of sideset data 00073 struct SSideSetData_10 { 00074 UnsignedInt32 mintMemberType; 00075 UnsignedInt32 mintMemberCount; 00076 UnsignedInt32 mintMemberSenseSize; 00077 UnsignedInt32* mpaintMemberIDs; 00078 char* mpachrMemberSense; 00079 UnsignedInt32* mpaintMemberSense; 00080 char* mpachrMemberSideNumber; 00081 }; 00082 // next edition of sideset data holds more information in a more flexible way 00083 struct SSideSetData_11 { 00084 UnsignedInt32 mintMemberCount; // number of members {type,id} ... 00085 UnsignedInt32* mpaintMemberTypes; // types of each member 00086 UnsignedInt32* mpaintMemberIDs; // ids of the members 00087 char* mpachrMemberSenses; // shell sense (forward, reverse, both) 00088 UnsignedInt32* mpaintMemberWRTEntities; // wrt entities, format is ( {num_wrt} {type,id} {type,id} ... 00089 // {num_wrt} {type,id} ... 00090 }; 00091 00092 struct SMaterialData { 00093 UnsignedInt32 mintMemberType; 00094 UnsignedInt32 mintMemberRows; //i.e. rows 00095 UnsignedInt32 mintMemberColumns; 00096 double* mpadblMemberData; 00097 }; 00098 00099 class CUBIT_UTIL_EXPORT CCubitFile 00100 { 00101 public: 00102 typedef UnsignedInt32 HModel; 00103 enum EErrorCode { eSuccess = 0, 00104 eFileReadError, eFileSeekError, eFileTellError, eFileWriteError, 00105 eFileUnrecognizedFormat, 00106 eDuplicateWrite, eCorruptBlock, 00107 eNotFound, eOrderError, 00108 eMemoryError, ePassedNullPointer, 00109 eUnknownError 00110 }; 00111 enum EMetaDataOwnerType { 00112 eModelMetaData, 00113 eGeomMetaData, eNodeMetaData, eElemMetaData, eGroupMetaData, 00114 eBlockMetaData, eNodeSetMetaData, eSideSetMetaData, 00115 eBCSetMetaData, eMaterialMetaData, eConstraintMetaData 00116 }; 00117 enum EModelType { 00118 eFEModel, eACISText, eACISBinary, eAssemblyModel, eSimModel, eBoundaryLayerModel 00119 }; 00120 enum ESideSetSenseSize { 00121 eSideSetSenseNone, eSideSetSenseByte, eSideSetSenseInt32 00122 }; 00123 enum EConstraintType { 00124 eConstraintDistributing, eConstraintKinematic, eConstraintRigidBody 00125 }; 00126 00127 CCubitFile(); 00128 virtual ~CCubitFile(); 00129 00130 EErrorCode Open(const char* xstrReadFileName, const char* xstrWriteFileName, 00131 const char* xstrBackupFileName = NULL); 00132 EErrorCode Close(); 00133 00134 UnsignedInt32 GetModelList(UnsignedInt32& xintNumModels, 00135 const SModelData*& xpaModels); 00136 UnsignedInt32 IsModel(HModel xintModel); 00137 UnsignedInt32 GetReadModelLength(HModel xintModel, 00138 UnsignedInt32& xintLength); 00139 UnsignedInt32 CreateModel(EModelType xeModelType, HModel& xintModel); 00140 UnsignedInt32 DeleteModel(HModel xintModel); 00141 UnsignedInt32 GetModelOwner(HModel xintModel, HModel& xintOwner); 00142 UnsignedInt32 SetModelOwner(HModel xintModel, HModel xintOwner); 00143 00144 // Returns a FILE* that can be directly written to. Be sure to 00145 // call EndWriteAssemblyModel() to correctly accomodate the written data. 00146 UnsignedInt32 BeginWriteModel(HModel xintModelId, EModelType type, 00147 FILE*& writeable_file); 00148 UnsignedInt32 EndWriteModel(HModel xintModelId); 00149 // Returns a FILE* that can be read from. The FILE* will NOT return EOF 00150 // at the end of the data...the reader should not go GetReadModelLength() 00151 // bytes beyond the current FILE* position. You should copy the contents 00152 // to another FILE if this is an issue for the reader. 00153 UnsignedInt32 BeginReadModel(HModel xintGeomModel, EModelType type, 00154 FILE*& readable_file); 00155 UnsignedInt32 EndReadModel(); 00156 00157 UnsignedInt32 BeginWriteGeomModel(HModel xintGeomModel, 00158 const char* xstrGeomFile); 00159 UnsignedInt32 EndWriteGeomModel(); 00160 UnsignedInt32 BeginReadGeomModel(HModel xintGeomModel, 00161 FILE* xpGeomFile); 00162 UnsignedInt32 EndReadGeomModel(); 00163 00164 UnsignedInt32 BeginWriteFEModel(HModel xintFEModel, 00165 UnsignedInt32 xintGeomCount, 00166 UnsignedInt32 xintGroupCount, 00167 UnsignedInt32 xintBlockCount, 00168 UnsignedInt32 xintNodeSetCount, 00169 UnsignedInt32 xintSideSetCount); 00170 UnsignedInt32 WriteNodes(UnsignedInt32 xintIndex, UnsignedInt32 xintGeomID, 00171 UnsignedInt32 xintNodeCount, UnsignedInt32 *xpaintNodeIDs, 00172 double *xpadblX, double *xpadblY, double *xpadblZ); 00173 UnsignedInt32 WriteElems(UnsignedInt32 xintIndex, 00174 UnsignedInt32 xintNumTypes, SElemData* xpaElemData); 00175 UnsignedInt32 WriteGroup(UnsignedInt32 xintIndex, 00176 UnsignedInt32 xintGroupID, UnsignedInt32 xintGroupType, 00177 ConstCharPtr xpachrGroupName, 00178 UnsignedInt32 xintNumTypes, SGroupData* xpaGroupData); 00179 UnsignedInt32 WriteBlock(UnsignedInt32 xintIndex, 00180 UnsignedInt32 xintBlockID, 00181 int block_unique_id, 00182 UnsignedInt32 xintBlockType, 00183 UnsignedInt32 xintBlockColor, UnsignedInt32 xintMixedElemType, 00184 UnsignedInt32 xintDefPyramidType, UnsignedInt32 xintMaterialID, 00185 UnsignedInt32 xintBlockDimension, 00186 UnsignedInt32 xintNumTypes, SBlockData* xpaBlockData, 00187 UnsignedInt32 xintAttributeOrder, double* xpadblAttributes); 00188 UnsignedInt32 WriteNodeSet(UnsignedInt32 xintIndex, 00189 UnsignedInt32 xintNodeSetID, 00190 int nodeset_unique_id, 00191 UnsignedInt32 xintColor, 00192 UnsignedInt32 xintPointSymbol, 00193 UnsignedInt32 xintNumTypes, SNodeSetData* xpaNodeSetData, 00194 const std::vector<char>& bcdata 00195 ); 00196 UnsignedInt32 WriteSideSet_11(UnsignedInt32 xintIndex, 00197 UnsignedInt32 xintSideSetID, 00198 int sideset_unique_id, 00199 UnsignedInt32 xintColor, 00200 UnsignedInt32 xintUseShells, 00201 UnsignedInt32 xintNumTypes, SSideSetData_11* xpaSideSetData, 00202 UnsignedInt32 xintNumDistFact, double* xpadblDistribution, 00203 const std::vector<char>& bcdata); 00204 UnsignedInt32 EndWriteFEModel(); 00205 00206 UnsignedInt32 BeginReadFEModel(HModel xintFEModel, 00207 UnsignedInt32& xintGeomCount, 00208 UnsignedInt32& xintGroupCount, 00209 UnsignedInt32& xintBlockCount, 00210 UnsignedInt32& xintNodeSetCount, 00211 UnsignedInt32& xintSideSetCount); 00212 UnsignedInt32 ReadNodes(UnsignedInt32 xintIndex, UnsignedInt32& xintGeomID, 00213 UnsignedInt32& xintNodeCount, UnsignedInt32*& xpaintNodeIDs, 00214 double*& xpadblX, double*& xpadblY, double*& xpadblZ); 00215 UnsignedInt32 ReadElems(HModel xintFEModel, UnsignedInt32 xintIndex, UnsignedInt32& xintGeomID, 00216 UnsignedInt32& xintNumTypes, SElemData*& xpaElemData); 00217 UnsignedInt32 ReadGroupIdentity(UnsignedInt32 xintIndex, 00218 UnsignedInt32& xintGroupID, 00219 UnsignedInt32& xintGroupType, 00220 ConstCharPtr& xpachrGroupName); 00221 UnsignedInt32 ReadGroupMembers(UnsignedInt32 xintIndex, 00222 UnsignedInt32& xintNumTypes, SGroupData*& xpaGroupData); 00223 UnsignedInt32 ReadBlock(UnsignedInt32 xintIndex, 00224 UnsignedInt32& xintBlockID, int& unique_id, UnsignedInt32& xintBlockType, 00225 UnsignedInt32& xintBlockColor, UnsignedInt32& xintMixedElemType, 00226 UnsignedInt32& xintDefPyramidType, UnsignedInt32& xintMaterialID, 00227 UnsignedInt32& xintBlockDimension, 00228 UnsignedInt32& xintNumTypes, SBlockData*& xpaBlockData, 00229 UnsignedInt32& xintAttributeOrder, double*& xpadblAttributes); 00230 UnsignedInt32 ReadNodeSet(UnsignedInt32 xintIndex, 00231 UnsignedInt32& xintNodeSetID, int& unique_id, UnsignedInt32& xintColor, 00232 UnsignedInt32& xintPointSymbol, 00233 UnsignedInt32& xintNumTypes, SNodeSetData*& xpaNodeSetData, 00234 std::vector<char>& bcdata); 00235 00236 // read old sideset format 00237 UnsignedInt32 ReadSideSet_10(UnsignedInt32 xintIndex, 00238 UnsignedInt32& xintSideSetID, UnsignedInt32& xintColor, 00239 UnsignedInt32& xintUseShells, 00240 UnsignedInt32& xintNumTypes, SSideSetData_10*& xpaSideSetData, 00241 UnsignedInt32& xintNumDistFact, double*& xpadblDistribution); 00242 00243 // read new sideset format 00244 UnsignedInt32 ReadSideSet_11(UnsignedInt32 xintIndex, 00245 UnsignedInt32& xintSideSetID, int& unique_id, UnsignedInt32& xintColor, 00246 UnsignedInt32& xintUseShells, 00247 UnsignedInt32& xintNumTypes, SSideSetData_11*& xpaSideSetData, 00248 UnsignedInt32& xintNumDistFact, double*& xpadblDistribution, 00249 std::vector<char>& bcdata); 00250 00251 UnsignedInt32 EndReadFEModel(); 00252 00253 // Simulation Model functions 00254 UnsignedInt32 BeginWriteSimModel(HModel xintGeomModel, 00255 UnsignedInt32 xintBCCount, 00256 UnsignedInt32 xintICCount, 00257 UnsignedInt32 xintBCSetCount, 00258 UnsignedInt32 xintMaterialCount, 00259 UnsignedInt32 xintAmplitudeCount, 00260 UnsignedInt32 xintConstraintCount 00261 ); 00262 UnsignedInt32 WriteBCSet(UnsignedInt32 xintIndex, 00263 UnsignedInt32 xintBCSetID, 00264 UnsignedInt32 xintBCSetUniqueID, 00265 UnsignedInt32 xintBCSetAnalysisType, 00266 UnsignedInt32 xintRestraintTypesCount, 00267 UnsignedInt32 xintLoadTypesCount, 00268 UnsignedInt32 xintContactPairTypesCount, 00269 SBCSetData* xpaBCSetRestraintData, 00270 SBCSetData* xpaBCSetLoadData, 00271 SBCSetData* xpaBCSetContactPairData 00272 ); 00273 UnsignedInt32 WriteMaterial(UnsignedInt32 xintIndex, 00274 UnsignedInt32 xintMaterialID, 00275 UnsignedInt32 xintMaterialUniqueID, 00276 UnsignedInt32 xintPropertiesCount, 00277 SMaterialData* xpaMaterialData 00278 ); 00279 UnsignedInt32 WriteConstraint(UnsignedInt32 xintIndex, 00280 UnsignedInt32 xintConstraintID, 00281 UnsignedInt32 xintConstraintUniqueID, 00282 UnsignedInt32 xintConstraintType, 00283 UnsignedInt32 xintIndependentTypeCount, 00284 SConstraintData* xpaIndependentData, 00285 UnsignedInt32 xintDependentTypeCount, 00286 SConstraintData* xpaDependentData 00287 ); 00288 UnsignedInt32 EndWriteSimModel(); 00289 00290 UnsignedInt32 BeginReadSimModel(HModel xintGeomModel, 00291 UnsignedInt32& xintBCCount, 00292 UnsignedInt32& xintICCount, 00293 UnsignedInt32& xintBCSetCount, 00294 UnsignedInt32& xintMaterialCount, 00295 UnsignedInt32& xintAmplitudeCount, 00296 UnsignedInt32& xintConstraintCount 00297 ); 00298 UnsignedInt32 ReadBCSet(UnsignedInt32 xintIndex, 00299 UnsignedInt32& xintBCSetID, 00300 UnsignedInt32& xintBCSetUniqueID, 00301 UnsignedInt32& xintBCSetAnalysisType, 00302 UnsignedInt32& xintRestraintTypesCount, 00303 UnsignedInt32& xintLoadTypesCount, 00304 UnsignedInt32& xintContactPairTypesCount, 00305 SBCSetData*& xpaBCSetRestraintData, 00306 SBCSetData*& xpaBCSetLoadData, 00307 SBCSetData*& xpaBCSetContactPairData 00308 ); 00309 UnsignedInt32 ReadMaterial(UnsignedInt32 xintIndex, 00310 UnsignedInt32& xintMaterialID, 00311 UnsignedInt32& xintMaterialUniqueID, 00312 UnsignedInt32& xintPropertiesCount, 00313 SMaterialData*& xpaMaterialData 00314 ); 00315 UnsignedInt32 ReadConstraint(UnsignedInt32 xintIndex, 00316 UnsignedInt32& xintConstraintID, 00317 UnsignedInt32& xintConstraintUniqueID, 00318 UnsignedInt32& xintConstraintType, 00319 UnsignedInt32& xintIndependentTypeCount, 00320 SConstraintData*& xpaIndependentData, 00321 UnsignedInt32& xintDependentTypeCount, 00322 SConstraintData*& xpaDependentData 00323 ); 00324 UnsignedInt32 EndReadSimModel(); 00325 00326 00327 UnsignedInt32 GetReadMetaData(EMetaDataOwnerType xeType, 00328 CMetaData*& xpMetaData); 00329 UnsignedInt32 GetWriteMetaData(EMetaDataOwnerType xeType, 00330 CMetaData*& xpMetaData); 00331 00332 EErrorCode GetError() const; // ??? 00333 00334 // enum EEndian { eLittleEndian = 0, eBigEndian = 0xFFFFFFFF }; 00335 static const UnsignedInt32 mintNativeEndian; 00336 enum ECompression { eNoCompression }; 00337 00338 private: 00339 char* mstrReadFileName; 00340 char* mstrWriteFileName; 00341 char* mstrBackupFileName; 00342 UnsignedInt32 mintWriteTempFile; 00343 CubitFile mpReadFile; 00344 CubitFile mpWriteFile; 00345 EErrorCode meErrorState; 00346 UnsignedInt32 mintWriteBuffNumModels; 00347 UnsignedInt32 mintNextModelID; 00348 00349 struct SCubitFileContentsHeader { 00350 UnsignedInt32 mintHeaderSourceEndian; 00351 UnsignedInt32 mintHeaderSchema; 00352 UnsignedInt32 mintNumModels; 00353 UnsignedInt32 mintModelTableOffset; 00354 UnsignedInt32 mintModelMetaDataOffset; 00355 UnsignedInt32 mintActiveFEModel; 00356 } mReadContents, mWriteContents; 00357 static const UnsignedInt32 mintSizeOfContents; 00358 struct SCubitFileModelEntry { 00359 UnsignedInt32 mintModelHandle; 00360 UnsignedInt32 mintModelOffset; 00361 UnsignedInt32 mintModelLength; 00362 EModelType mintModelType; 00363 UnsignedInt32 mintModelOwner; 00364 UnsignedInt32 mintModel64bitOSPad; // make struct 64 bit word aligned 00365 } *mpaReadModels, *mpaWriteModels; 00366 static const UnsignedInt32 mintSizeOfModel; 00367 enum EModelStat { eStatNotWritten, eStatWritten, eStatDelete, eStatWriting }; 00368 EModelStat* mpaReadModelStat; 00369 00370 void WriteModelTable(); 00371 UnsignedInt32 FindModel(HModel xintModel, SCubitFileModelEntry* xpaModels, 00372 UnsignedInt32 xintNumModels, UnsignedInt32& xintIndex); 00373 void CopyModel(UnsignedInt32 xintReadOffset, UnsignedInt32& xintWriteOffset, 00374 UnsignedInt32 xintLength, FILE* xpReadFile, FILE* xpWriteFile); 00375 void FreeAll(); 00376 00377 UnsignedInt32 mintFEModelIndex; 00378 UnsignedInt32 mintSimModelIndex; 00379 CFEModel* mpReadFEModel; 00380 CFEModel* mpWriteFEModel; 00381 CSimModel* mpReadSimModel; 00382 CSimModel* mpWriteSimModel; 00383 CMetaData* mpMetaData; 00384 struct { 00385 UnsignedInt32 mintNumModels; 00386 SModelData* mpaModelData; 00387 } mModelBuff; 00388 }; 00389 00390 } // namespace NCubitFile 00391 00392 #endif 00393
