cgma
00001 00002 00003 #ifndef CGMHistory_hpp 00004 #define CGMHistory_hpp 00005 00006 #include <vector> 00007 #include "CubitTransformMatrix.hpp" 00008 #include "CGMGeomConfigure.h" 00009 class RefEntity; 00010 class TopologyBridge; 00011 00012 class CUBIT_GEOM_EXPORT CGMHistory 00013 { 00014 public: 00015 CGMHistory(); 00016 ~CGMHistory(); 00017 00018 enum EventType 00019 { 00020 // Top level creation means an entity with no parent is created 00021 // this could be bodies, surfaces, curves or vertices 00022 TOP_LEVEL_ENTITY_CREATED, 00023 00024 // Top level deleted means an entity no longer has top level status 00025 // it may have been deleted or it may have been consumed into a higher 00026 // dimensional entity 00027 TOP_LEVEL_ENTITY_DELETED, 00028 00029 // An entity has been created 00030 ENTITY_CREATED, 00031 00032 // An entity has been deleted 00033 ENTITY_DELETED, 00034 00035 // An entity's topology changes, meaning it has gained new child entities 00036 // or lost old child entities. This can result from solid modeling 00037 // operations or from operations within cgm such as merging. 00038 TOPOLOGY_CHANGED, 00039 00040 // The geometry of an entity is changed such that it might have been 00041 // stretched, warped or other such changes where the topology may be the 00042 // same. If child entities changed, they'll have their own event. 00043 GEOMETRY_CHANGED, 00044 00045 // A transformation happend to this entity, all child entities are 00046 // transformed as well. In this case, a GEOMETRY_CHANGED does not occur. 00047 GEOMETRY_TRANSFORMED, 00048 00049 // The id of an entity changes 00050 ENTITY_ID_CHANGED, 00051 00052 // The name of an entity changes 00053 ENTITY_NAME_CHANGED, 00054 00055 // The name of an entity changes 00056 ENTITY_COLOR_CHANGED, 00057 00058 // An entity is subdivided into multiple entities 00059 // this is a supplemental event such that other events completely 00060 // describe the topology changes, but this event specifies where the 00061 // subdivision occurred 00062 SUBDIVISION, 00063 00064 // Multiple entities are absorbed into one entity 00065 // this is a supplemental event such that other events completely 00066 // describe the topology changes, but this event specifies where the 00067 // absorption occurred 00068 ABSORPTION, 00069 00070 // Multiple entities modified by a combination of subdivision and 00071 // absorption, and intermediate entities don't exist by the time 00072 // this history object is given to someone 00073 // this is a supplemental event such that other events completely 00074 // describe the topology changes, but this event specifies where the 00075 // subdivision/absorption occurred 00076 SUBDIVISION_ABSORPTION, 00077 00078 // An entity is merged into another 00079 // this is a supplemental event such that other events completely 00080 // describe the topology changes, but this event specifies where the 00081 // merge occurred 00082 MERGE, 00083 00084 // An entity is copied from another 00085 // you may also get this when an unmerge happens in cgm 00086 // this is a supplemental event such that other events completely 00087 // describe the topology changes, but this event specifies where the 00088 // copy occurred 00089 COPY, 00090 00091 // Cousin to SUBDIVISION. Think of it as a 1-to-n subdivision where 00092 // only 1 of the n actually survives, so it's really and 1-to-1 00093 // modification. 00094 CUT 00095 }; 00096 00097 //Event is a record of a change that occurred during an operation 00098 class CUBIT_GEOM_EXPORT Event 00099 { 00100 public: 00101 Event(EventType type, RefEntity* refentity); 00102 Event(EventType type, const std::vector<RefEntity*>& refentity_list); 00103 ~Event(); 00104 00105 EventType get_event_type() const; 00106 const std::vector<RefEntity*>& get_entities() const; 00107 00108 private: 00109 00110 // the type of event this is 00111 EventType eventType; 00112 // the entities this event applies to 00113 std::vector<RefEntity*> entities; 00114 00115 // extra data associated with event 00116 union 00117 { 00118 std::vector<RefEntity*> *other_entities; 00119 CubitTransformMatrix *matrix; 00120 // TODO add data types for other events 00121 }; 00122 }; 00123 00124 00125 class CUBIT_GEOM_EXPORT PortEvent 00126 { 00127 public: 00128 PortEvent(EventType type, std::vector<RefEntity*> &source_entities, 00129 std::vector<TopologyBridge*> &result_entities ); 00130 PortEvent( EventType type ); 00131 ~PortEvent(); 00132 00133 EventType get_event_type() const; 00134 const std::vector<RefEntity*>& get_entities() const; 00135 00136 EventType eventType; 00137 // the entities this event applies to 00138 std::vector<RefEntity*> RefEnts; 00139 std::vector<TopologyBridge*> TopologyBridges; 00140 00141 // extra data associated with event 00142 //union 00143 // { 00144 // std::vector<TopologyBridge*> *TopologyBridges; 00145 // CubitTransformMatrix *matrix; 00146 // TODO add data types for other events 00147 // }; 00148 }; 00149 00150 00151 00152 // get the number of events in this history 00153 int get_number_of_events() const; 00154 // get an event by index 00155 const Event* get_event( int index ) const; 00156 00157 void print_port_events(); 00158 00159 // add an event to this history 00160 void add_event( const Event &new_event ); 00161 // compress the events in this history 00162 // for example, if an event for volume 1 created and an event for volume 1 00163 // deleted exists, both are removed 00164 00165 void add_port_event( const PortEvent &event ); 00166 00167 void compress(); 00168 00169 // cleans out the history 00170 void clear(); 00171 00172 // start tracking events 00173 void start_tracking(); 00174 // stop tracking events 00175 void end_tracking(); 00176 // ask if tracking 00177 bool is_tracking() const; 00178 00179 private: 00180 // the list of events 00181 std::vector<Event> eventList; 00182 std::vector<PortEvent> portEventList; 00183 bool mTracking; 00184 }; 00185 00186 #endif 00187
