cgma
00001 // 00002 // class CGMMemFile 00003 // 00004 // This class mimics the MemFile construct, but for general CGM 00005 // entities. This class supports the saving and restoring of entities 00006 // to/from memory buffers, and the passing of these memory buffers to 00007 // processors using mpi. 00008 // 00009 00010 #ifndef CGMMEMFILE 00011 #define CGMMEMFILE 00012 //#include <vector> 00013 #include "CubitDefines.h" 00014 #include "DLIList.hpp" 00015 00016 class RefEntity; 00017 00018 class CGMMemFile 00019 { 00020 public: 00021 CGMMemFile(void* buffer = NULL, 00022 size_t bufSize = 0); 00023 //- constructor, with optional buffer passed in; if buffer is passed in, it 00024 //- will be used for the writing operation; if NULL, the next writing operation 00025 //- will create a buffer of the right size. NOTE: buffer is deleted in the 00026 //- destructor, even if it was passed in 00027 00028 virtual ~CGMMemFile(); 00029 //- destructor; deletes m_pBuffer 00030 00031 CubitStatus bcast_entity_list(DLIList<RefEntity*> &ref_entity_list); 00032 //- broadcasts the entity list; root takes list as input, 00033 //- others write as output; uses read_refentity_list and write_refentity_list 00034 //- functions 00035 00036 CubitStatus bcast_and_delete_entity_list(DLIList<RefEntity*> &ref_entity_list, 00037 DLIList<RefEntity*> &ref_entity_list_master); 00038 //- broadcasts the entity list; delete the rest that this processor doesn't need 00039 00040 //CubitStatus send_body_to_procs(DLIList<RefEntity*> &ref_entity_list); 00041 00042 //CubitStatus send_body_to_procs_balanced(DLIList<RefEntity*> &ref_entity_list); 00043 00044 //CubitStatus vol_balace_send_body_processors(DLIList<RefEntity*> &ref_entity_list); 00045 00046 CubitStatus scatter_entity_list(DLIList<RefEntity*> &ref_entity_list); 00047 //- scatter the exact amount of entity that each processors need; 00048 00049 CubitStatus scatter_balanced_entity_list(DLIList<RefEntity*> &ref_entity_list, 00050 DLIList<RefEntity*> &ref_entity_list_master, 00051 DLIList<RefEntity*> **balanced_lists); 00052 00053 CubitStatus scatter_test(DLIList<RefEntity*> &ref_entity_list); 00054 00055 //static int *get_body_to_proc(); 00056 static DLIList <int> *get_body_to_proc(); 00057 //static std::vector<int> *get_body_to_proc(); 00058 00059 //static std::vector<int> get_num_body_to_proc(); 00060 00061 00062 protected: 00063 //int balanceSurf; 00064 //- load balance surfaces 00065 00066 //double *totalLoads; 00067 00068 //DLIList<RefEntity*> **balancedLists; 00069 00070 unsigned char *m_pBuffer; 00071 //- the memory buffer 00072 00073 size_t m_sizeBuffer; 00074 //- the size of the buffer in bytes 00075 00076 unsigned long m_currentPosition; 00077 //- the current position in the buffer 00078 00079 static DLIList <int> bodyToProc; 00080 //static std::vector<int> bodyToProc; 00081 //- body to processor assignment vector 00082 00083 //static int *bodyToProc; 00084 00085 //static int nBodyToProc; 00086 00087 //static DLIList <int> *bodyToProcPtr; 00088 //- body to processor assignment vector pointer 00089 00090 virtual CubitStatus read_refentity_list(DLIList<RefEntity*> &ref_entity_list) = 0; 00091 //- read a RefEntity list from the buffer into ref_entity_list; relies on engine- 00092 //- specific implementation 00093 00094 virtual CubitStatus write_refentity_list(DLIList<RefEntity*> &ref_entity_list) = 0; 00095 //- write a RefEntity list to the buffer from ref_entity_list; relies on engine- 00096 //- specific implementation 00097 00098 virtual CubitStatus append_refentity_list(DLIList<RefEntity*> &ref_entity_list, 00099 int &buffer_size) = 0; 00100 00101 virtual CubitStatus get_refentity_list(DLIList<RefEntity*> &ref_entity_list) = 0; 00102 00103 virtual int get_refentity_list_size(DLIList<RefEntity*> ref_entity_list) = 0; 00104 //- get the size of the requested entity list in the buffer 00105 00106 CubitStatus bcast_buffer(); 00107 //- broadcasts the buffer contained in this object; uses ProcData singleton class 00108 00109 CubitStatus check_size(int &target_size, CubitBoolean keep = CUBIT_FALSE); 00110 //- check the size of the buffer and, if necessary, expand it 00111 }; 00112 00113 #endif
