cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CompositeGeom.cpp 00003 // 00004 // Purpose : Object used by CompositeSurface and CompositeCurve 00005 // to manage underlying entities. 00006 // 00007 // Special Notes : 00008 // 00009 // Creator : Jason Kraftcheck 00010 // 00011 // Creation Date : 12/19/01 00012 //------------------------------------------------------------------------- 00013 00014 #include "VGDefines.h" 00015 #include "GeometryEntity.hpp" 00016 #include "CompositeGeom.hpp" 00017 #include "CompositeAttrib.hpp" 00018 #include "DLIList.hpp" 00019 #include "CubitMessage.hpp" 00020 00021 // used to print debug info: 00022 #include "Lump.hpp" 00023 #include "Surface.hpp" 00024 #include "Curve.hpp" 00025 #include "Point.hpp" 00026 00027 const char* const COMPOSITE_DATA_ATTRIB_NAME = "COMPOSITE_ATTRIB"; 00028 00029 00030 //------------------------------------------------------------------------- 00031 // Purpose : Constructor 00032 // 00033 // Special Notes : 00034 // 00035 // Creator : Jason Kraftcheck 00036 // 00037 // Creation Date : 12/19/01 00038 //------------------------------------------------------------------------- 00039 CompositeGeom::CompositeGeom( int size ) 00040 : entityList(size), 00041 currentIndex(0), 00042 firstIndex(-1), 00043 needToUpdateBbox( true ), 00044 needToUpdateMeasure( true ), 00045 listHead(0) 00046 { 00047 // initialization above both allocated space for size 00048 // entities, and set the current count in the list to 00049 // size. We want the initial memory, but need to set 00050 // the count back to zero. 00051 entityList.size(0); 00052 } 00053 00054 //------------------------------------------------------------------------- 00055 // Purpose : Destructor 00056 // 00057 // Special Notes : 00058 // 00059 // Creator : Jason Kraftcheck 00060 // 00061 // Creation Date : 12/19/01 00062 //------------------------------------------------------------------------- 00063 CompositeGeom::~CompositeGeom() 00064 { 00065 while(listHead) 00066 { 00067 CompositeAttrib* dead = listHead; 00068 listHead = listHead->next; 00069 delete dead; 00070 } 00071 } 00072 00073 //------------------------------------------------------------------------- 00074 // Purpose : Find the index of an entity 00075 // 00076 // Special Notes : 00077 // 00078 // Creator : Jason Kraftcheck 00079 // 00080 // Creation Date : 12/19/01 00081 //------------------------------------------------------------------------- 00082 int CompositeGeom::index_of( TopologyBridge* ptr ) const 00083 { 00084 int i; 00085 for( i = entityList.size() - 1; i >= 0; i-- ) 00086 if( entityList[i].entity == ptr ) 00087 break; 00088 00089 return i; 00090 } 00091 00092 //------------------------------------------------------------------------- 00093 // Purpose : Insert an entry 00094 // 00095 // Special Notes : 00096 // 00097 // Creator : Jason Kraftcheck 00098 // 00099 // Creation Date : 12/19/01 00100 //------------------------------------------------------------------------- 00101 CubitStatus CompositeGeom::insert( int index, GeometryEntity* geom_ptr, 00102 CubitSense sense ) 00103 { 00104 if( index < 0 ) 00105 { 00106 assert( index >= 0 ); 00107 index = 0; 00108 } 00109 else if( index > entityList.size() ) 00110 { 00111 assert( index <= entityList.size() ); 00112 index = entityList.size(); 00113 } 00114 00115 CompositeEntry ent; 00116 ent.entity = geom_ptr; 00117 ent.sense = sense; 00118 ent.dist_sqr = ent.measure = 0.; 00119 00120 //force 0th surface to be one that has the composite attrib on it. 00121 DLIList<CubitSimpleAttrib> list; 00122 geom_ptr->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00123 if( list.size() ) 00124 index = 0; 00125 00126 entityList.insert( ent, index ); 00127 00128 update_cached_data(); 00129 00130 return CUBIT_SUCCESS; 00131 } 00132 00133 //------------------------------------------------------------------------- 00134 // Purpose : Remove an entry 00135 // 00136 // Special Notes : 00137 // 00138 // Creator : Jason Kraftcheck 00139 // 00140 // Creation Date : 12/19/01 00141 //------------------------------------------------------------------------- 00142 CubitStatus CompositeGeom::remove( int index, bool dead ) 00143 { 00144 if( (index < 0) || (index >= entityList.size()) ) 00145 { 00146 assert( index >= 0 && index < entityList.size() ); 00147 return CUBIT_FAILURE; 00148 } 00149 00150 if (!dead) 00151 clean_up_attribs(entityList[index].entity); 00152 00153 entityList.remove( index ); 00154 update_cached_data(); 00155 00156 return CUBIT_SUCCESS; 00157 } 00158 00159 //------------------------------------------------------------------------- 00160 // Purpose : Split this composite into two, where all entries 00161 // before the passed index remain in this entity and all 00162 // entries after the index become part of a new composite. 00163 // 00164 // Special Notes : The entry at the specified index remains in this. 00165 // 00166 // Creator : Jason Kraftcheck 00167 // 00168 // Creation Date : 12/19/01 00169 //------------------------------------------------------------------------- 00170 CompositeGeom* CompositeGeom::split( int index ) 00171 { 00172 int i; 00173 if( (index < 0) || (index >= entityList.size()) ) 00174 { 00175 assert( index >= 0 && index < entityList.size() ); 00176 return 0; 00177 } 00178 00179 // find EntityName attribute 00180 CompositeAttrib* name_attrib = listHead; 00181 while (name_attrib && name_attrib->name() != "ENTITY_NAME") 00182 name_attrib = name_attrib->next; 00183 00184 int first = index + 1; 00185 CompositeGeom* new_geom = new CompositeGeom( entityList.size() - first ); 00186 00187 for( i = first; i < entityList.size(); i++ ) 00188 new_geom->append( entityList[i].entity, entityList[i].sense ); 00189 00190 entityList.size( first ); 00191 update_cached_data(); 00192 00193 // copy entityname attrib to new entity 00194 if ( name_attrib ) 00195 { 00196 assert(!new_geom->listHead); 00197 new_geom->listHead = new CompositeAttrib(*name_attrib); 00198 } 00199 00200 return new_geom; 00201 } 00202 CompositeGeom* CompositeGeom::split( VGArray<int>& index_array ) 00203 { 00204 int i, j; 00205 00206 if( index_array.size() == 0 ) 00207 return 0; 00208 00209 for( i = 0; i < index_array.size(); i++ ) 00210 if( index_array[i] < 0 || index_array[i] >= entityList.size() ) 00211 { 00212 assert(0); 00213 return 0; 00214 } 00215 00216 00217 // find EntityName attribute 00218 CompositeAttrib* name_attrib = listHead; 00219 while (name_attrib && name_attrib->name() != "ENTITY_NAME") 00220 name_attrib = name_attrib->next; 00221 00222 CompositeGeom* new_geom = new CompositeGeom( index_array.size() ); 00223 for( i = 0; i < index_array.size(); i++ ) 00224 { 00225 int index = index_array[i]; 00226 assert( entityList[index].entity != NULL ); 00227 new_geom->append( entityList[index].entity, entityList[index].sense ); 00228 entityList[index].entity = 0; 00229 } 00230 00231 for( i = 0; i < entityList.size() && entityList[i].entity; i++ ); 00232 for( j = i + 1; j < entityList.size(); j++ ) 00233 { 00234 if( entityList[j].entity ) 00235 { 00236 entityList[i].entity = entityList[j].entity; 00237 entityList[i].sense = entityList[j].sense; 00238 entityList[j].entity = 0; 00239 i++; 00240 } 00241 } 00242 entityList.size( i ); 00243 00244 // copy entityname attrib to new entity 00245 if ( name_attrib ) 00246 { 00247 assert(!new_geom->listHead); 00248 new_geom->listHead = new CompositeAttrib(*name_attrib); 00249 } 00250 00251 update_cached_data(); 00252 return new_geom; 00253 } 00254 00255 //------------------------------------------------------------------------- 00256 // Purpose : change geometry entity 00257 // 00258 // Special Notes : 00259 // 00260 // Creator : Jason Kraftcheck 00261 // 00262 // Creation Date : 01/11/02 00263 //------------------------------------------------------------------------- 00264 CubitStatus CompositeGeom::swap( int index, GeometryEntity* new_geom ) 00265 { 00266 if( (index < 0) || (index >= entityList.size()) ) 00267 { 00268 assert( index >= 0 && index < entityList.size() ); 00269 return CUBIT_FAILURE; 00270 } 00271 00272 entityList[index].entity = new_geom; 00273 update_cached_data(); 00274 return CUBIT_SUCCESS; 00275 } 00276 00277 //------------------------------------------------------------------------- 00278 // Purpose : Return union of bounding boxes of all entities. 00279 // 00280 // Special Notes : 00281 // 00282 // Creator : Jason Kraftcheck 00283 // 00284 // Creation Date : 12/19/01 00285 //------------------------------------------------------------------------- 00286 CubitBox CompositeGeom::bounding_box() 00287 { 00288 if( entityList.size() == 0 ) 00289 { 00290 return CubitBox(); 00291 } 00292 00293 if( needToUpdateBbox ) 00294 update_data_bbox(); 00295 00296 CubitBox box( entityList[0].bbox ); 00297 for( int i = 1; i < entityList.size(); i++ ) 00298 box |= entityList[i].bbox; 00299 return box; 00300 } 00301 00302 //------------------------------------------------------------------------- 00303 // Purpose : Return sum of measure() for all entities. 00304 // 00305 // Special Notes : 00306 // 00307 // Creator : Jason Kraftcheck 00308 // 00309 // Creation Date : 12/19/01 00310 //------------------------------------------------------------------------- 00311 double CompositeGeom::measure() 00312 { 00313 if( entityList.size() == 0 ) 00314 return 0.0; 00315 00316 if( needToUpdateMeasure ) 00317 update_data_measure(); 00318 00319 return entityList[entityList.size()-1].measure; 00320 } 00321 00322 //------------------------------------------------------------------------- 00323 // Purpose : Update cached data for each entity 00324 // 00325 // Special Notes : 00326 // 00327 // Creator : Jason Kraftcheck 00328 // 00329 // Creation Date : 12/19/01 00330 //------------------------------------------------------------------------- 00331 void CompositeGeom::update_data_measure() 00332 { 00333 needToUpdateMeasure = false; 00334 double sum = 0.0; 00335 for( int i = 0; i < entityList.size(); i++ ) 00336 { 00337 sum += entityList[i].entity->measure(); 00338 entityList[i].measure = sum; 00339 } 00340 } 00341 00342 //------------------------------------------------------------------------- 00343 // Purpose : Update cached data for each entity 00344 // 00345 // Special Notes : 00346 // 00347 // Creator : Jason Kraftcheck 00348 // 00349 // Creation Date : 12/19/01 00350 //------------------------------------------------------------------------- 00351 void CompositeGeom::update_data_bbox() 00352 { 00353 needToUpdateBbox = false; 00354 for( int i = 0; i < entityList.size(); i++ ) 00355 { 00356 entityList[i].bbox = entityList[i].entity->bounding_box(); 00357 } 00358 } 00359 00360 //------------------------------------------------------------------------- 00361 // Purpose : Setup search based on distance between passed position 00362 // and the bounding box of each entity, and return the 00363 // index of the entity with the bounding box closest to 00364 // the passed position. 00365 // 00366 // Special Notes : 00367 // 00368 // Creator : Jason Kraftcheck 00369 // 00370 // Creation Date : 12/19/01 00371 //------------------------------------------------------------------------- 00372 int CompositeGeom::closest_box( const CubitVector& position ) 00373 { 00374 if( entityList.size() <= 0 ) return -1; 00375 00376 if( needToUpdateBbox ) update_data_bbox(); 00377 00378 int min_index = 0; 00379 double min_dist = entityList[0].dist_sqr 00380 = entityList[0].bbox.distance_squared( position ); 00381 00382 for( int i = 1; i < entityList.size(); i++ ) 00383 { 00384 CompositeEntry& ent = entityList[i]; 00385 double dist_sqr = ent.dist_sqr = ent.bbox.distance_squared( position ); 00386 if( dist_sqr < min_dist ) 00387 min_index = i; 00388 } 00389 00390 firstIndex = -1; 00391 currentIndex = min_index; 00392 return currentIndex; 00393 } 00394 00395 //------------------------------------------------------------------------- 00396 // Purpose : Interate through entities with bounding boxes 00397 // within the specified distance (squared) from the 00398 // position passed to closest_box(). 00399 // 00400 // Special Notes : -1 is returned ONCE to indicate the end of the list. 00401 // Behavior is undefined if closest_box() has never been 00402 // called. 00403 // 00404 // Creator : Jason Kraftcheck 00405 // 00406 // Creation Date : 12/19/01 00407 //------------------------------------------------------------------------- 00408 int CompositeGeom::next_box_within_dist( double dist_squared ) 00409 { 00410 if( entityList.size() > 0 ) 00411 { 00412 if( firstIndex < 0 ) 00413 { 00414 firstIndex = currentIndex; 00415 } 00416 else if( firstIndex == currentIndex ) 00417 { 00418 return -1; 00419 } 00420 00421 while( (currentIndex = (currentIndex + 1) % entityList.size()) 00422 != firstIndex ) 00423 { 00424 if( entityList[currentIndex].dist_sqr < dist_squared ) 00425 { 00426 return currentIndex; 00427 } 00428 } 00429 } 00430 00431 return -1; 00432 } 00433 00434 //------------------------------------------------------------------------- 00435 // Purpose : Reverse sense of composite 00436 // 00437 // Special Notes : 00438 // 00439 // Creator : Jason Kraftcheck 00440 // 00441 // Creation Date : 00442 //------------------------------------------------------------------------- 00443 CubitStatus CompositeGeom::reverse() 00444 { 00445 reverse_order(); 00446 reverse_rel_senses(); 00447 return CUBIT_SUCCESS; 00448 } 00449 CubitStatus CompositeGeom::reverse_order() 00450 { 00451 int i, half = entityList.size() / 2; 00452 for( i = 0; i < half; i++ ) 00453 { 00454 int j = entityList.size() - (i+1); 00455 GeometryEntity* temp_entity = entityList[i].entity; 00456 entityList[i].entity = entityList[j].entity; 00457 entityList[j].entity = temp_entity; 00458 CubitSense temp_sense = entityList[i].sense; 00459 entityList[i].sense = entityList[j].sense; 00460 entityList[j].sense = temp_sense; 00461 } 00462 update_cached_data(); 00463 return CUBIT_SUCCESS; 00464 } 00465 CubitStatus CompositeGeom::reverse_rel_senses() 00466 { 00467 for( int i = 0; i < entityList.size(); i++ ) 00468 { 00469 entityList[i].sense = 00470 entityList[i].sense == CUBIT_FORWARD ? CUBIT_REVERSED : 00471 entityList[i].sense == CUBIT_REVERSED ? CUBIT_FORWARD : 00472 CUBIT_UNKNOWN; 00473 } 00474 00475 return CUBIT_SUCCESS; 00476 } 00477 00478 00479 //------------------------------------------------------------------------- 00480 // Purpose : Combine 00481 // 00482 // Special Notes : 00483 // 00484 // Creator : Jason Kraftcheck 00485 // 00486 // Creation Date : 03/04/02 00487 //------------------------------------------------------------------------- 00488 CubitStatus CompositeGeom::merge( CompositeGeom& dead, bool prepend ) 00489 { 00490 int i; 00491 00492 if (entityList.size() == 1) 00493 { 00494 DLIList<CubitSimpleAttrib> list; 00495 entityList[0].entity->get_simple_attribute(list); 00496 list.reset(); 00497 for (i = list.size(); i--; ) 00498 { 00499 const CubitSimpleAttrib csa = list.get_and_step(); 00500 if (csa.character_type() != COMPOSITE_DATA_ATTRIB_NAME) 00501 listHead = new CompositeAttrib(csa, listHead); 00502 } 00503 } 00504 00505 // find EntityName attribute 00506 CompositeAttrib* this_name = listHead; 00507 while (this_name && this_name->name() != "ENTITY_NAME") 00508 this_name = this_name->next; 00509 00510 // merge entity name attributes 00511 CompositeAttrib* dead_name = dead.listHead; 00512 if (dead_name) 00513 { 00514 if (dead_name->name() == "ENTITY_NAME") 00515 { 00516 dead_name = dead.listHead; 00517 dead.listHead = dead_name->next; 00518 dead_name->next = 0; 00519 } 00520 else 00521 { 00522 while(dead_name->next && dead_name->next->name() != "ENTITY_NAME") 00523 dead_name = dead_name->next; 00524 if(dead_name->next) 00525 { 00526 CompositeAttrib* prev = dead_name; 00527 prev->next = dead_name = dead_name->next; 00528 dead_name->next = 0; 00529 } 00530 } 00531 } 00532 00533 00534 int insert ; 00535 if ( prepend ) 00536 { 00537 insert = 0; 00538 entityList.size_end( entityList.size() + dead.entityList.size() ); 00539 } 00540 else 00541 { 00542 insert = entityList.size(); 00543 entityList.size( entityList.size() + dead.entityList.size() ); 00544 } 00545 00546 for( i = 0; i < dead.entityList.size(); i++ ) 00547 { 00548 entityList[insert].entity = dead.entityList[i].entity; 00549 entityList[insert].sense = dead.entityList[i].sense; 00550 insert++; 00551 } 00552 00553 dead.entityList.size(0); 00554 update_cached_data(); 00555 00556 return CUBIT_SUCCESS; 00557 } 00558 00559 00560 //------------------------------------------------------------------------- 00561 // Purpose : Store an attribute 00562 // 00563 // Special Notes : 00564 // 00565 // Creator : Jason Kraftcheck 00566 // 00567 // Creation Date : 06/18/02 00568 //------------------------------------------------------------------------- 00569 void CompositeGeom::add_attribute( const CubitSimpleAttrib& csa ) 00570 { 00571 if (entityList.size() == 1) 00572 entityList[0].entity->append_simple_attribute_virt(csa); 00573 else 00574 listHead = new CompositeAttrib( csa, listHead ); 00575 } 00576 00577 //------------------------------------------------------------------------- 00578 // Purpose : Remove an attribute 00579 // 00580 // Special Notes : 00581 // 00582 // Creator : Jason Kraftcheck 00583 // 00584 // Creation Date : 06/18/02 00585 //------------------------------------------------------------------------- 00586 void CompositeGeom::rem_attribute( const CubitSimpleAttrib& csa ) 00587 { 00588 while (listHead && listHead->equals(csa)) 00589 { 00590 CompositeAttrib* dead = listHead; 00591 listHead = dead->next; 00592 delete dead; 00593 } 00594 00595 if (listHead) 00596 { 00597 CompositeAttrib* attrib = listHead; 00598 while (attrib->next) 00599 { 00600 if(attrib->next->equals(csa)) 00601 { 00602 CompositeAttrib* dead = attrib->next; 00603 attrib->next = dead->next; 00604 delete dead; 00605 } 00606 else 00607 { 00608 attrib = attrib->next; 00609 } 00610 } 00611 } 00612 00613 if (entityList.size() == 1) 00614 entityList[0].entity->remove_simple_attribute_virt(csa); 00615 } 00616 00617 //------------------------------------------------------------------------- 00618 // Purpose : Remove all attributes 00619 // 00620 // Special Notes : 00621 // 00622 // Creator : Jason Kraftcheck 00623 // 00624 // Creation Date : 06/18/02 00625 //------------------------------------------------------------------------- 00626 void CompositeGeom::rem_all_attributes() 00627 { 00628 while(listHead) 00629 { 00630 CompositeAttrib* dead = listHead; 00631 listHead = listHead->next; 00632 delete dead; 00633 } 00634 00635 if (entityList.size() == 1) 00636 entityList[0].entity->remove_all_simple_attribute_virt(); 00637 } 00638 00639 00640 //------------------------------------------------------------------------- 00641 // Purpose : Get all attributes 00642 // 00643 // Special Notes : 00644 // 00645 // Creator : Jason Kraftcheck 00646 // 00647 // Creation Date : 06/18/02 00648 //------------------------------------------------------------------------- 00649 void CompositeGeom::get_attributes( DLIList<CubitSimpleAttrib>& list ) 00650 { 00651 // special case: single-entity 'composite' 00652 if (entityList.size() == 1) 00653 { 00654 TopologyBridge* entity = entityList[0].entity; 00655 entity->get_simple_attribute(list); 00656 00657 // handle 8.1 attribs on single-entity 'composites' 00658 for (int i = list.size(); i--; ) 00659 { 00660 const CubitSimpleAttrib& attrib = list.step_and_get(); 00661 if (attrib.character_type() == COMPOSITE_DATA_ATTRIB_NAME && 00662 attrib.int_data_list()[0] == 1) 00663 { 00664 entity->remove_simple_attribute_virt(attrib); 00665 CubitSimpleAttrib newattrib = attrib; 00666 newattrib.string_data_list().erase(newattrib.string_data_list().begin()); 00667 newattrib.int_data_list().erase(newattrib.int_data_list().begin()); 00668 entity->append_simple_attribute_virt(newattrib); 00669 } 00670 } 00671 } 00672 00673 00674 for (CompositeAttrib* ptr = listHead; ptr; ptr = ptr->next) 00675 list.append(ptr->csa()); 00676 } 00677 00678 //------------------------------------------------------------------------- 00679 // Purpose : Get named attributes 00680 // 00681 // Special Notes : 00682 // 00683 // Creator : Jason Kraftcheck 00684 // 00685 // Creation Date : 03/03/03 00686 //------------------------------------------------------------------------- 00687 void CompositeGeom::get_attributes( const char* name, 00688 DLIList<CubitSimpleAttrib>& list ) 00689 { 00690 if (entityList.size() == 1) 00691 { 00692 // handle 8.1 attribs on single-entity 'composites' 00693 list.clean_out(); 00694 entityList[0].entity->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00695 while (list.size()) 00696 { 00697 CubitSimpleAttrib attrib = list.pop(); 00698 if (attrib.int_data_list()[0] == 1) 00699 { 00700 entityList[0].entity->remove_simple_attribute_virt(attrib); 00701 std::vector<CubitString> s(attrib.string_data_list().begin()+1, attrib.string_data_list().end()); 00702 std::vector<int> i(attrib.int_data_list().begin()+1, attrib.int_data_list().end()); 00703 CubitSimpleAttrib new_attrib(&s, &attrib.double_data_list(), &i); 00704 entityList[0].entity->append_simple_attribute_virt(new_attrib); 00705 } 00706 } 00707 00708 entityList[0].entity->get_simple_attribute(name, list); 00709 } 00710 00711 for (CompositeAttrib* ptr = listHead; ptr; ptr = ptr->next) 00712 if (ptr->name() == name) 00713 list.append(ptr->csa()); 00714 } 00715 00716 //------------------------------------------------------------------------- 00717 // Purpose : Write info about object for debugging 00718 // 00719 // Special Notes : 00720 // 00721 // Creator : Jason Kraftcheck 00722 // 00723 // Creation Date : 00724 //------------------------------------------------------------------------- 00725 void CompositeGeom::print_debug_info( const char* line_prefix ) 00726 { 00727 if( needToUpdateBbox ) 00728 update_data_bbox(); 00729 if( needToUpdateMeasure ) 00730 update_data_measure(); 00731 if( line_prefix == 0 ) 00732 line_prefix = ""; 00733 00734 PRINT_INFO("%sCompositeGeom @ %p : \n", line_prefix, (void*)this ); 00735 for( int i = 0; i < entityList.size(); i++ ) 00736 { 00737 GeometryEntity* ptr = entityList[i].entity; 00738 #ifdef TOPOLOGY_BRIDGE_IDS 00739 PRINT_INFO("%s %15s %d %7s\n", line_prefix, 00740 ptr ? fix_type_name(typeid(*ptr).name()) : "GeometryEntity", 00741 ptr ? ptr->get_id() : 0, 00742 entityList[i].sense == CUBIT_FORWARD ? "Forward" : 00743 entityList[i].sense == CUBIT_REVERSED ? "Reverse" : 00744 "Unknown"); 00745 #else 00746 /* 00747 PRINT_INFO("%s %15s %p %7s\n", line_prefix, 00748 ptr ? fix_type_name(typeid(*ptr).name()) : "GeometryEntity", 00749 ptr, 00750 entityList[i].sense == CUBIT_FORWARD ? "Forward" : 00751 entityList[i].sense == CUBIT_REVERSED ? "Reverse" : 00752 "Unknown"); 00753 */ 00754 PRINT_INFO("%s %15s %d %7s\n", line_prefix, 00755 ptr ? fix_type_name(typeid(*ptr).name()) : "GeometryEntity", 00756 ptr ? ptr->get_saved_id() : 0, 00757 entityList[i].sense == CUBIT_FORWARD ? "Forward" : 00758 entityList[i].sense == CUBIT_REVERSED ? "Reverse" : 00759 "Unknown"); 00760 00761 #endif 00762 } 00763 } 00764 00765 //------------------------------------------------------------------------- 00766 // Purpose : Reverse geometric sense of composite 00767 // 00768 // Special Notes : 00769 // 00770 // Creator : Jason Kraftcheck 00771 // 00772 // Creation Date : 00773 //------------------------------------------------------------------------- 00774 void CompositeGeom::reverse_sense( int index ) 00775 { 00776 assert(index < entityList.size() ); 00777 CubitSense old = entityList[index].sense; 00778 entityList[index].sense = (old == CUBIT_REVERSED) ? CUBIT_FORWARD : CUBIT_REVERSED; 00779 } 00780 00781 //------------------------------------------------------------------------- 00782 // Purpose : Read and remove attributes from underlying entities 00783 // 00784 // Special Notes : 00785 // 00786 // Creator : Jason Kraftcheck 00787 // 00788 // Creation Date : 06/30/03 00789 //------------------------------------------------------------------------- 00790 void CompositeGeom::read_attributes( GeometryEntity* geom_ptr ) 00791 { 00792 DLIList<CubitSimpleAttrib> list; 00793 int i; 00794 00795 // remove any attributes from previous read 00796 rem_all_attributes(); 00797 00798 if (geom_ptr) 00799 { 00800 // Special case for point-curves (no real curves to write 00801 // attirbutes to.) Write to passed entity instead. 00802 assert(entityList.size() == 0); 00803 geom_ptr->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00804 00805 list.reset(); 00806 for (i = list.size(); i--; ) 00807 { 00808 const CubitSimpleAttrib& attrib = list.get_and_step(); 00809 assert(attrib.int_data_list().size()); 00810 if (attrib.int_data_list()[0] == entityList.size()) 00811 { 00812 geom_ptr->remove_simple_attribute_virt(attrib); 00813 CubitSimpleAttrib c = attrib; 00814 c.int_data_list().erase(c.int_data_list().begin()); 00815 c.string_data_list().erase(c.string_data_list().begin()); 00816 listHead = new CompositeAttrib(c,listHead); 00817 } 00818 } 00819 00820 return; 00821 } 00822 00823 for (i = 0; i < entityList.size(); i++) 00824 { 00825 list.clean_out(); 00826 entityList[i].entity->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00827 00828 list.reset(); 00829 for (int j = list.size(); j--; ) 00830 { 00831 const CubitSimpleAttrib& attrib = list.get_and_step(); 00832 assert(attrib.int_data_list().size()); 00833 if (attrib.int_data_list()[0] == entityList.size()) 00834 { 00835 // Take the attributes off of the current entity and put them on the first entity 00836 // in this list. I believe this is ok to do because the attributes should apply to 00837 // the whole composite surface and not just the underlying entity they are on 00838 // (the one exception to this might be UNIQUE_ID but I haven't seen any problems 00839 // with this yet). The reason for doing this is that there is some code (I believe 00840 // in uncomposite() that assumes any attributes will be on the first entity 00841 // in the list. Previous code actually moved the entity to the beginning 00842 // of the list but this reordering of the list does not fly with composite 00843 // curves because there is code depending on the curves in the list being 00844 // ordered so that they connect end to end in a contiguous manner (the 00845 // faceting code, for one, relies on this). BWC 1/7/07. 00846 entityList[i].entity->remove_simple_attribute_virt(attrib); 00847 entityList[0].entity->append_simple_attribute_virt(attrib); 00848 00849 CubitSimpleAttrib c = attrib; 00850 c.int_data_list().erase(c.int_data_list().begin()); 00851 c.string_data_list().erase(c.string_data_list().begin()); 00852 00853 if( NULL == listHead ) 00854 listHead = new CompositeAttrib(c,listHead); 00855 else //this assures that we are not adding duplicate attribs 00856 { 00857 bool is_duplicate = false; 00858 00859 CompositeAttrib* curr_attrib = listHead; 00860 00861 while( curr_attrib ) 00862 { 00863 if( curr_attrib->equals( c ) ) 00864 { 00865 is_duplicate = true; 00866 break; 00867 } 00868 curr_attrib = curr_attrib->next; 00869 } 00870 00871 if( false == is_duplicate ) 00872 listHead = new CompositeAttrib(c,listHead); 00873 } 00874 } 00875 } 00876 } 00877 } 00878 00879 //------------------------------------------------------------------------- 00880 // Purpose : Save attributes on first underlying entity 00881 // 00882 // Special Notes : 00883 // 00884 // Creator : Jason Kraftcheck 00885 // 00886 // Creation Date : 06/30/03 00887 //------------------------------------------------------------------------- 00888 void CompositeGeom::write_attributes( GeometryEntity* geom_ptr ) 00889 { 00890 DLIList<CubitSimpleAttrib> list; 00891 00892 if (geom_ptr) 00893 { 00894 // Special case for point-curves (no real curves to write 00895 // attirbutes to.) Write to passed entity instead. 00896 assert(entityList.size() == 0); 00897 00898 // clean up any attributes from the previous write 00899 geom_ptr->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00900 while (list.size()) 00901 { 00902 CubitSimpleAttrib csa = list.pop(); 00903 geom_ptr->remove_simple_attribute_virt(csa); 00904 } 00905 } 00906 else 00907 { 00908 geom_ptr = entityList[0].entity; 00909 00910 // clean up any attributes from the previous write 00911 for (int i = 0; i < entityList.size(); i++) 00912 { 00913 entityList[i].entity->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00914 while (list.size()) 00915 { 00916 CubitSimpleAttrib csa = list.pop(); 00917 entityList[i].entity->remove_simple_attribute_virt(csa); 00918 } 00919 } 00920 } 00921 00922 00923 CubitString name = COMPOSITE_DATA_ATTRIB_NAME; 00924 int count = entityList.size(); 00925 CubitSimpleAttrib attrib; 00926 00927 for (CompositeAttrib* ptr = listHead; ptr; ptr = ptr->next) 00928 { 00929 attrib.string_data_list().push_back(name); 00930 attrib.int_data_list().push_back(count); 00931 00932 ptr->append_to_csa(attrib); 00933 00934 //append the name attribute on all the rest of the entities too. This 00935 //is so that if a one gets split, the results each get the name as well: 00936 //jack --> jack and jack@A 00937 if( ptr->name() == "ENTITY_NAME" ) 00938 { 00939 for( int k=1; k<entityList.size(); k++ ) 00940 entityList[k].entity->append_simple_attribute_virt( attrib ); 00941 } 00942 00943 geom_ptr->append_simple_attribute_virt(attrib); 00944 00945 attrib.string_data_list().clear(); 00946 attrib.int_data_list().clear(); 00947 attrib.double_data_list().clear(); 00948 } 00949 } 00950 00951 //------------------------------------------------------------------------- 00952 // Purpose : Clean out composite attributes. 00953 // 00954 // Special Notes : 00955 // 00956 // Creator : Jason Kraftcheck 00957 // 00958 // Creation Date : 07/01/03 00959 //------------------------------------------------------------------------- 00960 void CompositeGeom::clean_up_attribs( GeometryEntity* ent ) 00961 { 00962 DLIList<CubitSimpleAttrib> list; 00963 ent->get_simple_attribute(COMPOSITE_DATA_ATTRIB_NAME,list); 00964 while (list.size()) 00965 { 00966 CubitSimpleAttrib csa = list.pop(); 00967 ent->remove_simple_attribute_virt(csa); 00968 } 00969 }
