cgma
00001 /******************************************************************************* 00002 COPYRIGHT 2002 CATERPILLAR INC. ALL RIGHTS RESERVED 00003 00004 This program is the property of Caterpillar Inc., includes Caterpillar's 00005 confidential and trade secret information, and is maintained as an 00006 unpublished copyrighted work. It is not to be copied or used by others 00007 except under license from Caterpillar. This program is also protected as an 00008 unpublished work in accordance with the copyright act of 1976. In the event 00009 of either inadvertent or deliberate publication, Caterpillar Inc. intends to 00010 maintain copyright protection for this work under the relevant copyright 00011 laws pertaining to published works. The inclusion of a copyright notice 00012 hereon is precautionary only, and does not imply publication or disclosure. 00013 00014 00015 Filename : CubitFileFEModel.cpp 00016 00017 Purpose : Implements the reading and writing functionality for a FE 00018 model section of a Cubit (*.cub) format file. 00019 00020 Special Notes : 00021 00022 Creator : Will A. Helden 00023 00024 Creation Date : 02/15/02 00025 00026 Owner : Will A. Helden 00027 00028 *******************************************************************************/ 00029 00030 #include "CubitFileFEModel.hpp" 00031 #include "CubitFileIOWrapper.hpp" 00032 00033 using namespace NCubitFile; 00034 00036 // CFEModel 00038 00039 // The number of 32 bit words contained int each of the stored structures. 00040 const UnsignedInt32 CFEModel::mintSizeOfFEModelHeader = 00041 sizeof(SCubitFileFEModelHeader) / sizeof(UnsignedInt32); 00042 const UnsignedInt32 CFEModel::mintSizeOfGeomEntry = 00043 sizeof(SCubitFileGeomEntry) / sizeof(UnsignedInt32); 00044 const UnsignedInt32 CFEModel::mintSizeOfGroupEntry = 00045 sizeof(SCubitFileGroupEntry) / sizeof(UnsignedInt32); 00046 const UnsignedInt32 CFEModel::mintSizeOfBlockEntry = 00047 sizeof(SCubitFileBlockEntry) / sizeof(UnsignedInt32); 00048 const UnsignedInt32 CFEModel::mintSizeOfNodeSetEntry = 00049 sizeof(SCubitFileNodeSetEntry) / sizeof(UnsignedInt32); 00050 const UnsignedInt32 CFEModel::mintSizeOfSideSetEntry = 00051 sizeof(SCubitFileSideSetEntry) / sizeof(UnsignedInt32); 00052 00053 CFEModel::CFEModel() 00054 { 00055 mpReadFile = mpWriteFile = NULL; 00056 mpaGeoms = NULL; 00057 mpaGroups = NULL; 00058 mpaBlocks = NULL; 00059 mpaNodeSets = NULL; 00060 mpaSideSets = NULL; 00061 00062 mintFEModelOffset = 0; 00063 memset(&mFEModel, 0, sizeof(SCubitFileFEModelHeader)); 00064 mFEModel.mintFEModelEndian = CCubitFile::mintNativeEndian; 00065 00066 // Initialize the return buffers for file data - all memory allocated by 00067 // this object should also be freed up by it. 00068 memset(&mNodeBuff, 0, sizeof(SNodeReturnBuffer)); 00069 memset(&mElemBuff, 0, sizeof(SElemReturnBuffer)); 00070 memset(&mGroupBuff, 0, sizeof(SGroupReturnBuffer)); 00071 memset(&mBlockBuff, 0, sizeof(SBlockReturnBuffer)); 00072 memset(&mNodeSetBuff, 0, sizeof(SNodeSetReturnBuffer)); 00073 memset(&mSideSetBuff_10, 0, sizeof(SSideSetReturnBuffer_10)); 00074 memset(&mSideSetBuff_11, 0, sizeof(SSideSetReturnBuffer_11)); 00075 } 00076 00077 CFEModel::~CFEModel() 00078 { 00079 if(mpaGeoms) 00080 delete [] mpaGeoms; 00081 if(mpaGroups) 00082 delete [] mpaGroups; 00083 if(mpaBlocks) 00084 delete [] mpaBlocks; 00085 if(mpaNodeSets) 00086 delete [] mpaNodeSets; 00087 if(mpaSideSets) 00088 delete [] mpaSideSets; 00089 00090 if(mNodeBuff.mpaNodeIDs) 00091 delete [] mNodeBuff.mpaNodeIDs; 00092 if(mNodeBuff.mpadblX) 00093 delete [] mNodeBuff.mpadblX; 00094 if(mNodeBuff.mpadblY) 00095 delete [] mNodeBuff.mpadblY; 00096 if(mNodeBuff.mpadblZ) 00097 delete [] mNodeBuff.mpadblZ; 00098 if(mElemBuff.mpaElemData) 00099 delete [] mElemBuff.mpaElemData; 00100 if(mElemBuff.mpaElemIDs) 00101 delete [] mElemBuff.mpaElemIDs; 00102 if(mElemBuff.mpaElemGlobalIDs) 00103 delete [] mElemBuff.mpaElemGlobalIDs; 00104 if(mElemBuff.mpaElemConnect) 00105 delete [] mElemBuff.mpaElemConnect; 00106 if(mGroupBuff.mpaGroupData) 00107 delete [] mGroupBuff.mpaGroupData; 00108 if(mGroupBuff.mpaintMemberIDs) 00109 delete [] mGroupBuff.mpaintMemberIDs; 00110 if(mBlockBuff.mpaBlockData) 00111 delete [] mBlockBuff.mpaBlockData; 00112 if(mBlockBuff.mpaintMemberIDs) 00113 delete [] mBlockBuff.mpaintMemberIDs; 00114 if(mBlockBuff.mpadblAttributes) 00115 delete [] mBlockBuff.mpadblAttributes; 00116 if(mNodeSetBuff.mpaNodeSetData) 00117 delete [] mNodeSetBuff.mpaNodeSetData; 00118 if(mNodeSetBuff.mpaintMemberIDs) 00119 delete [] mNodeSetBuff.mpaintMemberIDs; 00120 00121 if(mSideSetBuff_10.mpaSideSetData) 00122 delete [] mSideSetBuff_10.mpaSideSetData; 00123 if(mSideSetBuff_10.mpaintMemberIDs) 00124 delete [] mSideSetBuff_10.mpaintMemberIDs; 00125 if(mSideSetBuff_10.mpachrMemberSense) 00126 delete [] mSideSetBuff_10.mpachrMemberSense; 00127 if(mSideSetBuff_10.mpaintMemberSense) 00128 delete [] mSideSetBuff_10.mpaintMemberSense; 00129 if(mSideSetBuff_10.mpachrMemberSideNum) 00130 delete [] mSideSetBuff_10.mpachrMemberSideNum; 00131 if(mSideSetBuff_10.mpadblDistribution) 00132 delete [] mSideSetBuff_10.mpadblDistribution; 00133 00134 if(mSideSetBuff_11.mpaSideSetData) 00135 delete [] mSideSetBuff_11.mpaSideSetData; 00136 if(mSideSetBuff_11.mpaintMemberTypes) 00137 delete [] mSideSetBuff_11.mpaintMemberTypes; 00138 if(mSideSetBuff_11.mpaintMemberIDs) 00139 delete [] mSideSetBuff_11.mpaintMemberIDs; 00140 if(mSideSetBuff_11.mpachrMemberSense) 00141 delete [] mSideSetBuff_11.mpachrMemberSense; 00142 if(mSideSetBuff_11.mpaintMemberWRTEntities) 00143 delete [] mSideSetBuff_11.mpaintMemberWRTEntities; 00144 if(mSideSetBuff_11.mpadblDistribution) 00145 delete [] mSideSetBuff_11.mpadblDistribution; 00146 } 00147 00148 00150 // Write Functions 00152 00153 UnsignedInt32 CFEModel::InitWrite(FILE* xpFile, 00154 UnsignedInt32 xintGeomCount, 00155 UnsignedInt32 xintGroupCount, 00156 UnsignedInt32 xintBlockCount, 00157 UnsignedInt32 xintNodeSetCount, 00158 UnsignedInt32 xintSideSetCount) 00159 { 00160 if(mpWriteFile) throw CCubitFile::eFileWriteError; 00161 00162 mpWriteFile = xpFile; 00163 CIOWrapper lIO(mpWriteFile); 00164 00165 // Write out the FE model header to reserve its position and size in the 00166 // file. 00167 mintFEModelOffset = lIO.BeginWriteBlock(); 00168 lIO.Write((UnsignedInt32*)&mFEModel, mintSizeOfFEModelHeader); 00169 mFEModel.mintFEModelLength = lIO.EndWriteBlock(); 00170 00171 mFEModel.mintGeometryCount = xintGeomCount; 00172 if(xintGeomCount) { 00173 // Create a geometry entity array for storing ownership statistics and 00174 // initially blank it. 00175 mpaGeoms = new SCubitFileGeomEntry[xintGeomCount]; 00176 memset(mpaGeoms, 0, sizeof(SCubitFileGeomEntry) * xintGeomCount); 00177 00178 // Write the blank geometry table to the file to reserve its position 00179 // and size in the file. 00180 mFEModel.mintGeomTableOffset = lIO.BeginWriteBlock(mintFEModelOffset); 00181 lIO.Write((UnsignedInt32*)mpaGeoms, 00182 xintGeomCount * mintSizeOfGeomEntry); 00183 mFEModel.mintFEModelLength += lIO.EndWriteBlock(); 00184 } 00185 00186 mFEModel.mintGroupCount = xintGroupCount; 00187 if(xintGroupCount) { 00188 // Create a group array for storing ownership statistics and 00189 // initially blank it. 00190 mpaGroups = new SCubitFileGroupEntry[xintGroupCount]; 00191 memset(mpaGroups, 0, sizeof(SCubitFileGroupEntry) * xintGroupCount); 00192 00193 // Write the blank group table to the file to reserve its position 00194 // and size in the file. 00195 mFEModel.mintGroupTableOffset = lIO.BeginWriteBlock(mintFEModelOffset); 00196 lIO.Write((UnsignedInt32*)mpaGroups, 00197 xintGroupCount * mintSizeOfGroupEntry); 00198 mFEModel.mintFEModelLength += lIO.EndWriteBlock(); 00199 } 00200 00201 mFEModel.mintBlockCount = xintBlockCount; 00202 if(xintBlockCount) { 00203 // Create a block array for storing ownership statistics and 00204 // initially blank it. 00205 mpaBlocks = new SCubitFileBlockEntry[xintBlockCount]; 00206 memset(mpaBlocks, 0, sizeof(SCubitFileBlockEntry) * xintBlockCount); 00207 00208 // Write the blank block table to the file to reserve its position 00209 // and size in the file. 00210 mFEModel.mintBlockTableOffset = lIO.BeginWriteBlock(mintFEModelOffset); 00211 lIO.Write((UnsignedInt32*)mpaBlocks, 00212 xintBlockCount * mintSizeOfBlockEntry); 00213 mFEModel.mintFEModelLength += lIO.EndWriteBlock(); 00214 } 00215 00216 mFEModel.mintNodeSetCount = xintNodeSetCount; 00217 if(xintNodeSetCount) { 00218 // Create a node set array for storing ownership statistics and 00219 // initially blank it. 00220 mpaNodeSets = new SCubitFileNodeSetEntry[xintNodeSetCount]; 00221 memset(mpaNodeSets, 0, sizeof(SCubitFileNodeSetEntry) * xintNodeSetCount); 00222 00223 // Write the blank geometry table to the file to reserve its position 00224 // and size in the file. 00225 mFEModel.mintNodeSetTableOffset = lIO.BeginWriteBlock(mintFEModelOffset); 00226 lIO.Write((UnsignedInt32*)mpaNodeSets, 00227 xintNodeSetCount * mintSizeOfNodeSetEntry); 00228 mFEModel.mintFEModelLength += lIO.EndWriteBlock(); 00229 } 00230 00231 mFEModel.mintSideSetCount = xintSideSetCount; 00232 if(xintSideSetCount) { 00233 // Create a SideSet array for storing ownership statistics and 00234 // initially blank it. 00235 mpaSideSets = new SCubitFileSideSetEntry[xintSideSetCount]; 00236 memset(mpaSideSets, 0, sizeof(SCubitFileSideSetEntry) * xintSideSetCount); 00237 00238 // Write the blank geometry table to the file to reserve its position 00239 // and size in the file. 00240 mFEModel.mintSideSetTableOffset = lIO.BeginWriteBlock(mintFEModelOffset); 00241 lIO.Write((UnsignedInt32*)mpaSideSets, 00242 xintSideSetCount * mintSizeOfSideSetEntry); 00243 mFEModel.mintFEModelLength += lIO.EndWriteBlock(); 00244 } 00245 00246 return mintFEModelOffset; 00247 } 00248 00249 void CFEModel::WriteNodes(UnsignedInt32 xintIndex, 00250 UnsignedInt32 xintGeomID, 00251 UnsignedInt32 xintNodeCount, 00252 UnsignedInt32 *xpaintNodeIDs, 00253 double *xpadblX, double *xpadblY, double *xpadblZ) 00254 { 00255 if(!mpWriteFile) 00256 throw CCubitFile::eFileWriteError; 00257 if(xintIndex >= mFEModel.mintGeometryCount) 00258 throw CCubitFile::eNotFound; 00259 if(!mpaGeoms) 00260 throw CCubitFile::eOrderError; 00261 if(mpaGeoms[xintIndex].mintNodeCount) 00262 throw CCubitFile::eDuplicateWrite; 00263 00264 mpaGeoms[xintIndex].mintGeomID = xintGeomID; 00265 00266 if(xintNodeCount) { 00267 if(!xpaintNodeIDs || !xpadblX || !xpadblY || !xpadblZ) 00268 throw CCubitFile::ePassedNullPointer; 00269 00270 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00271 00272 mpaGeoms[xintIndex].mintNodeCount = xintNodeCount; 00273 mpaGeoms[xintIndex].mintNodeOffset = 00274 lpIO->BeginWriteBlock(mintFEModelOffset); 00275 00276 lpIO->Write(xpaintNodeIDs, xintNodeCount); 00277 lpIO->Write(xpadblX, xintNodeCount); 00278 lpIO->Write(xpadblY, xintNodeCount); 00279 lpIO->Write(xpadblZ, xintNodeCount); 00280 00281 mFEModel.mintFEModelLength += lpIO->EndWriteBlock(); 00282 00283 delete lpIO; 00284 } 00285 } 00286 00287 void CFEModel::WriteElems(UnsignedInt32 xintIndex, 00288 UnsignedInt32 xintNumTypes, SElemData* xpaElemData) 00289 { 00290 if(!mpWriteFile) 00291 throw CCubitFile::eFileWriteError; 00292 if(xintIndex >= mFEModel.mintGeometryCount) 00293 throw CCubitFile::eNotFound; 00294 if(!mpaGeoms) 00295 throw CCubitFile::eOrderError; 00296 if(mpaGeoms[xintIndex].mintElemTypeCount) 00297 throw CCubitFile::eDuplicateWrite; 00298 00299 if(xintNumTypes) { 00300 if(!xpaElemData) 00301 throw CCubitFile::ePassedNullPointer; 00302 UnsignedInt32 lintElem; 00303 for(lintElem = 0; lintElem < xintNumTypes; lintElem++) { 00304 if(xpaElemData[lintElem].mintElemCount) { 00305 if(!xpaElemData[lintElem].mpaElemIDs) 00306 throw CCubitFile::ePassedNullPointer; 00307 if(!xpaElemData[lintElem].mpaElemGlobalIDs) 00308 throw CCubitFile::ePassedNullPointer; 00309 if(xpaElemData[lintElem].mintElemOrder) 00310 if(!xpaElemData[lintElem].mpaElemConnect) 00311 throw CCubitFile::ePassedNullPointer; 00312 } 00313 } 00314 00315 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00316 mpaGeoms[xintIndex].mintElemTypeCount = xintNumTypes; 00317 mpaGeoms[xintIndex].mintElemOffset = 00318 lpIO->BeginWriteBlock(mintFEModelOffset); 00319 00320 for(lintElem = 0; lintElem < xintNumTypes; lintElem++) { 00321 if(!xpaElemData[lintElem].mintElemCount) { 00322 mpaGeoms[xintIndex].mintElemTypeCount--; 00323 continue; 00324 } 00325 mpaGeoms[xintIndex].mintElemCount += 00326 xpaElemData[lintElem].mintElemCount; 00327 00328 lpIO->Write(&xpaElemData[lintElem].mintElemType, 1); 00329 lpIO->Write(&xpaElemData[lintElem].mintElemOrder, 1); 00330 lpIO->Write(&xpaElemData[lintElem].mintElemCount, 1); 00331 lpIO->Write(xpaElemData[lintElem].mpaElemIDs, 00332 xpaElemData[lintElem].mintElemCount); 00333 lpIO->Write(xpaElemData[lintElem].mpaElemGlobalIDs, 00334 xpaElemData[lintElem].mintElemCount); 00335 if(xpaElemData[lintElem].mintElemOrder) { 00336 lpIO->Write(xpaElemData[lintElem].mpaElemConnect, 00337 xpaElemData[lintElem].mintElemCount * 00338 xpaElemData[lintElem].mintElemOrder); 00339 } 00340 } 00341 00342 mpaGeoms[xintIndex].mintElemLength = lpIO->EndWriteBlock(); 00343 mFEModel.mintFEModelLength += mpaGeoms[xintIndex].mintElemLength; 00344 delete lpIO; 00345 } 00346 } 00347 00348 void CFEModel::WriteGroup(UnsignedInt32 xintIndex, 00349 UnsignedInt32 xintGroupID, 00350 UnsignedInt32 xintGroupType, 00351 const char* xpachrGroupName, 00352 UnsignedInt32 xintNumTypes, 00353 SGroupData* xpaGroupData) 00354 { 00355 if(!mpWriteFile) 00356 throw CCubitFile::eFileWriteError; 00357 if(xintIndex >= mFEModel.mintGroupCount) 00358 throw CCubitFile::eNotFound; 00359 if(!mpaGroups) 00360 throw CCubitFile::eOrderError; 00361 if(mpaGroups[xintIndex].mintMemberTypeCount) 00362 throw CCubitFile::eDuplicateWrite; 00363 00364 if(xintNumTypes) { 00365 // An empty group is valid, but an incompletely defined one is not. 00366 if(!xpaGroupData) 00367 throw CCubitFile::ePassedNullPointer; 00368 for(UnsignedInt32 lintGroup = 0; lintGroup < xintNumTypes; lintGroup++) { 00369 if(xpaGroupData[lintGroup].mintMemberCount && 00370 !xpaGroupData[lintGroup].mpaMemberIDs) 00371 throw CCubitFile::ePassedNullPointer; 00372 } 00373 } 00374 00375 mpaGroups[xintIndex].mintGroupID = xintGroupID; 00376 mpaGroups[xintIndex].mintGroupType = xintGroupType; 00377 mpaGroups[xintIndex].mintMemberTypeCount = xintNumTypes; 00378 if(mGroupMetaData.SetValue(xintGroupID, "NAME", xpachrGroupName) != 00379 CCubitFile::eSuccess) 00380 throw CCubitFile::eFileWriteError; 00381 00382 if(xintNumTypes) { 00383 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00384 mpaGroups[xintIndex].mintMemberOffset = 00385 lpIO->BeginWriteBlock(mintFEModelOffset); 00386 00387 for(UnsignedInt32 lintGroup = 0; lintGroup < xintNumTypes; lintGroup++) { 00388 if(!xpaGroupData[lintGroup].mintMemberCount) { 00389 mpaGroups[xintIndex].mintMemberTypeCount--; 00390 continue; 00391 } 00392 mpaGroups[xintIndex].mintMemberCount += 00393 xpaGroupData[lintGroup].mintMemberCount; 00394 00395 lpIO->Write(&xpaGroupData[lintGroup].mintMemberType, 1); 00396 lpIO->Write(&xpaGroupData[lintGroup].mintMemberCount, 1); 00397 lpIO->Write(xpaGroupData[lintGroup].mpaMemberIDs, 00398 xpaGroupData[lintGroup].mintMemberCount); 00399 } 00400 00401 mpaGroups[xintIndex].mintGroupLength = lpIO->EndWriteBlock(); 00402 mFEModel.mintFEModelLength += mpaGroups[xintIndex].mintGroupLength; 00403 delete lpIO; 00404 } 00405 else { 00406 // An empty group does not have a data block in the file. 00407 mpaGroups[xintIndex].mintMemberOffset = 0; 00408 mpaGroups[xintIndex].mintGroupLength = 0; 00409 } 00410 } 00411 00412 void CFEModel::WriteBlock(UnsignedInt32 xintIndex, 00413 UnsignedInt32 xintBlockID, 00414 int unique_id, 00415 UnsignedInt32 xintBlockType, 00416 UnsignedInt32 xintBlockColor, 00417 UnsignedInt32 xintMixedElemType, 00418 UnsignedInt32 xintDefPyramidType, 00419 UnsignedInt32 xintMaterialID, 00420 UnsignedInt32 xintBlockDimension, 00421 UnsignedInt32 xintNumTypes, 00422 SBlockData* xpaBlockData, 00423 UnsignedInt32 xintAttributeOrder, 00424 double* xpadblAttributes) 00425 { 00426 if(!mpWriteFile) 00427 throw CCubitFile::eFileWriteError; 00428 if(xintIndex >= mFEModel.mintBlockCount) 00429 throw CCubitFile::eNotFound; 00430 if(!mpaBlocks) 00431 throw CCubitFile::eOrderError; 00432 if(mpaBlocks[xintIndex].mintMemberTypeCount) 00433 throw CCubitFile::eDuplicateWrite; 00434 00435 UnsignedInt32 lintBlock; 00436 if(xintNumTypes) { 00437 // An empty block is valid, but an incompletely defined one is not. 00438 if(!xpaBlockData) 00439 throw CCubitFile::ePassedNullPointer; 00440 for(lintBlock = 0; lintBlock < xintNumTypes; lintBlock++) { 00441 if(xpaBlockData[lintBlock].mintMemberCount && 00442 !xpaBlockData[lintBlock].mpaMemberIDs) 00443 throw CCubitFile::ePassedNullPointer; 00444 } 00445 } 00446 00447 if(xintAttributeOrder) { 00448 if(!xpadblAttributes) 00449 throw CCubitFile::ePassedNullPointer; 00450 } 00451 00452 mpaBlocks[xintIndex].mintBlockID = xintBlockID; 00453 mpaBlocks[xintIndex].mintBlockElementType = xintBlockType; 00454 mpaBlocks[xintIndex].mintMemberTypeCount = xintNumTypes; 00455 mpaBlocks[xintIndex].mintBlockColor = xintBlockColor; 00456 mpaBlocks[xintIndex].mintBlockMixedElemType = xintMixedElemType; 00457 mpaBlocks[xintIndex].mintBlockDefPyramidType = xintDefPyramidType; 00458 mpaBlocks[xintIndex].mintBlockMaterial = xintMaterialID; 00459 mpaBlocks[xintIndex].mintBlockDimension = xintBlockDimension; 00460 mpaBlocks[xintIndex].mintAttributeOrder = xintAttributeOrder; 00461 00462 00463 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00464 mpaBlocks[xintIndex].mintMemberOffset = 00465 lpIO->BeginWriteBlock(mintFEModelOffset); 00466 00467 for(lintBlock = 0; lintBlock < xintNumTypes; lintBlock++) { 00468 if(!xpaBlockData[lintBlock].mintMemberCount) { 00469 mpaBlocks[xintIndex].mintMemberTypeCount--; 00470 continue; 00471 } 00472 mpaBlocks[xintIndex].mintMemberCount += 00473 xpaBlockData[lintBlock].mintMemberCount; 00474 00475 lpIO->Write(&xpaBlockData[lintBlock].mintMemberType, 1); 00476 lpIO->Write(&xpaBlockData[lintBlock].mintMemberCount, 1); 00477 lpIO->Write(xpaBlockData[lintBlock].mpaMemberIDs, 00478 xpaBlockData[lintBlock].mintMemberCount); 00479 } 00480 if(xintAttributeOrder) 00481 lpIO->Write(xpadblAttributes, xintAttributeOrder); 00482 00483 lpIO->Write("id", 2); 00484 lpIO->Write(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 00485 00486 mpaBlocks[xintIndex].mintBlockLength = lpIO->EndWriteBlock(); 00487 mFEModel.mintFEModelLength += mpaBlocks[xintIndex].mintBlockLength; 00488 delete lpIO; 00489 } 00490 00491 void CFEModel::WriteNodeSet(UnsignedInt32 xintIndex, 00492 UnsignedInt32 xintNodeSetID, 00493 int unique_id, 00494 UnsignedInt32 xintColor, 00495 UnsignedInt32 xintPointSymbol, 00496 UnsignedInt32 xintNumTypes, 00497 SNodeSetData* xpaNodeSetData, 00498 const std::vector<char>& bcdata) 00499 { 00500 if(!mpWriteFile) 00501 throw CCubitFile::eFileWriteError; 00502 if(xintIndex >= mFEModel.mintNodeSetCount) 00503 throw CCubitFile::eNotFound; 00504 if(!mpaNodeSets) 00505 throw CCubitFile::eOrderError; 00506 if(mpaNodeSets[xintIndex].mintMemberTypeCount) 00507 throw CCubitFile::eDuplicateWrite; 00508 00509 UnsignedInt32 lintNodeSet; 00510 if(xintNumTypes) { 00511 // An empty node set is valid, but an incompletely defined one is not. 00512 if(!xpaNodeSetData) 00513 throw CCubitFile::ePassedNullPointer; 00514 for(lintNodeSet = 0; lintNodeSet < xintNumTypes; lintNodeSet++) { 00515 if(xpaNodeSetData[lintNodeSet].mintMemberCount && 00516 !xpaNodeSetData[lintNodeSet].mpaMemberIDs) 00517 throw CCubitFile::ePassedNullPointer; 00518 } 00519 } 00520 00521 mpaNodeSets[xintIndex].mintNodeSetID = xintNodeSetID; 00522 mpaNodeSets[xintIndex].mintMemberTypeCount = xintNumTypes; 00523 mpaNodeSets[xintIndex].mintNodeSetPointSym = xintPointSymbol; 00524 mpaNodeSets[xintIndex].mintNodeSetColor = xintColor; 00525 00526 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00527 mpaNodeSets[xintIndex].mintMemberOffset = 00528 lpIO->BeginWriteBlock(mintFEModelOffset); 00529 00530 for(lintNodeSet = 0; lintNodeSet < xintNumTypes; lintNodeSet++) { 00531 if(!xpaNodeSetData[lintNodeSet].mintMemberCount) { 00532 mpaNodeSets[xintIndex].mintMemberTypeCount--; 00533 continue; 00534 } 00535 mpaNodeSets[xintIndex].mintMemberCount += 00536 xpaNodeSetData[lintNodeSet].mintMemberCount; 00537 00538 lpIO->Write(&xpaNodeSetData[lintNodeSet].mintMemberType, 1); 00539 lpIO->Write(&xpaNodeSetData[lintNodeSet].mintMemberCount, 1); 00540 lpIO->Write(xpaNodeSetData[lintNodeSet].mpaMemberIDs, 00541 xpaNodeSetData[lintNodeSet].mintMemberCount); 00542 } 00543 00544 UnsignedInt32 size = bcdata.size(); 00545 if(size) 00546 { 00547 lpIO->Write("bc", 2); 00548 lpIO->Write(&size, 1); 00549 lpIO->Write(&bcdata[0], size); 00550 } 00551 00552 lpIO->Write("id", 2); 00553 lpIO->Write(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 00554 00555 mpaNodeSets[xintIndex].mintNodeSetLength = lpIO->EndWriteBlock(); 00556 mFEModel.mintFEModelLength += mpaNodeSets[xintIndex].mintNodeSetLength; 00557 delete lpIO; 00558 } 00559 00560 void CFEModel::WriteSideSet_11(UnsignedInt32 xintIndex, 00561 UnsignedInt32 xintSideSetID, 00562 int unique_id, 00563 UnsignedInt32 xintColor, 00564 UnsignedInt32 xintUseShells, 00565 UnsignedInt32 xintNumTypes, 00566 SSideSetData_11* xpaSideSetData, 00567 UnsignedInt32 xintNumDistFact, 00568 double* xpadblDistribution, 00569 const std::vector<char>& bcdata) 00570 { 00571 if(!mpWriteFile) 00572 throw CCubitFile::eFileWriteError; 00573 if(xintIndex >= mFEModel.mintSideSetCount) 00574 throw CCubitFile::eNotFound; 00575 if(!mpaSideSets) 00576 throw CCubitFile::eOrderError; 00577 if(mpaSideSets[xintIndex].mintMemberTypeCount) 00578 throw CCubitFile::eDuplicateWrite; 00579 00580 UnsignedInt32 lintSideSet; 00581 if(xintNumTypes) { 00582 // An empty side set is valid, but an incompletely defined one is not. 00583 if(!xpaSideSetData) 00584 throw CCubitFile::ePassedNullPointer; 00585 for(lintSideSet = 0; lintSideSet < xintNumTypes; lintSideSet++) { 00586 if(xpaSideSetData[lintSideSet].mintMemberCount) { 00587 if(!xpaSideSetData[lintSideSet].mpaintMemberTypes) 00588 throw CCubitFile::ePassedNullPointer; 00589 if(!xpaSideSetData[lintSideSet].mpaintMemberIDs) 00590 throw CCubitFile::ePassedNullPointer; 00591 if(!xpaSideSetData[lintSideSet].mpachrMemberSenses) 00592 throw CCubitFile::ePassedNullPointer; 00593 if(!xpaSideSetData[lintSideSet].mpaintMemberWRTEntities) 00594 throw CCubitFile::ePassedNullPointer; 00595 } 00596 } 00597 } 00598 00599 if(xintNumDistFact) { 00600 if(!xpadblDistribution) 00601 throw CCubitFile::ePassedNullPointer; 00602 } 00603 00604 mpaSideSets[xintIndex].mintSideSetID = xintSideSetID; 00605 mpaSideSets[xintIndex].mintMemberTypeCount = xintNumTypes; 00606 mpaSideSets[xintIndex].mintSideSetColor = xintColor; 00607 mpaSideSets[xintIndex].mintUseShells = xintUseShells; 00608 mpaSideSets[xintIndex].mintNumDistFact = xintNumDistFact; 00609 00610 CIOWrapper* lpIO = new CIOWrapper(mpWriteFile); 00611 mpaSideSets[xintIndex].mintMemberOffset = 00612 lpIO->BeginWriteBlock(mintFEModelOffset); 00613 00614 for(lintSideSet = 0; lintSideSet < xintNumTypes; lintSideSet++) { 00615 if(!xpaSideSetData[lintSideSet].mintMemberCount) { 00616 mpaSideSets[xintIndex].mintMemberTypeCount--; 00617 continue; 00618 } 00619 mpaSideSets[xintIndex].mintMemberCount += 00620 xpaSideSetData[lintSideSet].mintMemberCount; 00621 00622 lpIO->Write(&xpaSideSetData[lintSideSet].mintMemberCount, 1); 00623 lpIO->Write(xpaSideSetData[lintSideSet].mpaintMemberTypes, 00624 xpaSideSetData[lintSideSet].mintMemberCount); 00625 lpIO->Write(xpaSideSetData[lintSideSet].mpaintMemberIDs, 00626 xpaSideSetData[lintSideSet].mintMemberCount); 00627 00628 //for the zero-eth one, mpachrMemberSenses is intMemberCount long 00629 if( 0 == lintSideSet ) 00630 lpIO->Write(xpaSideSetData[lintSideSet].mpachrMemberSenses, 00631 xpaSideSetData[lintSideSet].mintMemberCount, 1); 00632 else //for 1-n, it is 1 long 00633 lpIO->Write(xpaSideSetData[lintSideSet].mpachrMemberSenses, 1, 1); 00634 UnsignedInt32* end = xpaSideSetData[lintSideSet].mpaintMemberWRTEntities; 00635 int i; 00636 for(i=0; i<(int)xpaSideSetData[lintSideSet].mintMemberCount; i++) 00637 { 00638 UnsignedInt32 num_wrt = *end; 00639 end = end + 1 + (num_wrt * 2); 00640 } 00641 UnsignedInt32 wrt_size = static_cast<UnsignedInt32>(end - xpaSideSetData[lintSideSet].mpaintMemberWRTEntities); 00642 lpIO->Write(&wrt_size, 1); 00643 lpIO->Write(xpaSideSetData[lintSideSet].mpaintMemberWRTEntities, wrt_size); 00644 } 00645 if(xintNumDistFact) 00646 lpIO->Write(xpadblDistribution, xintNumDistFact); 00647 00648 UnsignedInt32 size = bcdata.size(); 00649 if(size) 00650 { 00651 lpIO->Write("bc", 2); 00652 lpIO->Write(&size, 1); 00653 lpIO->Write(&bcdata[0], size); 00654 } 00655 00656 lpIO->Write("id", 2); 00657 lpIO->Write(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 00658 00659 mpaSideSets[xintIndex].mintSideSetLength = lpIO->EndWriteBlock(); 00660 mFEModel.mintFEModelLength += mpaSideSets[xintIndex].mintSideSetLength; 00661 delete lpIO; 00662 } 00663 00664 UnsignedInt32 CFEModel::EndWrite() 00665 { 00666 CIOWrapper lIO(mpWriteFile); 00667 00668 if(mFEModel.mintGeometryCount) { 00669 lIO.BeginRewriteBlock(mintFEModelOffset, mFEModel.mintGeomTableOffset); 00670 lIO.Write((UnsignedInt32*)mpaGeoms, 00671 mFEModel.mintGeometryCount * mintSizeOfGeomEntry); 00672 lIO.EndWriteBlock(); 00673 } 00674 00675 if(mFEModel.mintGroupCount) { 00676 lIO.BeginRewriteBlock(mintFEModelOffset, mFEModel.mintGroupTableOffset); 00677 lIO.Write((UnsignedInt32*)mpaGroups, 00678 mFEModel.mintGroupCount * mintSizeOfGroupEntry); 00679 lIO.EndWriteBlock(); 00680 } 00681 00682 if(mFEModel.mintBlockCount) { 00683 lIO.BeginRewriteBlock(mintFEModelOffset, mFEModel.mintBlockTableOffset); 00684 lIO.Write((UnsignedInt32*)mpaBlocks, 00685 mFEModel.mintBlockCount * mintSizeOfBlockEntry); 00686 lIO.EndWriteBlock(); 00687 } 00688 00689 if(mFEModel.mintNodeSetCount) { 00690 lIO.BeginRewriteBlock(mintFEModelOffset, mFEModel.mintNodeSetTableOffset); 00691 lIO.Write((UnsignedInt32*)mpaNodeSets, 00692 mFEModel.mintNodeSetCount * mintSizeOfNodeSetEntry); 00693 lIO.EndWriteBlock(); 00694 } 00695 00696 if(mFEModel.mintSideSetCount) { 00697 lIO.BeginRewriteBlock(mintFEModelOffset, mFEModel.mintSideSetTableOffset); 00698 lIO.Write((UnsignedInt32*)mpaSideSets, 00699 mFEModel.mintSideSetCount * mintSizeOfSideSetEntry); 00700 lIO.EndWriteBlock(); 00701 } 00702 00703 UnsignedInt32 lintMetaDataLength; 00704 mGeomMetaData.WriteMetaData(mpWriteFile, mFEModel.mintGeomMetaDataOffset, 00705 lintMetaDataLength, mintFEModelOffset); 00706 mFEModel.mintFEModelLength += lintMetaDataLength; 00707 mNodeMetaData.WriteMetaData(mpWriteFile, mFEModel.mintNodeMetaDataOffset, 00708 lintMetaDataLength, mintFEModelOffset); 00709 mFEModel.mintFEModelLength += lintMetaDataLength; 00710 mElemMetaData.WriteMetaData(mpWriteFile, mFEModel.mintElemMetaDataOffset, 00711 lintMetaDataLength, mintFEModelOffset); 00712 mFEModel.mintFEModelLength += lintMetaDataLength; 00713 mGroupMetaData.WriteMetaData(mpWriteFile, mFEModel.mintGroupMetaDataOffset, 00714 lintMetaDataLength, mintFEModelOffset); 00715 mFEModel.mintFEModelLength += lintMetaDataLength; 00716 mBlockMetaData.WriteMetaData(mpWriteFile, mFEModel.mintBlockMetaDataOffset, 00717 lintMetaDataLength, mintFEModelOffset); 00718 mFEModel.mintFEModelLength += lintMetaDataLength; 00719 mNodeSetMetaData.WriteMetaData(mpWriteFile, mFEModel.mintNodeSetMetaDataOffset, 00720 lintMetaDataLength, mintFEModelOffset); 00721 mFEModel.mintFEModelLength += lintMetaDataLength; 00722 mSideSetMetaData.WriteMetaData(mpWriteFile, mFEModel.mintSideSetMetaDataOffset, 00723 lintMetaDataLength, mintFEModelOffset); 00724 mFEModel.mintFEModelLength += lintMetaDataLength; 00725 00726 lIO.BeginRewriteBlock(mintFEModelOffset, 0); 00727 lIO.Write((UnsignedInt32*)&mFEModel, mintSizeOfFEModelHeader); 00728 lIO.EndWriteBlock(); 00729 00730 mpWriteFile = NULL; 00731 return mFEModel.mintFEModelLength; 00732 } 00733 00734 00736 // Read Functions 00738 00739 void CFEModel::InitRead(FILE* xpFile, 00740 UnsignedInt32 xintAbsoluteOffset, 00741 UnsignedInt32& xintGeomCount, 00742 UnsignedInt32& xintGroupCount, 00743 UnsignedInt32& xintBlockCount, 00744 UnsignedInt32& xintNodeSetCount, 00745 UnsignedInt32& xintSideSetCount) 00746 { 00747 if(mpReadFile) 00748 throw CCubitFile::eOrderError; 00749 00750 mpReadFile = xpFile; 00751 mintFEModelOffset = xintAbsoluteOffset; 00752 CIOWrapper lIO(mpReadFile, xintAbsoluteOffset, 0); 00753 00754 lIO.BeginReadBlock(mintFEModelOffset, 0); 00755 lIO.Read((UnsignedInt32*)&mFEModel, mintSizeOfFEModelHeader); 00756 lIO.EndReadBlock(); 00757 xintGeomCount = mFEModel.mintGeometryCount; 00758 xintGroupCount = mFEModel.mintGroupCount; 00759 xintBlockCount = mFEModel.mintBlockCount; 00760 xintNodeSetCount = mFEModel.mintNodeSetCount; 00761 xintSideSetCount = mFEModel.mintSideSetCount; 00762 00763 // Restore the geometry definition header table if there is one. 00764 if(mFEModel.mintGeometryCount) { 00765 mpaGeoms = new SCubitFileGeomEntry[mFEModel.mintGeometryCount]; 00766 00767 lIO.BeginReadBlock(mintFEModelOffset, mFEModel.mintGeomTableOffset); 00768 lIO.Read((UnsignedInt32*)mpaGeoms, 00769 mFEModel.mintGeometryCount * mintSizeOfGeomEntry); 00770 lIO.EndReadBlock(); 00771 } 00772 00773 // Restore the group definition header table if there is one. 00774 if(mFEModel.mintGroupCount) { 00775 mpaGroups = new SCubitFileGroupEntry[mFEModel.mintGroupCount]; 00776 00777 lIO.BeginReadBlock(mintFEModelOffset, mFEModel.mintGroupTableOffset); 00778 lIO.Read((UnsignedInt32*)mpaGroups, 00779 mFEModel.mintGroupCount * mintSizeOfGroupEntry); 00780 lIO.EndReadBlock(); 00781 } 00782 00783 // Restore the block definition header table if there is one. 00784 if(mFEModel.mintBlockCount) { 00785 mpaBlocks = new SCubitFileBlockEntry[mFEModel.mintBlockCount]; 00786 00787 lIO.BeginReadBlock(mintFEModelOffset, mFEModel.mintBlockTableOffset); 00788 lIO.Read((UnsignedInt32*)mpaBlocks, 00789 mFEModel.mintBlockCount * mintSizeOfBlockEntry); 00790 lIO.EndReadBlock(); 00791 } 00792 00793 // Restore the node set definition header table if there is one. 00794 if(mFEModel.mintNodeSetCount) { 00795 mpaNodeSets = new SCubitFileNodeSetEntry[mFEModel.mintNodeSetCount]; 00796 00797 lIO.BeginReadBlock(mintFEModelOffset, mFEModel.mintNodeSetTableOffset); 00798 lIO.Read((UnsignedInt32*)mpaNodeSets, 00799 mFEModel.mintNodeSetCount * mintSizeOfNodeSetEntry); 00800 lIO.EndReadBlock(); 00801 } 00802 00803 // Restore the side set definition header table if there is one. 00804 if(mFEModel.mintSideSetCount) { 00805 mpaSideSets = new SCubitFileSideSetEntry[mFEModel.mintSideSetCount]; 00806 00807 lIO.BeginReadBlock(mintFEModelOffset, mFEModel.mintSideSetTableOffset); 00808 lIO.Read((UnsignedInt32*)mpaSideSets, 00809 mFEModel.mintSideSetCount * mintSizeOfSideSetEntry); 00810 lIO.EndReadBlock(); 00811 } 00812 00813 mGeomMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00814 mFEModel.mintGeomMetaDataOffset, mFEModel.mintFEModelEndian); 00815 mNodeMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00816 mFEModel.mintNodeMetaDataOffset, mFEModel.mintFEModelEndian); 00817 mElemMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00818 mFEModel.mintElemMetaDataOffset, mFEModel.mintFEModelEndian); 00819 mGroupMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00820 mFEModel.mintGroupMetaDataOffset, mFEModel.mintFEModelEndian); 00821 mBlockMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00822 mFEModel.mintBlockMetaDataOffset, mFEModel.mintFEModelEndian); 00823 mNodeSetMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00824 mFEModel.mintNodeSetMetaDataOffset, mFEModel.mintFEModelEndian); 00825 mSideSetMetaData.ReadMetaData(mpReadFile, mintFEModelOffset, 00826 mFEModel.mintSideSetMetaDataOffset, mFEModel.mintFEModelEndian); 00827 } 00828 00829 void CFEModel::ReadNodes(UnsignedInt32 xintIndex, 00830 UnsignedInt32& xintGeomID, 00831 UnsignedInt32& xintNodeCount, 00832 UnsignedInt32*& xpaintNodeIDs, 00833 double*& xpadblX, 00834 double*& xpadblY, 00835 double*& xpadblZ) 00836 { 00837 if(!mpReadFile) 00838 throw CCubitFile::eFileReadError; 00839 if(xintIndex >= mFEModel.mintGeometryCount) 00840 throw CCubitFile::eNotFound; 00841 if(!mpaGeoms) 00842 throw CCubitFile::eOrderError; 00843 00844 xintGeomID = mpaGeoms[xintIndex].mintGeomID; 00845 xintNodeCount = mpaGeoms[xintIndex].mintNodeCount; 00846 if(xintNodeCount) { 00847 if(mNodeBuff.mintNumNodes < xintNodeCount) { 00848 if(mNodeBuff.mpaNodeIDs) 00849 delete [] mNodeBuff.mpaNodeIDs; 00850 if(mNodeBuff.mpadblX) 00851 delete [] mNodeBuff.mpadblX; 00852 if(mNodeBuff.mpadblY) 00853 delete [] mNodeBuff.mpadblY; 00854 if(mNodeBuff.mpadblZ) 00855 delete [] mNodeBuff.mpadblZ; 00856 mNodeBuff.mintNumNodes = xintNodeCount; 00857 mNodeBuff.mpaNodeIDs = new UnsignedInt32[xintNodeCount]; 00858 mNodeBuff.mpadblX = new double[xintNodeCount]; 00859 mNodeBuff.mpadblY = new double[xintNodeCount]; 00860 mNodeBuff.mpadblZ = new double[xintNodeCount]; 00861 } 00862 xpaintNodeIDs = mNodeBuff.mpaNodeIDs; 00863 xpadblX = mNodeBuff.mpadblX; 00864 xpadblY = mNodeBuff.mpadblY; 00865 xpadblZ = mNodeBuff.mpadblZ; 00866 00867 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 00868 00869 lpIO->BeginReadBlock(mintFEModelOffset, 00870 mpaGeoms[xintIndex].mintNodeOffset); 00871 lpIO->Read(mNodeBuff.mpaNodeIDs, xintNodeCount); 00872 lpIO->Read(mNodeBuff.mpadblX, xintNodeCount); 00873 lpIO->Read(mNodeBuff.mpadblY, xintNodeCount); 00874 lpIO->Read(mNodeBuff.mpadblZ, xintNodeCount); 00875 lpIO->EndReadBlock(); 00876 00877 delete lpIO; 00878 } 00879 else { 00880 xpaintNodeIDs = NULL; 00881 xpadblX = xpadblY = xpadblZ = NULL; 00882 } 00883 } 00884 00885 void CFEModel::ReadElems(double data_version, 00886 UnsignedInt32 xintIndex, UnsignedInt32& xintGeomID, 00887 UnsignedInt32& xintNumTypes, SElemData*& xpaElemData) 00888 { 00889 if(!mpReadFile) 00890 throw CCubitFile::eFileReadError; 00891 if(xintIndex >= mFEModel.mintGeometryCount) 00892 throw CCubitFile::eNotFound; 00893 if(!mpaGeoms) 00894 throw CCubitFile::eOrderError; 00895 00896 xintGeomID = mpaGeoms[xintIndex].mintGeomID; 00897 xintNumTypes = mpaGeoms[xintIndex].mintElemTypeCount; 00898 if(xintNumTypes) { 00899 // Resize the element return buffer if necessary and then set the return 00900 // pointers to the buffer. 00901 // 00902 // NOTE: if the number of element types is greater than 1, a single buffer 00903 // is allocated for the total number of elements. In the read loop below 00904 // the pointer to the buffer needs to be updated with each loop so as 00905 // not to overwrite what was read previously. 00906 // 00907 00908 00909 00910 UnsignedInt32 lintConnGuess = 00911 mpaGeoms[xintIndex].mintElemLength / sizeof(UnsignedInt32) - 00912 mpaGeoms[xintIndex].mintElemCount; 00913 // - 3 * mpaGeoms[xintIndex].mintElemTypeCount; (exact) 00914 xpaElemData = AdjustBuffer(xintNumTypes, 00915 mElemBuff.mintNumTypes, mElemBuff.mpaElemData); 00916 UnsignedInt32* lpIDs = 00917 AdjustBuffer(mpaGeoms[xintIndex].mintElemCount, 00918 mElemBuff.mintNumElemIds, mElemBuff.mpaElemIDs); 00919 UnsignedInt32* lpGlobalIDs = NULL; 00920 if ( data_version >= 1.3 ) 00921 { 00922 lpGlobalIDs = 00923 AdjustBuffer(mpaGeoms[xintIndex].mintElemCount, 00924 mElemBuff.mintNumElemGids, mElemBuff.mpaElemGlobalIDs); 00925 } 00926 00927 UnsignedInt32* lpConnect = 00928 AdjustBuffer(lintConnGuess, 00929 mElemBuff.mintNumConnect, mElemBuff.mpaElemConnect); 00930 00931 // Read the element from the file. 00932 UnsignedInt32 lintNumElems, lintNumConnect; 00933 UnsignedInt32 lintTotalElems = 0, lintTotalConnect = 0; 00934 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 00935 00936 lpIO->BeginReadBlock(mintFEModelOffset, 00937 mpaGeoms[xintIndex].mintElemOffset); 00938 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 00939 lpIO->Read(&xpaElemData[lintType].mintElemType, 1); 00940 lpIO->Read(&xpaElemData[lintType].mintElemOrder, 1); 00941 lpIO->Read(&xpaElemData[lintType].mintElemCount, 1); 00942 00943 xpaElemData[lintType].mpaElemIDs = lpIDs; 00944 xpaElemData[lintType].mpaElemGlobalIDs = lpGlobalIDs; 00945 xpaElemData[lintType].mpaElemConnect = lpConnect; 00946 lintNumElems = xpaElemData[lintType].mintElemCount; 00947 lintNumConnect = lintNumElems * xpaElemData[lintType].mintElemOrder; 00948 // Make sure the total number of elements or connection entries 00949 // does not exceed what was specified in the geometry table entry. 00950 lintTotalElems += lintNumElems; 00951 lintTotalConnect += lintNumConnect; 00952 if((lintTotalElems > mpaGeoms[xintIndex].mintElemCount) || 00953 (lintTotalConnect > lintConnGuess)) 00954 throw CCubitFile::eFileReadError; 00955 00956 lpIO->Read(xpaElemData[lintType].mpaElemIDs, lintNumElems); 00957 if ( data_version >= 1.3 ) 00958 lpIO->Read(xpaElemData[lintType].mpaElemGlobalIDs, lintNumElems); 00959 if(xpaElemData[lintType].mintElemOrder) 00960 lpIO->Read(xpaElemData[lintType].mpaElemConnect, lintNumConnect); 00961 00962 // When the buffers are allocated above, a single buffer is allocated 00963 // based on the total number of elements. So for the case that there are 00964 // multiple types being read in, move the pointer to the buffer past 00965 // the end of the data that has been read in so we don't overwrite. 00966 lpIDs = &lpIDs[lintNumElems]; 00967 if ( data_version >= 1.3 ) 00968 lpGlobalIDs = &lpGlobalIDs[lintNumElems]; 00969 lpConnect = &lpConnect[lintNumConnect]; 00970 } 00971 lpIO->EndReadBlock(); 00972 delete lpIO; 00973 } 00974 else 00975 xpaElemData = NULL; 00976 } 00977 00978 void CFEModel::ReadGroupIdentity(UnsignedInt32 xintIndex, 00979 UnsignedInt32& xintGroupID, 00980 UnsignedInt32& xintGroupType, 00981 const char*& xpachrGroupName) 00982 { 00983 if(!mpReadFile) 00984 throw CCubitFile::eFileReadError; 00985 if(xintIndex >= mFEModel.mintGroupCount) 00986 throw CCubitFile::eNotFound; 00987 if(!mpaGroups) 00988 throw CCubitFile::eOrderError; 00989 00990 xintGroupID = mpaGroups[xintIndex].mintGroupID; 00991 xintGroupType = mpaGroups[xintIndex].mintGroupType; 00992 if(mGroupMetaData.GetValue(xintGroupID, "NAME", xpachrGroupName) != 00993 CCubitFile::eSuccess) 00994 xpachrGroupName = NULL; 00995 } 00996 00997 void CFEModel::ReadGroupMembers(UnsignedInt32 xintIndex, 00998 UnsignedInt32& xintNumTypes, 00999 SGroupData*& xpaGroupData) 01000 { 01001 if(!mpReadFile) 01002 throw CCubitFile::eFileReadError; 01003 if(xintIndex >= mFEModel.mintGroupCount) 01004 throw CCubitFile::eNotFound; 01005 if(!mpaGroups) 01006 throw CCubitFile::eOrderError; 01007 01008 xintNumTypes = mpaGroups[xintIndex].mintMemberTypeCount; 01009 if(xintNumTypes) { 01010 // Resize the group return buffer if necessary and then set the return 01011 // pointers to the buffer. 01012 xpaGroupData = AdjustBuffer(xintNumTypes, 01013 mGroupBuff.mintNumTypes, mGroupBuff.mpaGroupData); 01014 UnsignedInt32* lpIDs = 01015 AdjustBuffer(mpaGroups[xintIndex].mintMemberCount, 01016 mGroupBuff.mintNumMembers, mGroupBuff.mpaintMemberIDs); 01017 01018 // Read the group member data from the file. 01019 UnsignedInt32 lintNumMembers, lintTotalMembers = 0; 01020 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 01021 lpIO->BeginReadBlock(mintFEModelOffset, 01022 mpaGroups[xintIndex].mintMemberOffset); 01023 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 01024 lpIO->Read(&xpaGroupData[lintType].mintMemberType, 1); 01025 lpIO->Read(&xpaGroupData[lintType].mintMemberCount, 1); 01026 01027 xpaGroupData[lintType].mpaMemberIDs = lpIDs; 01028 lintNumMembers = xpaGroupData[lintType].mintMemberCount; 01029 // Make sure the total number of group members does not exceed what 01030 // was specified in the group table entry. 01031 lintTotalMembers += lintNumMembers; 01032 if(lintTotalMembers > mpaGroups[xintIndex].mintMemberCount) 01033 throw CCubitFile::eFileReadError; 01034 01035 lpIO->Read(xpaGroupData[lintType].mpaMemberIDs, lintNumMembers); 01036 01037 lpIDs = &lpIDs[lintNumMembers]; 01038 } 01039 lpIO->EndReadBlock(); 01040 delete lpIO; 01041 } 01042 else 01043 xpaGroupData = NULL; 01044 } 01045 01046 void CFEModel::ReadBlock(UnsignedInt32 xintIndex, 01047 UnsignedInt32& xintBlockID, 01048 int& unique_id, 01049 UnsignedInt32& xintBlockType, 01050 UnsignedInt32& xintBlockColor, 01051 UnsignedInt32& xintMixedElemType, 01052 UnsignedInt32& xintDefPyramidType, 01053 UnsignedInt32& xintMaterialID, 01054 UnsignedInt32& xintBlockDimension, 01055 UnsignedInt32& xintNumTypes, 01056 SBlockData*& xpaBlockData, 01057 UnsignedInt32& xintAttributeOrder, 01058 double*& xpadblAttributes) 01059 { 01060 unique_id = 0; 01061 if(!mpReadFile) 01062 throw CCubitFile::eFileReadError; 01063 if(xintIndex >= mFEModel.mintBlockCount) 01064 throw CCubitFile::eNotFound; 01065 if(!mpaBlocks) 01066 throw CCubitFile::eOrderError; 01067 01068 xintBlockID = mpaBlocks[xintIndex].mintBlockID; 01069 xintBlockType = mpaBlocks[xintIndex].mintBlockElementType; 01070 xintNumTypes = mpaBlocks[xintIndex].mintMemberTypeCount; 01071 xintBlockColor = mpaBlocks[xintIndex].mintBlockColor; 01072 xintMixedElemType = mpaBlocks[xintIndex].mintBlockMixedElemType; 01073 xintDefPyramidType = mpaBlocks[xintIndex].mintBlockDefPyramidType; 01074 xintMaterialID = mpaBlocks[xintIndex].mintBlockMaterial; 01075 xintBlockDimension = mpaBlocks[xintIndex].mintBlockDimension; 01076 xintAttributeOrder = mpaBlocks[xintIndex].mintAttributeOrder; 01077 01078 // Resize the block return buffer if necessary and then set the return 01079 // pointers to the buffer. 01080 xpaBlockData = AdjustBuffer(xintNumTypes, 01081 mBlockBuff.mintNumTypes, mBlockBuff.mpaBlockData); 01082 UnsignedInt32* lpIDs = 01083 AdjustBuffer(mpaBlocks[xintIndex].mintMemberCount, 01084 mBlockBuff.mintNumMembers, mBlockBuff.mpaintMemberIDs); 01085 xpadblAttributes = AdjustBuffer(xintAttributeOrder, 01086 mBlockBuff.mintAttributeOrder, mBlockBuff.mpadblAttributes); 01087 01088 // Read the block from the file. 01089 UnsignedInt32 lintNumMembers, lintTotalMembers = 0; 01090 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 01091 lpIO->BeginReadBlock(mintFEModelOffset, 01092 mpaBlocks[xintIndex].mintMemberOffset); 01093 UnsignedInt32 start_location = lpIO->GetLocation(); 01094 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 01095 lpIO->Read(&xpaBlockData[lintType].mintMemberType, 1); 01096 lpIO->Read(&xpaBlockData[lintType].mintMemberCount, 1); 01097 01098 xpaBlockData[lintType].mpaMemberIDs = lpIDs; 01099 lintNumMembers = xpaBlockData[lintType].mintMemberCount; 01100 // Make sure the total number of block members does not exceed what 01101 // was specified in the block table entry. 01102 lintTotalMembers += lintNumMembers; 01103 if(lintTotalMembers > mpaBlocks[xintIndex].mintMemberCount) 01104 throw CCubitFile::eFileReadError; 01105 01106 lpIO->Read(xpaBlockData[lintType].mpaMemberIDs, lintNumMembers); 01107 01108 lpIDs = &lpIDs[lintNumMembers]; 01109 } 01110 if(xintAttributeOrder) 01111 lpIO->Read(xpadblAttributes, xintAttributeOrder); 01112 01113 // see if there is more data 01114 int diff = lpIO->GetLocation() - start_location; 01115 int remaining = diff - mpaBlocks[xintIndex].mintBlockLength; 01116 while(remaining) 01117 { 01118 // remaining data could be bc data 01119 char type[2]; 01120 lpIO->Read(type, 2); 01121 if(type[0] == 'i' && type[1] == 'd') 01122 { 01123 lpIO->Read(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 01124 } 01125 remaining = (lpIO->GetLocation() - start_location) - 01126 mpaBlocks[xintIndex].mintBlockLength; 01127 } 01128 01129 lpIO->EndReadBlock(); 01130 delete lpIO; 01131 } 01132 01133 void CFEModel::ReadNodeSet(UnsignedInt32 xintIndex, 01134 UnsignedInt32& xintNodeSetID, 01135 int& unique_id, 01136 UnsignedInt32& xintColor, 01137 UnsignedInt32& xintPointSymbol, 01138 UnsignedInt32& xintNumTypes, 01139 SNodeSetData*& xpaNodeSetData, 01140 std::vector<char>& bcdata) 01141 { 01142 unique_id = 0; 01143 if(!mpReadFile) 01144 throw CCubitFile::eFileReadError; 01145 if(xintIndex >= mFEModel.mintNodeSetCount) 01146 throw CCubitFile::eNotFound; 01147 if(!mpaNodeSets) 01148 throw CCubitFile::eOrderError; 01149 01150 xintNodeSetID = mpaNodeSets[xintIndex].mintNodeSetID; 01151 xintNumTypes = mpaNodeSets[xintIndex].mintMemberTypeCount; 01152 xintPointSymbol = mpaNodeSets[xintIndex].mintNodeSetPointSym; 01153 xintColor = mpaNodeSets[xintIndex].mintNodeSetColor; 01154 01155 // fix for bug 8623: empty nodesets are allowed 01156 //if(xintNumTypes) 01157 //{ 01158 // Resize the node set return buffer if necessary and then set the return 01159 // pointers to the buffer. 01160 xpaNodeSetData = AdjustBuffer(xintNumTypes, 01161 mNodeSetBuff.mintNumTypes, mNodeSetBuff.mpaNodeSetData); 01162 UnsignedInt32* lpIDs = 01163 AdjustBuffer(mpaNodeSets[xintIndex].mintMemberCount, 01164 mNodeSetBuff.mintNumMembers, mNodeSetBuff.mpaintMemberIDs); 01165 01166 // Read the node set from the file. 01167 UnsignedInt32 lintNumMembers, lintTotalMembers = 0; 01168 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 01169 lpIO->BeginReadBlock(mintFEModelOffset, 01170 mpaNodeSets[xintIndex].mintMemberOffset); 01171 UnsignedInt32 start_location = lpIO->GetLocation(); 01172 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 01173 lpIO->Read(&xpaNodeSetData[lintType].mintMemberType, 1); 01174 lpIO->Read(&xpaNodeSetData[lintType].mintMemberCount, 1); 01175 01176 xpaNodeSetData[lintType].mpaMemberIDs = lpIDs; 01177 lintNumMembers = xpaNodeSetData[lintType].mintMemberCount; 01178 // Make sure the total number of node set members does not exceed 01179 // what was specified in the node set table entry. 01180 lintTotalMembers += lintNumMembers; 01181 if(lintTotalMembers > mpaNodeSets[xintIndex].mintMemberCount) 01182 throw CCubitFile::eFileReadError; 01183 01184 lpIO->Read(xpaNodeSetData[lintType].mpaMemberIDs, lintNumMembers); 01185 01186 lpIDs = &lpIDs[lintNumMembers]; 01187 } 01188 01189 // see if there is more data 01190 int diff = lpIO->GetLocation() - start_location; 01191 int remaining = diff - mpaNodeSets[xintIndex].mintNodeSetLength; 01192 while(remaining) 01193 { 01194 // remaining data could be bc data 01195 char type[2]; 01196 lpIO->Read(type, 2); 01197 if(type[0] == 'b' && type[1] == 'c') 01198 { 01199 // get serialize data size 01200 UnsignedInt32 size; 01201 lpIO->Read(&size, 1); 01202 bcdata.resize(size); 01203 lpIO->Read(&bcdata[0], size); 01204 } 01205 else if(type[0] == 'i' && type[1] == 'd') 01206 { 01207 lpIO->Read(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 01208 } 01209 remaining = (lpIO->GetLocation() - start_location) - 01210 mpaNodeSets[xintIndex].mintNodeSetLength; 01211 } 01212 01213 lpIO->EndReadBlock(); 01214 delete lpIO; 01215 /*} 01216 else 01217 xpaNodeSetData = NULL;*/ 01218 } 01219 01220 void CFEModel::ReadSideSet_10(UnsignedInt32 xintIndex, 01221 UnsignedInt32& xintSideSetID, 01222 UnsignedInt32& xintColor, 01223 UnsignedInt32& xintUseShells, 01224 UnsignedInt32& xintNumTypes, 01225 SSideSetData_10*& xpaSideSetData, 01226 UnsignedInt32& xintNumDistFact, 01227 double*& xpadblDistribution) 01228 { 01229 if(!mpReadFile) 01230 throw CCubitFile::eFileReadError; 01231 if(xintIndex >= mFEModel.mintSideSetCount) 01232 throw CCubitFile::eNotFound; 01233 if(!mpaSideSets) 01234 throw CCubitFile::eOrderError; 01235 01236 xintSideSetID = mpaSideSets[xintIndex].mintSideSetID; 01237 xintNumTypes = mpaSideSets[xintIndex].mintMemberTypeCount; 01238 xintColor = mpaSideSets[xintIndex].mintSideSetColor; 01239 xintUseShells = mpaSideSets[xintIndex].mintUseShells; 01240 xintNumDistFact = mpaSideSets[xintIndex].mintNumDistFact; 01241 01242 if(xintNumTypes) { 01243 // Resize the side set return buffer if necessary and then set the return 01244 // pointers to the buffer. 01245 xpaSideSetData = AdjustBuffer(xintNumTypes, 01246 mSideSetBuff_10.mintNumTypes, mSideSetBuff_10.mpaSideSetData); 01247 UnsignedInt32* lpaintIDs = 01248 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01249 mSideSetBuff_10.mintNumMembersIDs, mSideSetBuff_10.mpaintMemberIDs); 01250 char* lpachrSense = 01251 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01252 mSideSetBuff_10.mintNumMembersSense8, mSideSetBuff_10.mpachrMemberSense); 01253 UnsignedInt32* lpaintSense = 01254 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01255 mSideSetBuff_10.mintNumMembersSense32, mSideSetBuff_10.mpaintMemberSense); 01256 char* lpachrSideNum = 01257 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01258 mSideSetBuff_10.mintNumMembersSideNum, mSideSetBuff_10.mpachrMemberSideNum); 01259 xpadblDistribution = AdjustBuffer(xintNumDistFact, 01260 mSideSetBuff_10.mintNumDistFact, mSideSetBuff_10.mpadblDistribution); 01261 01262 // Read the block from the file. 01263 UnsignedInt32 lintNumMembers, lintTotalMembers = 0; 01264 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 01265 lpIO->BeginReadBlock(mintFEModelOffset, 01266 mpaSideSets[xintIndex].mintMemberOffset); 01267 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 01268 lpIO->Read(&xpaSideSetData[lintType].mintMemberType, 1); 01269 lpIO->Read(&xpaSideSetData[lintType].mintMemberCount, 1); 01270 lpIO->Read(&xpaSideSetData[lintType].mintMemberSenseSize, 1); 01271 01272 xpaSideSetData[lintType].mpaintMemberIDs = lpaintIDs; 01273 xpaSideSetData[lintType].mpachrMemberSideNumber = lpachrSideNum; 01274 lintNumMembers = xpaSideSetData[lintType].mintMemberCount; 01275 // Make sure the total number of side set members does not exceed 01276 // what was specified in the side set table entry. 01277 lintTotalMembers += lintNumMembers; 01278 if(lintTotalMembers > mpaSideSets[xintIndex].mintMemberCount) 01279 throw CCubitFile::eFileReadError; 01280 01281 lpIO->Read(xpaSideSetData[lintType].mpaintMemberIDs, lintNumMembers); 01282 switch(xpaSideSetData[lintType].mintMemberSenseSize) { 01283 case CCubitFile::eSideSetSenseNone: 01284 default: 01285 xpaSideSetData[lintType].mpachrMemberSense = NULL; 01286 xpaSideSetData[lintType].mpaintMemberSense = NULL; 01287 break; 01288 case CCubitFile::eSideSetSenseByte: 01289 xpaSideSetData[lintType].mpachrMemberSense = lpachrSense; 01290 xpaSideSetData[lintType].mpaintMemberSense = NULL; 01291 lpIO->Read(xpaSideSetData[lintType].mpachrMemberSense, 01292 lintNumMembers, 1); 01293 lpaintSense = &lpaintSense[lintNumMembers]; 01294 break; 01295 case CCubitFile::eSideSetSenseInt32: 01296 xpaSideSetData[lintType].mpachrMemberSense = NULL; 01297 xpaSideSetData[lintType].mpaintMemberSense = lpaintSense; 01298 lpIO->Read(xpaSideSetData[lintType].mpaintMemberSense, 01299 lintNumMembers); 01300 lpaintSense = &lpaintSense[lintNumMembers]; 01301 break; 01302 } 01303 lpIO->Read(xpaSideSetData[lintType].mpachrMemberSideNumber, 01304 lintNumMembers, 1); 01305 01306 lpaintIDs = &lpaintIDs[lintNumMembers]; 01307 lpachrSideNum = &lpachrSideNum[lintNumMembers]; 01308 } 01309 if(xintNumDistFact) 01310 lpIO->Read(xpadblDistribution, xintNumDistFact); 01311 lpIO->EndReadBlock(); 01312 delete lpIO; 01313 } 01314 else { 01315 xpaSideSetData = NULL; 01316 xpadblDistribution = NULL; 01317 } 01318 } 01319 01320 void CFEModel::ReadSideSet_11(UnsignedInt32 xintIndex, 01321 UnsignedInt32& xintSideSetID, 01322 int& unique_id, 01323 UnsignedInt32& xintColor, 01324 UnsignedInt32& xintUseShells, 01325 UnsignedInt32& xintNumTypes, 01326 SSideSetData_11*& xpaSideSetData, 01327 UnsignedInt32& xintNumDistFact, 01328 double*& xpadblDistribution, 01329 std::vector<char>& bcdata) 01330 { 01331 unique_id = 0; 01332 if(!mpReadFile) 01333 throw CCubitFile::eFileReadError; 01334 if(xintIndex >= mFEModel.mintSideSetCount) 01335 throw CCubitFile::eNotFound; 01336 if(!mpaSideSets) 01337 throw CCubitFile::eOrderError; 01338 01339 xintSideSetID = mpaSideSets[xintIndex].mintSideSetID; 01340 xintNumTypes = mpaSideSets[xintIndex].mintMemberTypeCount; 01341 xintColor = mpaSideSets[xintIndex].mintSideSetColor; 01342 xintUseShells = mpaSideSets[xintIndex].mintUseShells; 01343 xintNumDistFact = mpaSideSets[xintIndex].mintNumDistFact; 01344 01345 // fix for bug 8623: don't do this check: empty sidesets are allowed 01346 //if(xintNumTypes) { 01347 // Resize the side set return buffer if necessary and then set the return 01348 // pointers to the buffer. 01349 xpaSideSetData = AdjustBuffer(xintNumTypes, 01350 mSideSetBuff_11.mintNumTypes, mSideSetBuff_11.mpaSideSetData); 01351 UnsignedInt32 count = mSideSetBuff_11.mintNumMembersIDs; 01352 UnsignedInt32* lpaintTypes = 01353 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01354 mSideSetBuff_11.mintNumMembersIDs, mSideSetBuff_11.mpaintMemberTypes); 01355 UnsignedInt32* lpaintIDs = 01356 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01357 count, mSideSetBuff_11.mpaintMemberIDs); 01358 char* lpachrSense = 01359 AdjustBuffer(mpaSideSets[xintIndex].mintMemberCount, 01360 mSideSetBuff_11.mintNumMembersSense, mSideSetBuff_11.mpachrMemberSense); 01361 xpadblDistribution = AdjustBuffer(xintNumDistFact, 01362 mSideSetBuff_11.mintNumDistFact, mSideSetBuff_11.mpadblDistribution); 01363 01364 // Read the block from the file. 01365 UnsignedInt32 lintNumMembers, lintTotalMembers = 0; 01366 CIOWrapper* lpIO = new CIOWrapper(mpReadFile, mFEModel.mintFEModelEndian); 01367 lpIO->BeginReadBlock(mintFEModelOffset, 01368 mpaSideSets[xintIndex].mintMemberOffset); 01369 UnsignedInt32 start_location = lpIO->GetLocation(); 01370 for(UnsignedInt32 lintType = 0; lintType < xintNumTypes; lintType++) { 01371 lpIO->Read(&xpaSideSetData[lintType].mintMemberCount, 1); 01372 01373 lintNumMembers = xpaSideSetData[lintType].mintMemberCount; 01374 01375 xpaSideSetData[lintType].mpaintMemberTypes = lpaintTypes; 01376 xpaSideSetData[lintType].mpaintMemberIDs = lpaintIDs; 01377 01378 // Make sure the total number of side set members does not exceed 01379 // what was specified in the side set table entry. 01380 lintTotalMembers += lintNumMembers; 01381 if(lintTotalMembers > mpaSideSets[xintIndex].mintMemberCount) 01382 throw CCubitFile::eFileReadError; 01383 01384 lpIO->Read(xpaSideSetData[lintType].mpaintMemberTypes, lintNumMembers); 01385 01386 lpIO->Read(xpaSideSetData[lintType].mpaintMemberIDs, lintNumMembers); 01387 01388 xpaSideSetData[lintType].mpachrMemberSenses = lpachrSense; 01389 if(lintType == 0) 01390 lpIO->Read(xpaSideSetData[lintType].mpachrMemberSenses, lintNumMembers, 1); 01391 else 01392 lpIO->Read(xpaSideSetData[lintType].mpachrMemberSenses, 1, 1); 01393 01394 UnsignedInt32 wrt_size=0; 01395 lpIO->Read(&wrt_size, 1); 01396 01397 UnsignedInt32* lpaintWRT = NULL; 01398 UnsignedInt32 orig_size = 0; 01399 AdjustBuffer(wrt_size, orig_size, lpaintWRT); 01400 01401 xpaSideSetData[lintType].mpaintMemberWRTEntities = lpaintWRT; 01402 01403 lpIO->Read(xpaSideSetData[lintType].mpaintMemberWRTEntities, wrt_size); 01404 01405 lpaintIDs = &lpaintIDs[lintNumMembers]; 01406 lpaintTypes = &lpaintTypes[lintNumMembers]; 01407 } 01408 if(xintNumDistFact) 01409 lpIO->Read(xpadblDistribution, xintNumDistFact); 01410 01411 // see if there is more data 01412 int diff = lpIO->GetLocation() - start_location; 01413 int remaining = diff - mpaSideSets[xintIndex].mintSideSetLength; 01414 while(remaining) 01415 { 01416 // remaining data could be bc data 01417 char type[2]; 01418 lpIO->Read(type, 2); 01419 if(type[0] == 'b' && type[1] == 'c') 01420 { 01421 // get serialize data size 01422 UnsignedInt32 size; 01423 lpIO->Read(&size, 1); 01424 bcdata.resize(size); 01425 lpIO->Read(&bcdata[0], size); 01426 } 01427 // or unique id 01428 else if(type[0] == 'i' && type[1] == 'd') 01429 { 01430 lpIO->Read(reinterpret_cast<UnsignedInt32*>(&unique_id), 1); 01431 } 01432 remaining = (lpIO->GetLocation() - start_location) - 01433 mpaSideSets[xintIndex].mintSideSetLength; 01434 } 01435 01436 lpIO->EndReadBlock(); 01437 delete lpIO; 01438 //} 01439 //else { 01440 // xpaSideSetData = NULL; 01441 // xpadblDistribution = NULL; 01442 //} 01443 } 01444 01445 void CFEModel::EndRead() 01446 { 01447 mpReadFile = NULL; 01448 } 01449 01451 // Meta-Data Functions 01453 01454 CMetaData& CFEModel::GetGeomMetaData() 01455 { 01456 return mGeomMetaData; 01457 } 01458 01459 CMetaData& CFEModel::GetNodeMetaData() 01460 { 01461 return mNodeMetaData; 01462 } 01463 01464 CMetaData& CFEModel::GetElemMetaData() 01465 { 01466 return mElemMetaData; 01467 } 01468 01469 CMetaData& CFEModel::GetGroupMetaData() 01470 { 01471 return mGroupMetaData; 01472 } 01473 01474 CMetaData& CFEModel::GetBlockMetaData() 01475 { 01476 return mBlockMetaData; 01477 } 01478 01479 CMetaData& CFEModel::GetNodeSetMetaData() 01480 { 01481 return mNodeSetMetaData; 01482 } 01483 01484 CMetaData& CFEModel::GetSideSetMetaData() 01485 { 01486 return mSideSetMetaData; 01487 }
