cgma
00001 /******************************************************************************* 00002 COPYRIGHT 2002 CATERPILLAR INC. ALL RIGHTS RESERVED 00003 00004 This program is the property of Caterpillar Inc., includes Caterpillar's 00005 confidential and trade secret information, and is maintained as an 00006 unpublished copyrighted work. It is not to be copied or used by others 00007 except under license from Caterpillar. This program is also protected as an 00008 unpublished work in accordance with the copyright act of 1976. In the event 00009 of either inadvertent or deliberate publication, Caterpillar Inc. intends to 00010 maintain copyright protection for this work under the relevant copyright 00011 laws pertaining to published works. The inclusion of a copyright notice 00012 hereon is precautionary only, and does not imply publication or disclosure. 00013 00014 00015 Filename : CubitFileMetaData.cpp 00016 00017 Purpose : Implements meta-data (descriptions) in the Cubit file. 00018 00019 Special Notes : 00020 00021 Creator : Will A. Helden 00022 00023 Creation Date : 02/15/02 00024 00025 Owner : Will A. Helden 00026 00027 *******************************************************************************/ 00028 00029 #include "CubitFileMetaData.hpp" 00030 #include "CubitFileIOWrapper.hpp" 00031 #include <cstring> 00032 00033 using namespace NCubitFile; 00034 00036 // CMetaData - 00038 00039 CMetaData::CMetaData(UnsignedInt32 xintGrowSizeBy) 00040 { 00041 mHeader.mintMetaDataSchema = 0; 00042 mHeader.mintMetaDataCompress = 0; 00043 mHeader.mintMetaDataCount = 0; 00044 00045 mintGrowSizeBy = xintGrowSizeBy ? xintGrowSizeBy : 64; 00046 mintBufferSize = 0; 00047 mpaEntries = NULL; 00048 00049 // Initialize the return buffer - allocated structures needed to return 00050 // the results of meta data queries will be owned and freed by this object. 00051 mSearchBuff.mintNumOwners = mSearchBuff.mintNumNames = 00052 mSearchBuff.mintNumMetaData = 0; 00053 mSearchBuff.mpaintOwners = NULL; 00054 mSearchBuff.mpapachrNames = NULL; 00055 mSearchBuff.mintMetaDataType = eUnsignedInt32; 00056 mSearchBuff.mpaValues = NULL; 00057 mSearchBuff.mpaintNumValues = NULL; 00058 } 00059 00060 CMetaData::~CMetaData() 00061 { 00062 // Free the meta data. 00063 FreeAll(); 00064 00065 // Free the search return buffer. 00066 if(mSearchBuff.mpaintOwners) 00067 delete [] mSearchBuff.mpaintOwners; 00068 if(mSearchBuff.mpapachrNames) 00069 delete [] mSearchBuff.mpapachrNames; 00070 if(mSearchBuff.mpaValues) { 00071 switch(mSearchBuff.mintMetaDataType) { 00072 case eUnsignedInt32: 00073 delete [] (UnsignedInt32*)mSearchBuff.mpaValues; 00074 break; 00075 case eString: 00076 delete [] (ConstCharPtr*)mSearchBuff.mpaValues; 00077 break; 00078 case eDouble: 00079 delete [] (double*)mSearchBuff.mpaValues; 00080 break; 00081 case eUnsignedInt32Array: 00082 delete [] (ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues; 00083 break; 00084 case eDoubleArray: 00085 delete [] (ConstDoublePtr*)mSearchBuff.mpaValues; 00086 break; 00087 } 00088 } 00089 if(mSearchBuff.mpaintNumValues) 00090 delete [] mSearchBuff.mpaintNumValues; 00091 } 00092 00093 void CMetaData::GrowSize() 00094 // Grows the meta-data storage structure by the predetermined growth size. 00095 { 00096 // Try to allocate a new storage structure. 00097 UnsignedInt32 lintNewBufferSize = mintBufferSize + mintGrowSizeBy; 00098 SCubitFileMetaDataEntry* lpaNewEntries = 00099 new SCubitFileMetaDataEntry[lintNewBufferSize]; 00100 if(!lpaNewEntries) 00101 throw CCubitFile::eMemoryError; 00102 00103 // Copy the existing data into the front new structure. 00104 if(mpaEntries) { 00105 memcpy(lpaNewEntries, mpaEntries, 00106 mintBufferSize * sizeof(SCubitFileMetaDataEntry)); 00107 } 00108 // Initialize the remaining part of the new structure. 00109 for(UnsignedInt32 lintEntry = mintBufferSize; lintEntry < 00110 lintNewBufferSize; lintEntry++) { 00111 lpaNewEntries[lintEntry].mintMetaDataOwner = 0; 00112 lpaNewEntries[lintEntry].mintMetaDataType = eUnsignedInt32; 00113 lpaNewEntries[lintEntry].mpachrName = NULL; 00114 lpaNewEntries[lintEntry].muValue.mint = 0; 00115 lpaNewEntries[lintEntry].mintNumValues = 0; 00116 } 00117 // Replace the old structure with the new one and free the old one. 00118 if(mpaEntries) 00119 delete [] mpaEntries; 00120 mintBufferSize = lintNewBufferSize; 00121 mpaEntries = lpaNewEntries; 00122 } 00123 00124 UnsignedInt32 CMetaData::AddEntry(UnsignedInt32 xintOwner, 00125 ConstCharPtr xpachrName) 00126 // Creates a valueless meta-data entry for the passed id and name. 00127 // Private function, returns the index of the new entry, throws exceptions. 00128 { 00129 if(mHeader.mintMetaDataCount == mintBufferSize) 00130 GrowSize(); 00131 mpaEntries[mHeader.mintMetaDataCount].mintMetaDataOwner = xintOwner; 00132 UnsignedInt32 lintNameLength = std::strlen(xpachrName); 00133 mpaEntries[mHeader.mintMetaDataCount].mpachrName = 00134 new char[lintNameLength + 1]; 00135 if(!mpaEntries[mHeader.mintMetaDataCount].mpachrName) 00136 throw CCubitFile::eMemoryError; 00137 std::strcpy(mpaEntries[mHeader.mintMetaDataCount].mpachrName, xpachrName); 00138 return mHeader.mintMetaDataCount++; 00139 } 00140 00141 UnsignedInt32 CMetaData::Find(UnsignedInt32 xintOwner, 00142 ConstCharPtr xpachrName, 00143 UnsignedInt32& xintIndex) 00144 // Search for the index of a piece of data with the declared owner and name. 00145 // Private function, returns true/false, no exceptions thrown. 00146 { 00147 if(!mHeader.mintMetaDataCount) return 0; // false, not found 00148 for(UnsignedInt32 lintEntry = 0; lintEntry < 00149 mHeader.mintMetaDataCount; lintEntry++) { 00150 if(mpaEntries[lintEntry].mintMetaDataOwner == xintOwner) { 00151 if(!std::strcmp(xpachrName, mpaEntries[lintEntry].mpachrName)) { 00152 xintIndex = lintEntry; 00153 return 1; // true, found 00154 } 00155 } 00156 } 00157 return 0; // false, not found 00158 } 00159 00160 00162 // Get/Set Value Methods 00164 00165 UnsignedInt32 CMetaData::GetValue(UnsignedInt32 xintOwner, 00166 ConstCharPtr xpachrName, 00167 UnsignedInt32& xintValue) 00168 // Retrieve integer valued meta-data by id and name. 00169 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00170 { 00171 UnsignedInt32 lintEntry; 00172 if(Find(xintOwner, xpachrName, lintEntry)) { 00173 if(mpaEntries[lintEntry].mintMetaDataType == eUnsignedInt32) { 00174 xintValue = mpaEntries[lintEntry].muValue.mint; 00175 return CCubitFile::eSuccess; 00176 } 00177 } 00178 xintValue = 0; 00179 return CCubitFile::eNotFound; 00180 } 00181 00182 UnsignedInt32 CMetaData::GetValue(UnsignedInt32 xintOwner, 00183 ConstCharPtr xpachrName, 00184 ConstCharPtr& xpachrValue) 00185 // Retrieve string valued meta-data by id and name. 00186 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00187 { 00188 UnsignedInt32 lintEntry; 00189 if(Find(xintOwner, xpachrName, lintEntry)) { 00190 if(mpaEntries[lintEntry].mintMetaDataType == eString) { 00191 xpachrValue = mpaEntries[lintEntry].muValue.mpachr; 00192 return CCubitFile::eSuccess; 00193 } 00194 } 00195 xpachrValue = NULL; 00196 return CCubitFile::eNotFound; 00197 } 00198 00199 UnsignedInt32 CMetaData::GetValue(UnsignedInt32 xintOwner, 00200 ConstCharPtr xpachrName, 00201 double& xdblValue) 00202 // Retrieve double valued meta-data by id and name. 00203 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00204 { 00205 UnsignedInt32 lintEntry; 00206 if(Find(xintOwner, xpachrName, lintEntry)) { 00207 if(mpaEntries[lintEntry].mintMetaDataType == eDouble) { 00208 xdblValue = mpaEntries[lintEntry].muValue.mdbl; 00209 return CCubitFile::eSuccess; 00210 } 00211 } 00212 xdblValue = 0.0; 00213 return CCubitFile::eNotFound; 00214 } 00215 00216 UnsignedInt32 CMetaData::GetValue(UnsignedInt32 xintOwner, 00217 ConstCharPtr xpachrName, 00218 const UnsignedInt32*& xpaintValue, 00219 UnsignedInt32& xintNumValues) 00220 // Retrieve integer array valued meta-data by id and name. 00221 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00222 { 00223 UnsignedInt32 lintEntry; 00224 if(Find(xintOwner, xpachrName, lintEntry)) { 00225 if(mpaEntries[lintEntry].mintMetaDataType == eUnsignedInt32Array) { 00226 xpaintValue = mpaEntries[lintEntry].muValue.mpaint; 00227 xintNumValues = mpaEntries[lintEntry].mintNumValues; 00228 return CCubitFile::eSuccess; 00229 } 00230 } 00231 xpaintValue = NULL; 00232 xintNumValues = 0; 00233 return CCubitFile::eNotFound; 00234 } 00235 00236 UnsignedInt32 CMetaData::GetValue(UnsignedInt32 xintOwner, 00237 ConstCharPtr xpachrName, 00238 const double*& xpadblValue, 00239 UnsignedInt32& xintNumValues) 00240 // Retrieve double array valued meta-data by id and name. 00241 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00242 { 00243 UnsignedInt32 lintEntry; 00244 if(Find(xintOwner, xpachrName, lintEntry)) { 00245 if(mpaEntries[lintEntry].mintMetaDataType == eDoubleArray) { 00246 xpadblValue = mpaEntries[lintEntry].muValue.mpadbl; 00247 xintNumValues = mpaEntries[lintEntry].mintNumValues; 00248 return CCubitFile::eSuccess; 00249 } 00250 } 00251 xpadblValue = NULL; 00252 xintNumValues = 0; 00253 return CCubitFile::eNotFound; 00254 } 00255 00256 //----------------------------------------------------------------------------- 00257 00258 UnsignedInt32 CMetaData::SetValue(UnsignedInt32 xintOwner, 00259 ConstCharPtr xpachrName, 00260 UnsignedInt32 xintValue) 00261 // Assign integer valued meta-data to an id and name. 00262 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00263 { 00264 if(!xpachrName) 00265 return CCubitFile::ePassedNullPointer; 00266 00267 try { 00268 UnsignedInt32 lintEntry; 00269 if(Find(xintOwner, xpachrName, lintEntry)) 00270 FreeValueAt(lintEntry); 00271 else 00272 lintEntry = AddEntry(xintOwner, xpachrName); 00273 mpaEntries[lintEntry].mintMetaDataType = eUnsignedInt32; 00274 mpaEntries[lintEntry].muValue.mint = xintValue; 00275 return CCubitFile::eSuccess; 00276 } 00277 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00278 catch(...) { return CCubitFile::eUnknownError; } 00279 } 00280 00281 UnsignedInt32 CMetaData::SetValue(UnsignedInt32 xintOwner, 00282 ConstCharPtr xpachrName, 00283 ConstCharPtr xpachrValue) 00284 // Assign string valued meta-data to an id and name. 00285 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00286 { 00287 if(!xpachrName) 00288 throw CCubitFile::ePassedNullPointer; 00289 00290 try { 00291 UnsignedInt32 lintEntry, lintLength; 00292 if(Find(xintOwner, xpachrName, lintEntry)) 00293 FreeValueAt(lintEntry); 00294 else 00295 lintEntry = AddEntry(xintOwner, xpachrName); 00296 00297 mpaEntries[lintEntry].mintMetaDataType = eString; 00298 lintLength = xpachrValue ? std::strlen(xpachrValue) : 0; 00299 if(lintLength) { 00300 mpaEntries[lintEntry].muValue.mpachr = new char[lintLength + 1]; 00301 if(!mpaEntries[lintEntry].muValue.mpachr) 00302 throw CCubitFile::eMemoryError; 00303 std::strcpy(mpaEntries[lintEntry].muValue.mpachr, xpachrValue); 00304 } 00305 else 00306 mpaEntries[lintEntry].muValue.mpachr = NULL; 00307 00308 return CCubitFile::eSuccess; 00309 } 00310 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00311 catch(...) { return CCubitFile::eUnknownError; } 00312 } 00313 00314 UnsignedInt32 CMetaData::SetValue(UnsignedInt32 xintOwner, 00315 ConstCharPtr xpachrName, double xdblValue) 00316 // Assign double valued meta-data to an id and name. 00317 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00318 { 00319 if(!xpachrName) 00320 throw CCubitFile::ePassedNullPointer; 00321 00322 try { 00323 UnsignedInt32 lintEntry; 00324 if(Find(xintOwner, xpachrName, lintEntry)) 00325 FreeValueAt(lintEntry); 00326 else 00327 lintEntry = AddEntry(xintOwner, xpachrName); 00328 mpaEntries[lintEntry].mintMetaDataType = eDouble; 00329 mpaEntries[lintEntry].muValue.mdbl = xdblValue; 00330 return CCubitFile::eSuccess; 00331 } 00332 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00333 catch(...) { return CCubitFile::eUnknownError; } 00334 } 00335 00336 UnsignedInt32 CMetaData::SetValue(UnsignedInt32 xintOwner, 00337 ConstCharPtr xpachrName, 00338 const UnsignedInt32* xpaintValue, 00339 UnsignedInt32 xintNumValues) 00340 // Assign integer array valued meta-data to an id and name. 00341 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00342 { 00343 if(!xpachrName) 00344 throw CCubitFile::ePassedNullPointer; 00345 00346 try { 00347 UnsignedInt32 lintEntry; 00348 if(Find(xintOwner, xpachrName, lintEntry)) 00349 FreeValueAt(lintEntry); 00350 else 00351 lintEntry = AddEntry(xintOwner, xpachrName); 00352 00353 mpaEntries[lintEntry].mintMetaDataType = eUnsignedInt32Array; 00354 if(xpaintValue && xintNumValues) { 00355 mpaEntries[lintEntry].muValue.mpaint = 00356 new UnsignedInt32[xintNumValues]; 00357 if(!mpaEntries[lintEntry].muValue.mpaint) 00358 throw CCubitFile::eMemoryError; 00359 memcpy(mpaEntries[lintEntry].muValue.mpaint, xpaintValue, 00360 xintNumValues * sizeof(UnsignedInt32)); 00361 mpaEntries[lintEntry].mintNumValues = xintNumValues; 00362 } 00363 else { 00364 mpaEntries[lintEntry].muValue.mpaint = NULL; 00365 mpaEntries[lintEntry].mintNumValues = 0; 00366 } 00367 00368 return CCubitFile::eSuccess; 00369 } 00370 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00371 catch(...) { return CCubitFile::eUnknownError; } 00372 } 00373 00374 UnsignedInt32 CMetaData::SetValue(UnsignedInt32 xintOwner, 00375 ConstCharPtr xpachrName, 00376 const double* xpadblValue, 00377 UnsignedInt32 xintNumValues) 00378 // Assign double array valued meta-data to an id and name. 00379 // Public function, returns CCubitFile::EErrorCode, no exceptions thrown. 00380 { 00381 if(!xpachrName) 00382 throw CCubitFile::ePassedNullPointer; 00383 00384 try { 00385 UnsignedInt32 lintEntry; 00386 if(Find(xintOwner, xpachrName, lintEntry)) 00387 FreeValueAt(lintEntry); 00388 else 00389 lintEntry = AddEntry(xintOwner, xpachrName); 00390 00391 mpaEntries[lintEntry].mintMetaDataType = eDoubleArray; 00392 if(xpadblValue && xintNumValues) { 00393 mpaEntries[lintEntry].muValue.mpadbl = 00394 new double[xintNumValues]; 00395 if(!mpaEntries[lintEntry].muValue.mpadbl) 00396 throw CCubitFile::eMemoryError; 00397 memcpy(mpaEntries[lintEntry].muValue.mpadbl, xpadblValue, 00398 xintNumValues * sizeof(double)); 00399 mpaEntries[lintEntry].mintNumValues = xintNumValues; 00400 } 00401 else { 00402 mpaEntries[lintEntry].muValue.mpadbl = NULL; 00403 mpaEntries[lintEntry].mintNumValues = 0; 00404 } 00405 00406 return CCubitFile::eSuccess; 00407 } 00408 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00409 catch(...) { return CCubitFile::eUnknownError; } 00410 } 00411 00412 00413 00415 // Search Methods 00417 00418 00419 //----------------------------------------------------------------------------- 00420 00421 //----------------------------------------------------------------------------- 00422 00423 UnsignedInt32 CMetaData::GetMetaDataAll(UnsignedInt32& xintNumFound, 00424 const ConstCharPtr*& xpapachrName, 00425 const UnsignedInt32*& xpaintOwner, 00426 const UnsignedInt32*& xpaintValue) 00427 // Search the meta-data for all entries of type integer. 00428 { 00429 xintNumFound = 0; 00430 xpapachrName = NULL; 00431 xpaintOwner = NULL; 00432 xpaintValue = NULL; 00433 try { RebuildSearchBuff(eUnsignedInt32); } 00434 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00435 catch(...) { return CCubitFile::eUnknownError; } 00436 00437 if((xintNumFound = SearchAll(eUnsignedInt32)) > 0) { 00438 xpapachrName = mSearchBuff.mpapachrNames; 00439 xpaintOwner = mSearchBuff.mpaintOwners; 00440 xpaintValue = (UnsignedInt32*)mSearchBuff.mpaValues; 00441 } 00442 return CCubitFile::eSuccess; 00443 } 00444 00445 UnsignedInt32 CMetaData::GetMetaDataAll(UnsignedInt32& xintNumFound, 00446 const ConstCharPtr*& xpapachrName, 00447 const UnsignedInt32*& xpaintOwner, 00448 const ConstCharPtr*& xpapachrValue) 00449 // Search the meta-data for all entries of type string. 00450 { 00451 xintNumFound = 0; 00452 xpapachrName = NULL; 00453 xpaintOwner = NULL; 00454 xpapachrValue = NULL; 00455 try { RebuildSearchBuff(eString); } 00456 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00457 catch(...) { return CCubitFile::eUnknownError; } 00458 00459 if((xintNumFound = SearchAll(eString)) > 0) { 00460 xpapachrName = mSearchBuff.mpapachrNames; 00461 xpaintOwner = mSearchBuff.mpaintOwners; 00462 xpapachrValue = (ConstCharPtr*)mSearchBuff.mpaValues; 00463 } 00464 return CCubitFile::eSuccess; 00465 } 00466 00467 UnsignedInt32 CMetaData::GetMetaDataAll(UnsignedInt32& xintNumFound, 00468 const ConstCharPtr*& xpapachrName, 00469 const UnsignedInt32*& xpaintOwner, 00470 const double*& xpadblValue) 00471 // Search the meta-data for all entries of type double. 00472 { 00473 xintNumFound = 0; 00474 xpapachrName = NULL; 00475 xpaintOwner = NULL; 00476 xpadblValue = NULL; 00477 try { RebuildSearchBuff(eDouble); } 00478 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00479 catch(...) { return CCubitFile::eUnknownError; } 00480 00481 if((xintNumFound = SearchAll(eDouble)) > 0) { 00482 xpapachrName = mSearchBuff.mpapachrNames; 00483 xpaintOwner = mSearchBuff.mpaintOwners; 00484 xpadblValue = (double*)mSearchBuff.mpaValues; 00485 } 00486 return CCubitFile::eSuccess; 00487 } 00488 00489 UnsignedInt32 CMetaData::GetMetaDataAll(UnsignedInt32& xintNumFound, 00490 const ConstCharPtr*& xpapachrName, 00491 const UnsignedInt32*& xpaintOwner, 00492 const ConstUnsignedInt32Ptr*& xpapaintValue, 00493 const UnsignedInt32*& xpaintNumValues) 00494 // Search the meta-data for all entries of type integer array. 00495 { 00496 xintNumFound = 0; 00497 xpapachrName = NULL; 00498 xpaintOwner = NULL; 00499 xpapaintValue = NULL; 00500 xpaintNumValues = NULL; 00501 try { RebuildSearchBuff(eUnsignedInt32Array); } 00502 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00503 catch(...) { return CCubitFile::eUnknownError; } 00504 00505 if((xintNumFound = SearchAll(eUnsignedInt32Array)) > 0) { 00506 xpapachrName = mSearchBuff.mpapachrNames; 00507 xpaintOwner = mSearchBuff.mpaintOwners; 00508 xpapaintValue = (ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues; 00509 xpaintNumValues = mSearchBuff.mpaintNumValues; 00510 } 00511 return CCubitFile::eSuccess; 00512 } 00513 00514 UnsignedInt32 CMetaData::GetMetaDataAll(UnsignedInt32& xintNumFound, 00515 const ConstCharPtr*& xpapachrName, 00516 const UnsignedInt32*& xpaintOwner, 00517 const ConstDoublePtr*& xpapadblValue, 00518 const UnsignedInt32*& xpaintNumValues) 00519 // Search the meta-data for all entries of type double array. 00520 { 00521 xintNumFound = 0; 00522 xpapachrName = NULL; 00523 xpaintOwner = NULL; 00524 xpapadblValue = NULL; 00525 xpaintNumValues = NULL; 00526 try { RebuildSearchBuff(eDoubleArray); } 00527 catch(CCubitFile::EErrorCode xeErrorCode) { return xeErrorCode; } 00528 catch(...) { return CCubitFile::eUnknownError; } 00529 00530 if((xintNumFound = SearchAll(eDoubleArray)) > 0) { 00531 xpapachrName = mSearchBuff.mpapachrNames; 00532 xpaintOwner = mSearchBuff.mpaintOwners; 00533 xpapadblValue = (ConstDoublePtr*)mSearchBuff.mpaValues; 00534 xpaintNumValues = mSearchBuff.mpaintNumValues; 00535 } 00536 return CCubitFile::eSuccess; 00537 } 00538 00539 00540 //----------------------------------------------------------------------------- 00541 00542 void CMetaData::RebuildSearchBuff(UnsignedInt32 xintSearchType) 00543 // Grow the search return buffer of the class to match the current storage 00544 // buffer size and fit it for the passed return type. 00545 { 00546 if(!mintBufferSize) return; 00547 00548 if(mSearchBuff.mintNumOwners < mintBufferSize) { 00549 if(mSearchBuff.mpaintOwners) 00550 delete [] mSearchBuff.mpaintOwners; 00551 mSearchBuff.mpaintOwners = new UnsignedInt32[mintBufferSize]; 00552 mSearchBuff.mintNumOwners = mintBufferSize; 00553 if(!mSearchBuff.mpaintOwners) { 00554 mSearchBuff.mintNumOwners = 0; 00555 throw CCubitFile::eMemoryError; 00556 } 00557 } 00558 if(mSearchBuff.mintNumNames < mintBufferSize) { 00559 if(mSearchBuff.mpapachrNames) 00560 delete [] mSearchBuff.mpapachrNames; 00561 mSearchBuff.mpapachrNames = new ConstCharPtr[mintBufferSize]; 00562 mSearchBuff.mintNumNames = mintBufferSize; 00563 if(!mSearchBuff.mpapachrNames) { 00564 mSearchBuff.mintNumNames = 0; 00565 throw CCubitFile::eMemoryError; 00566 } 00567 } 00568 if((mSearchBuff.mintNumMetaData < mintBufferSize) || 00569 (mSearchBuff.mintMetaDataType != xintSearchType)) { 00570 if(mSearchBuff.mpaValues) { 00571 switch(mSearchBuff.mintMetaDataType) { 00572 case eUnsignedInt32: 00573 delete [] (UnsignedInt32*)mSearchBuff.mpaValues; break; 00574 case eString: 00575 delete [] (ConstCharPtr*)mSearchBuff.mpaValues; break; 00576 case eDouble: 00577 delete [] (double*)mSearchBuff.mpaValues; break; 00578 case eUnsignedInt32Array: 00579 delete [] (ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues; break; 00580 case eDoubleArray: 00581 delete [] (ConstDoublePtr*)mSearchBuff.mpaValues; break; 00582 } 00583 } 00584 if(mSearchBuff.mpaintNumValues) 00585 delete [] mSearchBuff.mpaintNumValues; 00586 mSearchBuff.mintMetaDataType = xintSearchType; 00587 mSearchBuff.mintNumMetaData = mintBufferSize; 00588 00589 switch(mSearchBuff.mintMetaDataType) { 00590 case eUnsignedInt32: 00591 mSearchBuff.mpaValues = new UnsignedInt32[mintBufferSize]; 00592 break; 00593 case eString: 00594 mSearchBuff.mpaValues = new ConstCharPtr[mintBufferSize]; 00595 break; 00596 case eDouble: 00597 mSearchBuff.mpaValues = new double[mintBufferSize]; 00598 break; 00599 case eUnsignedInt32Array: 00600 mSearchBuff.mpaValues = new ConstUnsignedInt32Ptr[mintBufferSize]; 00601 break; 00602 case eDoubleArray: 00603 mSearchBuff.mpaValues = new ConstDoublePtr[mintBufferSize]; 00604 break; 00605 } 00606 if(!mSearchBuff.mpaValues) { 00607 mSearchBuff.mintNumMetaData = 0; 00608 throw CCubitFile::eMemoryError; 00609 } 00610 00611 switch(mSearchBuff.mintMetaDataType) { 00612 case eUnsignedInt32Array: 00613 case eDoubleArray: 00614 mSearchBuff.mpaintNumValues = new UnsignedInt32[mintBufferSize]; 00615 if(!mSearchBuff.mpaintNumValues) { 00616 mSearchBuff.mintMetaDataType = 0; 00617 switch(mSearchBuff.mintMetaDataType) { 00618 case eUnsignedInt32: 00619 delete [] (UnsignedInt32*)mSearchBuff.mpaValues; break; 00620 case eString: 00621 delete [] (ConstCharPtr*)mSearchBuff.mpaValues; break; 00622 case eDouble: 00623 delete [] (double*)mSearchBuff.mpaValues; break; 00624 case eUnsignedInt32Array: 00625 delete [] (ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues; break; 00626 case eDoubleArray: 00627 delete [] (ConstDoublePtr*)mSearchBuff.mpaValues; break; 00628 } 00629 mSearchBuff.mpaValues = NULL; 00630 throw CCubitFile::eMemoryError; 00631 } 00632 break; 00633 default: 00634 mSearchBuff.mpaintNumValues = NULL; 00635 } 00636 } 00637 } 00638 00639 UnsignedInt32 CMetaData::SearchByID(UnsignedInt32 xintSearchType, 00640 UnsignedInt32 xintOwner) 00641 // Traverses the meta-data entries to find entries with an owner id matching 00642 // the passed one and copies the values and names of those entries to the 00643 // search buffer. 00644 // Private function, returns the number of entries meeting the search criteria, 00645 // no exceptions thrown. 00646 { 00647 if(!mHeader.mintMetaDataCount) return 0; // none found 00648 00649 UnsignedInt32 lintNumFound = 0; 00650 for(UnsignedInt32 lintEntry = 0; lintEntry < 00651 mHeader.mintMetaDataCount; lintEntry++) { 00652 if(mpaEntries[lintEntry].mintMetaDataOwner == xintOwner) { 00653 if(mpaEntries[lintEntry].mintMetaDataType == xintSearchType) { 00654 mSearchBuff.mpapachrNames[lintNumFound] = 00655 mpaEntries[lintEntry].mpachrName; 00656 switch(xintSearchType) { 00657 case eUnsignedInt32: 00658 ((UnsignedInt32*)mSearchBuff.mpaValues)[lintNumFound] = 00659 mpaEntries[lintEntry].muValue.mint; 00660 break; 00661 case eString: 00662 ((ConstCharPtr*)mSearchBuff.mpaValues)[lintNumFound] = 00663 mpaEntries[lintEntry].muValue.mpachr; 00664 break; 00665 case eDouble: 00666 ((double*)mSearchBuff.mpaValues)[lintNumFound] = 00667 mpaEntries[lintEntry].muValue.mdbl; 00668 break; 00669 case eUnsignedInt32Array: 00670 ((ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues)[lintNumFound] = 00671 mpaEntries[lintEntry].muValue.mpaint; 00672 mSearchBuff.mpaintNumValues[lintNumFound] = 00673 mpaEntries[lintEntry].mintNumValues; 00674 break; 00675 case eDoubleArray: 00676 ((ConstDoublePtr*)mSearchBuff.mpaValues)[lintNumFound] = 00677 mpaEntries[lintEntry].muValue.mpadbl; 00678 mSearchBuff.mpaintNumValues[lintNumFound] = 00679 mpaEntries[lintEntry].mintNumValues; 00680 break; 00681 } 00682 lintNumFound++; 00683 } 00684 } 00685 } 00686 return lintNumFound; // return number found 00687 } 00688 00689 UnsignedInt32 CMetaData::SearchByName(UnsignedInt32 xintSearchType, 00690 const char* xpachrName) 00691 // Traverses the meta-data entries to find entries with an name matching 00692 // the passed one and copies the owner id's and names of those entries to the 00693 // search buffer. 00694 // Private function, returns the number of entries meeting the search criteria, 00695 // no exceptions thrown. 00696 { 00697 if(!mHeader.mintMetaDataCount) return 0; // none found 00698 00699 UnsignedInt32 lintNumFound = 0; 00700 for(UnsignedInt32 lintEntry = 0; lintEntry < 00701 mHeader.mintMetaDataCount; lintEntry++) { 00702 if(!std::strcmp(xpachrName, mpaEntries[lintEntry].mpachrName)) { 00703 if(mpaEntries[lintEntry].mintMetaDataType == xintSearchType) { 00704 mSearchBuff.mpaintOwners[lintNumFound] = 00705 mpaEntries[lintEntry].mintMetaDataOwner; 00706 switch(xintSearchType) { 00707 case eUnsignedInt32: 00708 ((UnsignedInt32*)mSearchBuff.mpaValues)[lintNumFound] = 00709 mpaEntries[lintEntry].muValue.mint; 00710 break; 00711 case eString: 00712 ((ConstCharPtr*)mSearchBuff.mpaValues)[lintNumFound] = 00713 mpaEntries[lintEntry].muValue.mpachr; 00714 break; 00715 case eDouble: 00716 ((double*)mSearchBuff.mpaValues)[lintNumFound] = 00717 mpaEntries[lintEntry].muValue.mdbl; 00718 break; 00719 case eUnsignedInt32Array: 00720 ((ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues)[lintNumFound] = 00721 mpaEntries[lintEntry].muValue.mpaint; 00722 mSearchBuff.mpaintNumValues[lintNumFound] = 00723 mpaEntries[lintEntry].mintNumValues; 00724 break; 00725 case eDoubleArray: 00726 ((ConstDoublePtr*)mSearchBuff.mpaValues)[lintNumFound] = 00727 mpaEntries[lintEntry].muValue.mpadbl; 00728 mSearchBuff.mpaintNumValues[lintNumFound] = 00729 mpaEntries[lintEntry].mintNumValues; 00730 break; 00731 } 00732 lintNumFound++; 00733 } 00734 } 00735 } 00736 return lintNumFound; // return number found 00737 } 00738 00739 UnsignedInt32 CMetaData::SearchAll(UnsignedInt32 xintSearchType) 00740 // Traverses the meta-data entries to find all entries of the passed type. 00741 // Private function, returns the number of entries meeting the search criteria, 00742 // no exceptions thrown. 00743 { 00744 if(!mHeader.mintMetaDataCount) return 0; // none found 00745 00746 UnsignedInt32 lintNumFound = 0; 00747 for(UnsignedInt32 lintEntry = 0; lintEntry < 00748 mHeader.mintMetaDataCount; lintEntry++) { 00749 if(mpaEntries[lintEntry].mintMetaDataType == xintSearchType) { 00750 mSearchBuff.mpapachrNames[lintNumFound] = 00751 mpaEntries[lintEntry].mpachrName; 00752 mSearchBuff.mpaintOwners[lintNumFound] = 00753 mpaEntries[lintEntry].mintMetaDataOwner; 00754 switch(xintSearchType) { 00755 case eUnsignedInt32: 00756 ((UnsignedInt32*)mSearchBuff.mpaValues)[lintNumFound] = 00757 mpaEntries[lintEntry].muValue.mint; 00758 break; 00759 case eString: 00760 ((ConstCharPtr*)mSearchBuff.mpaValues)[lintNumFound] = 00761 mpaEntries[lintEntry].muValue.mpachr; 00762 break; 00763 case eDouble: 00764 ((double*)mSearchBuff.mpaValues)[lintNumFound] = 00765 mpaEntries[lintEntry].muValue.mdbl; 00766 break; 00767 case eUnsignedInt32Array: 00768 ((ConstUnsignedInt32Ptr*)mSearchBuff.mpaValues)[lintNumFound] = 00769 mpaEntries[lintEntry].muValue.mpaint; 00770 mSearchBuff.mpaintNumValues[lintNumFound] = 00771 mpaEntries[lintEntry].mintNumValues; 00772 break; 00773 case eDoubleArray: 00774 ((ConstDoublePtr*)mSearchBuff.mpaValues)[lintNumFound] = 00775 mpaEntries[lintEntry].muValue.mpadbl; 00776 mSearchBuff.mpaintNumValues[lintNumFound] = 00777 mpaEntries[lintEntry].mintNumValues; 00778 break; 00779 } 00780 lintNumFound++; 00781 } 00782 } 00783 return lintNumFound; // return number found 00784 } 00785 00786 00787 00789 // Deletion functions 00791 00792 UnsignedInt32 CMetaData::ClearMetaDataForID(UnsignedInt32 xintOwner) 00793 // Delete all meta-data entries with the same owner. 00794 { 00795 if(mHeader.mintMetaDataCount) { 00796 for(UnsignedInt32 lintEntry = 0; lintEntry < 00797 mHeader.mintMetaDataCount; lintEntry++) { 00798 if(mpaEntries[lintEntry].mintMetaDataOwner == xintOwner) 00799 FreeAt(lintEntry); 00800 } 00801 } 00802 return CCubitFile::eSuccess; 00803 } 00804 00805 void CMetaData::FreeValueAt(UnsignedInt32 xintEntry) 00806 // Frees any allocated memory associated with the value of the meta-data stored 00807 // at the passed index. Private function, no exceptions thrown. 00808 { 00809 switch(mpaEntries[xintEntry].mintMetaDataType) { 00810 case eString: 00811 if(mpaEntries[xintEntry].muValue.mpachr) 00812 delete [] mpaEntries[xintEntry].muValue.mpachr; 00813 mpaEntries[xintEntry].muValue.mpachr = NULL; 00814 break; 00815 case eUnsignedInt32Array: 00816 if(mpaEntries[xintEntry].muValue.mpaint) 00817 delete [] mpaEntries[xintEntry].muValue.mpaint; 00818 mpaEntries[xintEntry].muValue.mpaint = NULL; 00819 break; 00820 case eDoubleArray: 00821 if(mpaEntries[xintEntry].muValue.mpadbl) 00822 delete [] mpaEntries[xintEntry].muValue.mpadbl; 00823 mpaEntries[xintEntry].muValue.mpadbl = NULL; 00824 break; 00825 } 00826 } 00827 00828 void CMetaData::FreeAt(UnsignedInt32 xintEntry) 00829 // Frees the meta-data at the passed index and moves all data at higher indices 00830 // down to close the gap. Private function, no exceptions thrown. 00831 { 00832 // Free the allocated memory for an entry. 00833 delete [] mpaEntries[xintEntry].mpachrName; 00834 FreeValueAt(xintEntry); 00835 mHeader.mintMetaDataCount--; 00836 00837 // Move all entries in the meta-data table ahead of the deleted one down 00838 // to fill in the gap. 00839 if(xintEntry < mHeader.mintMetaDataCount) { 00840 for(UnsignedInt32 lintCopyTo = xintEntry; lintCopyTo < 00841 mHeader.mintMetaDataCount; lintCopyTo++) { 00842 memcpy(&mpaEntries[lintCopyTo], &mpaEntries[lintCopyTo + 1], 00843 sizeof(SCubitFileMetaDataEntry)); 00844 } 00845 } 00846 } 00847 00848 void CMetaData::FreeAll() 00849 // Frees all memory used to store meta-data data and resets the object back 00850 // to its constructed state. (Has no effect on the return buffers.) 00851 // Private function, no exceptions thrown. 00852 { 00853 if(mHeader.mintMetaDataCount) { 00854 for(UnsignedInt32 lintEntry = 0; lintEntry < mintBufferSize; lintEntry++) { 00855 if(mpaEntries[lintEntry].mpachrName) 00856 delete [] mpaEntries[lintEntry].mpachrName; 00857 FreeValueAt(lintEntry); 00858 } 00859 delete [] mpaEntries; 00860 mHeader.mintMetaDataCount = 0; 00861 mintBufferSize = 0; 00862 mpaEntries = NULL; 00863 } 00864 mHeader.mintMetaDataSchema = 0; 00865 mHeader.mintMetaDataCompress = 0; 00866 } 00867 00868 00870 // Read / Write File Methods 00872 00873 void CMetaData::WriteMetaData(FILE* xpFile, 00874 UnsignedInt32& xintWroteAtOffset, 00875 UnsignedInt32& xintLength, 00876 UnsignedInt32 xintOffsetFrom) 00877 // Write the meta-data stored in this object to the passed file. The file 00878 // position, offset from an optional passed value, and length are returned. 00879 { 00880 if(!xpFile) throw CCubitFile::eFileWriteError; 00881 00882 CIOWrapper* lpIO = new CIOWrapper(xpFile); 00883 xintWroteAtOffset = lpIO->BeginWriteBlock(xintOffsetFrom); 00884 00885 // Write a description header. 00886 lpIO->Write(&mHeader.mintMetaDataSchema, 1); 00887 lpIO->Write(&mHeader.mintMetaDataCompress, 1); 00888 lpIO->Write(&mHeader.mintMetaDataCount, 1); 00889 00890 // Write the actual meta-data entries. 00891 UnsignedInt32 lintEntry, lintNumEntries = mHeader.mintMetaDataCount; 00892 if(lintNumEntries) { 00893 for(lintEntry = 0; lintEntry < lintNumEntries; lintEntry++) { 00894 lpIO->Write(&mpaEntries[lintEntry].mintMetaDataOwner, 1); 00895 lpIO->Write(&mpaEntries[lintEntry].mintMetaDataType, 1); 00896 lpIO->Write(mpaEntries[lintEntry].mpachrName); 00897 switch(mpaEntries[lintEntry].mintMetaDataType) { 00898 case eUnsignedInt32: 00899 lpIO->Write(&mpaEntries[lintEntry].muValue.mint, 1); 00900 break; 00901 case eString: 00902 lpIO->Write(mpaEntries[lintEntry].muValue.mpachr); 00903 break; 00904 case eDouble: 00905 lpIO->Write(&mpaEntries[lintEntry].muValue.mdbl, 1); 00906 break; 00907 case eUnsignedInt32Array: 00908 lpIO->Write(&mpaEntries[lintEntry].mintNumValues, 1); 00909 if(mpaEntries[lintEntry].mintNumValues) { 00910 lpIO->Write(mpaEntries[lintEntry].muValue.mpaint, 00911 mpaEntries[lintEntry].mintNumValues); 00912 } 00913 break; 00914 case eDoubleArray: 00915 lpIO->Write(&mpaEntries[lintEntry].mintNumValues, 1); 00916 if(mpaEntries[lintEntry].mintNumValues) { 00917 lpIO->Write(mpaEntries[lintEntry].muValue.mpadbl, 00918 mpaEntries[lintEntry].mintNumValues); 00919 } 00920 break; 00921 } 00922 } 00923 } 00924 xintLength = lpIO->EndWriteBlock(); 00925 delete lpIO; 00926 } 00927 00928 void CMetaData::ReadMetaData(FILE* xpFile, 00929 UnsignedInt32 xintAbsoluteOffset, 00930 UnsignedInt32 xintRelativeOffset, 00931 UnsignedInt32 xintSourceEndian) 00932 // Reset the meta-data object and then fill it with data read from a passed 00933 // file at the passed location. The data will be in the passed endian format 00934 // which is not stored with the meta-data itself as the meta-data is never 00935 // fully independent. 00936 { 00937 // Delete all stored data 00938 FreeAll(); 00939 00940 if(!xpFile) throw CCubitFile::eFileReadError; 00941 00942 CIOWrapper* lpIO = new CIOWrapper(xpFile, xintSourceEndian); 00943 lpIO->BeginReadBlock(xintAbsoluteOffset, xintRelativeOffset); 00944 00945 // Read the description header. 00946 lpIO->Read(&mHeader.mintMetaDataSchema, 1); 00947 lpIO->Read(&mHeader.mintMetaDataCompress, 1); 00948 lpIO->Read(&mHeader.mintMetaDataCount, 1); 00949 00950 UnsignedInt32 lintEntry, lintNumEntries = mHeader.mintMetaDataCount; 00951 if(lintNumEntries) { 00952 // Grow the storage capacity of the meta-data object to match that of 00953 // the stored data. 00954 UnsignedInt32 lintGrowSizeBy = mintGrowSizeBy; 00955 mintGrowSizeBy = lintNumEntries; 00956 GrowSize(); 00957 mintGrowSizeBy = lintGrowSizeBy; 00958 00959 // Read the stored meta-data entries. 00960 for(lintEntry = 0; lintEntry < lintNumEntries; lintEntry++) { 00961 lpIO->Read(&mpaEntries[lintEntry].mintMetaDataOwner, 1); 00962 lpIO->Read(&mpaEntries[lintEntry].mintMetaDataType, 1); 00963 mpaEntries[lintEntry].mpachrName = lpIO->Read(); 00964 switch(mpaEntries[lintEntry].mintMetaDataType) { 00965 case eUnsignedInt32: 00966 lpIO->Read(&mpaEntries[lintEntry].muValue.mint, 1); 00967 break; 00968 case eString: 00969 mpaEntries[lintEntry].muValue.mpachr = lpIO->Read(); 00970 break; 00971 case eDouble: 00972 lpIO->Read(&mpaEntries[lintEntry].muValue.mdbl, 1); 00973 break; 00974 case eUnsignedInt32Array: 00975 lpIO->Read(&mpaEntries[lintEntry].mintNumValues, 1); 00976 if(mpaEntries[lintEntry].mintNumValues) { 00977 mpaEntries[lintEntry].muValue.mpaint = 00978 new UnsignedInt32[mpaEntries[lintEntry].mintNumValues]; 00979 if(!mpaEntries[lintEntry].muValue.mpaint) 00980 throw CCubitFile::eMemoryError; 00981 lpIO->Read(mpaEntries[lintEntry].muValue.mpaint, 00982 mpaEntries[lintEntry].mintNumValues); 00983 } 00984 break; 00985 case eDoubleArray: 00986 lpIO->Read(&mpaEntries[lintEntry].mintNumValues, 1); 00987 if(mpaEntries[lintEntry].mintNumValues) { 00988 mpaEntries[lintEntry].muValue.mpadbl = 00989 new double[mpaEntries[lintEntry].mintNumValues]; 00990 if(!mpaEntries[lintEntry].muValue.mpadbl) 00991 throw CCubitFile::eMemoryError; 00992 lpIO->Read(mpaEntries[lintEntry].muValue.mpadbl, 00993 mpaEntries[lintEntry].mintNumValues); 00994 } 00995 break; 00996 } 00997 } 00998 } 00999 delete lpIO; 01000 } 01001
