cgma
00001 //- Class: CubitMatrix 00002 //- 00003 //- Description: This file defines the CubitMatrix class which is a 00004 //- standard NxM Matrix. All relevant arithmetic operators are 00005 //- overloaded so CubitMatrix's can be used similar to built-in types. 00006 //- 00007 //- Owner: Dan Goodrich 00008 //- Checked by: 00009 00010 00011 #ifndef CUBITMATRIX_HPP 00012 #define CUBITMATRIX_HPP 00013 00014 #include "CubitVector.hpp" 00015 #include <vector> 00016 #include <stdexcept> 00017 #include <string> 00018 #include "CGMUtilConfigure.h" 00019 00020 class CUBIT_UTIL_EXPORT CubitMatrix 00021 { 00022 public: 00023 00024 //- Heading: Constructors and Destructor 00025 CubitMatrix(); 00026 //- Default constructor. 3x3 init to zeros. 00027 00028 CubitMatrix( const int num_rows, const int num_cols); 00029 //- Initializes NxM matrix to zeros. 00030 00031 CubitMatrix( const CubitVector& vec1, const CubitVector& vec2, 00032 const CubitVector& vec3); 00033 //- Constructor: create 3x3 Matrix from three vector components 00034 // where each vector forms one column of the matrix. 00035 00036 CubitMatrix( const CubitVector& vec1, const CubitVector& vec2, 00037 const CubitVector& vec3, const CubitVector& vec4 ); 00038 //- Constructor: create 3x4 Matrix from four vector components 00039 // where each vector forms one column of the matrix. 00040 00041 CubitMatrix( const CubitVector& vec1, const CubitVector& vec2 ); 00042 //- Constructor: create 3x3 Matrix from two vectors (otimes) 00043 // ( vec1 otimes vec2 )_ij = vec1_i * vec2_j 00044 00045 CubitMatrix( const int n ); 00046 //- Constructor: create n x n Identity matrix 00047 00048 CubitMatrix( std::vector<int> &is, std::vector<int> &js, std::vector<double> &es, int n, int m ); 00049 // - uses vectors i, j, and s to generate an m-by-n 00050 // - matrix, S, such that S(i(k),j(k)) = s(k). 00051 // - Vectors i, j, and s are all the same length. 00052 // - Any elements of s that have duplicate values of i and j are added 00053 // - together. 00054 00055 CubitMatrix( const CubitMatrix& matrix); 00056 //- Copy Constructor 00057 00058 virtual ~CubitMatrix(); 00059 //- destructor 00060 00061 void reset_size( const int n, const int m, double default_value = 0.0 ); 00062 //- resize this matrix and set all values to a default value. 00063 00064 //- Heading: Set and Inquire Functions 00065 int num_rows() const { return numRows; } 00066 int num_cols() const { return numCols; } 00067 00068 void print_matrix() const; 00069 void print_matrix( char *filename ) const; 00070 //- Prints matrix 00071 00072 void set_to_identity(); 00073 00074 bool is_identity( double tol = 1e-8 ) const; 00075 bool is_equal( const CubitMatrix &other, double tol = 1e-8 ) const; 00076 00077 //- Add an identity matrix into this matrix. 00078 void plus_identity(); 00079 00080 //- Change Matrix component row n, column m to val. 00081 void set(const int n, const int m, const double val) 00082 { 00083 if(n < 0 || n >= numRows || m < 0 || m >= numCols) 00084 throw std::invalid_argument (std::string("Index out of bounds")); 00085 //assert (n >= 0 && n < numRows); 00086 //assert (m >= 0 && m < numCols); 00087 matrixPtr[n][m] = val; 00088 } 00089 00090 //- add the value to the component row n col m 00091 void add(const int n, const int m, const double val) 00092 { 00093 matrixPtr[n][m] += val; 00094 } 00095 00096 //- Gets the values of the matrix at position (n,m) 00097 double get( int n, int m ) const 00098 { 00099 if(n < 0 || n >= numRows || m < 0 || m >= numCols) 00100 throw std::invalid_argument ("Index out of Bounds"); 00101 //assert (n >= 0 && n < numRows); 00102 //assert (m >= 0 && m < numCols); 00103 return matrixPtr[n][m]; 00104 } 00105 00106 //- Heading: Matrix Algebra functions 00107 // (assert if incompatible element sizes) 00108 CubitMatrix operator= (const CubitMatrix& matrix); 00109 CubitMatrix operator* (const CubitMatrix& matrix) const; 00110 CubitVector operator* (const CubitVector& vector) const; 00111 std::vector<double> operator* (const std::vector<double> & vector) const; 00112 CubitMatrix operator* (double val ) const; 00113 CubitMatrix operator/ (double val ) const; 00114 CubitMatrix operator+ (const CubitMatrix& matrix) const; 00115 CubitMatrix operator- (const CubitMatrix& matrix) const; 00116 00117 CubitMatrix& operator+=(const CubitMatrix &matrix); 00118 CubitMatrix& operator*=(const double multiplier); 00119 //- Scale the matrix by a linear factor: {this = this * multiplier}, 00120 00121 CubitMatrix inverse(); // inverts 1x1, 2x2, or 3x3 matrix 00122 // asserts if singular 00123 CubitMatrix symm() const; // returns matrix^transpose * matrix 00124 00125 CubitBoolean positive_definite() const; // returns true if matrix is positive definite 00126 00127 double determinant () const; 00128 double inf_norm () const; // infinity norm 00129 double frobenius_norm_squared() const; // square of frobenius norm of A 00130 double frobenius_norm_squared_symm() const; // square of frobenius norm of A^t A 00131 double frobenius_norm_squared_adj() const; // square of frobenius norm of adjoint A 00132 double frobenius_norm_squared_inv() const; // square of frobenius norm of A-inverse 00133 double condition() const; // condition number of A using frobenius norm 00134 int rank( void ) const; 00135 00136 double cofactor (const int row, const int col) const; 00137 CubitMatrix adjoint() const; 00138 CubitMatrix transpose() const; 00139 00140 // row and col indicate the row and column to leave out of the 00141 // resulting matrix. 00142 CubitMatrix sub_matrix( const int row, const int col ) const; 00143 00144 // Create a matrix containing the rows and cols of this that are true in 00145 // rows_to_include and cols_to_include. 00146 void sub_matrix( const std::vector<bool> &rows_to_include, 00147 const std::vector<bool> &cols_to_include, 00148 CubitMatrix &submatrix ); 00149 00150 // routines to perform Gaussian elimination with pivoting and scaling 00151 // on 3x3 matrix 00152 int gauss_elim (CubitVector &b); 00153 int factor (CubitVector &pivot); 00154 void solve (CubitVector &b, const CubitVector& pivot); 00155 00156 // routines to solve NxN system (from Numerical Recipes in C) 00157 CubitStatus solveNxN( CubitMatrix& rhs, // must be NxM, where M is any 00158 // number of colums. 00159 CubitMatrix& coef ); // must be NxM, same as rhs. 00160 CubitStatus solveNxN( const std::vector<double> &rhs, 00161 std::vector<double> &coef ); 00162 CubitStatus ludcmp( double *indx, double& d ); 00163 CubitStatus lubksb( double *indx, double *b ); 00164 00165 // matrix must have been sized to be 3x3 before calling. 00166 bool vector_outer_product(const CubitVector& vec1, 00167 const CubitVector& vec2 ); 00168 00169 private: 00170 double **matrixPtr; 00171 double *matrixMem; 00172 int numRows; 00173 int numCols; 00174 }; 00175 00176 #endif 00177 00178 00179
