cgma
00001 //- Class: CubitVector 00002 //- 00003 //- Description: This file defines the CubitVector class which is a 00004 //- standard three-dimensional vector. All relevant arithmetic 00005 //- operators are overloaded so CubitVectors can be used similar to 00006 //- built-in types. 00007 //- 00008 //- Owner: Greg Sjaardema 00009 //- Checked by: Randy Lober, January 94 00010 //- Version: $Id: 00011 00012 #ifndef CUBITVECTOR_HPP 00013 #define CUBITVECTOR_HPP 00014 00015 #include "CubitDefines.h" 00016 #include "CubitVectorStruct.h" 00017 #include "CGMUtilConfigure.h" 00018 00019 class CubitVector; 00020 typedef void ( CubitVector::*transform_function )( double gamma, 00021 double gamma2); 00022 // a pointer to some function that transforms the point, 00023 // taking a double parameter. e.g. blow_out, rotate, and scale_angle 00024 00025 class CUBIT_UTIL_EXPORT CubitVector 00026 { 00027 public: 00028 00029 //- Heading: Constructors and Destructor 00030 CubitVector(); //- Default constructor. 00031 00032 explicit CubitVector(const double x, const double y, const double z); 00033 //- Constructor: create vector from three components 00034 00035 explicit CubitVector( const double xyz[3] ); 00036 //- Constructor: create vector from tuple 00037 00038 explicit CubitVector (const CubitVector& tail, const CubitVector& head); 00039 //- Constructor for a CubitVector starting at tail and pointing 00040 //- to head. 00041 00042 CubitVector(const CubitVector& copy_from); //- Copy Constructor 00043 00044 explicit CubitVector(const CubitVectorStruct& from); 00045 00046 //- Heading: Set and Inquire Functions 00047 void set(const double x, const double y, const double z); 00048 //- Change vector components to {x}, {y}, and {z} 00049 00050 void set( const double xyz[3] ); 00051 //- Change vector components to xyz[0], xyz[1], xyz[2] 00052 00053 void set(const CubitVector& tail, const CubitVector& head); 00054 //- Change vector to go from tail to head. 00055 00056 void set(const CubitVector& to_copy); 00057 //- Same as i.=(const CubitVector&) 00058 00059 double x() const; //- Return x component of vector 00060 00061 double y() const; //- Return y component of vector 00062 00063 double z() const; //- Return z component of vector 00064 00065 double& x(); 00066 double& y(); 00067 double& z(); 00068 00069 void get_xyz( double &x, double &y, double &z ) const; //- Get x, y, z components 00070 void get_xyz( double xyz[3] ) const; //- Get xyz tuple 00071 00072 double &r(); //- Return r component of vector, if (r,theta) format 00073 00074 double &theta(); //- Return theta component of vector, if (r,theta) format 00075 00076 void x( const double x ); //- Set x component of vector 00077 00078 void y( const double y ); //- Set y component of vector 00079 00080 void z( const double z ); //- Set z component of vector 00081 00082 void r( const double x ); //- Set r component of vector, if (r,theta) format 00083 00084 void theta( const double y ); //- Set theta component of vector, if (r,theta) format 00085 00086 void xy_to_rtheta(); 00087 //- convert from cartesian to polar coordinates, just 2d for now 00088 //- theta is in [0,2 PI) 00089 00090 void rtheta_to_xy(); 00091 //- convert from polar to cartesian coordinates, just 2d for now 00092 00093 void scale_angle(double gamma, double ); 00094 //- tranform_function. 00095 //- transform (x,y) to (r,theta) to (r,gamma*theta) to (x',y') 00096 //- plus some additional scaling so long chords won't cross short ones 00097 00098 void blow_out(double gamma, double gamma2 = 0.0); 00099 //- transform_function 00100 //- blow points radially away from the origin, 00101 00102 void rotate(double angle, double ); 00103 //- transform function. 00104 //- transform (x,y) to (r,theta) to (r,theta+angle) to (x',y') 00105 00106 void project_to_plane( const CubitVector &planenormal ); 00107 //- project this vector onto a plane. 00108 00109 void project_to_line_segment( const CubitVector &pt0, const CubitVector &pt1 ); 00110 //- project this vector onto a line segment. 00111 00112 void reflect_about_xaxis(double dummy, double ); 00113 //- dummy argument to make it a transform function 00114 00115 double normalize(); 00116 //- Normalize (set magnitude equal to 1) vector - return the magnitude 00117 00118 CubitVector& length(const double new_length); 00119 //- Change length of vector to {new_length}. Can be used to move a 00120 //- location a specified distance from the origin in the current 00121 //- orientation. 00122 00123 double length() const; 00124 //- Calculate the length of the vector. 00125 //- Use {length_squared()} if only comparing lengths, not adding. 00126 00127 double distance_between(const CubitVector& test_vector) const; 00128 //- Calculate the distance from the head of one vector 00129 // to the head of the test_vector. 00130 00131 double distance_between_squared(const CubitVector& test_vector) const; 00132 //- Calculate the distance squared from the head of one vector 00133 // to the head of the test_vector. 00134 00135 double distance_from_infinite_line(const CubitVector& point_on_line, 00136 const CubitVector& line_direction) const; 00137 //- Calculate the minimum distance between the head of this vector and a 00138 // line of infinite length. 00139 00140 double distance_from_infinite_line_squared(const CubitVector& point_on_line, 00141 const CubitVector& line_direction) const; 00142 //- Calculate the square of the minimum distance between the head of this 00143 // vector and a line of infinite length. 00144 00145 double length_squared() const; 00146 //- Calculate the squared length of the vector. 00147 //- Faster than {length()} since it eliminates the square root if 00148 //- only comparing other lengths. 00149 00150 double interior_angle(const CubitVector &otherVector) const; 00151 //- Calculate the interior angle: acos((a%b)/(|a||b|)) 00152 //- Returns angle in degrees. 00153 00154 static bool colinear( const CubitVector &p0, 00155 const CubitVector &p1, 00156 const CubitVector &p2 ); 00157 //- determine if 3 points are colinear. 00158 00159 static CubitVector normal( const CubitVector &p0, 00160 const CubitVector &p1, 00161 const CubitVector &p2 ); 00162 //- normal given 3 positions. 00163 00164 static bool barycentric_coordinates( const CubitVector &v1, 00165 const CubitVector &v2, 00166 const CubitVector &v3, 00167 const CubitVector &point, 00168 double &coord_A, 00169 double &coord_B, 00170 double &coord_C ); 00171 00172 double vector_angle_quick(const CubitVector& vec1, const CubitVector& vec2); 00173 //- Calculate the interior angle between the projections of 00174 //- {vec1} and {vec2} onto the plane defined by the {this} vector. 00175 //- The angle returned is the right-handed angle around the {this} 00176 //- vector from {vec1} to {vec2}. Angle is in radians. 00177 00178 double vector_angle( const CubitVector &vector1, 00179 const CubitVector &vector2) const; 00180 //- Compute the angle between the projections of {vector1} and {vector2} 00181 //- onto the plane defined by *this. The angle is the 00182 //- right-hand angle, in radians, about *this from {vector1} to {vector2}. 00183 00184 void perpendicular_z(); 00185 //- Transform this vector to a perpendicular one, leaving 00186 //- z-component alone. Rotates clockwise about the z-axis by pi/2. 00187 00188 void print_me(); 00189 //- Prints out the coordinates of this vector. 00190 00191 void orthogonal_vectors( CubitVector &vector2, CubitVector &vector3 ) const; 00192 //- Finds 2 (arbitrary) vectors that are orthogonal to this one 00193 00194 void next_point( const CubitVector &direction, double distance, 00195 CubitVector& out_point ) const; 00196 //- Finds the next point in space based on *this* point (starting point), 00197 //- a direction and the distance to extend in the direction. The 00198 //- direction vector need not be a unit vector. The out_point can be 00199 //- "*this" (i.e., modify point in place). 00200 00201 CubitBoolean about_equal( const CubitVector &w, 00202 const double relative_tolerance = 1.0e-6, 00203 const double absolute_tolerance = 1.0e-6 ) const; 00204 // Return true if vectors are equal within either relative tolerance 00205 // or absolute tolerance. 00206 // 00207 // More specifically: 00208 // Return true if the magnitude of the difference is less than 00209 // 1. absolute_tolerance, 00210 // OR 00211 // 2. relative_tolerance times the magnitude of the vectors 00212 // 00213 // E.g. 00214 // if v = <1, 1.0e-7, 0>, w = <1, -1.0e-7, 0> and relative_tol = 1.0e-6, 00215 // then return true. 00216 00217 CubitBoolean within_tolerance(const CubitVector &vectorPtr2, 00218 double tolerance) const; 00219 //- Compare two vectors to see if they are spatially equal. 00220 // Return TRUE if difference in x, y, and z are all within tolerance. 00221 00222 CubitBoolean within_scaled_tolerance(const CubitVector &v2, double tol) const; 00223 // Return true if vectors are within_tolerance() or if, for each coord, 00224 // the ratio of the two vector's coords differs no more than tol from 1.0. 00225 // Can be used to see if two vectors are equal up to a certain number of 00226 // significant digits. For example, passing in a tolerance of 1e-6 will 00227 // return true if the two vectors are equal with 6 significant digits. 00228 00229 //- Heading: Operator Overloads ***************************** 00230 CubitVector& operator+=(const CubitVector &vec); 00231 //- Compound Assignment: addition: {this = this + vec} 00232 00233 CubitVector& operator-=(const CubitVector &vec); 00234 //- Compound Assignment: subtraction: {this = this - vec} 00235 00236 CubitVector& operator*=(const CubitVector &vec); 00237 //- Compound Assignment: cross product: {this = this * vec}, 00238 //- non-commutative 00239 00240 CubitVector& operator*=(const double scalar); 00241 //- Compound Assignment: multiplication: {this = this * scalar} 00242 00243 CubitVector& operator/=(const double scalar); 00244 //- Compound Assignment: division: {this = this / scalar} 00245 00246 CubitVector operator-() const; 00247 //- unary negation. 00248 00249 double operator[](int i) const; 00250 //- return the ith value of the vector (x, y, z) 00251 00252 friend CubitVector operator~(const CubitVector &vec); 00253 //- normalize. Returns a new vector which is a copy of {vec}, 00254 //- scaled such that {|vec|=1}. Uses overloaded bitwise NOT operator. 00255 00256 friend CubitVector operator+(const CubitVector &v1, 00257 const CubitVector &v2); 00258 //- vector addition 00259 00260 friend CubitVector operator-(const CubitVector &v1, 00261 const CubitVector &v2); 00262 //- vector subtraction 00263 00264 friend CubitVector operator*(const CubitVector &v1, 00265 const CubitVector &v2); 00266 //- vector cross product, non-commutative 00267 00268 friend CubitVector operator*(const CubitVector &v1, const double sclr); 00269 //- vector * scalar 00270 00271 friend CubitVector operator*(const double sclr, const CubitVector &v1); 00272 //- scalar * vector 00273 00274 friend double operator%(const CubitVector &v1, const CubitVector &v2); 00275 //- dot product 00276 00277 friend CubitVector operator/(const CubitVector &v1, const double sclr); 00278 //- vector / scalar 00279 00280 friend int operator==(const CubitVector &v1, const CubitVector &v2); 00281 //- Equality operator 00282 00283 friend int operator!=(const CubitVector &v1, const CubitVector &v2); 00284 //- Inequality operator 00285 00286 friend CubitVector interpolate(const double param, const CubitVector &v1, 00287 const CubitVector &v2); 00288 //- Interpolate between two vectors. Returns (1-param)*v1 + param*v2 00289 00290 CubitVector &operator=(const CubitVectorStruct &from); 00291 00292 operator CubitVectorStruct() 00293 { 00294 CubitVectorStruct to = {xVal, yVal, zVal}; 00295 return to; 00296 } 00297 00298 CubitVector &operator=(const CubitVector& from); 00299 00300 private: 00301 00302 double xVal; //- x component of vector. 00303 double yVal; //- y component of vector. 00304 double zVal; //- z component of vector. 00305 00306 static bool attempt_barycentric_coordinates_adjustment( const CubitVector &v1, 00307 const CubitVector &v2, 00308 const CubitVector &v3, 00309 const CubitVector &point, 00310 double &coord_A, 00311 double &coord_B, 00312 double &coord_C ); 00313 static bool private_barycentric_coordinates( bool adjust_on_fail, 00314 const CubitVector &v1, 00315 const CubitVector &v2, 00316 const CubitVector &v3, 00317 const CubitVector &point, 00318 double &coord_A, 00319 double &coord_B, 00320 double &coord_C ); 00321 00322 }; 00323 00324 CUBIT_UTIL_EXPORT CubitVector vectorRotate(const double angle, 00325 const CubitVector &normalAxis, 00326 const CubitVector &referenceAxis); 00327 //- A new coordinate system is created with the xy plane corresponding 00328 //- to the plane normal to {normalAxis}, and the x axis corresponding to 00329 //- the projection of {referenceAxis} onto the normal plane. The normal 00330 //- plane is the tangent plane at the root point. A unit vector is 00331 //- constructed along the local x axis and then rotated by the given 00332 //- ccw angle to form the new point. The new point, then is a unit 00333 //- distance from the global origin in the tangent plane. 00334 //- {angle} is in radians. 00335 00336 inline double CubitVector::x() const 00337 { return xVal; } 00338 inline double CubitVector::y() const 00339 { return yVal; } 00340 inline double CubitVector::z() const 00341 { return zVal; } 00342 inline double& CubitVector::x() 00343 { return xVal; } 00344 inline double& CubitVector::y() 00345 { return yVal; } 00346 inline double& CubitVector::z() 00347 { return zVal; } 00348 inline void CubitVector::get_xyz(double xyz[3]) const 00349 { 00350 xyz[0] = xVal; 00351 xyz[1] = yVal; 00352 xyz[2] = zVal; 00353 } 00354 inline void CubitVector::get_xyz(double &xOut, double &yOut, double &zOut) const 00355 { 00356 xOut = xVal; 00357 yOut = yVal; 00358 zOut = zVal; 00359 } 00360 inline double &CubitVector::r() 00361 { return xVal; } 00362 inline double &CubitVector::theta() 00363 { return yVal; } 00364 inline void CubitVector::x( const double xIn ) 00365 { xVal = xIn; } 00366 inline void CubitVector::y( const double yIn ) 00367 { yVal = yIn; } 00368 inline void CubitVector::z( const double zIn ) 00369 { zVal = zIn; } 00370 inline void CubitVector::r( const double xIn ) 00371 { xVal = xIn; } 00372 inline void CubitVector::theta( const double yIn ) 00373 { yVal = yIn; } 00374 inline CubitVector& CubitVector::operator+=(const CubitVector &v) 00375 { 00376 xVal += v.xVal; 00377 yVal += v.yVal; 00378 zVal += v.zVal; 00379 return *this; 00380 } 00381 00382 inline CubitVector& CubitVector::operator-=(const CubitVector &v) 00383 { 00384 xVal -= v.xVal; 00385 yVal -= v.yVal; 00386 zVal -= v.zVal; 00387 return *this; 00388 } 00389 00390 inline CubitVector& CubitVector::operator*=(const CubitVector &v) 00391 { 00392 double xcross, ycross, zcross; 00393 xcross = yVal * v.zVal - zVal * v.yVal; 00394 ycross = zVal * v.xVal - xVal * v.zVal; 00395 zcross = xVal * v.yVal - yVal * v.xVal; 00396 xVal = xcross; 00397 yVal = ycross; 00398 zVal = zcross; 00399 return *this; 00400 } 00401 00402 inline CubitVector::CubitVector(const CubitVector& copy_from) 00403 : xVal(copy_from.xVal), yVal(copy_from.yVal), zVal(copy_from.zVal) 00404 {} 00405 00406 inline CubitVector::CubitVector() 00407 : xVal(0), yVal(0), zVal(0) 00408 {} 00409 00410 inline CubitVector::CubitVector (const CubitVector& tail, 00411 const CubitVector& head) 00412 : xVal(head.xVal - tail.xVal), 00413 yVal(head.yVal - tail.yVal), 00414 zVal(head.zVal - tail.zVal) 00415 {} 00416 00417 inline CubitVector::CubitVector(const double xIn, 00418 const double yIn, 00419 const double zIn) 00420 : xVal(xIn), yVal(yIn), zVal(zIn) 00421 {} 00422 00423 inline CubitVector::CubitVector(const double xyz[3]) 00424 : xVal(xyz[0]), yVal(xyz[1]), zVal(xyz[2]) 00425 {} 00426 00427 // This sets the vector to be perpendicular to it's current direction. 00428 // NOTE: 00429 // This is a 2D function. It only works in the XY Plane. 00430 inline void CubitVector::perpendicular_z() 00431 { 00432 double temp = xVal; 00433 x( yVal ); 00434 y( -temp ); 00435 } 00436 00437 inline void CubitVector::set(const double xIn, 00438 const double yIn, 00439 const double zIn) 00440 { 00441 xVal = xIn; 00442 yVal = yIn; 00443 zVal = zIn; 00444 } 00445 00446 inline void CubitVector::set(const double xyz[3]) 00447 { 00448 xVal = xyz[0]; 00449 yVal = xyz[1]; 00450 zVal = xyz[2]; 00451 } 00452 00453 inline void CubitVector::set(const CubitVector& tail, 00454 const CubitVector& head) 00455 { 00456 xVal = head.xVal - tail.xVal; 00457 yVal = head.yVal - tail.yVal; 00458 zVal = head.zVal - tail.zVal; 00459 } 00460 00461 inline CubitVector& CubitVector::operator=(const CubitVector &from) 00462 { 00463 xVal = from.xVal; 00464 yVal = from.yVal; 00465 zVal = from.zVal; 00466 return *this; 00467 } 00468 00469 inline void CubitVector::set(const CubitVector& to_copy) 00470 { 00471 *this = to_copy; 00472 } 00473 00474 // Scale all values by scalar. 00475 inline CubitVector& CubitVector::operator*=(const double scalar) 00476 { 00477 xVal *= scalar; 00478 yVal *= scalar; 00479 zVal *= scalar; 00480 return *this; 00481 } 00482 00483 // Scales all values by 1/scalar 00484 inline CubitVector& CubitVector::operator/=(const double scalar) 00485 { 00486 if(scalar == 0) 00487 throw ("Cannot divide by zero."); 00488 //assert (scalar != 0); 00489 xVal /= scalar; 00490 yVal /= scalar; 00491 zVal /= scalar; 00492 return *this; 00493 } 00494 00495 inline CubitVector& CubitVector::operator=(const CubitVectorStruct &from) 00496 { 00497 xVal = from.xVal; 00498 yVal = from.yVal; 00499 zVal = from.zVal; 00500 return *this; 00501 } 00502 00503 inline CubitVector::CubitVector(const CubitVectorStruct &from) 00504 { 00505 xVal = from.xVal; 00506 yVal = from.yVal; 00507 zVal = from.zVal; 00508 } 00509 00510 // Returns the normalized 'this'. 00511 inline CubitVector operator~(const CubitVector &vec) 00512 { 00513 double mag = sqrt(vec.xVal*vec.xVal + 00514 vec.yVal*vec.yVal + 00515 vec.zVal*vec.zVal); 00516 00517 CubitVector temp = vec; 00518 if (mag != 0.0) 00519 { 00520 temp /= mag; 00521 } 00522 return temp; 00523 } 00524 00525 // Unary minus. Negates all values in vector. 00526 inline CubitVector CubitVector::operator-() const 00527 { 00528 return CubitVector(-xVal, -yVal, -zVal); 00529 } 00530 00531 inline double CubitVector::operator[](int i) const 00532 { 00533 if(i < 0 || i > 2) 00534 throw ("Index Out of Bounds"); 00535 //assert(i > -1 && i < 3); 00536 if (i == 0) return xVal; 00537 else if (i == 1) return yVal; 00538 else return zVal; 00539 } 00540 00541 inline CubitVector operator+(const CubitVector &vector1, 00542 const CubitVector &vector2) 00543 { 00544 double xv = vector1.xVal + vector2.xVal; 00545 double yv = vector1.yVal + vector2.yVal; 00546 double zv = vector1.zVal + vector2.zVal; 00547 return CubitVector(xv,yv,zv); 00548 // return CubitVector(vector1) += vector2; 00549 } 00550 00551 inline CubitVector operator-(const CubitVector &vector1, 00552 const CubitVector &vector2) 00553 { 00554 double xv = vector1.xVal - vector2.xVal; 00555 double yv = vector1.yVal - vector2.yVal; 00556 double zv = vector1.zVal - vector2.zVal; 00557 return CubitVector(xv,yv,zv); 00558 // return CubitVector(vector1) -= vector2; 00559 } 00560 00561 // Cross products. 00562 // vector1 cross vector2 00563 inline CubitVector operator*(const CubitVector &vector1, 00564 const CubitVector &vector2) 00565 { 00566 return CubitVector(vector1) *= vector2; 00567 } 00568 00569 // Returns a scaled vector. 00570 inline CubitVector operator*(const CubitVector &vector1, 00571 const double scalar) 00572 { 00573 return CubitVector(vector1) *= scalar; 00574 } 00575 00576 // Returns a scaled vector 00577 inline CubitVector operator*(const double scalar, 00578 const CubitVector &vector1) 00579 { 00580 return CubitVector(vector1) *= scalar; 00581 } 00582 00583 // Returns a vector scaled by 1/scalar 00584 inline CubitVector operator/(const CubitVector &vector1, 00585 const double scalar) 00586 { 00587 return CubitVector(vector1) /= scalar; 00588 } 00589 00590 inline int operator==(const CubitVector &v1, const CubitVector &v2) 00591 { 00592 return (v1.xVal == v2.xVal && v1.yVal == v2.yVal && v1.zVal == v2.zVal); 00593 } 00594 00595 inline int operator!=(const CubitVector &v1, const CubitVector &v2) 00596 { 00597 return (v1.xVal != v2.xVal || v1.yVal != v2.yVal || v1.zVal != v2.zVal); 00598 } 00599 00600 inline double CubitVector::length_squared() const 00601 { 00602 return( xVal*xVal + yVal*yVal + zVal*zVal ); 00603 } 00604 00605 inline double CubitVector::length() const 00606 { 00607 return( sqrt(xVal*xVal + yVal*yVal + zVal*zVal) ); 00608 } 00609 00610 inline double CubitVector::normalize() 00611 { 00612 double mag = length(); 00613 if (mag != 0) 00614 { 00615 xVal = xVal / mag; 00616 yVal = yVal / mag; 00617 zVal = zVal / mag; 00618 } 00619 return mag; 00620 } 00621 00622 00623 // Dot Product. 00624 inline double operator%(const CubitVector &vector1, 00625 const CubitVector &vector2) 00626 { 00627 return( vector1.xVal * vector2.xVal + 00628 vector1.yVal * vector2.yVal + 00629 vector1.zVal * vector2.zVal ); 00630 } 00631 00632 // Interpolate between two vectors. 00633 // Returns (1-param)*v1 + param*v2 00634 inline CubitVector interpolate(const double param, const CubitVector &v1, 00635 const CubitVector &v2) 00636 { 00637 CubitVector temp = (1.0 - param) * v1; 00638 temp += param * v2; 00639 return temp; 00640 } 00641 00642 inline CubitVector CubitVector::normal( const CubitVector &p0, 00643 const CubitVector &p1, 00644 const CubitVector &p2 ) 00645 { 00646 CubitVector edge0( p0, p1 ); 00647 CubitVector edge1( p0, p2 ); 00648 00649 return edge0 * edge1; // not normalized. 00650 } 00651 00652 #endif 00653
