cgma
00001 /* 00002 * 00003 * 00004 * Copyright (C) 2004 Sandia Corporation. Under the terms of Contract DE-AC04-94AL85000 00005 * with Sandia Corporation, the U.S. Government retains certain rights in this software. 00006 * 00007 * This file is part of facetbool--contact via [email protected] 00008 * 00009 * This library is free software; you can redistribute it and/or 00010 * modify it under the terms of the GNU Lesser General Public 00011 * License as published by the Free Software Foundation; either 00012 * version 2.1 of the License, or (at your option) any later version. 00013 * 00014 * This library is distributed in the hope that it will be useful, 00015 * but WITHOUT ANY WARRANTY; without even the implied warranty of 00016 * MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the GNU 00017 * Lesser General Public License for more details. 00018 * 00019 * You should have received a copy of the GNU Lesser General Public 00020 * License along with this library; if not, write to the Free Software 00021 * Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA 00022 * 00023 * 00024 * 00025 */ 00026 00027 #include <math.h> 00028 #include <algorithm> 00029 #include <vector> 00030 #include "CubitMessage.hpp" 00031 #include "FBTiler.hpp" 00032 00033 FBTiler::FBTiler(std::vector<FB_Coord *>& my_verts, int pd, int sd, int sequence, 00034 double a, double b, double c, 00035 std::vector<int> *tri_list) 00036 { 00037 00038 verts = my_verts; 00039 p_dir = pd; 00040 s_dir = sd; 00041 xnorm = a; 00042 ynorm = b; 00043 znorm = c; 00044 parent = sequence; 00045 my_tri_list = tri_list; 00046 } 00047 00048 FBTiler::~FBTiler() 00049 { 00050 00051 } 00052 00053 CubitStatus FBTiler::Tile_Poly(std::vector<int> *coordlist) 00054 { 00055 int v0, v1, v2, v3; 00056 std::vector<int>::iterator it, itmin, itmax; 00057 double min_p, min_s, max_p, max_s, test_p, test_s; 00058 CubitStatus status; 00059 00060 status = CUBIT_SUCCESS; 00061 00062 it = coordlist->begin(); 00063 00064 if ( coordlist->size() == 3 ) { 00065 v1 = *it++; v2 = *it++; v3 = *it++; 00066 add_triangle(v1, v2, v3); 00067 return status; 00068 } 00069 00070 // Get location in list of min and max coord in p_dir. 00071 min_p = min_s = CUBIT_DBL_MAX; 00072 max_p = max_s = -CUBIT_DBL_MAX; 00073 while ( it != coordlist->end() ) { 00074 v0 = *it; 00075 test_p = verts[v0]->coord[p_dir]; 00076 test_s = verts[v0]->coord[s_dir]; 00077 // if ( test_p < min_p ) { 00078 if ( (test_p - min_p) <= -EPSILON ) { 00079 itmin = it; 00080 min_p = test_p; 00081 if ( test_s < min_s ) 00082 min_s = test_s; 00083 } 00084 // if ( test_p > max_p ) { 00085 if ( (test_p - max_p) >= EPSILON ) { 00086 itmax = it; 00087 max_p = test_p; 00088 if ( test_s > max_s ) 00089 max_s = test_s; 00090 } 00091 if ( fabs(test_p - min_p) < EPSILON ) { 00092 if ( test_s < min_s ) { 00093 itmin = it; 00094 min_s = test_s; 00095 } 00096 } 00097 if ( fabs(test_p - max_p) < EPSILON ) { 00098 if ( test_s > max_s ) { 00099 itmax = it; 00100 max_s = test_s; 00101 } 00102 } 00103 00104 it++; 00105 } 00106 00107 // Now we've got to start at the min coord and make a single sorted list 00108 // of the coords, from min to max, noting whether the coord is on the 00109 // LEFT or RIGHT chain, or -- for the top and bottom coords -- on BOTH chains. 00110 00111 sortedchainlist.clear(); 00112 00113 std::vector<int>::iterator itleft, itright, itlistbegin, itlistend; 00114 it = itleft = itright = itmin; 00115 itlistbegin = coordlist->begin(); 00116 itlistend = coordlist->end(); 00117 00118 decrement_list_ptr(itleft,itlistbegin,itlistend); 00119 increment_list_ptr(itright,itlistbegin,itlistend); 00120 00121 v0 = *itmin; 00122 int v0left, v0right; 00123 double leftpdircoord, rightpdircoord; 00124 FBTilerChainVert *cvert; 00125 cvert = new FBTilerChainVert(v0,BOTH); 00126 sortedchainlist.push_back(cvert); 00127 v0left = *itleft; v0right = *itright; 00128 leftpdircoord = verts[v0left]->coord[p_dir]; 00129 rightpdircoord = verts[v0right]->coord[p_dir]; 00130 00131 while(1) { 00132 while ( (leftpdircoord - rightpdircoord) > -EPSILON2 ) { 00133 if ( itright == itmax ) break; 00134 v0 = v0right; 00135 cvert = new FBTilerChainVert(v0,LEFT); 00136 sortedchainlist.push_back(cvert); 00137 increment_list_ptr(itright,itlistbegin,itlistend); 00138 v0right = *itright; 00139 rightpdircoord = verts[v0right]->coord[p_dir]; 00140 00141 } 00142 while ( (rightpdircoord - leftpdircoord) > -EPSILON2 ) { 00143 if ( itleft == itmax ) break; 00144 v0 = v0left; 00145 cvert = new FBTilerChainVert(v0,RIGHT); 00146 sortedchainlist.push_back(cvert); 00147 decrement_list_ptr(itleft,itlistbegin,itlistend); 00148 v0left = *itleft; 00149 leftpdircoord = verts[v0left]->coord[p_dir]; 00150 00151 } 00152 if ( (itright == itmax) || (itleft == itmax) ) break; 00153 } 00154 00155 // In case we have some horizontal edges (wrt p_dir) left on the list, 00156 // the next two while statements will get them. 00157 while ( itright != itmax ) { 00158 v0 = v0right; 00159 cvert = new FBTilerChainVert(v0,LEFT); 00160 sortedchainlist.push_back(cvert); 00161 increment_list_ptr(itright,itlistbegin,itlistend); 00162 v0right = *itright; 00163 } 00164 while ( itleft != itmax ) { 00165 v0 = v0left; 00166 cvert = new FBTilerChainVert(v0,RIGHT); 00167 sortedchainlist.push_back(cvert); 00168 decrement_list_ptr(itleft,itlistbegin,itlistend); 00169 v0left = *itleft; 00170 } 00171 00172 // Put the top coord on the list. 00173 00174 v0 = *itmax; 00175 cvert = new FBTilerChainVert(v0,BOTH); 00176 sortedchainlist.push_back(cvert); 00177 status = retriangulate(coordlist); 00178 std::vector<FBTilerChainVert*>::iterator itv, itvlast; 00179 00180 itvlast = sortedchainlist.end(); 00181 itv = sortedchainlist.begin(); 00182 while ( itv != itvlast ) { 00183 delete *itv; 00184 itv++; 00185 } 00186 sortedchainlist.clear(); 00187 return status; 00188 } 00189 00190 int FBTiler::add_triangle(int v1, int v2, int v3) 00191 { 00192 int status; 00193 00194 status = 1; 00195 00196 // See if the winding is OK by comparing the normal to the parent's normal. 00197 double xn, yn, zn; 00198 double x1, y1, z1, x2, y2, z2, x3, y3, z3; 00199 double ux, uy, uz, vx, vy, vz, product; 00200 00201 x1 = verts[v1]->coord[0]; y1 = verts[v1]->coord[1]; z1 = verts[v1]->coord[2]; 00202 x2 = verts[v2]->coord[0]; y2 = verts[v2]->coord[1]; z2 = verts[v2]->coord[2]; 00203 x3 = verts[v3]->coord[0]; y3 = verts[v3]->coord[1]; z3 = verts[v3]->coord[2]; 00204 ux = x2 - x1; uy = y2 - y1; uz = z2 - z1; 00205 vx = x3 - x1; vy = y3 - y1; vz = z3 - z1; 00206 xn = uy*vz - uz*vy; yn = uz*vx - ux*vz; zn = ux*vy - uy*vx; 00207 product = xnorm*xn + ynorm*yn + znorm*zn; 00208 if ( product < 0.0 ) { // Must reverse the connections. 00209 int itemp; 00210 itemp = v1; v1 = v2; v2 = itemp; 00211 } 00212 my_tri_list->push_back(v1); 00213 my_tri_list->push_back(v2); 00214 my_tri_list->push_back(v3); 00215 00216 return status; 00217 00218 } 00219 00220 void FBTiler::dud_from_coord_list(int val, std::vector<int> *ivec) 00221 { 00222 std::vector<int>::iterator itv; 00223 bool ifoundit; 00224 // Also decrements ivec->size() if val was found. 00225 00226 ifoundit = false; 00227 itv = ivec->begin(); 00228 do { 00229 if ( ifoundit == false ) { 00230 if ( *itv == val ) { 00231 ifoundit = true; 00232 break; 00233 } 00234 } 00235 itv++; 00236 } while ( itv != ivec->end() ); 00237 if ( ifoundit == true ) { 00238 ivec->erase(itv); 00239 } 00240 00241 } 00242 00243 bool FBTiler::reflex_angle(int v0, int v1, int v2, std::vector<int> *coordlist) 00244 { 00245 double v0x, v0y, v1x, v1y, v2x, v2y, xbary, ybary; 00246 00247 v0x = verts[v0]->coord[s_dir]; 00248 v0y = verts[v0]->coord[p_dir]; 00249 v1x = verts[v1]->coord[s_dir]; 00250 v1y = verts[v1]->coord[p_dir]; 00251 v2x = verts[v2]->coord[s_dir]; 00252 v2y = verts[v2]->coord[p_dir]; 00253 // Are the three points colinear? 00254 00255 if ( fabs((v1x-v0x)*(v2y-v0y) - (v2x-v0x)*(v1y-v0y)) < EPSILON2 ) 00256 return true; 00257 00258 // Get coordinates of barycenter of the triangle formed by 00259 // v0, v1, and v2 00260 00261 xbary = (v0x + v1x + v2x)/3.; 00262 ybary = (v0y + v1y + v2y)/3.; 00263 00264 // Do a point-in-polygon test on this point and the polygon formed 00265 // by the chain. If point is in polygon, angle is not reflex; 00266 // otherwise, angle is reflex. Point in polygon algorithm from 00267 // Schneider and Eberly, Geometric Tools for COmputer Graphics, 00268 // Sec. 13.3. 00269 00270 bool inside = false; 00271 std::vector<int>::iterator itv; 00272 int u0, u1; 00273 00274 itv = coordlist->begin(); 00275 while ( itv != coordlist->end() ) { 00276 u0 = *itv++; 00277 if ( itv == coordlist->end() ) 00278 u1 = *(coordlist->begin()); 00279 else 00280 u1 = *itv; 00281 if ( ybary < verts[u1]->coord[p_dir] ) { 00282 // u1 is above the hroizontal ray in s_dir from the barycenter. 00283 if ( verts[u0]->coord[p_dir] <= ybary ) { 00284 // u0 is on or below the ray. 00285 if ( ( (ybary - verts[u0]->coord[p_dir])* 00286 (verts[u1]->coord[s_dir] -verts[ u0]->coord[s_dir]) ) > 00287 ( (xbary - verts[u0]->coord[s_dir])* 00288 (verts[u1]->coord[p_dir] - verts[u0]->coord[p_dir]) ) ) 00289 inside = !inside; 00290 } 00291 } else if ( ybary < verts[u0]->coord[p_dir] ) { 00292 // U1 is on or below the ray; u0 is above the ray. 00293 if ( ( (ybary - verts[u0]->coord[p_dir])* 00294 (verts[u1]->coord[s_dir] - verts[u0]->coord[s_dir]) ) < 00295 ( (xbary - verts[u0]->coord[s_dir])* 00296 (verts[u1]->coord[p_dir] - verts[u0]->coord[p_dir]) ) ) 00297 inside = !inside; 00298 } 00299 } 00300 00301 return !inside; 00302 00303 } 00304 00305 CubitStatus FBTiler::retriangulate(std::vector<int> *coordlist) 00306 { 00307 int stacktopadjacency, this_adjacency, adjacency_case; 00308 std::vector<FBTilerChainVert*> vstack; 00309 std::vector<FBTilerChainVert*>::iterator itv, itvlast; 00310 int v0, v1, v2; 00311 unsigned int i, numtris, totaltris; 00312 00313 // Put the first two verts on vstack. 00314 itv = sortedchainlist.begin(); 00315 vstack.push_back(*itv++); 00316 vstack.push_back(*itv); 00317 stacktopadjacency = (*itv)->whichchain; 00318 itvlast = itv; 00319 numtris = 0; 00320 totaltris = sortedchainlist.size() - 2; 00321 00322 while(1) { 00323 00324 if ( numtris == totaltris ) break; 00325 *itv++; 00326 if ( itv == sortedchainlist.end() ) { 00327 PRINT_ERROR("Tiler error in FacetBoolean: premature end of list.\n"); 00328 return CUBIT_FAILURE; 00329 } 00330 00331 this_adjacency = (*itv)->whichchain; 00332 v0 = (*itv)->v0; 00333 00334 adjacency_case = get_adjacency(stacktopadjacency,this_adjacency); 00335 00336 switch ( adjacency_case ) { 00337 00338 case 1: 00339 { 00340 v1 = vstack[0]->v0; 00341 for ( i = 1; i < vstack.size(); i++ ) { 00342 v2 = vstack[i]->v0; 00343 add_triangle(v0,v1,v2); 00344 dud_from_coord_list(v1,coordlist); 00345 numtris += 1; 00346 v1 = v2; 00347 } 00348 vstack.clear(); 00349 vstack.push_back(*itvlast); 00350 vstack.push_back(*itv); 00351 stacktopadjacency = (*itv)->whichchain; 00352 itvlast = itv; 00353 00354 break; 00355 } 00356 00357 case 2: 00358 { 00359 while ( vstack.size() > 1 ) { 00360 int size = vstack.size() - 1; 00361 v1 = vstack[size]->v0; 00362 // int v1chain = vstack[size]->whichchain; 00363 v2 = vstack[size-1]->v0; 00364 // bool isreflex = reflex_angle(v0,v1,v2,v1chain); 00365 bool isreflex = reflex_angle(v0,v1,v2,coordlist); 00366 if ( isreflex == true ) break; 00367 add_triangle(v0,v1,v2); 00368 dud_from_coord_list(v1,coordlist); 00369 numtris += 1; 00370 vstack.pop_back(); 00371 00372 } 00373 00374 vstack.push_back(*itv); 00375 stacktopadjacency = (*itv)->whichchain; 00376 itvlast = itv; 00377 00378 00379 break; 00380 } 00381 00382 } 00383 00384 } // endwhile 00385 00386 return CUBIT_SUCCESS; 00387 00388 } 00389 00390
