cgma
00001 #include "FacetAttrib.hpp" 00002 #include "CubitString.hpp" 00003 #include "CubitSimpleAttrib.hpp" 00004 #include "CubitFileIOWrapper.hpp" 00005 #include "CubitMessage.hpp" 00006 #include <algorithm> 00007 00008 // Constructor - copy from CubitSimpleAttrib 00009 FacetAttrib::FacetAttrib( const CubitSimpleAttrib& csa ) : listNext(0) 00010 { 00011 int i; 00012 00013 // save counts 00014 numStrings = csa.string_data_list().size(); 00015 numDoubles = csa.double_data_list().size(); 00016 numIntegers = csa.int_data_list().size(); 00017 00018 // allocate arrays, but don't try to allocate zero-length arrays 00019 stringArray = numStrings ? new CubitString[numStrings] : NULL; 00020 doubleArray = numDoubles ? new double[numDoubles] : NULL; 00021 integerArray = numIntegers ? new int[numIntegers] : NULL; 00022 00023 // copy data into arrays 00024 for( i = 0; i < numStrings; i++ ) 00025 stringArray[i] = csa.string_data_list()[i]; 00026 for( i = 0; i < numIntegers; i++ ) 00027 integerArray[i] = csa.int_data_list()[i]; 00028 for( i = 0; i < numDoubles; i++ ) 00029 doubleArray[i] = csa.double_data_list()[i]; 00030 } 00031 00032 // Private constructor for use by restore(FILE*) 00033 FacetAttrib::FacetAttrib( int string_count, CubitString strings[], 00034 int double_count, double doubles[], 00035 int int_count, int integers[] ) 00036 : stringArray(strings), doubleArray(doubles), integerArray(integers), 00037 numStrings(string_count), numDoubles(double_count), numIntegers(int_count), 00038 listNext(0) 00039 {} 00040 00041 00042 // Destructor -- free arrays 00043 FacetAttrib::~FacetAttrib() 00044 { 00045 // "delete"ing NULL pointers is okay. 00046 delete [] integerArray; 00047 delete [] doubleArray; 00048 delete [] stringArray; 00049 } 00050 00051 // Copy this into a new CubitSimpleAttrib 00052 CubitSimpleAttrib FacetAttrib::get_CSA() const 00053 { 00054 // Set initial list size 00055 std::vector<CubitString> string_list(numStrings); 00056 std::vector<int> int_list(numIntegers); 00057 std::vector<double> double_list(numDoubles); 00058 00059 // Don't need to 'new' objects in DLIList because 00060 // CSA will make copies. Just put addresses in list. 00061 int i; 00062 for( i = 0; i < numStrings; i++ ) 00063 string_list[i] = stringArray[i]; 00064 for( i = 0; i < numIntegers; i++ ) 00065 int_list[i] = integerArray[i]; 00066 for( i = 0; i < numDoubles; i++ ) 00067 double_list[i] = doubleArray[i]; 00068 00069 return CubitSimpleAttrib( &string_list, &double_list, &int_list ); 00070 } 00071 00072 // compare to a CubitSimpleAttrib 00073 bool FacetAttrib::equals( const CubitSimpleAttrib& csa ) const 00074 { 00075 // compare counts 00076 if( csa.int_data_list().size() != (size_t)numIntegers || 00077 csa.double_data_list().size() != (size_t)numDoubles || 00078 csa.string_data_list().size() != (size_t)numStrings ) 00079 return false; 00080 00081 // compare strings first because most likely the 00082 // first string (the name) will differ. 00083 if(!std::equal(stringArray, stringArray+numStrings, csa.string_data_list().begin())) 00084 return false; 00085 if(!std::equal(doubleArray, doubleArray+numDoubles, csa.double_data_list().begin())) 00086 return false; 00087 if(!std::equal(integerArray, integerArray+numIntegers, csa.int_data_list().begin())) 00088 return false; 00089 00090 return true; 00091 } 00092 00093 // write to a file at the current file offset 00094 CubitStatus FacetAttrib::save(FILE *save_file) const 00095 { 00096 if( save_file == NULL) 00097 { 00098 PRINT_ERROR("Problem saving MBG attributes: null FILE ptr\n"); 00099 return CUBIT_FAILURE; 00100 } 00101 00102 NCubitFile::CIOWrapper wrapper(save_file); 00103 00104 // write a version number for the attribute data 00105 unsigned int Attrib_Version = 1; 00106 wrapper.Write(&Attrib_Version, 1); 00107 00108 // write the number of strings, number of doubles, and number of integers 00109 int counts[3] = { numStrings, numDoubles, numIntegers }; 00110 wrapper.Write(reinterpret_cast<unsigned int*>(counts), 3); 00111 00112 // write the string data 00113 int i; 00114 for( i = 0; i < numStrings; i++ ) 00115 wrapper.Write(stringArray[i].c_str()); 00116 00117 // write the doubles 00118 wrapper.Write(doubleArray, numDoubles); 00119 00120 // write the integers 00121 wrapper.Write(reinterpret_cast<unsigned int*>(integerArray), numIntegers); 00122 00123 return CUBIT_SUCCESS; 00124 } 00125 00126 00127 // read from file starting at current file offset 00128 FacetAttrib* FacetAttrib::restore(FILE *restore_file, unsigned int endian) 00129 { 00130 if( restore_file == NULL ) 00131 return NULL; 00132 00133 NCubitFile::CIOWrapper wrapper(endian, restore_file ); 00134 00135 // write a version number for the attribute data 00136 unsigned int version; 00137 wrapper.Read(&version, 1); 00138 00139 // haven't handled any version changes yet 00140 if( version != 1 ) 00141 { 00142 PRINT_ERROR("Wrong FacetAttrib version : %u\n", version ); 00143 return NULL; 00144 } 00145 00146 // read the number of strings, number of doubles, and number of integers 00147 int counts[3]; 00148 wrapper.Read(reinterpret_cast<unsigned int*>(counts), 3); 00149 int n_strings = counts[0]; 00150 int n_doubles = counts[1]; 00151 int n_ints = counts[2]; 00152 00153 // allocate arrays, but don't try to allocate zero-length array 00154 CubitString* strings = n_strings ? new CubitString[n_strings] : NULL; 00155 double *doubles = n_doubles ? new double[n_doubles] : NULL; 00156 int *ints = n_ints ? new int[n_ints] : NULL; 00157 00158 // read the string data 00159 int i; 00160 for( i = 0; i < n_strings; i++ ) 00161 { 00162 char *string = wrapper.Read(); 00163 strings[i] = CubitString(string); 00164 delete [] string; 00165 } 00166 00167 // write the doubles 00168 wrapper.Read(doubles, n_doubles); 00169 00170 // write the integers 00171 wrapper.Read(reinterpret_cast<unsigned int*>(ints), n_ints); 00172 00173 return new FacetAttrib(n_strings, strings, n_doubles, doubles, n_ints, ints); 00174 } 00175 00176
