cgma
00001 //- Class: FacetorUtil 00002 //- Description: Utility functions used by FactorTool and available to other classes. 00003 // FacetorUtil uses template functions that accepts both CubitNode, CubitTri, CubitEdge classes 00004 //- and CubitPoint, CubitFacet, CubitFacetEdge classes. CubitPoint, CubitFacet, and 00005 //- CubitFacetEdge classes have been modified to account for the difference between the mdb 00006 //= entities and geometric entities. 00007 //------------------------------------------------------------------------- 00008 // Filename : FacetorTool.hpp 00009 // 00010 // Purpose : 2D Delaunay Mesher 00011 // 00012 // Creator : Christopher Hynes 00013 // 00014 // Creation Date : 5/31/2002 00015 // 00016 // Owner : Steve Owen 00017 //------------------------------------------------------------------------- 00018 00019 #ifndef FACETOR_UTIL_HPP 00020 #define FACETOR_UTIL_HPP 00021 00022 00023 #include "CubitDefines.h" 00024 class ParamTool; 00025 00026 template<class SURF, class TRI, class EDGE, class NODE, class TRICHILD, class NODECHILD, class SIZEFUNC> 00027 class FacetorUtil 00028 { 00029 public: 00030 FacetorUtil(){} 00031 ~FacetorUtil(){} 00032 00033 //- Insert one node into a Delaunay mesh 00034 static CubitStatus insert_node(NODE *node_ptr, 00035 DLIList<TRI*>& facet_list, 00036 SURF* surface_ptr, 00037 int& curr_visit_flag, 00038 TRI*& last_tri); 00039 00040 // Insert a node at the circumcenter of a tri 00041 static CubitStatus insert_at_circumcenter(TRI *tri_ptr, 00042 DLIList<TRI*>& facet_list, 00043 TRI*& start_tri, 00044 int& curr_visit_flag, 00045 SURF* surface_ptr, 00046 DLIList<TRI*>* sorted_lists, 00047 const int num_lists, 00048 const double interval, 00049 const double quality_angle, 00050 SIZEFUNC* sizing_function, 00051 ParamTool* p_tool); 00052 00053 // Compute the angles at the triangle vertices and classify 00054 // by its worst triangle 00055 static CubitStatus classify_tri_by_angle(TRI* tri_ptr, 00056 DLIList<TRI*>* sorted_lists, 00057 const int num_lists, 00058 const double interval, 00059 const double quality_angle); 00060 00061 private: 00062 00063 //Get the tri_visited flag. 00064 static CubitBoolean tri_visited(TRI *tri_ptr, 00065 int curr_visit_flag); 00066 00067 //Set the tri_visited flag. 00068 static void tri_visited(TRI *tri_ptr, 00069 CubitBoolean visited, 00070 int curr_visit_flag); 00071 00072 //Search every TRI until the one that the_point is in 00073 //is found. 00074 static CubitStatus exhaustive_locate_point(CubitVector& the_point, 00075 DLIList<TRI*>& facet_list, 00076 TRI*& tri_ptr); 00077 00078 static CubitStatus point_in_circumcircle(CubitVector& the_point, 00079 TRI* tri_ptr, 00080 DLIList<TRI*>& tri_list, 00081 SURF* surface_ptr, 00082 int curr_visit_flag); 00083 00084 //Find the TRI in facet_list that the_point is in. 00085 //If starting_tri is not NULL the search will begin 00086 //with it. 00087 static CubitStatus locate_point(CubitVector& the_point, 00088 DLIList<TRI*>& facet_list, 00089 TRI* starting_tri, 00090 SURF* owning_surface, 00091 TRI*& tri_ptr); 00092 00093 //check the void created in Bowyer-Watson to ensure the boundary 00094 //seems valid. 00095 static CubitStatus valid_void( NODE * /*point_ptr*/, 00096 DLIList<TRI *> &tri_list, 00097 SURF* surface_ptr, 00098 int curr_visit_flag); 00099 00100 static CubitStatus natural_neighbor_tris(CubitVector& the_point, 00101 DLIList<TRI*>& facet_list, 00102 TRI*& start_tri, 00103 SURF* surface_ptr, 00104 int& curr_visit_flag, 00105 DLIList<TRI*>& tri_list); 00106 00107 //- Bowyer-Watson insertion into an existing Delaunay Mesh 00108 static CubitStatus bowyer_watson_insert(NODE* point_ptr, 00109 DLIList<TRI*>& tri_list, 00110 DLIList<TRI*>& facet_list, 00111 int& curr_visit_flag, 00112 SURF* surf_ptr, 00113 TRI*& last_tri); 00114 00115 //Return true if all three points in tri_ptr are colinear. 00116 //Return false otherwise. 00117 static CubitBoolean are_nodes_colinear(TRI* tri_ptr); 00118 00119 static CubitVector& circumcenter(TRI* tri_ptr); 00120 00121 static double get_size(CubitVector &cc, TRI *tri_ptr); 00122 00123 // get and set the tri sort array index that this tri is in 00124 static void tri_sort_list( TRI *tri_ptr, int sort_list_index ); 00125 static int tri_sort_list( TRI *tri_ptr ); 00126 00127 static double radius(TRI* tri_ptr); 00128 }; 00129 00130 #include "FacetorUtil.cpp" 00131 #endif
