cgma
00001 //- Class: MemoryBlock 00002 //- Owner: Jim Hipp 00003 //- Description: MemoryBlock provides stack storage for block or "Chunk" 00004 //- memory allocated with overloaded 'new' operators in classes 00005 //- utilizing a MemoryManager object. 00006 //- Checked By: 00007 //- Version: 00008 00009 #include"MemoryBlock.hpp" 00010 00011 00012 // destructor: recusively deletes stack of allocated memory 00013 MemoryBlock::~MemoryBlock() 00014 { 00015 delete [] block; 00016 if (next) 00017 { 00018 delete next; 00019 next = NULL; 00020 } 00021 } 00022 00023 // retreive total amount of memory allocated (bytes) including all blocks 00024 // beneath 'this' block on the stack 00025 int MemoryBlock::get_memory_allocation() 00026 { 00027 MemoryBlock* block_ptr = this; 00028 00029 // sum all allocated memory 00030 00031 int amount = 0; 00032 while (block_ptr) 00033 { 00034 amount += block_ptr->size; 00035 block_ptr = block_ptr->next; 00036 } 00037 00038 return amount; 00039 } 00040 00041 00042
