cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OCCAttribSet.cpp 00003 // 00004 // Purpose : Common attribute functionality for MBG 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 03/01/03 00011 //------------------------------------------------------------------------- 00012 00013 #include "OCCAttribSet.hpp" 00014 //#include "OCCAttrib.hpp" 00015 #include "OCCQueryEngine.hpp" 00016 #include "CubitSimpleAttrib.hpp" 00017 #include "CubitFileIOWrapper.hpp" 00018 00019 #ifndef OCC_VERSION_MINOR 00020 #include "Standard_Version.hxx" 00021 #endif 00022 00023 #if OCC_VERSION_MINOR < 5 00024 #include "TDataStd_Shape.hxx" 00025 typedef TDataStd_Shape TDataXtd_Shape; 00026 typedef Handle_TDataStd_Shape Handle_TDataXtd_Shape; 00027 #else 00028 #include "TDataXtd_Shape.hxx" 00029 #endif 00030 00031 #include "TDF_Label.hxx" 00032 #include "TopTools_DataMapOfShapeInteger.hxx" 00033 #include "TCollection_ExtendedString.hxx" 00034 #include "Handle_TDataStd_Name.hxx" 00035 #include "Handle_TDataStd_ExtStringArray.hxx" 00036 #include "Handle_TDataStd_RealArray.hxx" 00037 #include "Handle_TDataStd_IntegerArray.hxx" 00038 #include "TDataStd_Name.hxx" 00039 #include "TDataStd_ExtStringArray.hxx" 00040 #include "TDataStd_RealArray.hxx" 00041 #include "TDataStd_IntegerArray.hxx" 00042 #include "TopoDS_Shape.hxx" 00043 #include "TDF_ChildIterator.hxx" 00044 #include <vector> 00045 typedef std::map<int, TDF_Label>::value_type labType; 00046 00047 void OCCAttribSet::FindShape(TopoDS_Shape& shape, 00048 TDF_Label& aLabel, 00049 CubitBoolean& found) 00050 { 00051 found = CUBIT_FALSE; 00052 if(!OCCQueryEngine::instance()->OCCMap->IsBound(shape)) 00053 return; 00054 00055 int k = OCCQueryEngine::instance()->OCCMap->Find(shape); 00056 std::map<int, TDF_Label>::iterator it = 00057 OCCQueryEngine::instance()->Shape_Label_Map->find(k); 00058 if(it != OCCQueryEngine::instance()->Shape_Label_Map->end()) 00059 { 00060 aLabel = (*it).second; 00061 found = CUBIT_TRUE; 00062 } 00063 } 00064 00065 void OCCAttribSet::append_attribute( const CubitSimpleAttrib& csa, TopoDS_Shape& shape ) 00066 { 00067 if(shape.IsNull()) 00068 return; 00069 00070 //Add attributes on child of myLabel 00071 //1. add shape attribute, first check to make sure there's no shape attribute 00072 CubitBoolean found = CUBIT_FALSE; 00073 int result = 1; 00074 TDF_Label aLabel, lab; 00075 Handle_TDataStd_Name attr_name; 00076 CubitString type = csa.string_data_list()[0]; 00077 TCollection_ExtendedString cstring( (Standard_CString)type.c_str() ); 00078 00079 FindShape(shape, aLabel, found); 00080 00081 if(!found) 00082 { 00083 aLabel = OCCQueryEngine::instance()->mainLabel.NewChild(); 00084 Handle_TDataXtd_Shape attr_shape = TDataXtd_Shape::Set(aLabel, shape); 00085 //aLabel.AddAttribute(attr_shape); 00086 //test if the attribute has been attached 00087 assert(aLabel.IsAttribute(TDataXtd_Shape::GetID())); 00088 00089 if(!OCCQueryEngine::instance()->OCCMap->IsBound(shape)) 00090 { 00091 OCCQueryEngine::instance()->iTotalTBCreated++; 00092 int k = OCCQueryEngine::instance()->iTotalTBCreated; 00093 OCCQueryEngine::instance()->OCCMap->Bind(shape, k); 00094 } 00095 00096 int k = OCCQueryEngine::instance()->OCCMap->Find(shape); 00097 OCCQueryEngine::instance()->Shape_Label_Map->insert(labType(k, aLabel)); 00098 } 00099 00100 //2. add type attribute , below attributes are added on child lable of myLabel 00101 //First check if the attributes are already exist, if so, create new data. 00102 else 00103 { 00104 TCollection_ExtendedString name_string; 00105 for (TDF_ChildIterator it(aLabel,CUBIT_FALSE); it.More(); it.Next()) 00106 { 00107 lab = it.Value(); 00108 result = find_attribute(lab, csa); 00109 if(result != 1) 00110 break; 00111 } 00112 } 00113 //if not exist, create new child label 00114 Handle_TDataStd_ExtStringArray attr_string; 00115 const std::vector<CubitString>& strings = csa.string_data_list(); 00116 int size = strings.size()-1; 00117 00118 if (result == 1) 00119 { 00120 lab = aLabel.NewChild(); 00121 attr_name = TDataStd_Name::Set(lab, cstring); 00122 //lab.AddAttribute(attr_name); 00123 assert(lab.IsAttribute(TDataStd_Name::GetID())); 00124 } 00125 00126 else if(result == 3)//nothing to do 00127 return; 00128 00129 else if(result == 2) 00130 //adding the name strings 00131 { 00132 lab.FindAttribute(TDataStd_ExtStringArray::GetID(), attr_string); 00133 TCollection_ExtendedString name1, name2; 00134 std::vector<CubitString> new_names; 00135 int length = 0; 00136 for(int j = 1; j < (int)strings.size();j++) 00137 { 00138 CubitString name_string = strings[j]; 00139 TCollection_ExtendedString cstring(name_string.c_str(), Standard_True ); 00140 bool dup = false; 00141 length = attr_string->Length() ; 00142 00143 for(int i = 0; i < length; i++) 00144 { 00145 name1 = attr_string->Value(i); 00146 //it could be string[0] = "volume 1", string[1] = "volume_1"; 00147 00148 if(name1.IsEqual(cstring)) 00149 { 00150 dup = true; 00151 break; 00152 } 00153 } 00154 if(!dup) 00155 new_names.push_back(name_string); 00156 } 00157 if(new_names.size() > 0) 00158 { 00159 lab.ForgetAttribute(attr_string); 00160 Handle_TDataStd_ExtStringArray attr_string_new; 00161 attr_string_new = TDataStd_ExtStringArray::Set(lab, 0, 00162 length+new_names.size()-1); 00163 for(int i = 0; i < attr_string_new->Length(); i++) 00164 { 00165 if (i < length) 00166 attr_string_new->SetValue(i, attr_string->Value(i)); 00167 else 00168 { 00169 TCollection_ExtendedString cstring(new_names[i-length].c_str(), Standard_True ); 00170 attr_string_new->SetValue(i, cstring); 00171 } 00172 } 00173 } 00174 return; 00175 } 00176 //3. add string attribute 00177 if(size > 0) 00178 { 00179 //set the length of String Array . 00180 attr_string = TDataStd_ExtStringArray::Set(lab, 0, size-1); 00181 } 00182 for(int i = 1; i < (int)strings.size(); i++) 00183 { 00184 TCollection_ExtendedString cstring(strings[i].c_str(), Standard_True ); 00185 attr_string->SetValue(i-1, cstring) ; 00186 } 00187 00188 if (size > 0) 00189 { 00190 //lab.AddAttribute(attr_string); 00191 assert(lab.IsAttribute(TDataStd_ExtStringArray::GetID())); 00192 } 00193 //4. add double attribute 00194 const std::vector<double>& doubles = csa.double_data_list(); 00195 Handle_TDataStd_RealArray attr_double; 00196 size = doubles.size(); 00197 if(size > 0) 00198 { 00199 //set the length of double array . 00200 attr_double = TDataStd_RealArray::Set(lab,0, size-1); 00201 } 00202 for(int i = 0; i < size; i++) 00203 attr_double->SetValue(i, doubles[i]); 00204 00205 if(size > 0) 00206 { 00207 //lab.AddAttribute(attr_double); 00208 assert(lab.IsAttribute(TDataStd_RealArray::GetID())); 00209 } 00210 //5. add int attribute 00211 const std::vector<int>& ints = csa.int_data_list(); 00212 Handle_TDataStd_IntegerArray attr_int; 00213 size = ints.size(); 00214 if(size > 0) 00215 { 00216 //set the length of int array be 11, can be extended. 00217 attr_int = TDataStd_IntegerArray::Set(lab, 0, size-1); 00218 } 00219 for(int i = 0; i < size; i++) 00220 attr_int->SetValue(i, ints[i]); 00221 00222 if(size > 0) 00223 { 00224 //lab.AddAttribute(attr_int); 00225 assert(lab.IsAttribute(TDataStd_IntegerArray::GetID())); 00226 } 00227 } 00228 00229 // return 1 = not found 00230 // return 2 = found ENTITY_NAME attribute 00231 // return 3 = found the same attribute 00232 int OCCAttribSet::find_attribute(TDF_Label child, 00233 const CubitSimpleAttrib& csa) 00234 { 00235 const std::vector<int>& ints = csa.int_data_list(); 00236 CubitString type = csa.character_type(); 00237 Standard_Boolean isMultiByte = Standard_True; 00238 TCollection_ExtendedString cstring( type.c_str(), isMultiByte ); 00239 const std::vector<double>& doubles = csa.double_data_list(); 00240 const std::vector<CubitString>& strings = csa.string_data_list(); 00241 00242 //find the same type attribute first 00243 Handle_TDataStd_Name attr_name; 00244 TCollection_ExtendedString old_string; 00245 if(child.FindAttribute(TDataStd_Name::GetID(), attr_name)) 00246 { 00247 old_string = attr_name->Get(); 00248 Standard_Boolean isMultiByte = Standard_True; 00249 char const* string = "ENTITY_NAME"; 00250 TCollection_ExtendedString string2( string, isMultiByte ); 00251 if(old_string != cstring) 00252 return 1; 00253 00254 else if(cstring.IsEqual(string2)) 00255 return 2; 00256 } 00257 00258 else 00259 return 1; 00260 00261 //continue to compare the rest attributes. 00262 CubitBoolean is_same = CUBIT_TRUE; 00263 if(ints.size()> 0 ) 00264 { 00265 Handle_TDataStd_IntegerArray attr_ints; 00266 if(child.FindAttribute(TDataStd_IntegerArray::GetID(), attr_ints) && 00267 attr_ints->Length() == (int)ints.size()) 00268 { 00269 for(int i = 0; i < (int)ints.size(); i++) 00270 if(attr_ints->Value(i) != ints[i]) 00271 { 00272 is_same = CUBIT_FALSE; 00273 break; 00274 } 00275 } 00276 } 00277 if(!is_same) 00278 return 1; 00279 00280 if(doubles.size() > 0 ) 00281 { 00282 Handle_TDataStd_RealArray attr_doubles; 00283 if(child.FindAttribute(TDataStd_RealArray::GetID(), attr_doubles) && 00284 attr_doubles->Length() == (int)doubles.size()) 00285 { 00286 for(int i = 0; i < (int)doubles.size(); i++) 00287 if(attr_doubles->Value(i) != doubles[i]) 00288 { 00289 is_same = CUBIT_FALSE; 00290 break; 00291 } 00292 } 00293 } 00294 00295 if(!is_same) 00296 return 1; 00297 00298 if(strings.size() > 0 ) 00299 { 00300 Handle_TDataStd_ExtStringArray attr_strings; 00301 if(child.FindAttribute(TDataStd_ExtStringArray::GetID(), attr_strings) && 00302 attr_strings->Length() == (int)strings.size()-1) 00303 { 00304 for(int i = 1; i < (int)strings.size(); i++) 00305 { 00306 CubitString astring = strings[i]; 00307 TCollection_ExtendedString string( astring.c_str() , Standard_True); 00308 if(attr_strings->Value(i-1) != string) 00309 { 00310 is_same = CUBIT_FALSE; 00311 break; 00312 } 00313 } 00314 } 00315 if(!is_same) 00316 return 1; 00317 } 00318 return 3 ; 00319 } 00320 00321 void OCCAttribSet::remove_attribute( const CubitSimpleAttrib& csa) 00322 { 00323 CubitString type = csa.character_type(); 00324 if(type.length() == 0) 00325 return; 00326 00327 TDF_Label myLabel; 00328 for (TDF_ChildIterator it(OCCQueryEngine::instance()->mainLabel, CUBIT_FALSE); it.More(); it.Next()) 00329 { 00330 //find the same type attribute first 00331 myLabel = it.Value(); 00332 00333 //forget csa attribute from the document 00334 for (TDF_ChildIterator it1(myLabel, CUBIT_FALSE); it1.More(); it1.Next()) 00335 { 00336 //find the same type attribute first 00337 TDF_Label child = it1.Value(); 00338 00339 int found = find_attribute(child, csa); 00340 00341 if(found == 3) 00342 child.ForgetAllAttributes(false ); 00343 } 00344 } 00345 } 00346 00347 void OCCAttribSet::remove_attribute( TopoDS_Shape& shape) 00348 { 00349 CubitBoolean found = CUBIT_FALSE; 00350 TDF_Label myLabel; 00351 00352 FindShape(shape, myLabel, found); 00353 00354 if(!found) 00355 return; 00356 00357 myLabel.ForgetAllAttributes(false); 00358 /* 00359 if(OCCQueryEngine::instance()->OCCMap->IsBound(shape)) 00360 { 00361 int k = OCCQueryEngine::instance()->OCCMap->Find(shape); 00362 OCCQueryEngine::instance()->Shape_Label_Map->erase(k); 00363 } 00364 */ 00365 } 00366 00367 void OCCAttribSet::remove_attribute( const CubitSimpleAttrib& csa, 00368 TopoDS_Shape& shape) 00369 { 00370 CubitBoolean found = CUBIT_FALSE; 00371 TDF_Label myLabel; 00372 00373 FindShape(shape, myLabel, found); 00374 00375 if(!found) 00376 return; 00377 00378 int num_children = 0; 00379 int num_found = 0; 00380 for (TDF_ChildIterator it1(myLabel, CUBIT_FALSE); it1.More(); it1.Next()) 00381 { 00382 //find the same type attribute first 00383 TDF_Label child = it1.Value(); 00384 if (child.NbAttributes() == 0) 00385 continue; 00386 00387 num_children ++; 00388 00389 if(csa.isEmpty()) 00390 { 00391 //only name attributes can't be forget here. 00392 Handle_TDataStd_Name attr_name; 00393 if(child.FindAttribute(TDataStd_Name::GetID(), attr_name)) 00394 { 00395 TCollection_ExtendedString old_string = attr_name->Get(); 00396 char const* string1 = "ENTITY_NAME"; 00397 Standard_Boolean isMultiByte = Standard_True; 00398 TCollection_ExtendedString cstring( string1, isMultiByte ); 00399 if( old_string == cstring) 00400 continue; 00401 } 00402 child.ForgetAllAttributes(false ); 00403 num_found ++; 00404 } 00405 00406 else 00407 { 00408 int found = find_attribute(child, csa); 00409 00410 if(found == 3) 00411 { 00412 child.ForgetAllAttributes(false ); 00413 num_found ++; 00414 } 00415 } 00416 } 00417 /* 00418 if(num_children == num_found) 00419 { 00420 if(OCCQueryEngine::instance()->OCCMap->IsBound(shape)) 00421 { 00422 int k = OCCQueryEngine::instance()->OCCMap->Find(shape); 00423 OCCQueryEngine::instance()->Shape_Label_Map->erase(k); 00424 } 00425 } 00426 */ 00427 } 00428 00429 void OCCAttribSet::get_attributes(TDF_Label &lab, 00430 DLIList<CubitSimpleAttrib>& list) 00431 { 00432 std::vector<CubitString> strings; 00433 CubitString string; 00434 std::vector<double> doubles; 00435 std::vector<int> ints; 00436 00437 Handle_TDataStd_Name attr_name; 00438 TCollection_ExtendedString name_string; 00439 Handle_TDataStd_ExtStringArray attr_string; 00440 Handle_TDataStd_RealArray attr_doubles; 00441 Handle_TDataStd_IntegerArray attr_ints; 00442 00443 if(lab.FindAttribute(TDataStd_Name::GetID(), attr_name)) 00444 { 00445 name_string = attr_name->Get(); 00446 int length = name_string.Length(); 00447 std::vector<char> temp_type(length+1); 00448 for (int i = 1 ; i <= length; i++) 00449 { 00450 Standard_ExtCharacter c = name_string.Value(i); 00451 temp_type[i-1] = ToCharacter(c); 00452 } 00453 temp_type[length] = '\0'; 00454 string = CubitString(&temp_type[0]); 00455 strings.push_back(string); 00456 } 00457 if(lab.FindAttribute(TDataStd_ExtStringArray::GetID(), attr_string)) 00458 { 00459 int length = attr_string->Length(); 00460 for (int i = 0 ; i < length; i++) 00461 { 00462 name_string = attr_string->Value(i); 00463 int length2 = name_string.Length(); 00464 if (length2 == 0) 00465 continue; 00466 std::vector<char> temp_string(length2+1); 00467 for(int j = 1; j <= length2; j ++) 00468 { 00469 Standard_ExtCharacter c = name_string.Value(j); 00470 temp_string[j-1] = ToCharacter(c); 00471 } 00472 temp_string[length2] = '\0'; 00473 const char *s = &temp_string[0]; 00474 string = CubitString(s); 00475 strings.push_back(string); 00476 } 00477 } 00478 if(lab.FindAttribute(TDataStd_RealArray::GetID(), attr_doubles)) 00479 { 00480 for(int i = 0; i < attr_doubles->Length(); i++) 00481 { 00482 double d = attr_doubles->Value(i); 00483 doubles.push_back(d); 00484 } 00485 } 00486 if(lab.FindAttribute(TDataStd_IntegerArray::GetID(), attr_ints)) 00487 { 00488 for(int i = 0; i < attr_ints->Length(); i++) 00489 { 00490 int j = attr_ints->Value(i); 00491 ints.push_back(j); 00492 } 00493 } 00494 if(strings.size() > 0 || doubles.size() || ints.size()) 00495 { 00496 list.append(CubitSimpleAttrib(&strings, &doubles, &ints)); 00497 } 00498 } 00499 00500 CubitStatus OCCAttribSet::get_attributes( TopoDS_Shape& shape, 00501 DLIList<CubitSimpleAttrib>& list) 00502 { 00503 CubitBoolean found = CUBIT_FALSE; 00504 TDF_Label myLabel; 00505 00506 FindShape(shape, myLabel, found); 00507 00508 if(!found) 00509 return CUBIT_FAILURE; 00510 00511 TDF_Label lab; 00512 for (TDF_ChildIterator it(myLabel,CUBIT_FALSE); it.More(); it.Next()) 00513 { 00514 lab = it.Value(); 00515 get_attributes(lab, list); 00516 } 00517 return CUBIT_SUCCESS; 00518 } 00519 00520 CubitStatus OCCAttribSet::get_attributes( const CubitString& name, 00521 TopoDS_Shape& shape, 00522 DLIList<CubitSimpleAttrib>& list ) 00523 { 00524 CubitBoolean found = CUBIT_FALSE; 00525 TDF_Label aLabel; 00526 00527 FindShape(shape, aLabel, found); 00528 00529 if(!found) 00530 return CUBIT_FAILURE; 00531 00532 Handle_TDataStd_Name attr_name; 00533 TCollection_ExtendedString cstring( (Standard_CString)name.c_str() ); 00534 TDF_Label lab; 00535 for (TDF_ChildIterator it(aLabel,CUBIT_FALSE); it.More(); it.Next()) 00536 { 00537 lab = it.Value(); 00538 00539 //check if the type attribute is the same, disable it 00540 TCollection_ExtendedString old_string; 00541 if(lab.FindAttribute(TDataStd_Name::GetID(), attr_name)) 00542 { 00543 old_string = attr_name->Get(); 00544 00545 if(old_string == cstring) 00546 { 00547 get_attributes(lab, list); 00548 break; 00549 } 00550 } 00551 } 00552 00553 return CUBIT_SUCCESS; 00554 } 00555 00556 00557 int OCCAttribSet::attribute_count() 00558 { 00559 int count = 0; 00560 00561 return count; 00562 } 00563
