cgma
00001 #ifndef OCC_DRAW_TOOL_HPP 00002 #define OCC_DRAW_TOOL_HPP 00003 00004 #include "CubitDefines.h" 00005 00006 class TopoDS_Shape; 00007 class TopoDS_Face; 00008 class TopoDS_Edge; 00009 class TopoDS_Vertex; 00010 class Surface; 00011 class Curve; 00012 00013 template <class X> class DLIList; 00014 00015 class OCCDrawTool 00016 { 00017 public: 00018 // ********** BEGIN FRIEND DECLARATIONS ********** 00019 00020 // ********** END FRIEND DECLARATIONS ********** 00021 00022 ~OCCDrawTool(); 00023 00024 static OCCDrawTool* instance(); 00025 //- Gives access to the singleton object of this class 00026 00027 //do not remove this function....it is handy for debugging. 00028 CubitStatus draw_TopoDS_Shape( TopoDS_Shape *shape, int color, 00029 CubitBoolean tessellate = CUBIT_FALSE, 00030 CubitBoolean flush = CUBIT_FALSE ); 00031 //- Draw the given TopoDS_Shape. Handles entities of type CompSolid, Solid, Shell, 00032 //- Face, Loop, Edge or Vertex. The tessellate option only applies 00033 //- to Faces - if true, the Face is tessellated and each triangle is drawn; 00034 //- otherwise, only the outer curves are drawn. 00035 00036 CubitStatus draw_surface( Surface *surface, int color, CubitBoolean tessellate, CubitBoolean flush ); 00037 CubitStatus draw_curve( Curve *curve, int color, CubitBoolean flush ); 00038 00039 CubitStatus draw_FACE( TopoDS_Face *face, int color, 00040 CubitBoolean tessellate = CUBIT_FALSE, 00041 CubitBoolean flush = CUBIT_FALSE ); 00042 //- Draw the given Face. If tessellate is true, the FACE is tessellated and 00043 //- each triangle is drawn; otherwise, only the outer curves are drawn. 00044 00045 CubitStatus draw_EDGE( TopoDS_Edge *edge, int color, 00046 CubitBoolean flush = CUBIT_FALSE ); 00047 //- Draw the given EDGE 00048 00049 CubitStatus draw_VERTEX( TopoDS_Vertex *vertex, int color, 00050 CubitBoolean flush = CUBIT_FALSE ); 00051 //- Draw the given VERTEX 00052 00053 protected: 00054 OCCDrawTool(); 00055 //- Class Constructor. (Not callable by user code. Class is constructed 00056 //- by the {instance()} member function. 00057 00058 private: 00059 00060 static OCCDrawTool* instance_; 00061 }; 00062 00063 #endif
