cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OctTreeCell.cpp 00003 // 00004 // Purpose : Oct-tree node used by OctTree 00005 // 00006 // Special Notes : OctTree handles all memory allocation for this 00007 // class. 00008 // 00009 // Creator : Jason Kraftcheck 00010 // 00011 // Creation Date : 01/30/02 00012 //------------------------------------------------------------------------- 00013 00014 #include "OctTreeCell.hpp" 00015 #include "CubitVector.hpp" 00016 00017 template <class X, class E> 00018 OctTreeCell<X,E>::OctTreeCell( OctTreeEntry<X,E> array[], int size ) 00019 : node_count_(size) 00020 { 00021 children_ = 0; 00022 OctTreeEntry<X,E>** prev_ptr_ptr = &head_; 00023 for( int i = 0; i < node_count_; i++ ) 00024 { 00025 OctTreeEntry<X,E>* entry = array + i; 00026 *prev_ptr_ptr = entry; 00027 prev_ptr_ptr = &(entry->next); 00028 } 00029 *prev_ptr_ptr = 0; 00030 } 00031 00032 template <class X, class E> 00033 void OctTreeCell<X,E>::append_nodes( DLIList<X*>& list ) 00034 { 00035 OctTreeEntry<X,E>* entry = node_count_ ? head_ : 0; 00036 for( ; entry; entry = entry->next ) 00037 list.append( entry->node ); 00038 } 00039 00040 template <class X, class E> 00041 void OctTreeCell<X,E>::append_all_nodes( DLIList<X*>& list ) 00042 { 00043 if( node_count_ ) 00044 { 00045 append_nodes( list ); 00046 } 00047 else if( children_ ) 00048 { 00049 for( int i = 0; i < 8; i++ ) 00050 children_[i].append_all_nodes( list ); 00051 } 00052 } 00053 00054 template <class X, class E> 00055 void OctTreeCell<X,E>::add_nodes( OctTreeEntry<X,E>* node ) 00056 { 00057 assert( leaf() ); 00058 00059 OctTreeEntry<X,E>* last = node; 00060 int count = 1; 00061 while( last->next ) 00062 { 00063 count++; 00064 last = last->next; 00065 } 00066 00067 last->next = head_; 00068 head_ = node; 00069 node_count_ += count; 00070 } 00071 00072 template <class X, class E> 00073 OctTreeCell<X,E>* OctTreeCell<X,E>::child( int quadrant ) 00074 { 00075 assert( quadrant >= 0 && quadrant < 8 && !node_count_ ); 00076 if( children_ ) 00077 return children_ + quadrant; 00078 else 00079 return 0; 00080 } 00081 00082 template <class X, class E> 00083 bool OctTreeCell<X,E>::split( const CubitVector& my_center, 00084 OctTreeCell<X,E>* storage ) 00085 { 00086 assert( leaf() ); 00087 bool result = false; 00088 00089 if( node_count_ > 3 ) 00090 { 00091 // Data is a union. Make sure you never change 00092 // the order of the following two lines! 00093 OctTreeEntry<X,E>* node = head_; 00094 children_ = storage; 00095 00096 while( node ) 00097 { 00098 CubitVector coords = E::coordinates(node->node); 00099 int x = coords.x() < my_center.x() ? X_MIN : X_MAX; 00100 int y = coords.y() < my_center.y() ? Y_MIN : Y_MAX; 00101 int z = coords.z() < my_center.z() ? Z_MIN : Z_MAX; 00102 OctTreeEntry<X,E>* next = node->next; 00103 node->next = 0; 00104 children_[x|y|z].add_nodes( node ); 00105 node = next; 00106 } 00107 result = true; 00108 node_count_ = 0; 00109 } 00110 00111 return result; 00112 } 00113 00114 template <class X, class E> 00115 void OctTreeCell<X,E>::node_locations( CubitVector& box_min, 00116 CubitVector& box_max, 00117 CubitVector& average, 00118 CubitVector* std_dev ) 00119 { 00120 if( !node_count_ ) 00121 return; 00122 00123 00124 double x_min, y_min, z_min; 00125 double x_max, y_max, z_max; 00126 double x_avg, y_avg, z_avg; 00127 CubitVector coords = E::coordinates( head_->node ); 00128 x_min = x_max = x_avg = coords.x(); 00129 y_min = y_max = y_avg = coords.y(); 00130 z_min = z_max = z_avg = coords.z(); 00131 00132 for( OctTreeEntry<X,E>* entry = head_->next; entry; entry = entry->next ) 00133 { 00134 X* node = entry->node; 00135 coords = E::coordinates( node ); 00136 00137 double x = coords.x(); 00138 if( x < x_min ) x_min = x; 00139 else if ( x > x_max ) x_max = x; 00140 x_avg += x; 00141 00142 double y = coords.y(); 00143 if( y < y_min ) y_min = y; 00144 else if ( y > y_max ) y_max = y; 00145 y_avg += y; 00146 00147 double z = coords.z(); 00148 if( z < z_min ) z_min = z; 00149 else if ( z > z_max ) z_max = z; 00150 z_avg += z; 00151 } 00152 00153 box_min.set( x_min, y_min, z_min ); 00154 box_max.set( x_max, y_max, z_max ); 00155 00156 double inv = 1.0 / node_count_; 00157 x_avg *= inv; 00158 y_avg *= inv; 00159 z_avg *= inv; 00160 average.set( x_avg, y_avg, z_avg ); 00161 00162 if( std_dev ) 00163 { 00164 X* hn = head_->node; 00165 coords = E::coordinates(hn); 00166 double x_dev = (coords.x() - x_avg) * (coords.x() - x_avg); 00167 double y_dev = (coords.y() - y_avg) * (coords.y() - y_avg); 00168 double z_dev = (coords.z() - z_avg) * (coords.z() - z_avg); 00169 00170 for( OctTreeEntry<X,E>* entry = head_->next; entry; entry = entry->next ) 00171 { 00172 X* node = entry->node; 00173 coords = E::coordinates(node); 00174 00175 double x = coords.x(); 00176 double dx = x - x_avg; 00177 x_dev += dx * dx; 00178 00179 double y = coords.y(); 00180 double dy = y - y_avg; 00181 y_dev += dy * dy; 00182 00183 double z = coords.z(); 00184 double dz = z - z_avg; 00185 z_dev += dz * dz; 00186 } 00187 00188 inv = 1.0 / ( node_count_ - 1 ); 00189 x_dev = sqrt(x_dev * inv); 00190 y_dev = sqrt(y_dev * inv); 00191 z_dev = sqrt(z_dev * inv); 00192 00193 std_dev->set( x_dev, y_dev, z_dev ); 00194 } 00195 } 00196
