cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : NodeSearch.hpp 00003 // 00004 // Purpose : Class for O(ln n) search for nodes within a specified 00005 // tolerance of a specified position. 00006 // 00007 // Special Notes : 00008 // 00009 // Creator : Jason Kraftcheck 00010 // 00011 // Creation Date : 01/30/02 00012 //------------------------------------------------------------------------- 00013 00014 #ifndef OCT_TREE_HPP 00015 #define OCT_TREE_HPP 00016 00017 #include "CubitVector.hpp" 00018 #include "DLIList.hpp" 00019 00020 template <class X, class E> class OctTreeCell; 00021 template <class X, class E> struct OctTreeEntry; 00022 00023 template <class X> class DefaultPointQuery{ 00024 public: static inline CubitVector coordinates(const X* x) 00025 { return x->coordinates(); } 00026 }; 00027 00028 template < class X, class E = DefaultPointQuery<X> > 00029 class OctTree 00030 { 00031 00032 public: 00033 00034 OctTree( DLIList<X*>& nodes, double tolerance, 00035 int min_nodes_per_box = -1, 00036 double min_box_dimension = -1.0 ); 00037 //- Constructor 00038 //- nodes - list of nodes to build oct-tree for 00039 //- tolerance - tolerance for comparison of node positions 00040 //- min_nodes_per_box - don't subdivide boxes in tree with 00041 //- this many or fewer nodes. 00042 //- min_box_dimension - don't subdivide boxes in tree if 00043 //- all three dimensions are less than this 00044 00045 ~OctTree(); 00046 // - Destructor 00047 00048 void nodes_near( const CubitVector& position, 00049 DLIList<X*>& result_list ); 00050 //- Get the list of all nodes in the tree for which 00051 //- the distance between the passed position and the 00052 //- node is less than or equal to the tolerance 00053 //- value passed to the constructor. 00054 00055 void tree_size( DLIList<int>& count_at_each_level, 00056 DLIList<int>& leaves_at_each_level ); 00057 //- Get the size of the tree at each level. 00058 00059 private: 00060 00061 double tolerance_; 00062 double min_box_size_; 00063 int min_nodes_; 00064 // values passed to constructor 00065 00066 OctTreeCell<X,E>* root_; 00067 // root of oct-tree 00068 00069 CubitVector min_; 00070 CubitVector max_; 00071 // bounding box of entire oct-tree (and size of root box) 00072 00073 OctTreeEntry<X,E>* node_memory_; 00074 // memory allocated for linked-list entries 00075 // this is allocated by the constructor, passed to 00076 // the root node of the oct-tree for its internal use 00077 // and released by the destructor. All use of this 00078 // memory is internal to the NodeSearchBox class. 00079 00080 void split_node( OctTreeCell<X,E>* node, 00081 const CubitVector& min, 00082 const CubitVector& max ); 00083 //- Recursive function to subdivide octree nodes 00084 00085 OctTreeCell<X,E>* allocate_8(); 00086 //- Allocate a block of 8 oct-tree nodes for use as 00087 //- children of some current node. 00088 00089 DLIList<OctTreeCell<X,E>*> mem_pages_; 00090 OctTreeCell<X,E>* curr_page_end_; 00091 //- This data is the memory pool from which allocate_8() 00092 //- allocates oct-tree nodes. 00093 00094 void push_search_box( int quadrant_flags ); 00095 //- Push the child box of 'current_box' indicated 00096 //- by quadrant_flags onto box_list stack or onto 00097 //- leaf_list. 00098 00099 void pop_to_current(); 00100 //- Pop one box from box_list and store it in 00101 //- current_* variables. Also updates 'center' 00102 00103 OctTreeCell<X,E>* box_list[64]; // stack of none-leaf boxes to be searched 00104 CubitVector box_min[64]; // minimum of boxes in box_list 00105 CubitVector box_max[64]; // maximum of boxes in box_list 00106 int box_count; // count of boxes in box_list 00107 DLIList<X*> search_results; // results of a search 00108 // State information for tree search 00109 00110 CubitVector current_min; 00111 CubitVector current_max; 00112 CubitVector center; 00113 OctTreeCell<X,E>* current_box; 00114 // More state information for tree search 00115 // The 'current' box during a search, and related info. 00116 00117 00118 void tree_size( OctTreeCell<X,E>* box, 00119 DLIList<int>& boxes, 00120 DLIList<int>& leaves ); 00121 00122 }; 00123 00124 #include "OctTree.cpp" 00125 00126 #endif 00127
