cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : OffsetSplitTool.hpp 00003 // 00004 // Purpose : 00005 // 00006 // Split Surface <id_list> Offset Curve <id_list> 00007 // Distance <val> [Segment <val>] [Partition] [Blunt] [Preview [Create]] 00008 // 00009 // Special Notes : 00010 // 00011 // Creator : Sam Showman 00012 // 00013 // Creation Date : 05/10/2005 00014 //------------------------------------------------------------------------- 00015 #ifndef OFFSETSPLITTOOL_HPP 00016 #define OFFSETSPLITTOOL_HPP 00017 00018 #include "CubitDefines.h" 00019 #include "RefEdge.hpp" 00020 #include "RefVertex.hpp" 00021 #include "CoEdge.hpp" 00022 00023 class RefEdge; 00024 class RefFace; 00025 class GeometryModifyEngine; 00026 class Curve; 00027 class Surface; 00028 template <class X> class DLIList; 00029 00030 class OffsetSplitTool 00031 { 00032 public: 00033 00034 OffsetSplitTool(); 00035 ~OffsetSplitTool(){} 00036 00037 CubitStatus split_surfaces_offset(DLIList<RefFace*> &ref_face_list, 00038 DLIList<RefEdge*> &edge_list, 00039 int num_segs, 00040 double distance, 00041 CubitBoolean divide_flg = CUBIT_FALSE, 00042 CubitBoolean blunt_flg = CUBIT_FALSE, 00043 CubitBoolean preview_flg = CUBIT_FALSE, 00044 CubitBoolean create_ref_edges_flg = CUBIT_FALSE); 00045 //- Splits surface by offsetting curves. 00046 //- ref_face_list - list of surfaces to split. 00047 //- num_segs - the number of segments to create (must be >= 1 ); 00048 //- distance - distance of the offset 00049 //- divide_flg - divide the surface between each offset curve to create a better 00050 //- region for map mesh. 00051 //- blunt_flg - create a blunt type ending instead of the arc type ending 00052 //- preview_flg - if CUBIT_TRUE, just draw the curves that will be used to split 00053 //- instead of actually splitting. 00054 //- create_ref_edges_flg - valid only if preview_flg=CUBIT_TRUE. If CUBIT_TRUE, 00055 //- create RefEdges *instead* of splitting. 00056 00057 private: 00058 CubitStatus draw_preview( 00059 DLIList<Curve*> &curve_list, 00060 int color=CUBIT_BLUE_INDEX); 00061 //- Draw the curves 00062 00063 CubitStatus draw_preview( 00064 Curve *curve_ptr, 00065 CubitBoolean flush=CUBIT_TRUE, 00066 int color=CUBIT_BLUE_INDEX); 00067 //- Draw the curves 00068 00069 Curve *create_sweep_curve( 00070 Curve *curve_in, 00071 double distance, 00072 double chord_tol, 00073 CubitBoolean iterate = CUBIT_FALSE); 00074 //- Create a sweep curve offset a distance given the input curve. 00075 00076 Surface *create_sweep_section( 00077 Curve* path, 00078 double distance, 00079 CubitVector up_vector, 00080 double fraction = 0.0); 00081 //- Uses two arcs to create a surface section normal to the input curve 00082 00083 BodySM* create_sweep_body( 00084 Surface* section, 00085 Curve* path); 00086 //- Sweeps the input surface along the curve path 00087 00088 CubitStatus create_ref_edges( 00089 DLIList<Curve*> &curve_list ); 00090 //- Creates RefEdges from the list of Curve entities 00091 00092 DLIList<Curve*> create_divide_curves( 00093 DLIList<Curve*> &curve_list, 00094 Surface* surface_in, 00095 double distance); 00096 //- Creates perpendicular curves of length 'distance' at the ends of the 00097 //- input curves. The curves are projected to the input surface if the 00098 //- Surface in not of type 'PLANE_SURFACE_TYPE'. 00099 00100 DLIList<Curve*> sourceCurves; 00101 //- List of the Curve entities to offset. 00102 00103 static double tolerance; 00104 //- Linear tolerace 00105 }; 00106 00107 #endif 00108
