cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : ParamCubitPlane.cc 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Jason Kraftcheck 00009 // 00010 // Creation Date : 07/06/98 00011 //------------------------------------------------------------------------- 00012 00013 #include "ParamCubitPlane.hpp" 00014 #include "CubitVector.hpp" 00015 #include "CubitMessage.hpp" 00016 #include "math.h" 00017 00018 //------------------------------------------------------------------------- 00019 // Purpose : Default constructor 00020 // 00021 // Special Notes : 00022 // 00023 // Creator : Jason Kraftcheck 00024 // 00025 // Creation Date : 07/06/98 00026 //------------------------------------------------------------------------- 00027 ParamCubitPlane::ParamCubitPlane( const CubitVector& zero_position, 00028 const CubitVector& u_direction, 00029 const CubitVector& v_direction, 00030 CubitStatus& result ) 00031 { 00032 if( mk_plane_with_points( zero_position, zero_position + u_direction, 00033 zero_position + v_direction ) == (int)CUBIT_SUCCESS ) 00034 { 00035 is_plane_valid_= CUBIT_TRUE; 00036 result = CUBIT_SUCCESS; 00037 } 00038 else 00039 { 00040 is_plane_valid_= CUBIT_FALSE; 00041 result = CUBIT_FAILURE; 00042 return ; 00043 } 00044 00045 p_ = zero_position; 00046 s_ = u_direction; 00047 t_ = v_direction; 00048 n_ = s_ * t_; 00049 00050 double n_len = n_.length(); 00051 if( 1000 * CUBIT_DBL_MIN > n_len ) n_epsilon_ = CUBIT_DBL_MIN; 00052 else n_epsilon_ = n_len / 1000; 00053 } 00054 00055 00056 //------------------------------------------------------------------------- 00057 // Purpose : closest point 00058 // 00059 // Special Notes : 00060 // 00061 // Creator : Jason Kraftcheck 00062 // 00063 // Creation Date : 07/06/98 00064 //------------------------------------------------------------------------- 00065 CubitStatus ParamCubitPlane::closest_point( const CubitVector& position, 00066 CubitVector& closest_position ) const 00067 { 00068 assert( is_plane_valid_); 00069 if( !is_plane_valid_) return CUBIT_FAILURE; 00070 00071 closest_position = position - (normal() * distance(position)); 00072 return CUBIT_SUCCESS; 00073 } 00074 00075 //------------------------------------------------------------------------- 00076 // Purpose : closest point 00077 // 00078 // Special Notes : 00079 // 00080 // Creator : Jason Kraftcheck 00081 // 00082 // Creation Date : 07/06/98 00083 //------------------------------------------------------------------------- 00084 CubitStatus ParamCubitPlane::move_to_plane( CubitVector& position ) const 00085 { 00086 const CubitVector v = position; 00087 CubitStatus s = closest_point( v, position ); 00088 return s; 00089 } 00090 00091 //------------------------------------------------------------------------- 00092 // Purpose : make arbitrary parameterization 00093 // 00094 // Special Notes : 00095 // 00096 // Creator : Jason Kraftcheck 00097 // 00098 // Creation Date : 07/06/98 00099 //------------------------------------------------------------------------- 00100 void ParamCubitPlane::make_parameterization() 00101 { 00102 //Choose the zero-point for the parameterization 00103 //as close to the origin as possible. 00104 // p_.set( 0.0, 0.0, 0.0); 00105 // move_to_plane( p_ ); 00106 is_plane_valid_ = CUBIT_TRUE; 00107 00108 const CubitVector temp_p(0.0, 0.0, 0.0); 00109 CubitStatus s = closest_point( temp_p, p_ ); 00110 assert( s == CUBIT_SUCCESS ); 00111 if (CUBIT_SUCCESS != s) { 00112 PRINT_ERROR("ParamCubitPlane::closest_point failed.\n"); 00113 return; 00114 } 00115 00116 CubitVector n = normal(); 00117 CubitVector p1; 00118 00119 p1 = p_; 00120 double x = fabs( n.x() ); 00121 double y = fabs( n.y() ); 00122 double z = fabs( n.z() ); 00123 00124 //Choose a direction from the zero point (p_) for 00125 //the second point as the direction of the smallest 00126 //component of the normal. The third point defining 00127 //the plane will be defined by the cross product of 00128 //the vector from the zero_point to this point and 00129 //the normal vector of the plane. 00130 if( (x <= y) && (x <= z) ) 00131 { 00132 p1.x( p1.x() + 1 ); 00133 } 00134 else if( (y <= x) && (y <= z) ) 00135 { 00136 p1.y( p1.y() + 1 ); 00137 } 00138 else 00139 { 00140 p1.z( p1.z() + 1 ); 00141 } 00142 00143 move_to_plane( p1 ); 00144 s_ = p1 - p_; 00145 t_ = -(s_ * n); 00146 n_ = s_ * t_; 00147 00148 double n_len = n_.length(); 00149 if( 1000 * CUBIT_DBL_MIN > n_len ) n_epsilon_ = CUBIT_DBL_MIN; 00150 else n_epsilon_ = n_len / 1000; 00151 00152 00153 is_plane_valid_= CUBIT_TRUE; 00154 }
