cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : ParamCubitPlane.hpp 00003 // 00004 // Purpose : A class derived from CubitPlane with a parameterization, 00005 // essentially a planar surface. 00006 // 00007 // Special Notes : 00008 // 00009 // Creator : Jason Kraftcheck 00010 // 00011 // Creation Date : 07/06/98 00012 //------------------------------------------------------------------------- 00013 #ifndef PARAM_CUBIT_PLANE_HPP 00014 #define PARAM_CUBIT_PLANE_HPP 00015 00016 #include "CubitPlane.hpp" 00017 #include "CGMUtilConfigure.h" 00018 00019 class CubitVector; 00020 00021 00022 class CUBIT_UTIL_EXPORT ParamCubitPlane : public CubitPlane 00023 { 00024 public: 00025 00026 ParamCubitPlane( const CubitVector& zero_position, 00027 const CubitVector& u_direction, 00028 const CubitVector& v_direction, 00029 CubitStatus& result ); 00030 //I zero_position 00031 //I- The position on the plane where (u,v) = (0,0). 00032 //I u_direction 00033 //I- A vector parallel to the plane along which u increases 00034 //I- and v is constant. 00035 //I v_direction 00036 //I- A vector parallel to the plane along which v increases 00037 //I- and u is constant. 00038 //O result 00039 //O- CUBIT_FAILURE if u_direction and v_direction are parallel, or 00040 //O- are of zero length. 00041 //- Create a parametric CubitPlane with the specified 00042 //- parameterization. 00043 //- 00044 //- Note: The size of a step in the u and v directions 00045 //- is determined by the lenght of the respective 00046 //- u and v direction vectors passed. 00047 00048 ParamCubitPlane( const ParamCubitPlane& copy_this ); 00049 //- Copy constructor. 00050 00051 ParamCubitPlane( double A, double B, double C, double D ); 00052 ParamCubitPlane( const CubitVector& normal, double D ); 00053 ParamCubitPlane( const CubitVector& normal, const CubitVector& point ); 00054 ParamCubitPlane( DLIList<CubitVector*>& positions ); 00055 ParamCubitPlane( const CubitPlane& copy_this ); 00056 //- Constructors from CubitPlane 00057 //- An arbitraty parameterization is generated. 00058 00059 CubitStatus closest_point( const CubitVector& position, 00060 CubitVector& closest_position ) const; 00061 //R CubitStatus 00062 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00063 //I position 00064 //I- A position to evaluate 00065 //O closest_position 00066 //O- The projection of the passed position onto the surface 00067 //O- along the normal. 00068 //- Find the closest point on the plane. 00069 00070 CubitStatus move_to_plane( CubitVector& position ) const; 00071 //R CubitStatus 00072 //R- CUBIT_SUCCESS/CUBIT_FAILURE 00073 //I position 00074 //I- A position to evaluate 00075 //O position 00076 //O- The projection of the passed position onto the surface 00077 //O- along the normal. 00078 //- Move the passed position to the plane. 00079 00080 private: 00081 00082 void make_parameterization(); 00083 //- This method is used by various constructors to generate 00084 //- an arbitrary parameterization after the members of the 00085 //- parent class CubitPlane have been initialized. 00086 00087 CubitVector p_, s_, t_; 00088 CubitBoolean is_plane_valid_; 00089 CubitVector n_; //Non-unit normal vector. 00090 double n_epsilon_; 00091 }; 00092 00093 #endif 00094
