cgma
00001 //- Class: ParamTool 00002 //------------------------------------------------------------------------- 00003 // Filename : ParamTool.hpp 00004 // 00005 // Purpose : Surface Parameterization for mesh by triangulation flattening 00006 // 00007 // Note: set_up_space must be called before using the transform functions 00008 // 00009 // Creator : Christopher Hynes 00010 // 00011 // Creation Date : 7/10/2002 00012 // 00013 // Owner : Christopher Hynes 00014 //------------------------------------------------------------------------- 00015 00016 #ifndef PARAM_TOOL_HPP 00017 #define PARAM_TOOL_HPP 00018 00019 #include "CubitDefines.h" 00020 #include "CGMUtilConfigure.h" 00021 00022 class CubitVector; 00023 00024 00025 class CUBIT_UTIL_EXPORT ParamTool 00026 { 00027 public: 00028 00029 ParamTool() {} 00030 virtual ~ParamTool() {} 00031 00032 virtual CubitStatus transform_to_uv(const CubitVector &xyz_location, CubitVector &uv_location) = 0; 00033 00034 virtual CubitStatus transform_to_xyz(CubitVector &xyz_location, const CubitVector &uv_location) = 0; 00035 00036 virtual CubitStatus uv_derivitives( double /*u_param*/ , double /*v_param*/, 00037 CubitVector &/*du*/, CubitVector &/*dv*/ ) 00038 { 00039 return CUBIT_FAILURE; 00040 } 00041 00042 }; 00043 00044 #endif // PARAM_TOOL_HPP 00045
