cgma
00001 //----------------------------------------------------------------------------------- 00002 // Class: PointLoopFacetor 00003 // Description: 00004 // Creates a set of CubitFacets which is a Delauney triagulation of the boundary 00005 // points. No interior points are added. The points form a closed loop, and may 00006 // consist of several loops. The first loop must be the exterior loop, followed by 00007 // any internal loops (or holes). 00008 // Creator: David R. White 00009 // Owner: David R. White 00010 // Creation Date: 3/1/2003 00011 //------------------------------------------------------------------------------------ 00012 #ifndef POINTLOOPFACETOR_HPP 00013 #define POINTLOOPFACETOR_HPP 00014 00015 template <class X> class DLIList; 00016 class CubitPoint; 00017 class CubitFacet; 00018 00019 typedef DLIList<CubitPoint*> PointList; 00020 typedef DLIList<PointList*> PointLoopList; 00021 #include "CubitDefines.h" 00022 00023 class PointLoopFacetor 00024 { 00025 private: 00026 00027 public: 00028 PointLoopFacetor() 00029 {} 00030 ~PointLoopFacetor() 00031 {} 00032 static CubitStatus generate_facets( PointLoopList &boundary_loops, 00033 DLIList<CubitFacet*> &resulting_triangles); 00037 00038 static void write_xy(PointLoopList &boundary_loops); 00039 static void write_xyz(PointLoopList &boundary_loops); 00040 00041 }; 00042 #endif 00043
