cgma
00001 #include "cassert" 00002 #include "PriorityQueue.hpp" 00003 #include "CubitMessage.hpp" 00004 00005 00006 #ifdef INLINE_TEMPLATES 00007 #define MY_INLINE inline 00008 #else 00009 #define MY_INLINE 00010 #endif 00011 00012 template <class Object> MY_INLINE 00013 PriorityQueue<Object>::PriorityQueue(typename PriorityQueue<Object>::CompareFunc compare) 00014 : theItems(1) 00015 { 00016 lessThanFunc = compare; 00017 } 00018 template <class Object> MY_INLINE 00019 int PriorityQueue<Object>::size() const 00020 { 00021 return theItems.size() - 1; 00022 } 00023 template <class Object> MY_INLINE 00024 bool PriorityQueue<Object>::empty() const 00025 { 00026 if ( size() == 0 ) 00027 return true; 00028 else 00029 return false; 00030 } 00031 template <class Object> MY_INLINE 00032 const Object PriorityQueue<Object>::top() const 00033 { 00034 if ( empty() ) 00035 { 00036 PRINT_ERROR("Empty priority queue had top request.\n"); 00037 assert(!empty()); 00038 return (Object)0; 00039 } 00040 return theItems[1]; 00041 } 00042 template <class Object> MY_INLINE 00043 void PriorityQueue<Object>::push(Object x) 00044 { 00045 theItems.push_back(x); 00046 theItems[0] = x;//stash the item here... 00047 //Percolate up. 00048 int hole = size(); 00049 //While x is less than the parrent, do (1): then go up the tree (hole /= 2 is the parent...). 00050 for ( ; lessThanFunc(x, theItems[hole/2]); hole /= 2 ) 00051 { 00052 //(1) set the replace the parent with the child. 00053 theItems[hole] = theItems[hole/2]; 00054 } 00055 //Now where the item is greater than the parent, set this value. 00056 theItems[hole] = x; 00057 } 00058 template <class Object> MY_INLINE 00059 void PriorityQueue<Object>::pop() 00060 { 00061 if ( empty() ) 00062 { 00063 PRINT_ERROR("Trying to delete min from empty priority queue.\n"); 00064 assert(!empty()); 00065 return; 00066 } 00067 00068 int hole = 1; 00069 int child; 00070 00071 Object tmp = theItems.back(); 00072 theItems.pop_back(); 00073 int the_size = size(); 00074 //while the current isn't at the end, do (1): then set hole to child. 00075 for ( ; hole*2 <= the_size; hole = child ) 00076 { 00077 child = hole*2; 00078 if ( child != the_size && 00079 lessThanFunc(theItems[child+1], theItems[child]) ) 00080 child++; 00081 if ( lessThanFunc(theItems[child], tmp) ) 00082 theItems[hole] = theItems[child]; 00083 else 00084 break; 00085 } 00086 if ( !empty() ) 00087 theItems[hole] = tmp; 00088 } 00089 00090 template <class Object> MY_INLINE 00091 int PriorityQueue<Object>::where_is_item(Object &a, int start_index, bool queue_is_valid) 00092 { 00093 size_t i; 00094 00095 if (!queue_is_valid) 00096 { 00097 for (i=0; i < theItems.size(); ++i) 00098 { 00099 if (theItems[i] == a) {return i;} 00100 } 00101 return -1; 00102 } 00103 00104 if (a == theItems[start_index]) {return start_index;} 00105 if (!lessThanFunc(a, theItems[start_index]) && 2*start_index+1 <= size()) 00106 { 00107 int result; 00108 result = where_is_item(a, 2*start_index); 00109 if (result > 0) {return result;} 00110 result = where_is_item(a, 2*start_index+1); 00111 if (result > 0) {return result;} 00112 } 00113 00114 return -1; 00115 } 00116 00117 template <class Object> MY_INLINE 00118 bool PriorityQueue<Object>::update_item(Object &a, bool queue_is_valid) 00119 { 00120 int index = where_is_item(a, queue_is_valid); 00121 if (index == -1) {return false;} 00122 else {return update_item(index);} 00123 } 00124 00125 template <class Object> MY_INLINE 00126 bool PriorityQueue<Object>::update_item(int object_index) 00127 { 00128 if (object_index == 0) {return true;} 00129 00130 if (lessThanFunc(theItems[object_index], theItems[object_index/2])) 00131 { 00132 Object temp = theItems[object_index]; 00133 theItems[object_index] = theItems[object_index/2]; 00134 theItems[object_index/2] = temp; 00135 update_item(object_index/2); 00136 return true; 00137 } 00138 00139 int smaller_child = 2*object_index; 00140 if (2*object_index > size()) {return true;} 00141 if (2*object_index+1 <= size()) 00142 { 00143 if (lessThanFunc(theItems[2*object_index+1],theItems[2*object_index])) {++smaller_child;} 00144 } 00145 00146 if (lessThanFunc(theItems[smaller_child], theItems[object_index])) 00147 { 00148 Object temp = theItems[object_index]; 00149 theItems[object_index] = theItems[smaller_child]; 00150 theItems[smaller_child] = temp; 00151 update_item(smaller_child); 00152 } 00153 00154 return true; 00155 } 00156 00157 template <class Object> MY_INLINE 00158 bool PriorityQueue<Object>::validate(int index) 00159 { 00160 bool fine = true, kid_one = false, kid_two = false; 00161 if (2*index <= size()) 00162 { 00163 kid_one = true; 00164 if ((lessThanFunc(theItems[2*index], theItems[index]))) 00165 { 00166 fine = false; 00167 } 00168 } 00169 00170 if (2*index+1 <= size()) 00171 { 00172 kid_two = true; 00173 if ((lessThanFunc(theItems[2*index+1], theItems[index]))) 00174 { 00175 fine = false; 00176 } 00177 } 00178 00179 if (fine) 00180 { 00181 if (kid_one && !kid_two) {return validate(2*index);} 00182 if (!kid_one && kid_two) {return validate(2*index+1);} 00183 if (kid_one && kid_two) {return (validate(2*index) && validate(2*index+1));} 00184 else {return true;} 00185 } 00186 00187 return false; 00188 00189 }
