cgma
00001 //--------------------------------------------------------------------------- 00002 // Class Name: RTreeNode 00003 // Description: Node of Rectangle tree. Contians many of the 00004 // required functions for building the tree and traversing it. 00005 // The algorithm was taken from the following paper: 00006 // Guttman, A., "R-Trees: A Dynamic Index Structure for 00007 // Spatial Searching", Proceedings of the SIGMOD 00008 // Conference, Boston, June 1984, p. 47-57. 00009 // Creation Date: 3/13/02 00010 // Owner: David R. White 00011 //--------------------------------------------------------------------------- 00012 00013 //--------------------------------- 00014 //Include Files 00015 //--------------------------------- 00016 #include "RTreeNode.hpp" 00017 #include "DLIList.hpp" 00018 #include "CubitMessage.hpp" 00019 00020 //--------------------------- 00021 //Initialize Static Members 00022 //--------------------------- 00023 00024 #ifdef INLINE_TEMPLATES 00025 #define MY_INLINE inline 00026 #else 00027 #define MY_INLINE 00028 #endif 00029 00030 00031 template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (Y data, double tol, 00032 int max_children, 00033 int min_children) 00034 { 00035 maxChildren = max_children; 00036 minChildren = min_children; 00037 myChildrenNodes = new RTreeNode<Y>* [maxChildren]; 00038 int ii; 00039 for ( ii = 0; ii < maxChildren; ii++ ) 00040 myChildrenNodes[ii] = (RTreeNode<Y>*) NULL; 00041 if ( data == NULL ) 00042 { 00043 PRINT_ERROR("Building RTree with null data is not allowed!\n"); 00044 assert(data != NULL); 00045 } 00046 myData = data; 00047 myLevel = DATA_RNODE; 00048 CubitBox temp_box = data->bounding_box(); 00049 //Check to see if any of the min/max pairs are less than the tolerance. 00050 //make them bigger if they are... 00051 CubitVector min = temp_box.minimum(); 00052 CubitVector max = temp_box.maximum(); 00053 if ( max.x() - min.x() < tol ) 00054 { 00055 min.x(min.x()-.6*tol); 00056 max.x(max.x()+.6*tol); 00057 } 00058 if ( max.y() - min.y() < tol ) 00059 { 00060 min.y(min.y()-.6*tol); 00061 max.y(max.y()+.6*tol); 00062 } 00063 if ( max.z() - min.z() < tol ) 00064 { 00065 min.z(min.z()-.6*tol); 00066 max.z(max.z()+.6*tol); 00067 } 00068 myBoundingBox = new CubitBox(min, max); 00069 myParent = NULL; 00070 nextChildIndex = 0; 00071 markedFlag = 0; 00072 distIsBox = 1; 00073 myDist = CUBIT_DBL_MAX; 00074 } 00075 template <class Y> MY_INLINE RTreeNode<Y>::RTreeNode (CubitBox &bounding_box, 00076 int max_children, 00077 int min_children) 00078 { 00079 maxChildren = max_children; 00080 minChildren = min_children; 00081 myBoundingBox = new CubitBox(bounding_box); 00082 myChildrenNodes = new RTreeNode<Y>* [maxChildren]; 00083 int ii; 00084 for ( ii = 0; ii < maxChildren; ii++ ) 00085 myChildrenNodes[ii] = (RTreeNode<Y>*) NULL; 00086 myData = NULL; 00087 myLevel = UNSET_RNODE; 00088 myParent = NULL; 00089 nextChildIndex = 0; 00090 markedFlag = 0; 00091 distIsBox = 1; 00092 myDist = CUBIT_DBL_MAX; 00093 } 00094 //----------------------------------------------------------- 00095 // Destructor 00096 //----------------------------------------------------------- 00097 template <class Y> MY_INLINE RTreeNode<Y>::~RTreeNode() 00098 { 00099 if ( myChildrenNodes ) 00100 delete [] myChildrenNodes; 00101 if ( myBoundingBox ) 00102 delete myBoundingBox; 00103 } 00104 00105 //----------------------------------------------------------- 00106 // Algorithm: insert 00107 // Insert a new index entry e into an R-Tree. 00108 // I1. [Find postiion for new record] Invoke choose_leaf to select 00109 // a leaf node in l, in which to place e. 00110 // I2. [Add record to leaf node].a) If l has room for 00111 // another entry, install E. b) Otherwise invoke split_node to 00112 // obtain l and ll containing e and all the old entries of l. 00113 // I3. [Propogate changes upward] Invoke adjust_tree on l, also passing ll 00114 // if a split was performed. 00115 // I4. [Grow Tree Taller] If node split propogation caused the root 00116 // to split create a new root whose children are the two resulting 00117 // nodes. 00118 //----------------------------------------------------------- 00119 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::insert(RTreeNode<Y> *e, RTreeNode<Y> *&new_root) 00120 { 00121 CubitStatus stat; 00122 new_root = NULL;//only set this if the root node changes. Assume 00123 //that this RTreeNode object is the root... 00124 00125 00126 // I1. Invoke choose_leaf to select a leaf node l in which to place 00127 //e 00128 RTreeNode<Y> *l = choose_leaf(this, e); 00129 //just test. 00130 // make sure l is not null. 00131 // make sure l is one level above e. 00132 if ( l == NULL || l->get_leaf_level() != (e->get_leaf_level() + 1) ) 00133 { 00134 PRINT_ERROR("Choosing leaf for inseartion into rtree failed.\n"); 00135 return CUBIT_FAILURE; 00136 } 00137 RTreeNode<Y> *ll = NULL; 00138 //I2 a) If l has room for another entry install e. 00139 if ( l->can_add() ) 00140 { 00141 l->add_child(e, CUBIT_TRUE); 00142 } 00143 else 00144 { 00145 //I2 b) 00146 //Otherwise invoke split_node to obtain l and ll containing e and 00147 //all the old entries of l. 00148 stat = quadratic_split_node(l,e,ll); 00149 if ( stat != CUBIT_SUCCESS || ll == NULL ) 00150 { 00151 PRINT_ERROR("Problems splitting node during insertion to RTree.\n"); 00152 return CUBIT_FAILURE; 00153 } 00154 } 00155 //I3. Propagate changes upward. 00156 //I4, grow tree taller (do both inside adjust_tree...) 00157 stat = adjust_tree(l, ll, this, new_root); 00158 if ( stat!= CUBIT_SUCCESS ) 00159 return stat; 00160 return CUBIT_SUCCESS; 00161 } 00162 00163 //-------------------------------------------- 00164 // Algorithm: ChooseLeaf: Select a leaf node in which to place 00165 // a new index entry e. Recursive search the subtrees of n 00166 // until n is a leaf node. 00167 //---------------------------------------------- 00168 template <class Y> MY_INLINE RTreeNode<Y>* RTreeNode<Y>::choose_leaf( RTreeNode<Y>* n, 00169 RTreeNode<Y>* e ) 00170 { 00171 //If n is a leaf node, or one level greater than e, 00172 //we are done. 00173 if ( n->get_leaf_level() == (e->get_leaf_level() + 1) ) 00174 return n; 00175 //Now choose the entry f in n (children of n that is) 00176 //whose bounding box f_box needs 00177 //least enlargement to include e_box. Resolve ties by 00178 //choosing the entry with the bounding box of smallest volume. 00179 double min_enlargement = CUBIT_DBL_MAX, curr_enlargement; 00180 RTreeNode<Y> *curr_node; 00181 int child_index = -1; 00182 int ii; 00183 for(ii = 0; (ii < maxChildren) && (n->myChildrenNodes[ii] != NULL); ii++ ) 00184 { 00185 00186 curr_node = n->myChildrenNodes[ii]; 00187 curr_enlargement = calc_enlargement(curr_node, e); 00188 if ( curr_enlargement <= min_enlargement ) 00189 { 00190 if ( curr_enlargement == min_enlargement && child_index >= 0 ) 00191 { 00192 //only reset if the curr_node has a smaller volume. 00193 double curr_vol = volume(curr_node); 00194 double old_vol = volume(n->myChildrenNodes[child_index]); 00195 if ( old_vol < curr_vol ) 00196 continue; 00197 } 00198 child_index = ii; 00199 min_enlargement = curr_enlargement; 00200 } 00201 } 00202 //do error checking... 00203 if ( child_index == -1 || child_index >= maxChildren ) 00204 return (RTreeNode<Y>*)NULL; 00205 RTreeNode<Y> *f = n->myChildrenNodes[child_index]; 00206 //Now continue on... 00207 curr_node = choose_leaf(f,e); 00208 return curr_node; 00209 } 00210 //---------------------------------------------------------------------- 00211 // calc_enlargement: Calculate the enlargement required for increasing 00212 // the bounding box of current so that it would encapsulate the bounding 00213 // box of add_to. So to do that, create the union of the two bounding 00214 // boxes, then of that supper box subtrace the volume of the current. 00215 // The result should be the volumetric difference between how much 00216 // current has and how much it would need be or the enlargement. 00217 //---------------------------------------------------------------------- 00218 template <class Y> MY_INLINE double RTreeNode<Y>::calc_enlargement(RTreeNode<Y> *current, RTreeNode<Y> *add_to ) 00219 { 00220 //The enlargement area is the volume of the box that would 00221 //be the union of current and add_to minus the volume of the current. 00222 CubitBox curr_box = current->bounding_box(); 00223 CubitBox add_to_box = add_to->bounding_box(); 00224 CubitBox supper = curr_box; 00225 //Unite add_to_box to the curr_box. 00226 supper|= add_to_box; 00227 double area_big = volume(supper); 00228 return area_big - volume(current); 00229 } 00230 template <class Y> MY_INLINE double RTreeNode<Y>::calc_enlargement(CubitBox ¤t, CubitBox &add_to ) 00231 { 00232 //The enlargement area is the volume of the box that would 00233 //be the union of current and add_to minus the volume of the current. 00234 CubitBox supper = current; 00235 // unite the add_to box. 00236 supper |= add_to; 00237 double area_big = volume(supper); 00238 return area_big - volume(current); 00239 } 00240 //------------------------------------------------------------------ 00241 // Algorithm: adjust_tree 00242 // Description: Ascend from a leaf node L to the root, adjusting covering 00243 // bounding boxes and propagating nodes splits as necesary. 00244 //------------------------------------------------------------------ 00245 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::adjust_tree(RTreeNode<Y> *l, RTreeNode<Y> *ll, 00246 RTreeNode<Y> *root_node, 00247 RTreeNode<Y> *&new_root) 00248 { 00249 CubitStatus stat; 00250 //we need to move up the tree and correct things that have changed. 00251 if ( l == root_node ) 00252 { 00253 if ( ll == NULL ) 00254 return CUBIT_SUCCESS; 00255 else 00256 { 00257 //Create a new root node and store l and ll there 00258 CubitBox root_box = l->bounding_box(); 00259 root_box |= ll->bounding_box(); 00260 new_root = new RTreeNode<Y>(root_box, maxChildren, minChildren); 00261 int new_level = l->get_leaf_level() + 1; 00262 new_root->set_leaf_level(new_level); 00263 new_root->add_child(l, CUBIT_TRUE); 00264 new_root->add_child(ll, CUBIT_TRUE); 00265 return CUBIT_SUCCESS; 00266 } 00267 } 00268 RTreeNode<Y> *parent_node = l->get_parent(); 00269 RTreeNode<Y> *new_group = NULL; 00270 if ( ll != NULL ) 00271 { 00272 //We need to add ll to the parent if we can, 00273 //and then we need to update the parent's bounding box... 00274 if ( parent_node->can_add() ) 00275 { 00276 parent_node->add_child(ll, CUBIT_FALSE); 00277 //we need to recalculate the bounding box for the 00278 //entire set since both l and ll were modified... 00279 parent_node->recalc_b_box(); 00280 } 00281 else 00282 { 00283 //Now we must split the children of the parent. l should 00284 //already be in the chilren list of the paretn. So send 00285 //to split node the parent_node and ll. 00286 //parent node during this process will have its b_box recalced. 00287 stat = quadratic_split_node(parent_node, ll, new_group); 00288 if ( stat != CUBIT_SUCCESS || new_group == NULL ) 00289 { 00290 PRINT_ERROR("Problems splitting node during insertion to RTree.\n"); 00291 return CUBIT_FAILURE; 00292 } 00293 } 00294 } 00295 else 00296 { 00297 //just recalulate the b_box for the parent_node. 00298 parent_node->recalc_b_box(); 00299 } 00300 stat = adjust_tree(parent_node, new_group, root_node, new_root); 00301 if ( stat != CUBIT_SUCCESS ) 00302 return CUBIT_FAILURE; 00303 return CUBIT_SUCCESS; 00304 } 00305 //------------------------------------------------------------------ 00306 // Algorithm: quadratic_split_node 00307 // Description: For the RTree, this is where most of the variations 00308 // on implementations have occured. The best method proposed by Guttman 00309 // was a quadratic split, which I'll implement here. The Rstar tree 00310 // did some slightly more complicated things which I might try later. 00311 // Description of function: 00312 // e is the node to which we want to add l, but l's children's list 00313 // is full. Split the children of l and e up into two groups. The 00314 // groups are stored in l and ll. 00315 // Assume: assume that l's myChildrenNodes are maxChildren in size. 00316 // 00317 // Divide a set of maxChildren + 1 index entries into two groups. 00318 // QS1 [Pick first entry for each group] Apply algorithm pick_seeds, 00319 // to choose two entries to be the first elements of the groups. 00320 // Assign each to a group. 00321 // QS2 [Check if done] If all entries have been assigned, stop. 00322 // If one group has so few entries that all the rest must 00323 // be assigned to it in order for it to have the minimum number m, 00324 // assign them and stop. 00325 // QS3 [Select entry to assign] Invoke Algorithm pick_next to choose 00326 // the next entry to assign. Add it to the group whose covering 00327 // rectangle will have to be enlarged least to accommodate it. 00328 // Resolve ties by adding the entry to the group with the smaller 00329 // volume, then to the one with fewer entries, then to either. Repeat 00330 // QS2. 00331 // 00332 //------------------------------------------------------------------ 00333 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::quadratic_split_node( RTreeNode<Y> *l, 00334 RTreeNode<Y> *e, 00335 RTreeNode<Y> *&ll ) 00336 { 00337 int ii; 00338 //create a new list containing all the nodes we want to split. 00339 RTreeNode<Y> **input_list = new RTreeNode<Y>* [maxChildren + 1]; 00340 DLIList <RTreeNode<Y>*> nodes_remaining; 00341 for ( ii = 0; ii < maxChildren; ii++ ) 00342 { 00343 input_list[ii] = l->myChildrenNodes[ii]; 00344 } 00345 input_list[maxChildren] = e; 00346 00347 //QS1, pick first entry for each group. 00348 RTreeNode<Y> *seed_1, *seed_2; 00349 CubitStatus stat = pick_seeds(input_list, maxChildren+1,seed_1, 00350 seed_2); 00351 if ( stat != CUBIT_SUCCESS ) 00352 { 00353 delete [] input_list; 00354 return stat; 00355 } 00356 //now flush out l. This cleans out the bounding box and 00357 //chindrenNodes and resets the bounding box. Also 00358 //create ll, make l and ll non-leaf nodes and add 00359 //seed_1 and seed_2 to l and ll. (doesn't matter which...) 00360 l->flush(seed_1->bounding_box()); 00361 l->add_child(seed_1, CUBIT_FALSE); 00362 //this is still a leaf node. 00363 //this will change if necessary the parent... 00364 l->set_leaf_level(e->get_leaf_level() + 1); 00365 ll = new RTreeNode<Y>(seed_2->bounding_box(), maxChildren, minChildren ); 00366 ll->add_child(seed_2, CUBIT_FALSE); 00367 ll->set_leaf_level(l->get_leaf_level()); 00368 //build the nodes remaining list... 00369 for ( ii = 0; ii < maxChildren+1; ii++ ) 00370 { 00371 if ( input_list[ii] != seed_1 && 00372 input_list[ii] != seed_2 ) 00373 nodes_remaining.append(input_list[ii]); 00374 } 00375 delete [] input_list; 00376 RTreeNode<Y> *next_node; 00377 CubitBoolean add_to_group_1; 00378 //Q2 00379 while (nodes_remaining.size() > 0 ) 00380 { 00381 //Q2 continued. 00382 if ( l->space_left() < minChildren && 00383 minChildren - l->space_left() >= nodes_remaining.size() ) 00384 { 00385 //just add the rest of the nodes to l. 00386 for ( ii = nodes_remaining.size(); ii > 0; ii-- ) 00387 l->add_child(nodes_remaining.get_and_step(), CUBIT_TRUE); 00388 nodes_remaining.clean_out(); 00389 break; 00390 } 00391 else if ( ll->space_left() < minChildren && 00392 minChildren - ll->space_left() >= nodes_remaining.size() ) 00393 { 00394 //just add the rest of the nodes to l. 00395 for ( ii = nodes_remaining.size(); ii > 0; ii-- ) 00396 ll->add_child(nodes_remaining.get_and_step(), CUBIT_TRUE); 00397 nodes_remaining.clean_out(); 00398 break; 00399 } 00400 //Q3 00401 //pick next selects the next node and the group to 00402 //put it in. It also removes the node from nodes remaining. 00403 //Some of these steps were added to pick next for efficiency... 00404 stat = pick_next(nodes_remaining, l, ll, next_node, 00405 add_to_group_1 ); 00406 if ( stat != CUBIT_SUCCESS ) 00407 return stat; 00408 if ( add_to_group_1 ) 00409 l->add_child(next_node, CUBIT_TRUE); 00410 else 00411 ll->add_child(next_node, CUBIT_TRUE); 00412 } 00413 return CUBIT_SUCCESS; 00414 } 00415 template <class Y> MY_INLINE void RTreeNode<Y>::flush( CubitBox &new_box ) 00416 { 00417 int ii; 00418 nextChildIndex = 0; 00419 for ( ii = 0; ii < maxChildren; ii++ ) 00420 myChildrenNodes[ii] = NULL; 00421 delete myBoundingBox; 00422 myBoundingBox = new CubitBox(new_box); 00423 } 00424 template <class Y> MY_INLINE void RTreeNode<Y>::add_child(RTreeNode<Y> *child_node, 00425 CubitBoolean recalc_b_box) 00426 { 00427 assert(nextChildIndex < maxChildren && child_node != NULL ); 00428 myChildrenNodes[nextChildIndex] = child_node; 00429 //update the bounding box. by uniting with child node... 00430 if ( recalc_b_box ) 00431 { 00432 CubitBox *old_box = myBoundingBox; 00433 myBoundingBox = new CubitBox( *old_box |= child_node->bounding_box()); 00434 delete old_box; 00435 } 00436 nextChildIndex++; 00437 child_node->set_parent(this); 00438 } 00439 template <class Y> MY_INLINE CubitBoolean RTreeNode<Y>::can_add() 00440 { 00441 if (nextChildIndex >= maxChildren ) 00442 return CUBIT_FALSE; 00443 else 00444 return CUBIT_TRUE; 00445 } 00446 template <class Y> MY_INLINE int RTreeNode<Y>::space_left() 00447 { 00448 return maxChildren - nextChildIndex; 00449 } 00450 //------------------------------------------------------------------ 00451 // Algorithm pick_seeds: 00452 // Select two entries to be the first elements of the groups. 00453 // PS1 [Calculate inefficiency of grouping entries together] For 00454 // each pair of entries, e1 and e2, compose a rectangle (bounding_box) 00455 // j, including e1 and e2, calculate: 00456 // d = volume(j) - volume(e1) - volume(e2) 00457 // PS2 [Choose the most wasteful pair] Choose the pair with the largest 00458 // d. 00459 //------------------------------------------------------------------ 00460 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::pick_seeds(RTreeNode<Y> **input_list, 00461 const int input_list_size, 00462 RTreeNode<Y> *&seed_1, 00463 RTreeNode<Y> *&seed_2) 00464 { 00465 int ii, jj; 00466 RTreeNode<Y> *e_1, *e_2; 00467 CubitBox e_box_1, e_box_2, j; 00468 double d, max_d = -CUBIT_DBL_MAX; 00469 seed_1 = (RTreeNode<Y>*)NULL; 00470 seed_2 = (RTreeNode<Y>*)NULL; 00471 00472 for(ii = 0; ii < input_list_size; ii++ ) 00473 { 00474 e_1 = input_list[ii]; 00475 e_box_1 = e_1->bounding_box(); 00476 for ( jj = ii+1; jj < input_list_size; jj++ ) 00477 { 00478 e_2 = input_list[jj]; 00479 e_box_2 = e_2->bounding_box(); 00480 //unite the boxes. 00481 j = e_box_1; 00482 j |= e_box_2; 00483 //find the most wastefull boxes to separate the groups. 00484 d = volume(j) - volume(e_box_1) - volume(e_box_2); 00485 if ( d > max_d ) 00486 { 00487 seed_1 = e_1; 00488 seed_2 = e_2; 00489 max_d = d; 00490 } 00491 } 00492 } 00493 return CUBIT_SUCCESS; 00494 } 00495 //------------------------------------------------------------------ 00496 // Algorithm pick_next: 00497 // Select one remaining entry for classification in a group. 00498 // PN1 [Determine cost of putting each entry in group] For each entry 00499 // e not yet in a group, calculate d1 = area increase required in the 00500 // covering rectangle of group_1 to include E. Calculate d2 similarly 00501 // for group_2 00502 // PN2 [Find entry with greatest preference for one group] Choose 00503 // any entry with the maximum difference between d1 and d2. 00504 //------------------------------------------------------------------ 00505 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::pick_next(DLIList <RTreeNode<Y>*> &remaining_nodes, 00506 RTreeNode<Y>* group_1, 00507 RTreeNode<Y>* group_2, 00508 RTreeNode<Y>*& next, 00509 CubitBoolean &add_to_group_1) 00510 { 00511 int ii, next_index = 0; 00512 double d1, d2, max_diff = -CUBIT_DBL_MAX; 00513 add_to_group_1 = CUBIT_TRUE; 00514 RTreeNode<Y> *max_diff_node = (RTreeNode<Y>*)NULL; 00515 RTreeNode<Y> *curr_node; 00516 CubitBox group_1_box = group_1->bounding_box(); 00517 CubitBox group_2_box = group_2->bounding_box(); 00518 CubitBox curr_box; 00519 double v1 = volume(group_1_box); 00520 double v2 = volume(group_2_box); 00521 remaining_nodes.reset(); 00522 for ( ii = 0; ii < remaining_nodes.size(); ii++ ) 00523 { 00524 curr_node = remaining_nodes.get_and_step(); 00525 curr_box = curr_node->bounding_box(); 00526 d1 = calc_enlargement(group_1_box, curr_box); 00527 d2 = calc_enlargement(group_2_box, curr_box); 00528 if ( d1 > d2 ) 00529 { 00530 if ( max_diff < d1 - d2 ) 00531 { 00532 //add to group whose covering area would have 00533 //to be enlarged least. 00534 add_to_group_1 = CUBIT_FALSE; 00535 max_diff = d1 - d2; 00536 max_diff_node = curr_node; 00537 next_index = ii; 00538 } 00539 } 00540 else if ( d2 > d1 ) 00541 { 00542 if ( max_diff < d2 - d1 ) 00543 { 00544 //add to group whose covering area would have 00545 //to be enlarged least. 00546 add_to_group_1 = CUBIT_TRUE; 00547 max_diff = d2 - d1; 00548 max_diff_node = curr_node; 00549 next_index = ii; 00550 } 00551 } 00552 else { 00553 if ( max_diff < 0.0 ) 00554 { 00555 //Add to group with smaller area. 00556 if ( v1 < v2 ) 00557 add_to_group_1 = CUBIT_TRUE; 00558 else if ( v2 < v1 ) 00559 add_to_group_1 = CUBIT_FALSE; 00560 else 00561 { 00562 //add to group with fewest entries. 00563 int num_left_1 = group_1->space_left(); 00564 int num_left_2 = group_2->space_left(); 00565 if ( num_left_1 > num_left_2 ) 00566 add_to_group_1 = CUBIT_TRUE; 00567 else 00568 add_to_group_1 = CUBIT_FALSE; 00569 } 00570 max_diff = 0.0; 00571 max_diff_node = curr_node; 00572 next_index = ii; 00573 } 00574 } 00575 } 00576 next = NULL; 00577 if ( max_diff_node == NULL ) 00578 return CUBIT_FAILURE; 00579 else 00580 next = max_diff_node; 00581 //remove next from the remaining_nodes list. 00582 remaining_nodes.reset(); 00583 remaining_nodes.step(next_index); 00584 RTreeNode<Y> *check_node = remaining_nodes.remove(); 00585 if ( check_node != max_diff_node ) 00586 { 00587 PRINT_ERROR("Error in pick next algorithm logic of rtree..."); 00588 return CUBIT_FAILURE; 00589 } 00590 return CUBIT_SUCCESS; 00591 } 00592 template <class Y> MY_INLINE void RTreeNode<Y>::recalc_b_box() 00593 { 00594 if(myLevel == DATA_RNODE ) 00595 return; 00596 int ii; 00597 CubitBox temp_box; 00598 CubitBoolean first_box = CUBIT_TRUE; 00599 for ( ii = 0; ii < nextChildIndex; ii++ ) 00600 { 00601 if ( first_box ) 00602 { 00603 temp_box = myChildrenNodes[ii]->bounding_box(); 00604 first_box = CUBIT_FALSE; 00605 } 00606 else 00607 temp_box |= myChildrenNodes[ii]->bounding_box(); 00608 } 00609 delete myBoundingBox; 00610 myBoundingBox = new CubitBox(temp_box); 00611 return; 00612 } 00613 //------------------------------------------------------------- 00614 // Algorithm: remove. Remove index record e from an R-tree. 00615 // D1) [Find node containing record]. Invoke find_leaf to locate 00616 // the leaf node l containing e. Stop if the record was not 00617 // found. 00618 // D2) [Delete record.] Remove e from l. 00619 // D3) [Propagate changes.] Invoke CondenseTree, passing L. 00620 // D4) [Shorten tree.] If the root node has only one child 00621 // after the tree has been adjusted, make the child the new 00622 // root. 00623 //------------------------------------------------------------- 00624 template <class Y> MY_INLINE CubitBoolean RTreeNode<Y>::remove( Y e, 00625 RTreeNode<Y> *&new_root, 00626 CubitBoolean &delete_root) 00627 { 00628 //D1) Find node containting record. 00629 if(this->is_data()){ 00630 if(this->get_data() == e){ 00631 myData = NULL; 00632 myLevel = UNSET_RNODE; 00633 return CUBIT_TRUE; 00634 } 00635 else if(this->num_children() == 0){ 00636 return CUBIT_FALSE; 00637 } 00638 } 00639 RTreeNode<Y> *l = NULL; 00640 CubitBox my_box = e->bounding_box(); 00641 CubitStatus stat = find_leaf(e, my_box, this, l); 00642 if ( l == NULL || stat != CUBIT_SUCCESS ) 00643 return CUBIT_FALSE; 00644 //Now l is the RTreeNode that holds the actual data (a DATA_RNODE) 00645 //not a leaf. This was done for efficiency. 00646 RTreeNode<Y> *data_node = l; 00647 l = data_node->get_parent(); 00648 //D2) [Delete record] Remove e from l. 00649 00650 //remove the data node from the children and delete 00651 //the node. 00652 l->remove_child(data_node); 00653 delete data_node; 00654 00655 //D3) [Propogate Changes]. 00656 stat = condense_tree(l, this, new_root); 00657 //D4) [Shorten the tree]. 00658 RTreeNode<Y> *root = this; 00659 if ( new_root != NULL ) 00660 root = new_root; 00661 if ( root->num_children() == 1 ) 00662 { 00663 new_root = root->get_child(0); 00664 new_root->set_parent((RTreeNode<Y>*)NULL); 00665 delete_root = CUBIT_TRUE; 00666 } 00667 return CUBIT_TRUE; 00668 } 00669 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::find_leaf( Y e, 00670 CubitBox &e_box, 00671 RTreeNode<Y> *t, 00672 RTreeNode<Y> *&l ) 00673 { 00674 int ii; 00675 l = NULL; 00676 int loop_size = t->num_children(); 00677 RTreeNode<Y> *curr_node; 00678 if ( t->get_leaf_level() > LEAF_RNODE ) 00679 { 00680 for ( ii = 0; ii < loop_size; ii++ ) 00681 { 00682 curr_node = t->get_child(ii); 00683 if ( curr_node == NULL ) 00684 { 00685 PRINT_ERROR("Problems finding boxes in range.\n"); 00686 assert(curr_node != NULL); 00687 return CUBIT_FAILURE; 00688 } 00689 if ( e_box.overlap(GEOMETRY_RESABS, curr_node->bounding_box()) ) 00690 { 00691 //okay now search through this now. 00692 find_leaf(e, e_box,curr_node,l); 00693 if ( l != NULL ) 00694 return CUBIT_SUCCESS; 00695 } 00696 } 00697 } 00698 else if ( t->is_leaf() ) 00699 { 00700 //search through the children for e. 00701 for ( ii = 0; ii < loop_size; ii++ ) 00702 { 00703 curr_node = t->get_child(ii); 00704 if ( curr_node == NULL ) 00705 { 00706 PRINT_ERROR("Problems finding boxes in range.\n"); 00707 assert(curr_node != NULL); 00708 return CUBIT_FAILURE; 00709 } 00710 if ( curr_node->get_data() == e ) 00711 { 00712 l = curr_node; 00713 return CUBIT_SUCCESS; 00714 } 00715 } 00716 } 00717 return CUBIT_SUCCESS; 00718 } 00719 template <class Y> MY_INLINE CubitBoolean RTreeNode<Y>::remove_child( RTreeNode<Y> *child ) 00720 { 00721 //first find which item this child is at. 00722 int ii; 00723 int index_child = -1; 00724 int loop_size = this->num_children(); 00725 for ( ii = 0; ii < loop_size; ii++ ) 00726 { 00727 if ( myChildrenNodes[ii] == child ) 00728 index_child = ii; 00729 } 00730 if ( index_child == -1 ) 00731 return CUBIT_FALSE; 00732 //Now we need to bubble the array from this point 00733 //upward. 00734 for ( ii = index_child; ii < loop_size-1; ii++ ) 00735 { 00736 myChildrenNodes[ii] = myChildrenNodes[ii+1]; 00737 } 00738 //decrement the position of the next available child. 00739 nextChildIndex--; 00740 //now go from nextChildIndex to the end and make sure it is 00741 //null. 00742 for (ii = nextChildIndex; ii < maxChildren; ii++ ) 00743 myChildrenNodes[ii] = NULL; 00744 00745 return CUBIT_TRUE; 00746 } 00747 //-------------------------------------------------------------------------- 00748 // Algorithm: condense_tree 00749 // Given a leaf node l from which an entry has been deleted, eliminate 00750 // the node if it has too few entries and relocate its entries. Propagate 00751 // node elimination upaward as necessary. Adjust all covering rectangles 00752 // on the path to the root, making them smaller if possible. 00753 // CT1) [Initialize] Set n=l, Set q, the set of eliminated nodes, to be 00754 // empty. 00755 // CT2) [Find parent entry] If n is the root, go to CT6. Otherwise 00756 // let p be the parent of n, and let en be n's entry in p. 00757 // CT3) [Eliminate under-full node.] If n has fewer than minChildren, 00758 // delete en from p and add n to set q. 00759 // CT4) [Adjust covering rectangle] If n has not been eliminated, adjust 00760 // en's bounding box to tightly contain all entries in n. 00761 // CT5) [Move up one level in tree] Set n=p, and repeat from CT2. 00762 // CT6) [Reinsert orphaned entries]. Reinsert all entries of nodes in set q. 00763 // entries from eliminated leaf nodes are re-inserted in tree leaves 00764 // as described in algorithm insert, but entries from higher-level 00765 // nodes must be placed higher in the tree so that leaves of their 00766 // dependent subtrees will be on the same level as leaves of the 00767 // main tree. 00768 //-------------------------------------------------------------------------- 00769 template <class Y> MY_INLINE CubitStatus RTreeNode<Y>::condense_tree(RTreeNode<Y> *l, 00770 RTreeNode<Y> *root, 00771 RTreeNode<Y> *&new_root ) 00772 { 00773 int ii; 00774 new_root = NULL; 00775 //CT1) 00776 RTreeNode<Y> *n = l, *p; 00777 DLIList <RTreeNode<Y>*> set_q; 00778 //CT2) 00779 while ( n != root ) 00780 { 00781 p = n->get_parent(); 00782 if ( n->num_children() < minChildren ) 00783 { 00784 //CT3 00785 //take these children and add them to set_q. 00786 for ( ii = 0;ii < n->num_children(); ii++ ) 00787 set_q.append(n->get_child(ii)); 00788 //remove n from p. 00789 p->remove_child(n); 00790 //delete n. 00791 delete n; 00792 //now continue on. 00793 } 00794 else 00795 { 00796 //CT4 00797 n->recalc_b_box(); 00798 } 00799 //CT5 00800 n = p; 00801 } 00802 //now reinsert all nodes in set_q. 00803 RTreeNode<Y> *curr_node, *temp_root; 00804 temp_root = root; 00805 for (ii = set_q.size(); ii > 0; ii-- ) 00806 { 00807 curr_node = set_q.get_and_step(); 00808 temp_root->insert(curr_node, new_root); 00809 if ( new_root != NULL ) 00810 temp_root = new_root; 00811 } 00812 if ( temp_root != root ) 00813 new_root = temp_root; 00814 return CUBIT_SUCCESS; 00815 } 00816 00817 00818 00819
