cgma
00001 //--------------------------------------------------------------------------- 00002 // Class Name: RTree 00003 // Description: Rectangle tree. A tree for multidimensional access methods. 00004 // The algorithm was taken from the following paper: 00005 // Guttman, A., "R-Trees: A Dynamic Index Structure for 00006 // Spatial Searching", Proceedings of the SIGMOD 00007 // Conference, Boston, June 1984, p. 47-57. 00008 // Creation Date: 3/29/02 00009 // Owner: David R. White 00010 //--------------------------------------------------------------------------- 00011 #ifndef RTREE_HPP 00012 #define RTREE_HPP 00013 00014 #include "CubitDefines.h" 00015 #include "GeometryDefines.h" 00016 #include "AbstractTree.hpp" 00017 00018 class CubitBox; 00019 class CubitVector; 00020 00021 template <class X> class DLIList; 00022 template <class Y> class RTreeNode; 00023 00024 template <class Z> class RTree : public AbstractTree<Z> 00025 { 00026 private: 00027 double myTolerance; 00028 int maxChildren; 00029 int minChildren; 00030 RTreeNode<Z> *myRoot; 00031 CubitStatus recursive_find(RTreeNode<Z> *rect_tree, 00032 const CubitBox &range_box, 00033 DLIList <Z> &range_members); 00034 //- recurses down the rtree to find all all the data members 00035 //- that fall in the range of the range_box. 00036 00037 CubitStatus recursive_find(RTreeNode<Z> *rect_tree, 00038 const CubitVector &ray_origin, 00039 const CubitVector &ray_direction, 00040 DLIList <Z> &range_members); 00041 //- recurses down the rtree to find all all the data members 00042 //- that fall in the range of the ray. 00043 00044 void to_list(DLIList <RTreeNode<Z>*> &member_list, 00045 RTreeNode<Z> *top); 00046 //- converts the tree under top to a list. Note, top is NOT in the list 00047 //- at the end. 00048 double min_dist_sq(CubitVector &q, 00049 CubitBox &b_box); 00050 //- Calculates the distance between a point and a box, this is 00051 //- for the nearest neighbor point search. 00052 00053 00054 class LessThan 00055 { 00056 public: 00057 bool operator()(const Z& x, const Z& y) const 00058 { 00059 return x->get_dist() < y->get_dist(); 00060 } 00061 00062 }; 00063 00064 00065 00066 public: 00067 RTree(double tol = GEOMETRY_RESABS); 00068 RTree(double tol, int max_c, int min_c); 00069 ~RTree(); 00070 //- Constructor/Destructor 00071 00072 CubitStatus add(Z data); 00073 //- Adds the data member to the RTree. 00074 00075 CubitStatus find( const CubitBox &range_box, DLIList <Z> &range_members); 00076 //- searches the range tree for members that intersect this range box 00077 //- within the tolerance. 00078 00079 CubitStatus find( const CubitVector &ray_origin, const CubitVector &ray_direction, 00080 DLIList <Z> &range_members); 00081 //- searches the range tree for members that intersect this ray 00082 //- within the tolerance. 00083 00084 CubitBoolean remove(Z data ); 00085 //- Remove the data member's entry in the rectangle tree. 00086 //- Returns CUBIT_TRUE if item removed. FALSE if item not 00087 //- in tree. 00088 00089 typedef double (*DistSqFunc)(CubitVector &a, Z& b); 00090 CubitStatus k_nearest_neighbor(CubitVector &q, 00091 int k, 00092 double &closest_dist, 00093 DLIList<Z> &nearest_neighbors, 00094 DistSqFunc dist_sq_point_data); 00095 00096 void set_tol(double tol) 00097 {myTolerance = tol;} 00098 double get_tol() 00099 {return myTolerance;} 00100 //- Sets/Gets the tolerance used for the bounding box overlap test, 00101 //- which is used during the range search. 00102 00103 static bool less_than_func(RTreeNode<Z> *&node_a, 00104 RTreeNode<Z> *&node_b); 00105 //- Function to use with the priority queue for sorting. 00106 00107 }; 00108 00109 #include "RTree.cpp" 00110 00111 #endif 00112
