cgma
00001 //- Class: SDLList 00002 //- Owner: Greg Sjaardema 00003 //- Checked by: 00004 //- Version: $Id: 00005 00006 #include "SDLList.hpp" 00007 00008 00009 //- Constructor: Create a list with initial size {increment}. The list 00010 //- will be grown by {increment} each time it is filled. Memory for the 00011 //- list is not allocated until the first element is inserted using 00012 //- {insertLink}. 00013 //- If {increment} is zero, the default increment ({INCREMENT}) will be used 00014 //- From an efficiency standpoint, it is very important that the 00015 //- increment be set large enough to reduce the number of list 00016 //- growths, but small enough to not waste memory. 00017 //- It is more efficient to sligthly overestimate the increment than 00018 //- to underestimate the increment. 00019 SDLList::SDLList ( int increment ): DLList( increment ) 00020 {} 00021 00022 //- Copy Constructor 00023 SDLList::SDLList(const SDLList& from) : DLList(from) 00024 { 00025 listIsSorted = from.listIsSorted; 00026 } 00027 00028 //- Copy Constructor 00029 SDLList::SDLList(const DLList& from) : DLList(from) 00030 { 00031 listIsSorted = CUBIT_FALSE; 00032 } 00033 00034 SDLList::~SDLList() 00035 { 00036 } 00037 00038 //- put new item in list after current item and make it current 00039 void SDLList::insert_link ( void* new_item ) 00040 { 00041 DLList::insert_link(new_item); 00042 listIsSorted = CUBIT_FALSE; 00043 } 00044 00045 //- merge the input list, merge_list, with the current list, making 00046 //- sure not to add duplicate items into the current list 00047 void SDLList::merge_unique ( DLList& merge_list, int merge_list_unique ) 00048 { 00049 DLList::merge_unique(merge_list, merge_list_unique); 00050 listIsSorted = CUBIT_FALSE; 00051 } 00052 00053 //- put new item in list at index 0 and make it current 00054 void SDLList::insert_link_first(void* new_item) 00055 { 00056 DLList::insert_link_first(new_item); 00057 listIsSorted = CUBIT_FALSE; 00058 } 00059 00060 //- remove the item at the current location and return a pointer to it. 00061 //- used for efficiency in cases where preservation of list order is not 00062 //- important. moves last list item (itemCount - 1) to current index and 00063 //- decrements itemCount. eliminates the need to perform the list bubble 00064 //- down (i.e. cut_link) but sacrifices list order in the process. this 00065 //- function should not be used when up-stream order from the removed node is 00066 //- important. when processing a list using this function the user should 00067 //- reset the list to the head (index = 0) before beginning to ensure all 00068 //- list nodes are processed properly. 00069 //- Returns {NULL} if there are no items in list 00070 void* SDLList::extract_link () 00071 { 00072 listIsSorted = CUBIT_FALSE; 00073 return DLList::extract_link(); 00074 } 00075 00076 00077 void* SDLList::change_item_to ( void *new_item ) 00078 { 00079 listIsSorted = CUBIT_FALSE; 00080 return DLList::change_item_to(new_item); 00081 } 00082 00083 // sort_list sorts ordered lists in an ascending or descending fashion 00084 // (depending on the assignment of compare_order function pointer). The 00085 // list is sorted using a standard Heap Sort algorithm ("Algorithms in C++", 00086 // Robert Sedgewick). 00087 void SDLList::sort_list() 00088 { 00089 listIsSorted = CUBIT_TRUE; 00090 if (itemCount > 1) 00091 { 00092 int mid = (itemCount >> 1) + 1; 00093 int ir = itemCount; 00094 void* temp_element = NULL; 00095 00096 while(CUBIT_TRUE) 00097 { 00098 if (mid > 1) 00099 { 00100 mid--; 00101 temp_element = listArray[mid - 1]; 00102 } 00103 else 00104 { 00105 ir--; 00106 temp_element = listArray[ir]; 00107 listArray[ir] = listArray[0]; 00108 if (ir == 1) 00109 { 00110 listArray[0] = temp_element; 00111 return; 00112 } 00113 } 00114 00115 int i = mid; 00116 int j = mid + mid; 00117 00118 while (j <= ir) 00119 { 00120 if (j < ir) 00121 { 00122 if ((*compare_order_obj)(listArray[j], listArray[j - 1])) j++; 00123 } 00124 if ((*compare_order_obj)(listArray[j - 1], temp_element)) 00125 { 00126 listArray[i - 1] = listArray[j - 1]; 00127 i = j; 00128 j += j; 00129 } 00130 else 00131 { 00132 j = ir + 1; 00133 } 00134 } 00135 00136 listArray[i - 1] = temp_element; 00137 } 00138 } 00139 } 00140 00141 // binary_search performs a standard array based binary search (essentially 00142 // bisection) to bracket/locate an insert/search position. 00143 void SDLList::binary_search(int* min_location, int* max_location, void* item) 00144 const 00145 { 00146 // sort the list if necessary and initialize binary search parameters 00147 assert( listIsSorted ); 00148 00149 *min_location = 0; 00150 *max_location = itemCount - 1; 00151 int bracket_width = *max_location; 00152 int compare_location = itemCount >> 1; 00153 00154 // bracket the location (binary search) 00155 00156 while(bracket_width > 1) 00157 { 00158 if ((*compare_order)(item, listArray[compare_location])) 00159 { 00160 *min_location = compare_location; 00161 bracket_width = *max_location - *min_location; 00162 compare_location += (bracket_width >> 1); 00163 } 00164 else 00165 { 00166 *max_location = compare_location; 00167 bracket_width = *max_location - *min_location; 00168 compare_location -= (bracket_width >> 1); 00169 } 00170 } 00171 00172 // if there are duplicate entries in the list, bracket them with min_location 00173 // and max_location 00174 while ( *min_location > 0 && (*compare_equal)(item, listArray[*min_location-1])) 00175 (*min_location)--; 00176 00177 // (max_location already backets the item) 00178 00179 } 00180 00181 // move_to_item_sorted finds the index of the given value, then sets the 00182 // current index there 00183 CubitBoolean SDLList::move_to_item_sorted(void* value) 00184 { 00185 int item_index; 00186 CubitBoolean item_exists = where_is_item_sorted( value, item_index ); 00187 index = item_index; // always 00188 return item_exists; 00189 } 00190 00191 00192 // where_is_item_sorted performs a binary search on the list to locate value. 00193 // If the item with value is found then the current index is set to the item's 00194 // index and TRUE is returned. If item is not found then index is set to 00195 // just before where the item would be, and FALSE is returned. 00196 CubitBoolean SDLList::where_is_item_sorted( void *value, int &insert_index ) 00197 { 00198 // if entries exist then find insertion index 00199 00200 if ( 0 == itemCount ) { 00201 insert_index = 0; 00202 return CUBIT_FALSE; 00203 } 00204 00205 if (!listIsSorted) 00206 { 00207 sort_list(); 00208 } 00209 00210 // perform the binary search 00211 00212 int min_location, max_location; 00213 binary_search(&min_location, &max_location, value); 00214 00215 // if item occupies a place in the list then min_location and/or 00216 // max_location specifies the location ... otherwise item was not found 00217 00218 if ((*compare_equal)(value, listArray[min_location])) 00219 { 00220 insert_index = min_location; 00221 return CUBIT_TRUE; 00222 } 00223 else if ((*compare_equal)(value, listArray[max_location])) 00224 { 00225 insert_index = max_location; 00226 return CUBIT_TRUE; 00227 } 00228 // else not found, 00229 insert_index = min_location; 00230 // is it beyond the end? 00231 if (itemCount == max_location ) { 00232 if ((*compare_order)(value, listArray[max_location])) 00233 insert_index = itemCount; 00234 } 00235 return CUBIT_FALSE; 00236 } 00237 00238 00239 // insert_item_sorted performs a binary search to find the insert 00240 // index in the list for new_item. The function then calls insert_link 00241 // after setting the index to the insert position - 1. 00242 void SDLList::insert_item_sorted(void* value, void* new_item) 00243 { 00244 assert(new_item != NULL); 00245 00246 // if entries exist then find insertion index 00247 00248 if ( itemCount > 0) 00249 { 00250 // perform the binary search and set index to the min_location 00251 00252 int min_location, max_location; 00253 if (!listIsSorted) 00254 { 00255 sort_list(); 00256 } 00257 binary_search(&min_location, &max_location, value); 00258 index = min_location; 00259 00260 // test for special cases (insert first or last) 00261 00262 if (index == 0) 00263 { 00264 // if new_items value < first (ascending) or new_items value > first 00265 // (descending) then insert as first item (index = -1) 00266 00267 if (!(*compare_order)(value, listArray[index])) 00268 { 00269 index--; 00270 } 00271 } 00272 if (index == (itemCount - 2)) 00273 { 00274 // if new_items value > last (ascending) or new_items value < last 00275 // (descending) then insert as last item (index = itemCount - 1) 00276 00277 if ((*compare_order)(value, listArray[index + 1])) 00278 { 00279 index++; 00280 } 00281 } 00282 } 00283 00284 // insert new_item 00285 insert_link(new_item); 00286 listIsSorted = CUBIT_TRUE; 00287 } 00288 00289 // move_to_and_remove_item_sorted uses move_to_item_sorted function to perform 00290 // a binary search to locate the objects's index for which the objects 00291 // functionName() = value. If found, the objects index is set as the current 00292 // index. Then cut_link is called to remove the object from the list. 00293 void* SDLList::move_to_and_remove_item_sorted(void* value) 00294 { 00295 if (move_to_item_sorted(value)) 00296 return cut_link(); 00297 else 00298 return (void*) NULL; 00299 } 00300 00301 00302 SDLList& SDLList::operator=(const SDLList& from) 00303 { 00304 if (this != &from) { 00305 DLList::operator=(from); 00306 } 00307 return *this; 00308 } 00309
