cgma
00001 //- Class: SettingHolder 00002 //- Description: SettingHolder class - used for save and restore settings 00003 //- Owner: Wesley Gill 00004 //- Checked By: 00005 //- Version 00006 00007 #ifndef SETTINGHOLDER_HPP 00008 #define SETTINGHOLDER_HPP 00009 00010 #include "CubitString.hpp" 00011 #include "CubitDefines.h" 00012 #include "CGMUtilConfigure.h" 00013 00014 typedef enum SETTING_TYPE 00015 { 00016 SETTING_UNKNOWN_VALUE_TYPE = -1, 00017 SETTING_INT_VALUE_TYPE = 0, 00018 SETTING_DOUBLE_VALUE_TYPE = 1, 00019 SETTING_CUBITBOOLEAN_VALUE_TYPE = 2, 00020 SETTING_CUBITSTRING_VALUE_TYPE = 3 00021 // int = 0, double = 1, CubitBoolean = 2, CubitString = 3, debug = 4 00022 } SettingType; 00023 00024 00025 class CUBIT_UTIL_EXPORT SettingHolder 00026 { 00027 friend class SettingHandler; 00028 public: 00029 SettingHolder(); 00030 ~SettingHolder(); 00031 00032 //- constructor for int settings 00033 SettingHolder(CubitString, void (*)(int), int (*)(), int); 00034 00035 //- constructor for double settings 00036 SettingHolder(CubitString, void (*)(double), double (*)(), double); 00037 00038 //- constructor for CubitBoolean settings 00039 SettingHolder(CubitString, void (*setFn)(CubitBoolean), 00040 CubitBoolean (*getFn)(), CubitBoolean); 00041 00042 //- constructor for CubitString settings 00043 SettingHolder(CubitString n, void (*setFn) (CubitString), 00044 CubitString (*getFn)(), char* value); 00045 00046 //- constructor for int settings 00047 SettingHolder(CubitString, void (*)(int), int (*)()); 00048 00049 //- constructor for double settings 00050 SettingHolder(CubitString, void (*)(double), double (*)()); 00051 00052 //- constructor for CubitBoolean settings 00053 SettingHolder(CubitString, void (*)(CubitBoolean), CubitBoolean (*)()); 00054 00055 //- constructor for CubitString settings 00056 SettingHolder(CubitString n, void (*setFn) (CubitString), 00057 CubitString (*getFn)()); 00058 00059 00060 private: 00061 00062 //Use an enum for setting_type?? 00063 00064 SettingType setting_type; // Defines the type of setting 00065 // int = 0, double = 1, CubitBoolean = 2, CubitString = 3, debug = 4 00066 00067 CubitString name; // Name of the setting 00068 CubitString description; // Description of the setting 00069 int int_value; 00070 double double_value; 00071 CubitString string_value; 00072 00073 int (*get_int_function) (); // Pointer to get int function 00074 double (*get_double_function) (); // Pointer to get double function 00075 CubitBoolean (*get_bool_function) (); // Pointer to get boolean function 00076 CubitString (*get_string_function) (); // Pointer to get string function 00077 00078 void (*set_int_function) (int); // Pointer to set int function 00079 void (*set_double_function) (double); // Pointer to set double function 00080 void (*set_bool_function) (CubitBoolean); // Pointer to set bool function 00081 void (*set_string_function) (CubitString); // Pointer to set string function 00082 00083 }; 00084 00085 #endif 00086 00087 00088 00089 00090
