cgma
00001 //- Class: TDGeomFacet 00002 //- Description: Tool data for building a geometry from a mesh. 00003 //- Owner: Steve Owen 00004 //- Checked by: 00005 //- Version: 00006 #include "TDGeomFacet.hpp" 00007 #include "CubitFacetEdge.hpp" 00008 #include "CubitFacet.hpp" 00009 #include "CastTo.hpp" 00010 #include "ChollaVolume.hpp" 00011 #include "ChollaSurface.hpp" 00012 #include "ChollaCurve.hpp" 00013 #include "ChollaPoint.hpp" 00014 #include "CubitPoint.hpp" 00015 00016 TDGeomFacet::TDGeomFacet() 00017 { 00018 blockId = -1; 00019 hitFlag = 0; 00020 partnerEdgeList = NULL; 00021 partnerPointList = NULL; 00022 } 00023 00024 TDGeomFacet::~TDGeomFacet() 00025 { 00026 if (partnerEdgeList != NULL) 00027 delete partnerEdgeList; 00028 if (partnerPointList != NULL) 00029 delete partnerPointList; 00030 } 00031 00032 int TDGeomFacet::is_geom_facet(const ToolData* td) 00033 { 00034 return (CAST_TO(const_cast<ToolData*>(td), TDGeomFacet) != NULL); 00035 } 00036 00037 CubitStatus TDGeomFacet::add_geom_facet( FacetEntity *facet_ptr, int block_id ) 00038 { 00039 TDGeomFacet* td = (TDGeomFacet*) facet_ptr->get_TD( &TDGeomFacet::is_geom_facet ); 00040 if ( td == NULL ) 00041 { 00042 td = new TDGeomFacet; 00043 facet_ptr->add_TD( td ); 00044 } 00045 td->set_block_id( block_id); 00046 return CUBIT_SUCCESS; 00047 } 00048 00049 CubitStatus TDGeomFacet::add_geom_facet( CubitFacet *facet_ptr, int block_id) 00050 { 00051 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00052 if ( td == NULL ) 00053 { 00054 td = new TDGeomFacet; 00055 facet_ptr->add_TD( td ); 00056 } 00057 td->set_block_id( block_id); 00058 return CUBIT_SUCCESS; 00059 } 00060 CubitStatus TDGeomFacet::add_geom_facet( CubitFacetEdge *edge_ptr, int block_id ) 00061 { 00062 TDGeomFacet *td = (TDGeomFacet*) edge_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00063 if ( td == NULL ) 00064 { 00065 td = new TDGeomFacet; 00066 edge_ptr->add_TD( td ); 00067 } 00068 td->set_block_id( block_id); 00069 return CUBIT_SUCCESS; 00070 } 00071 CubitStatus TDGeomFacet::add_geom_facet( CubitPoint *point_ptr, int block_id ) 00072 { 00073 TDGeomFacet* td = (TDGeomFacet*) point_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00074 if ( td == NULL ) 00075 { 00076 td = new TDGeomFacet; 00077 point_ptr->add_TD( td ); 00078 } 00079 td->set_block_id( block_id); 00080 00081 return CUBIT_SUCCESS; 00082 } 00083 00084 TDGeomFacet* TDGeomFacet::get_geom_facet( FacetEntity *facet_ptr ) 00085 { 00086 TDGeomFacet* td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00087 if ( td != NULL ) 00088 { 00089 return td; 00090 } 00091 return (TDGeomFacet*) NULL; 00092 } 00093 TDGeomFacet* TDGeomFacet::get_geom_facet( CubitPoint *point_ptr ) 00094 { 00095 TDGeomFacet *td = (TDGeomFacet*) point_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00096 if ( td != NULL ) 00097 { 00098 return td; 00099 } 00100 return (TDGeomFacet*) NULL; 00101 } 00102 TDGeomFacet* TDGeomFacet::get_geom_facet( CubitFacetEdge *edge_ptr ) 00103 { 00104 TDGeomFacet *td = (TDGeomFacet*) edge_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00105 if ( td != NULL ) 00106 { 00107 return td; 00108 } 00109 return (TDGeomFacet*) NULL; 00110 } 00111 TDGeomFacet* TDGeomFacet::get_geom_facet( CubitFacet *facet_ptr ) 00112 { 00113 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00114 if ( td != NULL ) 00115 { 00116 return td; 00117 } 00118 return (TDGeomFacet*) NULL; 00119 } 00120 00121 00122 int TDGeomFacet::get_block_id( FacetEntity *facet_ptr ) 00123 { 00124 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00125 if ( td != NULL ) 00126 { 00127 return td->get_block_id(); 00128 } 00129 return -1; 00130 } 00131 00132 int TDGeomFacet::get_block_id( CubitFacet *facet_ptr ) 00133 { 00134 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00135 if ( td != NULL ) 00136 { 00137 return td->get_block_id(); 00138 } 00139 return -1; 00140 } 00141 00142 int TDGeomFacet::get_block_id( CubitFacetEdge *edge_ptr ) 00143 { 00144 TDGeomFacet *td = (TDGeomFacet*) edge_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00145 if ( td != NULL ) 00146 { 00147 return td->get_block_id(); 00148 } 00149 return -1; 00150 } 00151 void TDGeomFacet::add_cholla_owner( ChollaEntity *cholla_entity ) 00152 { 00153 ChollaSurface *cholla_surface = dynamic_cast<ChollaSurface *> (cholla_entity); 00154 if (cholla_surface != NULL) 00155 add_cholla_surf(cholla_surface); 00156 else 00157 { 00158 ChollaCurve *cholla_curve = dynamic_cast<ChollaCurve *> (cholla_entity); 00159 if (cholla_curve != NULL) 00160 add_cholla_curve( cholla_curve ); 00161 else 00162 { 00163 ChollaPoint *cholla_point = dynamic_cast<ChollaPoint *> (cholla_entity); 00164 if (cholla_point != NULL) 00165 add_cholla_point( cholla_point ); 00166 else 00167 assert(0); // not a recognized cholla entity 00168 } 00169 } 00170 return; 00171 } 00172 void TDGeomFacet::add_cholla_surf( ChollaSurface *f_s_m ) 00173 { 00174 int ii; 00175 for ( ii = ChollaSurfaceList.size(); ii > 0; ii-- ) 00176 { 00177 ChollaSurface *fsm_ptr = ChollaSurfaceList.get_and_step(); 00178 if (f_s_m == fsm_ptr) 00179 { 00180 return; 00181 } 00182 } 00183 ChollaSurfaceList.append(f_s_m); 00184 return; 00185 } 00186 int TDGeomFacet::get_hit_flag( FacetEntity *facet_ptr ) 00187 { 00188 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00189 if ( td != NULL ) 00190 { 00191 return td->get_hit_flag(); 00192 } 00193 return -1; 00194 } 00195 void TDGeomFacet::set_hit_flag( FacetEntity *facet_ptr, int new_val ) 00196 { 00197 TDGeomFacet *td = (TDGeomFacet*) facet_ptr->get_TD(&TDGeomFacet::is_geom_facet); 00198 if ( td != NULL ) 00199 { 00200 td->set_hit_flag(new_val); 00201 } 00202 return; 00203 } 00204 00205 CubitBoolean TDGeomFacet::is_partner( CubitFacetEdge *edge_ptr ) 00206 { 00207 if (partnerEdgeList == NULL) 00208 return CUBIT_FALSE; 00209 for (int ii=0; ii<partnerEdgeList->size(); ii++) 00210 { 00211 if (partnerEdgeList->get_and_step() == edge_ptr) 00212 return CUBIT_TRUE; 00213 } 00214 return CUBIT_FALSE; 00215 } 00216 CubitBoolean TDGeomFacet::is_partner( CubitPoint *point_ptr ) 00217 { 00218 if (partnerPointList == NULL) 00219 return CUBIT_FALSE; 00220 for (int ii=0; ii<partnerPointList->size(); ii++) 00221 { 00222 if (partnerPointList->get_and_step() == point_ptr) 00223 return CUBIT_TRUE; 00224 } 00225 return CUBIT_FALSE; 00226 } 00227 00228 void TDGeomFacet::reset_TD_as_new() 00229 { 00230 blockId = -1; 00231 hitFlag = 0; 00232 partnerEdgeList = NULL; 00233 partnerPointList = NULL; 00234 ChollaSurfaceList.clean_out(); 00235 ChollaCurveList.clean_out(); 00236 myPoints.clean_out(); 00237 //normal??????; 00238 //need to delete these? 00239 partnerEdgeList=NULL; 00240 partnerPointList=NULL; 00241 00242 } 00243 00244 int TDGeomFacet::geo_type() 00245 { 00246 if (ChollaSurfaceList.size() > 0) 00247 return 2; 00248 else if (ChollaCurveList.size() > 0) 00249 return 1; 00250 else if (myPoints.size() > 0) 00251 return 0; 00252 return -1; 00253 } 00254 00255 CubitBoolean TDGeomFacet::is_in_volume( ChollaVolume *chvol_ptr ) 00256 { 00257 for (int ii=0; ii<ChollaSurfaceList.size(); ii++) 00258 { 00259 ChollaSurface *chsurf_ptr = ChollaSurfaceList.get_and_step(); 00260 if (chsurf_ptr->is_in_volume( chvol_ptr )) 00261 return CUBIT_TRUE; 00262 } 00263 for (int jj=0; jj<ChollaCurveList.size(); jj++) 00264 { 00265 ChollaCurve *chcurv_ptr = ChollaCurveList.get_and_step(); 00266 if (chcurv_ptr->is_in_volume( chvol_ptr )) 00267 return CUBIT_TRUE; 00268 } 00269 return CUBIT_FALSE; 00270 } 00271 00272 00273
