cgma
00001 //-Class: TDSplitSurface.hpp 00002 00003 #ifndef TD_SPLIT_SURFACE_HPP 00004 #define TD_SPLIT_SURFACE_HPP 00005 00006 #include "ToolData.hpp" 00007 #include "CastTo.hpp" 00008 #include "DLIList.hpp" 00009 #include "CubitVector.hpp" 00010 #include "Cubit2DPoint.hpp" 00011 #include "CGMGeomConfigure.h" 00012 00013 class RefFace; 00014 class RefEdge; 00015 class RefVertex; 00016 class CoEdge; 00017 00018 //================================================================================ 00019 // Description: A trivial class to hold two parameter values so that they 00020 // can be stored in a DLIList. They are the min and max parameter 00021 // space along the composite curve. (Split Surface Param) 00022 // Author : Steve Storm 00023 // Date : 2/3/2004 00024 //================================================================================ 00025 class CUBIT_GEOM_EXPORT SSParam 00026 { 00027 public: 00028 00029 SSParam( double min, double max ); 00030 ~SSParam(); 00031 00032 double umin(); 00033 double umax(); 00034 00035 private: 00036 00037 double uMin; 00038 double uMax; 00039 }; 00040 00041 inline double SSParam::umin() 00042 { return uMin; } 00043 00044 inline double SSParam::umax() 00045 { return uMax; } 00046 00047 //================================================================================ 00048 // Description: This class (Split Surface Side) holds a chain of curves on one 00049 // side of the surface. It is needed to handle queries using a 00050 // composite curve concept. 00051 // Author : Steve Storm 00052 // Date : 2/3/2004 00053 //================================================================================ 00054 class CUBIT_GEOM_EXPORT SSSide 00055 { 00056 public: 00057 00058 SSSide( RefFace *ref_face_ptr, DLIList<CoEdge*> &co_edges, 00059 const CubitVector *collapsed_loc_ptr = NULL ); 00060 ~SSSide(); 00061 00062 CubitStatus position_from_u( double u_value, 00063 CubitVector& output_position ); 00064 00065 CubitStatus u_from_position ( const CubitVector& input_position, 00066 double &u ); 00067 CubitStatus u_from_position ( const CubitVector& input_position, 00068 CoEdge *co_edge_ptr, SSParam *param, 00069 double &u ); 00070 00071 CubitBoolean is_vertex_on( RefVertex *ref_vertex_ptr ); 00072 //- Determines if the given vertex lies on this side spatially. 00073 00074 double length(); 00075 //- Return curve length of this side 00076 00077 CubitStatus build_param_list_from_facets( double tolerance = 0.1 ); 00078 //- This function builds paramList using the graphics facets. The 00079 //- coordList will be filled during syncronization - syncronize_lists. 00080 //- The tolerance is used by the geometry engine as the allowable deviation 00081 //- of the facets from the actual curve. 00082 00083 CubitStatus build_param_list( double fraction, double distance, int num_segs, 00084 DLIList<RefVertex*> &through_vertex_list ); 00085 //- This function fills the paramList and coordList with the 00086 //- appropriate number of points for the A and C sides of the surface. 00087 //- This is typically one point at the 50% location; however it could 00088 //- be at a specified fraction value, at a vertex location or multiple 00089 //- points evenly spaced. 00090 00091 CubitStatus syncronize_lists( SSSide *other_side, 00092 double param_tol=.1 ); 00093 //- Update lists in "this" and other_side. Parameter values from 00094 //- both lists will be merged so that paramList will be identical 00095 //- on both SSSides. This also populates coordList. Use this 00096 //- function to syncronize the B-D sides. 00097 00098 DLIList<CoEdge*> *co_edges(); 00099 //- Returns a pointer to this side's CoEdge list 00100 00101 int coord_list_size(); 00102 //- Return size of coordList 00103 void coord_list_reset(); 00104 //- Set coordList to start of list 00105 void coord_list_last(); 00106 //- Set coordList to end of list 00107 CubitVector *coord_list_get(); 00108 //- Return value of current item in coordList 00109 CubitVector *coord_list_get_and_step(); 00110 //- Get and step on the coordList 00111 CubitVector *coord_list_get_and_back(); 00112 //- Get and back on the coordList 00113 00114 int param_list_size(); 00115 //- Return size of paramList 00116 void param_list_reset(); 00117 //- Set paramList to start of list 00118 void param_list_last(); 00119 //- Set paramList to end of list 00120 double param_list_get(); 00121 //- Return value of current item in paramList 00122 double param_list_get_and_step(); 00123 //- Get and step on the paramList 00124 double param_list_get_and_back(); 00125 //- Get and back on the paramList 00126 00127 CubitBoolean is_collapsed(); 00128 //- Return whether this side is collapsed or not 00129 00130 private: 00131 00132 RefFace *refFacePtr; 00133 DLIList<CoEdge*> coEdgeChain; 00134 double paramHigh; // Parameter space of chain goes from 0.0 to curve length 00135 DLIList<SSParam*> coEdgeParamList; // Holds low and high parameter on each CoEdge 00136 00137 DLIList<CubitVector*> coordList; // Coordinates for determining split locations 00138 DLIList<double> paramList; // Parameters for determining split locations 00139 // Note: sideA and sideC just contain the interior locs, while sideB and sideD 00140 // contain interior plus end locs built from curve facetting 00141 00142 CubitBoolean isCollapsed; // CUBIT_TRUE if edge is collapsed (just a point) 00143 }; 00144 00145 inline double SSSide::length() 00146 { return paramHigh; } 00147 00148 inline DLIList<CoEdge*> *SSSide::co_edges() 00149 { return &coEdgeChain; } 00150 00151 inline int SSSide::coord_list_size() 00152 { return coordList.size(); } 00153 inline void SSSide::coord_list_reset() 00154 { coordList.reset(); } 00155 inline void SSSide::coord_list_last() 00156 { coordList.last(); } 00157 inline CubitVector *SSSide::coord_list_get() 00158 { return coordList.get(); } 00159 inline CubitVector *SSSide::coord_list_get_and_step() 00160 { return coordList.get_and_step(); } 00161 inline CubitVector *SSSide::coord_list_get_and_back() 00162 { return coordList.get_and_back(); } 00163 00164 inline int SSSide::param_list_size() 00165 { return paramList.size(); } 00166 inline void SSSide::param_list_reset() 00167 { paramList.reset(); } 00168 inline void SSSide::param_list_last() 00169 { paramList.last(); } 00170 inline double SSSide::param_list_get() 00171 { return paramList.get(); } 00172 inline double SSSide::param_list_get_and_step() 00173 { return paramList.get_and_step(); } 00174 inline double SSSide::param_list_get_and_back() 00175 { return paramList.get_and_back(); } 00176 00177 inline CubitBoolean SSSide::is_collapsed() 00178 { return isCollapsed;} 00179 00180 //================================================================================ 00181 // Description: This class holds data on the surface defining the sides of 00182 // the surface to be split. 00183 // Author : Steve Storm 00184 // Date : 2/3/2004 00185 //================================================================================ 00186 class CUBIT_GEOM_EXPORT TDSplitSurface : public ToolData 00187 { 00188 public: 00189 00190 TDSplitSurface( int vertex_type ); 00191 //- Constructor if placed on a CoEdge 00192 00193 TDSplitSurface( RefFace *ref_face_ptr ); 00194 //- Constructor if placed on a RefFace 00195 00196 ~TDSplitSurface(); 00197 //- Destructor 00198 00199 RefFace *ref_face_ptr(); 00200 //- Return this TDSplitSurface's RefFace ptr 00201 00202 void add_type( int type ); 00203 int get_type(); 00204 //- For CoEdges 00205 00206 CubitStatus add_coedges( DLIList<CoEdge*> &co_edge_list, 00207 int side_interval[] ); 00208 CubitStatus add_a_coedges( DLIList<CoEdge*> &a_coedges, 00209 RefVertex *start_vertex_ptr = NULL ); 00210 CubitStatus add_b_coedges( DLIList<CoEdge*> &b_coedges, 00211 RefVertex *start_vertex_ptr = NULL ); 00212 CubitStatus add_c_coedges( DLIList<CoEdge*> &c_coedges, 00213 RefVertex *start_vertex_ptr = NULL ); 00214 CubitStatus add_d_coedges( DLIList<CoEdge*> &d_coedges, 00215 RefVertex *start_vertex_ptr = NULL ); 00216 //- Add the curves into SSSide. Note any side could be collapsed because of 00217 //- a triangle, if that is true a vertex needs to be provided to give the 00218 //- coordinate of the side. 00219 00220 CubitStatus tessellate_sides( double tol, double fraction, double distance, 00221 int num_segs, 00222 DLIList<RefVertex*> &through_vertex_list ); 00223 //- Tessellates curves on the sides to find boundary coordinates in preparation 00224 //- for the mapping algirithm. To give a smooth mapping, the tessellations 00225 //- are matched across the sides (ie., all locations on either side are at the 00226 //- same parameter value along the side). The through_vertex_list if optional - 00227 //- if specified, the split will pass through vertices in the through_vertex_list 00228 //- that are on sides A or C spatially. 00229 00230 RefVertex *start_vertex( CoEdge *co_edge_ptr ); 00231 //- Get the starting vertex of the given CoEdge. 00232 00233 DLIList<CoEdge*> *get_a_coedges(); 00234 DLIList<CoEdge*> *get_b_coedges(); 00235 DLIList<CoEdge*> *get_c_coedges(); 00236 DLIList<CoEdge*> *get_d_coedges(); 00237 //- Just return a pointer to the curves 00238 00239 double length_a(); 00240 double length_b(); 00241 double length_c(); 00242 double length_d(); 00243 //- Return the length of the given side 00244 00245 int coord_list_size_a(); 00246 void coord_list_reset_a(); 00247 void coord_list_last_a(); 00248 CubitVector *coord_list_get_a(); 00249 CubitVector *coord_list_get_and_step_a(); 00250 CubitVector *coord_list_get_and_back_a(); 00251 //- Used to traverse the coordinates on side A 00252 00253 int coord_list_size_b(); 00254 void coord_list_reset_b(); 00255 void coord_list_last_b(); 00256 CubitVector *coord_list_get_b(); 00257 CubitVector *coord_list_get_and_step_b(); 00258 CubitVector *coord_list_get_and_back_b(); 00259 //- Used to traverse the coordinates on side B 00260 00261 int coord_list_size_c(); 00262 void coord_list_reset_c(); 00263 void coord_list_last_c(); 00264 CubitVector *coord_list_get_c(); 00265 CubitVector *coord_list_get_and_step_c(); 00266 CubitVector *coord_list_get_and_back_c(); 00267 //- Used to traverse the coordinates on side C 00268 00269 int coord_list_size_d(); 00270 void coord_list_reset_d(); 00271 void coord_list_last_d(); 00272 CubitVector *coord_list_get_d(); 00273 CubitVector *coord_list_get_and_step_d(); 00274 CubitVector *coord_list_get_and_back_d(); 00275 //- Used to traverse the coordinates on side D 00276 00277 int param_list_size_a(); 00278 void param_list_reset_a(); 00279 void param_list_last_a(); 00280 double param_list_get_a(); 00281 double param_list_get_and_step_a(); 00282 double param_list_get_and_back_a(); 00283 //- Used to traverse the parameters on side A 00284 00285 int param_list_size_b(); 00286 void param_list_reset_b(); 00287 void param_list_last_b(); 00288 double param_list_get_b(); 00289 double param_list_get_and_step_b(); 00290 double param_list_get_and_back_b(); 00291 //- Used to traverse the parameters on side B 00292 00293 int param_list_size_c(); 00294 void param_list_reset_c(); 00295 void param_list_last_c(); 00296 double param_list_get_c(); 00297 double param_list_get_and_step_c(); 00298 double param_list_get_and_back_c(); 00299 //- Used to traverse the parameters on side C 00300 00301 int param_list_size_d(); 00302 void param_list_reset_d(); 00303 void param_list_last_d(); 00304 double param_list_get_d(); 00305 double param_list_get_and_step_d(); 00306 double param_list_get_and_back_d(); 00307 //- Used to traverse the parameters on side D 00308 00309 CubitBoolean is_a_collapsed(); 00310 CubitBoolean is_b_collapsed(); 00311 CubitBoolean is_c_collapsed(); 00312 CubitBoolean is_d_collapsed(); 00313 //- Return whether sides are collapsed or not 00314 00315 static int is_split_surface(const ToolData* td) 00316 {return (CAST_TO(td, const TDSplitSurface) != NULL);} 00317 00318 private: 00319 00320 RefFace *refFacePtr; 00321 00322 SSSide *sideA; 00323 SSSide *sideB; 00324 SSSide *sideC; 00325 SSSide *sideD; 00326 00327 // For vertices 00328 int vertexType; 00329 }; 00330 00331 inline RefFace *TDSplitSurface::ref_face_ptr() 00332 { return refFacePtr; } 00333 00334 inline int TDSplitSurface::get_type() 00335 { return vertexType; } 00336 00337 inline double TDSplitSurface::length_a() 00338 { return sideA->length(); } 00339 inline double TDSplitSurface::length_b() 00340 { return sideB->length(); } 00341 inline double TDSplitSurface::length_c() 00342 { return sideC->length(); } 00343 inline double TDSplitSurface::length_d() 00344 { return sideD->length(); } 00345 00346 inline int TDSplitSurface::coord_list_size_a() 00347 { return sideA->coord_list_size(); } 00348 inline void TDSplitSurface::coord_list_reset_a() 00349 { sideA->coord_list_reset(); } 00350 inline CubitVector *TDSplitSurface::coord_list_get_and_step_a() 00351 { return sideA->coord_list_get_and_step(); } 00352 00353 inline int TDSplitSurface::coord_list_size_b() 00354 { return sideB->coord_list_size(); } 00355 inline void TDSplitSurface::coord_list_reset_b() 00356 { sideB->coord_list_reset(); } 00357 inline CubitVector *TDSplitSurface::coord_list_get_and_step_b() 00358 { return sideB->coord_list_get_and_step(); } 00359 00360 inline int TDSplitSurface::coord_list_size_c() 00361 { return sideC->coord_list_size(); } 00362 inline void TDSplitSurface::coord_list_reset_c() 00363 { sideC->coord_list_reset(); } 00364 inline void TDSplitSurface::coord_list_last_c() 00365 { sideC->coord_list_last(); } 00366 inline CubitVector *TDSplitSurface::coord_list_get_and_step_c() 00367 { return sideC->coord_list_get_and_step(); } 00368 inline CubitVector *TDSplitSurface::coord_list_get_and_back_c() 00369 { return sideC->coord_list_get_and_back(); } 00370 00371 inline int TDSplitSurface::coord_list_size_d() 00372 { return sideD->coord_list_size(); } 00373 inline void TDSplitSurface::coord_list_reset_d() 00374 { sideD->coord_list_reset(); } 00375 inline void TDSplitSurface::coord_list_last_d() 00376 { sideD->coord_list_last(); } 00377 inline CubitVector *TDSplitSurface::coord_list_get_and_step_d() 00378 { return sideD->coord_list_get_and_step(); } 00379 inline CubitVector *TDSplitSurface::coord_list_get_and_back_d() 00380 { return sideD->coord_list_get_and_back(); } 00381 00382 inline void TDSplitSurface::param_list_reset_a() 00383 { sideA->param_list_reset(); } 00384 inline void TDSplitSurface::param_list_last_a() 00385 { sideA->param_list_last(); } 00386 inline double TDSplitSurface::param_list_get_and_step_a() 00387 { return sideA->param_list_get_and_step(); } 00388 00389 inline void TDSplitSurface::param_list_reset_b() 00390 { sideB->param_list_reset(); } 00391 inline double TDSplitSurface::param_list_get_and_step_b() 00392 { return sideB->param_list_get_and_step(); } 00393 00394 inline void TDSplitSurface::param_list_last_c() 00395 { sideC->param_list_last(); } 00396 inline double TDSplitSurface::param_list_get_and_back_c() 00397 { return sideC->param_list_get_and_back(); } 00398 00399 inline void TDSplitSurface::param_list_last_d() 00400 { sideD->param_list_last(); } 00401 inline double TDSplitSurface::param_list_get_and_back_d() 00402 { return sideD->param_list_get_and_back(); } 00403 00404 inline CubitBoolean TDSplitSurface::is_a_collapsed() 00405 { return sideA->is_collapsed(); } 00406 00407 inline CubitBoolean TDSplitSurface::is_b_collapsed() 00408 { return sideB->is_collapsed(); } 00409 00410 inline CubitBoolean TDSplitSurface::is_c_collapsed() 00411 { return sideC->is_collapsed(); } 00412 00413 inline CubitBoolean TDSplitSurface::is_d_collapsed() 00414 { return sideD->is_collapsed(); } 00415 00416 00417 //================================================================================ 00418 // Description: This class holds data on vertices for split across extend 00419 // Author : Steve Storm 00420 // Date : 10/7/2007 00421 //================================================================================ 00422 class CUBIT_GEOM_EXPORT TDSplitSurfaceExtend : public ToolData 00423 { 00424 public: 00425 00426 TDSplitSurfaceExtend(); 00427 //- Constructor 00428 00429 ~TDSplitSurfaceExtend(); 00430 //- Destructor 00431 00432 void set_success(); 00433 //- This indicates we successfully extended from this vertex 00434 00435 CubitBoolean is_success(); 00436 //- Did we successfully extend from this vertex? 00437 00438 static int is_split_surface_extend(const ToolData* td) 00439 {return (CAST_TO(td, const TDSplitSurfaceExtend) != NULL);} 00440 00441 private: 00442 00443 CubitBoolean successFlg; 00444 }; 00445 00446 inline void 00447 TDSplitSurfaceExtend::set_success() 00448 { successFlg = CUBIT_TRUE; } 00449 00450 inline CubitBoolean 00451 TDSplitSurfaceExtend::is_success() 00452 { return successFlg; } 00453 #endif // TD_SPLIT_SURFACE_HPP
