cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : TDUPtr.hpp 00003 // 00004 // Purpose : Smart pointer that becomes NULL when pointed-to object 00005 // is destroted. 00006 // 00007 // Special Notes : Uses ToolData mechanism. Pointed-to object must be 00008 // a ToolDataUser 00009 // 00010 // Creator : Jason Kraftcheck 00011 // 00012 // Creation Date : 03/12/03 00013 //------------------------------------------------------------------------- 00014 00015 /* Example Usage: 00016 00017 TDUPtr<Battleship> my_ptr = new Battleship; 00018 00019 // ... 00020 // do some stuff 00021 // ... 00022 00023 if ( my_ptr == NULL ) 00024 PRINT_INFO("You sunk my Battleship!\n"); 00025 else 00026 PRINT_INFO("Location: %d, %d\n", my_ptr->x(), my_ptr->y() ); 00027 */ 00028 00029 00030 #ifndef TDU_PTR_HPP 00031 #define TDU_PTR_HPP 00032 00033 #include "ToolData.hpp" 00034 #include "CubitMessage.hpp" 00035 #include "CGMUtilConfigure.h" 00036 00037 // Base class for TDUPtr - used because TDUPtr is a template, 00038 // so a common base type for all the template types is required. 00039 class TDUPtrListNode 00040 { 00041 public: 00042 00043 virtual ~TDUPtrListNode(){} 00044 00045 inline TDUPtrListNode() : nextInTD(0) {} 00046 00047 private: 00048 00049 friend class TDPtr; 00050 00051 virtual void nullify() = 0; 00052 TDUPtrListNode* nextInTD; 00053 }; 00054 00055 // The actuall pointer class -- this is the one you 00056 // should be using. 00057 template <class T> class TDUPtr : public TDUPtrListNode 00058 { 00059 public: 00060 00061 inline TDUPtr() : ptrTo(0) {} 00062 00063 inline TDUPtr( T* ptr ) : ptrTo(0) 00064 { change_ptr(ptr); } 00065 00066 inline TDUPtr( const TDUPtr<T>& copy ) : TDUPtrListNode(), ptrTo(0) 00067 { change_ptr(copy.ptrTo); } 00068 00069 inline virtual ~TDUPtr() 00070 { change_ptr(0); } 00071 00072 inline T& operator*() const { return *ptrTo; } 00073 inline T* operator->() const { return ptrTo; } 00074 inline operator bool() const { return ptrTo != 0; } 00075 00076 inline TDUPtr<T>& operator=( const TDUPtr<T>& copy ) 00077 { change_ptr(copy.ptrTo); return *this; } 00078 00079 inline TDUPtr<T>& operator=( T* ptr ) 00080 { change_ptr(ptr); return *this; } 00081 00082 inline bool operator==( const TDUPtr<T>& other ) const 00083 { return ptrTo == other.ptrTo; } 00084 inline bool operator!=( const TDUPtr<T>& other ) const 00085 { return ptrTo != other.ptrTo; } 00086 inline bool operator==( const T* ptr ) const 00087 { return ptrTo == ptr; } 00088 inline bool operator!=( const T* ptr ) const 00089 { return ptrTo != ptr; } 00090 00091 inline void change_ptr( T* ptr ); 00092 00093 inline T* ptr() const 00094 { return ptrTo; } 00095 00096 private: 00097 00098 virtual void nullify() 00099 { ptrTo = 0; } 00100 00101 T* ptrTo; 00102 00103 }; 00104 00105 // The ToolData used to associate pointer objects with TDU. 00106 class CUBIT_UTIL_EXPORT TDPtr : public ToolData 00107 { 00108 public: 00109 static void add_to_TD( TDUPtrListNode* add, ToolDataUser* to ); 00110 static void remove_from_TD( TDUPtrListNode* remove, ToolDataUser* from ); 00111 00112 virtual ~TDPtr(); 00113 00114 private: 00115 00116 inline TDPtr() : listHead(0) { } 00117 00118 static int is_ptr( const ToolData* td ) 00119 { return dynamic_cast<const TDPtr*>(td) != 0; } 00120 00121 TDUPtrListNode* listHead; 00122 }; 00123 00124 template <class T> inline void TDUPtr<T>::change_ptr( T* ptr ) 00125 { 00126 if( ptr != ptrTo ) 00127 { 00128 TDPtr::remove_from_TD(this, ptrTo); 00129 ptrTo = ptr; 00130 TDPtr::add_to_TD(this, ptrTo); 00131 } 00132 } 00133 00134 00135 #endif 00136
