cgma
00001 //#include "cstring" 00002 #include "TextProgressTool.hpp" 00003 #include "CubitMessage.hpp" 00004 00005 //============================================================================= 00006 // Description: constructor 00007 // Notes: This will initialize the progress bar and display it 00008 // The difference between nLower and nUpper will be the number of 00009 // integral steps the progress bar will before the process is complete 00010 // Author: sjowen 00011 // Date: 11/7/01 00012 //============================================================================= 00013 TextProgressTool::TextProgressTool() 00014 { 00015 nTotal = 0; 00016 nCurrent = 0; 00017 nShown = 0; 00018 } 00019 00020 TextProgressTool::~TextProgressTool() 00021 { 00022 } 00023 00024 void TextProgressTool::start(int nLower, int nUpper, 00025 const char* title /* = NULL */, 00026 const char* info_string /* = NULL */, 00027 CubitBoolean , 00028 CubitBoolean ) 00029 { 00030 const char* progress_title = title ? title : "Progress"; 00031 00032 //bSmooth; bHasCancelButton; 00033 PRINT_INFO("%s\n",progress_title); 00034 if (info_string != NULL) 00035 { 00036 PRINT_INFO("%s\n",info_string); 00037 } 00038 PRINT_INFO("0 | | | | 50 | | | | 100\n"); 00039 00040 nTotal = nUpper - nLower; 00041 nCurrent = 0; 00042 nShown = 0; 00043 } 00044 00045 //============================================================================= 00046 // Description: end 00047 // Notes: closes/finishes the prgress bar window 00048 // Author: sjowen 00049 // Date: 11/7/01 00050 //============================================================================= 00051 void TextProgressTool::end() 00052 { 00053 PRINT_INFO("\n"); 00054 } 00055 00056 //============================================================================= 00057 // Description: makes one integer step of the progress bar 00058 // Notes: 00059 // Author: sjowen 00060 // Date: 11/7/01 00061 //============================================================================= 00062 void TextProgressTool::step() 00063 { 00064 if( nTotal > 0 ) 00065 { 00066 nCurrent++; 00067 int n = 50 * nCurrent / nTotal; 00068 for( ; nShown < n; nShown++ ) 00069 PRINT_INFO("*"); 00070 } 00071 } 00072 00073 //============================================================================= 00074 // Description: moves the progress bar to the specified percentage 00075 // Notes: only moves if percentage is greater the the current step 00076 // pcnt should be between 0 and 1 00077 // Author: sjowen 00078 // Date: 11/7/01 00079 //============================================================================= 00080 void TextProgressTool::percent( double pcnt ) 00081 { 00082 int ncur = (int)(pcnt * (double)nTotal + 0.5); 00083 if(ncur > nTotal) 00084 ncur = nTotal; 00085 if (ncur > nCurrent) 00086 { 00087 int ii; 00088 for (ii=nCurrent; ii<ncur; ii++) 00089 { 00090 step(); 00091 } 00092 nCurrent = ncur; 00093 } 00094 } 00095 00096 void TextProgressTool::check_interrupt() 00097 { 00098 }
