cgma
00001 #include <stdlib.h> 00002 #include <stdio.h> 00003 #include <assert.h> 00004 #include <string> 00005 #include <iostream> 00006 #include <fstream> 00007 #include <string.h> 00008 00009 #include <vector> 00010 00011 #include <iGeom.h> 00012 00013 //#include "SimpleArray.h" 00014 template<typename T> 00015 class SimpleArray 00016 { 00017 public: 00018 T *array; 00019 int array_alloc; 00020 int array_size; 00021 00022 SimpleArray() : array(NULL), array_alloc(0), array_size(0){} 00023 ~SimpleArray() {reset();} 00024 00025 T operator[](unsigned int lhs) {return array[lhs];} 00026 00027 void reset() { 00028 if (0 != array) { 00029 free(array); array = NULL; array_alloc = array_size = 0; 00030 } 00031 } 00032 int size() {return array_size;} 00033 00034 }; 00035 #define SA_ARRAY_INOUT(a) &a.array, &a.array_alloc, &a.array_size 00036 #define SA_ARRAY_IN(a) a.array, a.array_size 00037 00038 using namespace std; 00039 00040 int main( int argc, char **argv) 00041 { 00042 assert( argc == 2 ); 00043 string engine_opt = ";engine=OCC"; 00044 string filename = argv[1]; 00045 00046 int err; 00047 iGeom_Instance geom; 00048 iGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() ); 00049 00050 iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 ); 00051 00052 iBase_EntitySetHandle root_set; 00053 iGeom_getRootSet( geom, &root_set, &err); 00054 00055 cout << "Model Contents " << endl; 00056 const char *gtype[] = {"vertices: ", "edges: ", "faces: ", "regions: "}; 00057 for (int i = 0; i <= 3; ++i) { 00058 int count; 00059 iGeom_getNumOfType( geom, root_set, i, &count, &err ); 00060 std::cout << gtype[i] << count << std::endl; 00061 } 00062 00063 iBase_TagHandle idtag; 00064 iGeom_getTagHandle( geom, "GLOBAL_ID", &idtag, &err, strlen("GLOBAL_ID") ); 00065 00066 SimpleArray<iBase_EntityHandle> vertices; 00067 iGeom_getEntities( geom, root_set, iBase_VERTEX, SA_ARRAY_INOUT(vertices), &err); 00068 00069 SimpleArray<double> vCoords; 00070 iGeom_getVtxArrCoords(geom, SA_ARRAY_IN(vertices), iBase_INTERLEAVED, SA_ARRAY_INOUT(vCoords), &err); 00071 00072 SimpleArray<iBase_EntityHandle> edges; 00073 iGeom_getEntities( geom, root_set, iBase_EDGE, SA_ARRAY_INOUT(edges), &err); 00074 00075 SimpleArray<double> edgelength; 00076 iGeom_measure( geom, SA_ARRAY_IN(edges), SA_ARRAY_INOUT(edgelength), &err); 00077 00078 double minlength = edgelength[0]; 00079 for( int i = 0; i < edges.size(); i++) 00080 minlength = std::min(minlength, edgelength[i]); 00081 00082 double ustart, uend, delta; 00083 double x, y, z; 00084 int N = 10; 00085 00086 int id; 00087 int numNodes = 0, numEdges = 0; 00088 vector<double> xCoord, yCoord, zCoord; 00089 for( int i = 0; i < edges.size(); i++) { 00090 iGeom_getEntURange( geom, edges[i], &ustart, &uend, &err); 00091 iGeom_getIntData( geom, edges[i], idtag, &id, &err); 00092 delta = (uend-ustart)/(double)N; 00093 for( int j = 0; j < N+1; j++) { 00094 double u = ustart + j*delta; 00095 iGeom_getEntUtoXYZ( geom, edges[i], u, &x, &y, &z, &err); 00096 xCoord.push_back(x); 00097 yCoord.push_back(y); 00098 zCoord.push_back(z); 00099 numNodes++; 00100 } 00101 numEdges += N; 00102 } 00103 00104 SimpleArray<iBase_EntityHandle> faces; 00105 iGeom_getEntities( geom, root_set, iBase_FACE, SA_ARRAY_INOUT(faces), &err); 00106 00107 int eid, vid1, vid2; 00108 SimpleArray<iBase_EntityHandle> edgenodes; 00109 SimpleArray<iBase_EntityHandle> faceedges; 00110 SimpleArray<iBase_EntityHandle> facenodes; 00111 00112 for( int i = 0; i < faces.size(); i++) 00113 { 00114 iGeom_getIntData( geom, faces[i], idtag, &id, &err); 00115 iGeom_getEntAdj( geom, faces[i], iBase_EDGE, SA_ARRAY_INOUT( faceedges ), &err); 00116 cout << "Face " << id << ": " << faceedges.size() << " edges." << endl; 00117 for(int j = 0; j < faceedges.size(); ++j) 00118 { 00119 iGeom_getIntData( geom, faceedges[j], idtag, &eid, &err); 00120 iGeom_getEntAdj( geom, faceedges[j], iBase_VERTEX, SA_ARRAY_INOUT(edgenodes), &err); 00121 cout << "Edge " << eid << ", " << edgenodes.size() << " vertices: "; 00122 assert( edgenodes.size() == 2 ); 00123 iGeom_getIntData( geom, edgenodes[0], idtag, &vid1, &err); 00124 iGeom_getIntData( geom, edgenodes[1], idtag, &vid2, &err); 00125 cout << vid1 << ", " << vid2 << endl; 00126 } 00127 } 00128 00129 }
