cgma
00001 #ifndef MCNP2CAD_GEOMETRY_H 00002 #define MCNP2CAD_GEOMETRY_H 00003 00004 #include <vector> 00005 #include <iosfwd> 00006 00007 #include "dataref.hpp" 00008 00009 // under visual studio, the following macro must be defined 00010 // in order to get M_PI and friends from the cmath header. 00011 #ifdef _MSC_VER 00012 #define _USE_MATH_DEFINES 00013 #endif 00014 00015 #include <cmath> 00016 00017 class Vector3d{ 00018 00019 public: 00020 00021 double v[3]; 00022 Vector3d(){ 00023 v[2] = v[1] = v[0] = 0; 00024 } 00025 00026 Vector3d( const double p[3] ){ 00027 v[0] = p[0]; 00028 v[1] = p[1]; 00029 v[2] = p[2]; 00030 } 00031 00032 Vector3d( double x, double y, double z ){ 00033 v[0] = x; 00034 v[1] = y; 00035 v[2] = z; 00036 } 00037 00038 Vector3d( const std::vector<double>& p, int idx = 0 ){ 00039 v[0] = p.at(idx+0); 00040 v[1] = p.at(idx+1); 00041 v[2] = p.at(idx+2); 00042 } 00043 00044 double length() const{ 00045 return sqrt( v[0]*v[0] + v[1]*v[1] + v[2]*v[2] ); 00046 } 00047 00048 Vector3d normalize() const { 00049 double length = this->length(); 00050 return Vector3d( v[0]/length, v[1]/length, v[2]/length ); 00051 } 00052 00053 Vector3d operator-() const { 00054 return Vector3d(-v[0], -v[1], -v[2]); 00055 } 00056 00057 Vector3d reverse() const { 00058 return -(*this); 00059 } 00060 00061 Vector3d scale( double d ) const { 00062 return Vector3d(v[0]*d, v[1]*d, v[2]*d); 00063 } 00064 00065 Vector3d operator*( double d ) const { 00066 return scale(d); 00067 } 00068 00069 Vector3d add( const Vector3d& alt ) const { 00070 return Vector3d( v[0]+alt.v[0], v[1]+alt.v[1], v[2]+alt.v[2] ); 00071 } 00072 00073 Vector3d operator+( const Vector3d& alt ) const { 00074 return add(alt); 00075 } 00076 00077 double dot( const Vector3d& alt ) const { 00078 return v[0]*alt.v[0] + v[1]*alt.v[1] + v[2]*alt.v[2]; 00079 } 00080 00081 Vector3d cross( const Vector3d& alt ) const { 00082 Vector3d c; 00083 c.v[0] = v[1]*alt.v[2] - v[2]*alt.v[1]; 00084 c.v[1] = v[2]*alt.v[0] - v[0]*alt.v[2]; 00085 c.v[2] = v[0]*alt.v[1] - v[1]*alt.v[0]; 00086 return c; 00087 } 00088 00089 Vector3d rotate_about( const Vector3d& v_p, double theta_p, bool degrees = true ) const { 00090 Vector3d v = v_p.normalize(); 00091 double theta = theta_p; 00092 if( degrees ) { theta *= M_PI / 180.0; } 00093 double cos_t = cos( theta ); 00094 Vector3d ret = scale(cos_t) + v.scale((1.0-cos_t)*(dot(v))) + cross(v).scale( sin(theta) ); 00095 return ret; 00096 } 00097 00099 Vector3d projection( const Vector3d& v ) const { 00100 return scale( this->dot(v) / this->dot(*this) ); 00101 } 00102 00103 }; 00104 00105 std::ostream& operator<<(std::ostream& str, const Vector3d& v ); 00106 00107 00108 // determinant of 3x3 matrix (C-style matrix ordering) 00109 double matrix_det( double mat[9] ); 00110 00111 class Transform{ 00112 00113 public: 00114 enum mat_format{ C_STYLE, FORTRAN_STYLE }; 00115 00116 protected: 00117 Vector3d translation; 00118 bool has_rot; 00119 double theta; Vector3d axis; 00120 bool invert; 00121 00122 void set_rots_from_matrix( double raw_matrix[9], enum mat_format ); 00123 00124 public: 00125 Transform():translation(),has_rot(false),invert(false){} 00126 Transform( const Vector3d& v ):translation(v),has_rot(false),invert(false){} 00127 Transform( const std::vector< double >& inputs, bool degree_format_p = false, enum mat_format = FORTRAN_STYLE ); 00128 Transform( double rot[9], const Vector3d& trans, enum mat_format = C_STYLE ); 00129 00130 const Vector3d& getTranslation() const { return translation; } 00131 bool hasRot() const{ return has_rot; } 00132 bool hasInversion() const{ return invert; } 00133 double getTheta() const { return theta; } 00134 const Vector3d& getAxis() const { return axis; } 00135 void print( std::ostream& str ) const; 00136 00137 Transform reverse() const; 00138 00139 }; 00140 00141 std::ostream& operator<<(std::ostream& str, const Transform& t ); 00142 00144 class FillNode { 00145 00146 protected: 00147 int universe; 00148 DataRef<Transform>* tr; 00149 00150 public: 00151 FillNode(): 00152 universe(0), tr(new NullRef<Transform>()) 00153 {} 00154 00155 FillNode( int universe_p ): 00156 universe(universe_p), tr(new NullRef<Transform>()) 00157 {} 00158 00159 FillNode( int universe_p, DataRef<Transform>* tr_p ): 00160 universe(universe_p), tr(tr_p) 00161 {} 00162 00163 FillNode( const FillNode& node_p ): 00164 universe(node_p.universe), tr(node_p.tr->clone()) 00165 {} 00166 00167 FillNode& operator=( const FillNode& node_p ){ 00168 if( this != &node_p ){ 00169 universe = node_p.universe; 00170 tr = node_p.tr->clone(); 00171 } 00172 return *this; 00173 } 00174 00175 ~FillNode(){ 00176 delete tr; 00177 } 00178 00179 int getFillingUniverse() const { return universe; } 00180 00181 bool hasTransform() const{ return tr->hasData();} 00182 const Transform& getTransform() const { return tr->getData(); } 00183 00184 void setTransform( DataRef<Transform>* tr_p ){ 00185 delete tr; 00186 tr = tr_p; 00187 } 00188 }; 00189 00190 typedef std::pair<int,int> irange; 00191 00193 class Fill{ 00194 00195 protected: 00196 std::vector<FillNode> nodes; 00197 bool has_grid; 00198 irange xrange, yrange, zrange; 00199 00200 00201 size_t indicesToSerialIndex( int x, int y, int z ) const ; 00202 00203 public: 00204 Fill(): 00205 nodes(1,FillNode()),has_grid(false) 00206 {} 00207 00208 Fill( const FillNode& origin_p ): 00209 nodes(1,origin_p), has_grid(false) 00210 {} 00211 00212 Fill( irange x, irange y, irange z, std::vector<FillNode> nodes_p ): 00213 nodes(nodes_p), has_grid(true), xrange(x), yrange(y), zrange(z) 00214 {} 00215 00216 const FillNode& getOriginNode() const; 00217 const FillNode& getNode( int x, int y, int z ) const; 00218 00219 friend class Lattice; 00220 }; 00221 00222 00223 class Lattice{ 00224 00225 protected: 00226 int num_finite_dims; 00227 Vector3d v1, v2, v3; 00228 00229 DataRef<Fill> *fill; 00230 00231 public: 00232 Lattice() : fill(new NullRef<Fill>()){} 00233 Lattice( int dims, const Vector3d& v1_p, const Vector3d& v2_p, const Vector3d& v3_p, const FillNode& singleton_fill ); 00234 Lattice( int dims, const Vector3d& v1_p, const Vector3d& v2_p, const Vector3d& v3_p, const Fill& full_fill ); 00235 00236 Lattice( const Lattice& l ); 00237 Lattice& operator=( const Lattice& l ); 00238 ~Lattice(){ delete fill; } 00239 00240 00241 int numFiniteDirections() const { return num_finite_dims; } 00242 Transform getTxForNode( int x, int y, int z ) const ; 00243 00244 const FillNode& getFillForNode( int x, int y, int z ) const ; 00245 00246 bool isFixedSize() const { return fill->getData().has_grid; } 00247 irange getXRange() const { return fill->getData().xrange; } 00248 irange getYRange() const { return fill->getData().yrange; } 00249 irange getZRange() const { return fill->getData().zrange; } 00250 00251 00252 }; 00253 00254 00255 #endif /* MCNP2CAD_GEOMETRY_H */
