cgma
00001 00010 #undef NDEBUG 00011 #include <cassert> 00012 00013 #include "GeometryModifyTool.hpp" 00014 #include "GeometryQueryTool.hpp" 00015 #include "OCCQueryEngine.hpp" 00016 #include "CubitMessage.hpp" 00017 #include "Body.hpp" 00018 #include "RefVolume.hpp" 00019 #include "Shell.hpp" 00020 #include "RefFace.hpp" 00021 #include "RefEdge.hpp" 00022 #include "RefVertex.hpp" 00023 #include "CastTo.hpp" 00024 #include "OCCModifyEngine.hpp" 00025 #include "OCCLump.hpp" 00026 #include "OCCBody.hpp" 00027 #include "OCCSurface.hpp" 00028 #include "OCCCurve.hpp" 00029 #include "OCCShell.hpp" 00030 #include "TopoDS_Shape.hxx" 00031 #include "InitCGMA.hpp" 00032 #include "CubitCompat.hpp" 00033 00034 #ifndef SRCDIR 00035 # define SRCDIR . 00036 #endif 00037 00038 #define STRINGIFY_(X) #X 00039 #define STRINGIFY(X) STRINGIFY_(X) 00040 #define SRCPATH STRINGIFY(SRCDIR) "/" 00041 00042 // forward declare some functions used and defined later 00043 CubitStatus read_geometry(int, const char **, bool local = false); 00044 CubitStatus make_Point(); 00045 // macro for printing a separator line 00046 #define PRINT_SEPARATOR PRINT_INFO("=======================================\n"); 00047 00048 00049 // main program - initialize, then send to proper function 00050 int main (int argc, char **argv) 00051 { 00052 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00053 if (CUBIT_SUCCESS != status) return 1; 00054 00055 //Do make point. 00056 status = make_Point(); 00057 if (status == CUBIT_FAILURE) 00058 PRINT_INFO("Operation Failed"); 00059 00060 int ret_val = ( CubitMessage::instance()->error_count() ); 00061 if ( ret_val != 0 ) 00062 { 00063 PRINT_ERROR("Errors found during Mergechk session.\n"); 00064 } 00065 else 00066 ret_val = 0; 00067 00068 return ret_val; 00069 00070 } 00071 00076 CubitStatus read_geometry(int num_files, const char **argv, bool local) 00077 { 00078 CubitStatus status = CUBIT_SUCCESS; 00079 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00080 assert(gti); 00081 int i; 00082 00083 PRINT_SEPARATOR; 00084 00085 for (i = 0; i < num_files; i++) { 00086 std::string filename( local ? "./" : SRCPATH ); 00087 filename += argv[i]; 00088 status = CubitCompat_import_solid_model(filename.c_str(), "OCC"); 00089 if (status != CUBIT_SUCCESS) { 00090 PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str()); 00091 abort(); 00092 } 00093 } 00094 PRINT_SEPARATOR; 00095 00096 return CUBIT_SUCCESS; 00097 } 00098 00099 CubitStatus make_Point() 00100 { 00101 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00102 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00103 00104 OCCQueryEngine::instance(); 00105 //OCCModifyEngine* ome = OCCModifyEngine::instance(); 00106 00107 // Read in the geometry from files specified on the command line 00108 const char *argv = "Solid_2.brep"; 00109 CubitStatus status = read_geometry(1, &argv, false); 00110 if (status == CUBIT_FAILURE) exit(1); 00111 //Read in 1 volume. 00112 00113 argv = "Solid_7.brep"; 00114 status = read_geometry(1, &argv, false); 00115 if (status == CUBIT_FAILURE) exit(1); 00116 //Read in 1 volume. 00117 00118 DLIList<Body*> from_bodies; 00119 DLIList<Body*> new_bodies; 00120 gti->bodies(from_bodies); 00121 //Bug 247 test, when this bug get fixed, the comment should be removed. 00122 // status = gmti->imprint(from_bodies, new_bodies, CUBIT_FALSE); 00123 00124 DLIList<Body*> bodies; 00125 bodies.clean_out(); 00126 gti->bodies(bodies); 00127 //delete all entities 00128 gti->delete_Body(bodies); 00129 00130 DLIList<RefEntity*> free_entities; 00131 gti->get_free_ref_entities(free_entities); 00132 for(int i = 0; i < free_entities.size(); i++) 00133 gti->delete_RefEntity(free_entities.get_and_step()); 00134 00135 Body* body = gmti->brick(10, 10, 10); 00136 DLIList<Shell*> shells; 00137 body->shells(shells); 00138 ShellSM* shell = shells.get()->get_shell_sm_ptr(); 00139 OCCShell* occ_shell = CAST_TO(shell, OCCShell); 00140 DLIList<TopologyBridge*> parents; 00141 occ_shell->get_parents_virt(parents); 00142 assert (parents.size() == 1); 00143 return status; 00144 }
