cgma
00001 00010 #undef NDEBUG 00011 #include <cassert> 00012 00013 #include "GeometryModifyTool.hpp" 00014 #include "GeometryQueryTool.hpp" 00015 #include "CubitMessage.hpp" 00016 #include "Body.hpp" 00017 #include "RefVolume.hpp" 00018 #include "RefFace.hpp" 00019 #include "RefEdge.hpp" 00020 #include "RefVertex.hpp" 00021 #include "InitCGMA.hpp" 00022 #include "OCCModifyEngine.hpp" 00023 #include "CubitCompat.hpp" 00024 00025 #include <algorithm> 00026 00027 #ifndef SRCDIR 00028 # define SRCDIR . 00029 #endif 00030 00031 #define STRINGIFY_(X) #X 00032 #define STRINGIFY(X) STRINGIFY_(X) 00033 #define SRCPATH STRINGIFY(SRCDIR) "/" 00034 00035 // forward declare some functions used and defined later 00036 CubitStatus read_geometry(int, char **, bool local = false); 00037 CubitStatus make_Point(); 00038 // macro for printing a separator line 00039 #define PRINT_SEPARATOR PRINT_INFO("=======================================\n"); 00040 00041 00042 // main program - initialize, then send to proper function 00043 int main (int argc, char **argv) 00044 { 00045 CubitStatus status = InitCGMA::initialize_cgma("OCC"); 00046 if (CUBIT_SUCCESS != status) return 1; 00047 00048 //Do make point. 00049 status = make_Point(); 00050 if (status == CUBIT_FAILURE) 00051 PRINT_INFO("Operation Failed"); 00052 00053 int ret_val = ( CubitMessage::instance()->error_count() ); 00054 if ( ret_val > 0 ) 00055 { 00056 PRINT_ERROR("Errors found during Mergechk session.\n"); 00057 } 00058 return ret_val; 00059 00060 } 00061 00062 std::string type_from_file_name( const std::string& filename ) 00063 { 00064 size_t dot_pos = filename.find_last_of( '.' ); 00065 if (dot_pos == std::string::npos) 00066 return std::string(); 00067 00068 std::string extension = filename.substr( dot_pos + 1 ); 00069 std::transform( extension.begin(), extension.end(), extension.begin(), ::tolower ); 00070 if (extension == "occ" || extension == "brep") 00071 return "OCC"; 00072 else if (extension == "step" || extension == "stp") 00073 return "STEP"; 00074 else if (extension == "iges" || extension == "igs") 00075 return "IGES"; 00076 else 00077 return std::string(); 00078 } 00079 00084 CubitStatus read_geometry(int num_files, const char **argv, bool local) 00085 { 00086 CubitStatus status = CUBIT_SUCCESS; 00087 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00088 assert(gti); 00089 int i; 00090 00091 PRINT_SEPARATOR; 00092 00093 for (i = 0; i < num_files; i++) { 00094 std::string type = type_from_file_name( argv[i] ); 00095 if (type.empty()) // just guess OCC 00096 type = "OCC"; 00097 std::string filename( local ? "./" : SRCPATH ); 00098 filename += argv[i]; 00099 status = CubitCompat_import_solid_model(filename.c_str(), type.c_str()); 00100 if (status != CUBIT_SUCCESS) { 00101 PRINT_ERROR("Problems reading geometry file %s.\n", filename.c_str()); 00102 abort(); 00103 } 00104 } 00105 PRINT_SEPARATOR; 00106 00107 return CUBIT_SUCCESS; 00108 } 00109 00110 CubitStatus make_Point() 00111 { 00112 GeometryQueryTool *gti = GeometryQueryTool::instance(); 00113 GeometryModifyTool *gmti = GeometryModifyTool::instance(); 00114 00115 DLIList<Body*> bodies; 00116 DLIList<RefEntity*> free_entities; 00117 00118 // Read in the geometry from files specified on the command line 00119 const char *argv = "stitch.name_occ"; 00120 CubitStatus status = read_geometry(1, &argv, false); 00121 if (status == CUBIT_FAILURE) exit(1); 00122 //Read in 2 volumes. 00123 00124 gti->bodies(bodies); 00125 DLIList<Body*> new_bodies; 00126 DLIList<Body*> from_bodies; 00127 BodySM* from_body = bodies.get()->get_body_sm_ptr(); 00128 from_bodies.append(bodies.get()); 00129 CubitVector v1(.5,1,3); 00130 CubitVector v2(.5,2,2); 00131 CubitVector v3(.5,1,1); 00132 BodySM* midplane_bodysm = 0; 00133 status = OCCModifyEngine::instance()->get_mid_plane(v1, v2, v3, from_body, midplane_bodysm); 00134 if(midplane_bodysm) 00135 { 00136 Body *midplane_body; 00137 midplane_body = gti->make_Body(midplane_bodysm); 00138 double d = midplane_body->measure(); 00139 assert( d > 99.9999 && d < 100.00001); 00140 } 00141 00142 v1.x(2); 00143 v2.x(2); 00144 v3.x(2); 00145 00146 midplane_bodysm = 0; 00147 status = OCCModifyEngine::instance()->get_mid_plane(v1, v2, v3, from_body, midplane_bodysm); 00148 if(midplane_bodysm) 00149 { 00150 Body *midplane_body; 00151 midplane_body = gti->make_Body(midplane_bodysm); 00152 double d = midplane_body->measure(); 00153 assert( d > 69.9999 && d < 70.00001); 00154 } 00155 00156 DLIList<Body*> neighbor_list; 00157 status = gmti->webcut_with_plane(from_bodies, v1, v2, v3, new_bodies, neighbor_list, ONLY_INVOLVED_BODIES); 00158 double d = new_bodies.step_and_get()->measure(); 00159 //CubitVector v = new_bodies.get()->center_point(); 00160 int n = new_bodies.get()->num_ref_faces(); 00161 assert(n==8); 00162 assert(d <= 710 && d > 709.999999); 00163 // n = 8 00164 //new bodies has 2 bodies, one has a volume = 170 and the other has a 00165 //volume = 710; each of them has 8 ref_faces. 00166 00167 bodies.clean_out(); 00168 gti->bodies(bodies); 00169 //delete all entities 00170 gti->delete_Body(bodies); 00171 00172 gti->get_free_ref_entities(free_entities); 00173 assert(free_entities.size() ==0); 00174 00175 return CUBIT_SUCCESS; 00176 }
