cgma
00001 00018 #include "iGeom.h" 00019 #include <iostream> 00020 #include <set> 00021 #include <algorithm> 00022 #include <vector> 00023 #include <iterator> 00024 #include <algorithm> 00025 #include <iomanip> 00026 #include <assert.h> 00027 #include <string.h> 00028 #include <math.h> 00029 #define CHECK( STR ) if (err != iBase_SUCCESS) return print_error( STR, err, geom, __FILE__, __LINE__ ) 00030 00031 #define STRINGIFY(S) XSTRINGIFY(S) 00032 #define XSTRINGIFY(S) #S 00033 00034 static bool print_error( const char* desc, 00035 int err, 00036 iGeom_Instance geom, 00037 const char* file, 00038 int line ) 00039 { 00040 char buffer[1024]; 00041 iGeom_getDescription( geom, buffer, sizeof(buffer) ); 00042 buffer[sizeof(buffer)-1] = '\0'; 00043 00044 std::cerr << "ERROR: " << desc << std::endl 00045 << " Error code: " << err << std::endl 00046 << " Error desc: " << buffer << std::endl 00047 << " At : " << file << ':' << line << std::endl 00048 ; 00049 00050 return false; // must always return false or CHECK macro will break 00051 } 00052 00053 typedef iBase_TagHandle TagHandle; 00054 typedef iBase_EntityHandle GentityHandle; 00055 typedef iBase_EntitySetHandle GentitysetHandle; 00056 00057 /* Frees allocated arrays for us */ 00058 template <typename T> class SimpleArray 00059 { 00060 private: 00061 T* arr; 00062 int arrSize; 00063 int arrAllocated; 00064 00065 public: 00066 SimpleArray() : arr(0) , arrSize(0), arrAllocated(0) {} 00067 SimpleArray( unsigned s ) :arrSize(s), arrAllocated(s) { 00068 arr = (T*)malloc(s*sizeof(T)); 00069 for (unsigned i = 0; i < s; ++i) 00070 new (arr+i) T(); 00071 } 00072 00073 ~SimpleArray() { 00074 for (int i = 0; i < size(); ++i) 00075 arr[i].~T(); 00076 free(arr); 00077 } 00078 00079 T** ptr() { return &arr; } 00080 int& size() { return arrSize; } 00081 int size() const { return arrSize; } 00082 int& capacity() { return arrAllocated; } 00083 int capacity() const { return arrAllocated; } 00084 00085 typedef T* iterator; 00086 typedef const T* const_iterator; 00087 iterator begin() { return arr; } 00088 const_iterator begin() const { return arr; } 00089 iterator end() { return arr + arrSize; } 00090 const_iterator end() const { return arr + arrSize; } 00091 00092 00093 T& operator[]( unsigned idx ) { return arr[idx]; } 00094 T operator[]( unsigned idx ) const { return arr[idx]; } 00095 }; 00096 00097 #define ARRAY_INOUT( A ) A.ptr(), &A.capacity(), &A.size() 00098 #define ARRAY_IN( A ) &A[0], A.size() 00099 00100 bool gLoad_test(const std::string filename, iGeom_Instance); 00101 00102 bool tags_test(iGeom_Instance geom); 00103 bool tag_get_set_test(iGeom_Instance geom); 00104 bool tag_info_test(iGeom_Instance geom); 00105 bool gentityset_test(iGeom_Instance geom, bool /*multiset*/, bool /*ordered*/); 00106 bool topology_adjacencies_test(iGeom_Instance geom); 00107 bool construct_test(iGeom_Instance geom); 00108 bool primitives_test(iGeom_Instance geom); 00109 bool transforms_test(iGeom_Instance geom); 00110 bool booleans_test(iGeom_Instance geom); 00111 bool faceting_test(iGeom_Instance geom); 00112 bool shutdown_test(iGeom_Instance geom, std::string &engine_opt); 00113 bool save_entset_test(iGeom_Instance geom); 00114 bool mesh_size_test(iGeom_Instance geom); 00115 00116 void handle_error_code(const bool result, 00117 int &number_failed, 00118 int &/*number_not_implemented*/, 00119 int &number_successful) 00120 { 00121 if (result) { 00122 std::cout << "Success"; 00123 number_successful++; 00124 } 00125 else { 00126 std::cout << "Failure"; 00127 number_failed++; 00128 } 00129 } 00130 00131 int main( int argc, char *argv[] ) 00132 { 00133 // Check command line arg 00134 #ifdef FORCE_OCC 00135 #ifndef HAVE_OCC 00136 #error "Cannot force use of OCC w/out OCC support" 00137 #endif 00138 std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; 00139 std::string engine_opt = ";engine=OCC"; 00140 #elif defined(HAVE_OCC) 00141 std::string filename = STRINGIFY(SRCDIR) "/../test/LeverArm.brep"; 00142 std::string engine_opt = ";engine=OCC"; 00143 #else 00144 std::string filename = STRINGIFY(SRCDIR) "/brick.facet"; 00145 std::string engine_opt = ";engine=FACET"; 00146 #endif 00147 if (argc == 1) { 00148 std::cout << "Using default input file: " << filename << std::endl; 00149 } 00150 else if (argc == 2) { 00151 filename = argv[1]; 00152 } 00153 else { 00154 std::cerr << "Usage: " << argv[0] << " [geom_filename]" << std::endl; 00155 return 1; 00156 } 00157 00158 bool result; 00159 int number_tests = 0; 00160 int number_tests_successful = 0; 00161 int number_tests_not_implemented = 0; 00162 int number_tests_failed = 0; 00163 00164 // initialize the Mesh 00165 int err; 00166 iGeom_Instance geom; 00167 iGeom_newGeom( engine_opt.c_str(), &geom, &err, engine_opt.length() ); 00168 00169 // Print out Header information 00170 std::cout << "\n\nITAPS GEOMETRY INTERFACE TEST PROGRAM:\n\n"; 00171 // gLoad test 00172 std::cout << " gLoad: "; 00173 result = gLoad_test(filename, geom); 00174 handle_error_code(result, number_tests_failed, 00175 number_tests_not_implemented, 00176 number_tests_successful); 00177 number_tests++; 00178 std::cout << "\n"; 00179 00180 // tags test 00181 std::cout << " tags: "; 00182 result = tags_test(geom); 00183 handle_error_code(result, number_tests_failed, 00184 number_tests_not_implemented, 00185 number_tests_successful); 00186 number_tests++; 00187 std::cout << "\n"; 00188 00189 // gentitysets test 00190 std::cout << " gentity sets: "; 00191 result = gentityset_test(geom, false, false); 00192 handle_error_code(result, number_tests_failed, 00193 number_tests_not_implemented, 00194 number_tests_successful); 00195 number_tests++; 00196 std::cout << "\n"; 00197 00198 // topology adjacencies test 00199 std::cout << " topology adjacencies: "; 00200 result = topology_adjacencies_test(geom); 00201 handle_error_code(result, number_tests_failed, 00202 number_tests_not_implemented, 00203 number_tests_successful); 00204 number_tests++; 00205 std::cout << "\n"; 00206 #if defined(HAVE_OCC) 00207 // construct test 00208 std::cout << " construct: "; 00209 result = construct_test(geom); 00210 handle_error_code(result, number_tests_failed, 00211 number_tests_not_implemented, 00212 number_tests_successful); 00213 number_tests++; 00214 std::cout << "\n"; 00215 00216 // primitives test 00217 std::cout << " primitives: "; 00218 result = primitives_test(geom); 00219 handle_error_code(result, number_tests_failed, 00220 number_tests_not_implemented, 00221 number_tests_successful); 00222 number_tests++; 00223 std::cout << "\n"; 00224 00225 // transforms test 00226 std::cout << " transforms: "; 00227 result = transforms_test(geom); 00228 handle_error_code(result, number_tests_failed, 00229 number_tests_not_implemented, 00230 number_tests_successful); 00231 number_tests++; 00232 std::cout << "\n"; 00233 00234 // booleans test 00235 std::cout << " booleans: "; 00236 result = booleans_test(geom); 00237 handle_error_code(result, number_tests_failed, 00238 number_tests_not_implemented, 00239 number_tests_successful); 00240 number_tests++; 00241 std::cout << "\n"; 00242 #endif 00243 00244 // this is not run for occ or facet; keep it for the time being 00245 #if 0 00246 00247 // save entset test 00248 std::cout << " save entset: "; 00249 result = save_entset_test(geom); 00250 handle_error_code(result, number_tests_failed, 00251 number_tests_not_implemented, 00252 number_tests_successful); 00253 number_tests++; 00254 std::cout << "\n"; 00255 #endif 00256 00257 //not working for cubit13.1 cgm at iGeom_CGMA.cc, line 7428, get_graphics for 00258 //faces, comment out 00259 // facet tests 00260 #ifdef HAVE_OCC 00261 std::cout << " faceting: "; 00262 result = faceting_test(geom); 00263 handle_error_code(result, number_tests_failed, 00264 number_tests_not_implemented, 00265 number_tests_successful); 00266 number_tests++; 00267 std::cout << "\n"; 00268 #endif 00269 00270 // shutdown test 00271 std::cout << " shutdown: "; 00272 result = shutdown_test(geom, engine_opt); 00273 handle_error_code(result, number_tests_failed, 00274 number_tests_not_implemented, 00275 number_tests_successful); 00276 number_tests++; 00277 std::cout << "\n"; 00278 00279 00280 // summary 00281 00282 std::cout << "\nTSTT TEST SUMMARY: \n" 00283 << " Number Tests: " << number_tests << "\n" 00284 << " Number Successful: " << number_tests_successful << "\n" 00285 << " Number Not Implemented: " << number_tests_not_implemented << "\n" 00286 << " Number Failed: " << number_tests_failed 00287 << "\n\n" << std::endl; 00288 00289 return number_tests_failed; 00290 } 00291 00292 00298 bool gLoad_test(const std::string filename, iGeom_Instance geom) 00299 { 00300 int err; 00301 iGeom_load( geom, &filename[0], 0, &err, filename.length(), 0 ); 00302 CHECK( "ERROR : can not load a geometry" ); 00303 00304 iBase_EntitySetHandle root_set; 00305 iGeom_getRootSet( geom, &root_set, &err ); 00306 CHECK( "ERROR : getRootSet failed!" ); 00307 00308 // print out the number of entities 00309 std::cout << "Model contents: " << std::endl; 00310 const char *gtype[] = {"vertices: ", "edges: ", "faces: ", "regions: "}; 00311 for (int i = 0; i <= 3; ++i) { 00312 int count; 00313 iGeom_getNumOfType( geom, root_set, i, &count, &err ); 00314 CHECK( "Error: problem getting entities after gLoad." ); 00315 std::cout << gtype[i] << count << std::endl; 00316 } 00317 00318 return true; 00319 } 00320 00326 bool tags_test(iGeom_Instance geom) 00327 { 00328 bool success = true; 00329 00330 success = tag_info_test(geom); 00331 if (!success) return success; 00332 00333 success = tag_get_set_test(geom); 00334 if (!success) return success; 00335 00336 return true; 00337 } 00338 00339 bool tag_info_test(iGeom_Instance geom) 00340 { 00341 int err; 00342 00343 iBase_EntitySetHandle root_set; 00344 iGeom_getRootSet( geom, &root_set, &err ); 00345 CHECK( "ERROR : getRootSet failed!" ); 00346 00347 // create an arbitrary tag, size 4 00348 iBase_TagHandle this_tag, tmp_handle; 00349 std::string tag_name("tag_info tag"), tmp_name; 00350 iGeom_createTag( geom, &tag_name[0], 4, iBase_BYTES, &this_tag, &err, tag_name.length() ); 00351 CHECK( "ERROR : can not create a tag." ); 00352 00353 // get information on the tag 00354 00355 char name_buffer[256]; 00356 iGeom_getTagName( geom, this_tag, name_buffer, &err, sizeof(name_buffer) ); 00357 CHECK( "ERROR : Couldn't get tag name." ); 00358 if (tag_name != name_buffer) { 00359 std::cerr << "ERROR: getTagName returned '" << name_buffer 00360 << "' for tag created as '" << tag_name << "'" << std::endl; 00361 return false; 00362 } 00363 00364 00365 iGeom_getTagHandle( geom, &tag_name[0], &tmp_handle, &err, tag_name.length() ); 00366 CHECK( "ERROR : Couldn't get tag handle." ); 00367 if (tmp_handle != this_tag) { 00368 std::cerr << "ERROR: getTagHandle didn't return consistent result." << std::endl; 00369 return false; 00370 } 00371 00372 int tag_size; 00373 iGeom_getTagSizeBytes( geom, this_tag, &tag_size, &err ); 00374 CHECK( "ERROR : Couldn't get tag size." ); 00375 if (tag_size != 4) { 00376 std::cerr << "ERROR: getTagSizeBytes: expected 4, got " << tag_size << std::endl; 00377 return false; 00378 } 00379 00380 iGeom_getTagSizeValues( geom, this_tag, &tag_size, &err ); 00381 CHECK( "ERROR : Couldn't get tag size." ); 00382 if (tag_size != 4) { 00383 std::cerr << "ERROR: getTagSizeValues: expected 4, got " << tag_size << std::endl; 00384 return false; 00385 } 00386 00387 int tag_type; 00388 iGeom_getTagType( geom, this_tag, &tag_type, &err ); 00389 CHECK( "ERROR : Couldn't get tag type." ); 00390 if (tag_type != iBase_BYTES) { 00391 std::cerr << "ERROR: getTagType: expected " << iBase_BYTES 00392 << ", got " << tag_type << std::endl; 00393 return false; 00394 } 00395 00396 iGeom_destroyTag( geom, this_tag, true, &err ); 00397 CHECK( "ERROR : Couldn't delete a tag." ); 00398 00399 // print information about all the tags in the model 00400 00401 std::set<iBase_TagHandle> tags; 00402 SimpleArray<iBase_EntityHandle> entities; 00403 iGeom_getEntities( geom, root_set, iBase_ALL_TYPES, 00404 ARRAY_INOUT(entities), &err ); 00405 CHECK( "getEntities( ..., iBase_ALL_TYPES, ... ) failed." ); 00406 for (int i = 0; i < entities.size(); ++i) { 00407 SimpleArray<iBase_TagHandle> tag_arr; 00408 iGeom_getAllTags( geom, entities[i], ARRAY_INOUT(tag_arr), &err); 00409 CHECK( "getAllTags failed." ); 00410 std::copy( tag_arr.begin(), tag_arr.end(), std::inserter( tags, tags.begin() ) ); 00411 } 00412 00413 std::cout << "Tags defined on model: "; 00414 bool first = true; 00415 for (std::set<iBase_TagHandle>::iterator sit = tags.begin(); sit != tags.end(); ++sit) { 00416 iGeom_getTagName( geom, *sit, name_buffer, &err, sizeof(name_buffer) ); 00417 name_buffer[sizeof(name_buffer)-1] = '\0'; // mnake sure of NUL termination 00418 CHECK( "getTagName failed." ); 00419 00420 if (!first) std::cout << ", "; 00421 std::cout << name_buffer; 00422 first = false; 00423 } 00424 if (first) std::cout << "<none>"; 00425 std::cout << std::endl; 00426 00427 return true; 00428 } 00429 00430 bool tag_get_set_test(iGeom_Instance geom) 00431 { 00432 int err; 00433 00434 // create an arbitrary tag, size 4 00435 iBase_TagHandle this_tag; 00436 std::string tag_name("tag_get_set tag"); 00437 iGeom_createTag( geom, &tag_name[0], sizeof(int), iBase_BYTES, &this_tag, &err, tag_name.length() ); 00438 CHECK( "ERROR : can not create a tag for get_set test." ); 00439 00440 iBase_EntitySetHandle root_set; 00441 iGeom_getRootSet( geom, &root_set, &err ); 00442 CHECK( "ERROR : getRootSet failed!" ); 00443 00444 // set this tag to an integer on each entity; keep track of total sum 00445 int sum = 0, num = 0, dim; 00446 for (dim = 0; dim <= 3; dim++) { 00447 SimpleArray<iBase_EntityHandle> gentity_handles; 00448 iGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err ); 00449 int num_ents = gentity_handles.size(); 00450 std::vector<int> tag_vals( num_ents ); 00451 for (int i = 0; i < num_ents; ++i) { 00452 tag_vals[i] = num; 00453 sum += num; 00454 ++num; 00455 } 00456 00457 iGeom_setArrData( geom, ARRAY_IN( gentity_handles ), 00458 this_tag, 00459 &tag_vals[0], tag_vals.size()*sizeof(int), 00460 &err ); 00461 CHECK( "ERROR : can't set tag on entities" ); 00462 } 00463 00464 // check tag values for entities now 00465 int get_sum = 0; 00466 for (dim = 0; dim <= 3; dim++) { 00467 SimpleArray<iBase_EntityHandle> gentity_handles; 00468 iGeom_getEntities( geom, root_set, dim, ARRAY_INOUT( gentity_handles ), &err ); 00469 int num_ents = gentity_handles.size(); 00470 00471 std::vector<int> tag_vals( num_ents ); 00472 void* vals_ptr = &tag_vals[0]; 00473 int vals_size = tag_vals.size(), vals_alloc = tag_vals.size()*sizeof(int); 00474 00475 iGeom_getArrData( geom, ARRAY_IN( gentity_handles ), this_tag, 00476 &vals_ptr, &vals_alloc, &vals_size, &err ); 00477 CHECK( "ERROR : can't get tag on entities" ); 00478 00479 for (int i = 0; i < num_ents; ++i) 00480 get_sum += tag_vals[i]; 00481 } 00482 00483 if (get_sum != sum) { 00484 std::cerr << "ERROR: getData didn't return consistent results." << std::endl; 00485 return false; 00486 } 00487 00488 iGeom_destroyTag( geom, this_tag, true, &err ); 00489 CHECK( "ERROR : couldn't delete tag." ); 00490 00491 return true; 00492 } 00493 00499 bool gentityset_test(iGeom_Instance geom, bool /*multiset*/, bool /*ordered*/) 00500 { 00501 int num_type = 4; 00502 iBase_EntitySetHandle ges_array[4]; 00503 int number_array[4]; 00504 int num_all_gentities_super = 0; 00505 int ent_type = iBase_VERTEX; 00506 00507 int err; 00508 iBase_EntitySetHandle root_set; 00509 iGeom_getRootSet( geom, &root_set, &err ); 00510 CHECK( "ERROR : getRootSet failed!" ); 00511 00512 // get the number of sets in the whole model 00513 int all_sets = 0; 00514 iGeom_getNumEntSets( geom, root_set, 0, &all_sets, &err ); 00515 CHECK( "Problem getting the number of all gentity sets in whole model." ); 00516 00517 // add gentities to entitysets by type 00518 for (; ent_type < num_type; ent_type++) { 00519 // initialize the entityset 00520 iGeom_createEntSet( geom, true, &ges_array[ent_type], &err ); 00521 CHECK( "Problem creating entityset." ); 00522 00523 // get entities by type in total "mesh" 00524 SimpleArray<iBase_EntityHandle> gentities; 00525 iGeom_getEntities( geom, root_set, ent_type, ARRAY_INOUT(gentities), &err ); 00526 CHECK( "Failed to get gentities by type in gentityset_test." ); 00527 00528 // add gentities into gentity set 00529 iGeom_addEntArrToSet( geom, ARRAY_IN( gentities ), ges_array[ent_type], &err ); 00530 CHECK( "Failed to add gentities in entityset_test." ); 00531 00532 // Check to make sure entity set really has correct number of entities in it 00533 iGeom_getNumOfType( geom, ges_array[ent_type], ent_type, &number_array[ent_type], &err ); 00534 CHECK( "Failed to get number of gentities by type in entityset_test." ); 00535 00536 // compare the number of entities by type 00537 int num_type_gentity = gentities.size(); 00538 00539 if (number_array[ent_type] != num_type_gentity) 00540 { 00541 std::cerr << "Number of gentities by type is not correct" 00542 << std::endl; 00543 return false; 00544 } 00545 00546 // add to number of all entities in super set 00547 num_all_gentities_super += num_type_gentity; 00548 } 00549 00550 // make a super set having all entitysets 00551 iBase_EntitySetHandle super_set; 00552 iGeom_createEntSet( geom, true, &super_set, &err ); 00553 CHECK( "Failed to create a super set in gentityset_test." ); 00554 00555 for (int i = 0; i < num_type; i++) { 00556 iGeom_addEntSet( geom, ges_array[i], super_set, &err ); 00557 CHECK( "Failed to create a super set in gentityset_test." ); 00558 } 00559 00560 //----------TEST BOOLEAN OPERATIONS----------------// 00561 00562 iBase_EntitySetHandle temp_ges1; 00563 iGeom_createEntSet( geom, true, &temp_ges1, &err ); 00564 CHECK( "Failed to create a super set in gentityset_test." ); 00565 00566 // Subtract 00567 // add all EDGEs and FACEs to temp_es1 00568 // get all EDGE entities 00569 SimpleArray<iBase_EntityHandle> gedges, gfaces, temp_gentities1; 00570 iGeom_getEntities( geom, ges_array[iBase_EDGE], iBase_EDGE, ARRAY_INOUT(gedges), &err ); 00571 CHECK( "Failed to get gedge gentities in gentityset_test." ); 00572 00573 // add EDGEs to ges1 00574 iGeom_addEntArrToSet( geom, ARRAY_IN(gedges), temp_ges1, &err ); 00575 CHECK( "Failed to add gedge gentities in gentityset_test." ); 00576 00577 // get all FACE gentities 00578 iGeom_getEntities( geom, ges_array[iBase_FACE], iBase_FACE, ARRAY_INOUT(gfaces), &err ); 00579 CHECK( "Failed to get gface gentities in gentityset_test." ); 00580 00581 // add FACEs to es1 00582 iGeom_addEntArrToSet( geom, ARRAY_IN(gfaces), temp_ges1, &err ); 00583 CHECK( "Failed to add gface gentities in gentityset_test." ); 00584 00585 // subtract EDGEs 00586 iGeom_subtract( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err ); 00587 CHECK( "Failed to subtract gentitysets in gentityset_test." ); 00588 00589 iGeom_getEntities( geom, temp_ges1, iBase_FACE, ARRAY_INOUT(temp_gentities1), &err ); 00590 CHECK( "Failed to get gface gentities in gentityset_test." ); 00591 00592 if (gfaces.size() != temp_gentities1.size()) { 00593 std::cerr << "Number of entitysets after subtraction not correct \ 00594 in gentityset_test." << std::endl; 00595 return false; 00596 } 00597 00598 // check there's nothing but gfaces in temp_ges1 00599 int num_gents; 00600 iGeom_getNumOfType( geom, temp_ges1, iBase_EDGE, &num_gents, &err ); 00601 CHECK( "Failed to get dimensions of gentities in gentityset_test." ); 00602 if (0 != num_gents) { 00603 std::cerr << "Subtraction failed to remove all edges" << std::endl; 00604 return false; 00605 } 00606 00607 //------------Intersect------------ 00608 // 00609 00610 // clean out the temp_ges1 00611 iGeom_rmvEntArrFromSet( geom, ARRAY_IN(gfaces), temp_ges1, &err ); 00612 CHECK( "Failed to remove gface gentities in gentityset_test." ); 00613 00614 // check if it is really cleaned out 00615 iGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err ); 00616 CHECK( "Failed to get number of gentities by type in gentityset_test." ); 00617 00618 if (num_gents != 0) { 00619 std::cerr << "failed to remove correctly." << std::endl; 00620 return false; 00621 } 00622 00623 // add EDGEs to temp ges1 00624 iGeom_addEntArrToSet( geom, ARRAY_IN(gedges), temp_ges1, &err ); 00625 CHECK( "Failed to add gedge gentities in gentityset_test." ); 00626 00627 // add FACEs to temp ges1 00628 iGeom_addEntArrToSet( geom, ARRAY_IN(gfaces), temp_ges1, &err ); 00629 CHECK( "Failed to add gface gentities in gentityset_test." ); 00630 00631 // intersect temp_ges1 with gedges set 00632 // temp_ges1 entityset is altered 00633 iGeom_intersect( geom, temp_ges1, ges_array[iBase_EDGE], &temp_ges1, &err ); 00634 CHECK( "Failed to intersect in gentityset_test." ); 00635 00636 // try to get FACEs, but there should be nothing but EDGE 00637 iGeom_getNumOfType( geom, temp_ges1, iBase_FACE, &num_gents, &err ); 00638 CHECK( "Failed to get gface gentities in gentityset_test." ); 00639 00640 if (num_gents != 0) { 00641 std::cerr << "wrong number of gfaces." << std::endl; 00642 return false; 00643 } 00644 00645 00646 //-------------Unite-------------- 00647 00648 // get all regions 00649 iBase_EntitySetHandle temp_ges2; 00650 SimpleArray<iBase_EntityHandle> gregions; 00651 00652 iGeom_createEntSet( geom, true, &temp_ges2, &err ); 00653 CHECK( "Failed to create a temp gentityset in gentityset_test." ); 00654 00655 iGeom_getEntities( geom, ges_array[iBase_REGION], iBase_REGION, ARRAY_INOUT(gregions), &err ); 00656 CHECK( "Failed to get gregion gentities in gentityset_test." ); 00657 00658 // add REGIONs to temp es2 00659 iGeom_addEntArrToSet( geom, ARRAY_IN(gregions), temp_ges2, &err ); 00660 CHECK( "Failed to add gregion gentities in gentityset_test." ); 00661 00662 // unite temp_ges1 and temp_ges2 00663 // temp_ges1 gentityset is altered 00664 iGeom_unite( geom, temp_ges1, temp_ges2, &temp_ges1, &err ); 00665 CHECK( "Failed to unite in gentityset_test." ); 00666 00667 // perform the check 00668 iGeom_getNumOfType( geom, temp_ges1, iBase_REGION, &num_gents, &err ); 00669 CHECK( "Failed to get number of gregion gentities by type in gentityset_test." ); 00670 00671 if (num_gents != number_array[iBase_REGION]) { 00672 std::cerr << "different number of gregions in gentityset_test." << std::endl; 00673 return false; 00674 } 00675 00676 00677 //--------Test parent/child stuff in entiysets----------- 00678 00679 // Add 2 sets as children to another 00680 iBase_EntitySetHandle parent_child; 00681 iGeom_createEntSet( geom, true, &parent_child, &err ); 00682 CHECK( "Problem creating gentityset in gentityset_test." ); 00683 00684 iGeom_addPrntChld( geom, ges_array[iBase_VERTEX], parent_child, &err ); 00685 CHECK( "Problem add parent in gentityset_test." ); 00686 00687 // check if parent is really added 00688 SimpleArray<iBase_EntitySetHandle> parents; 00689 iGeom_getPrnts( geom, parent_child, 1, ARRAY_INOUT(parents), &err ); 00690 CHECK( "Problem getting parents in gentityset_test." ); 00691 00692 if (parents.size() != 1) { 00693 std::cerr << "number of parents is not correct in gentityset_test." 00694 << std::endl; 00695 return false; 00696 } 00697 00698 // add parent and child 00699 //sidl::array<void*> parent_child_array = sidl::array<void*>::create1d(1); 00700 //int num_parent_child_array; 00701 //sidl::array<void*> temp_gedge_array = sidl::array<void*>::create1d(1); 00702 //int num_temp_gedge_array; 00703 //parent_child_array.set(0, parent_child); 00704 //temp_gedge_array.set(0, ges_array[TSTTG::EntityType_EDGE]); 00705 iGeom_addPrntChld( geom, ges_array[iBase_EDGE], parent_child, &err ); 00706 CHECK( "Problem adding parent and child in gentityset_test." ); 00707 00708 //sidl::array<void*> temp_gface_array = sidl::array<void*>::create1d(1); 00709 //int num_temp_gface_array; 00710 //temp_gface_array.set(0, ges_array[TSTTG::EntityType_FACE]); 00711 iGeom_addPrntChld( geom, parent_child, ges_array[iBase_FACE], &err ); 00712 CHECK( "Problem adding parent and child in gentityset_test." ); 00713 00714 // add child 00715 iGeom_addPrntChld( geom, parent_child, ges_array[iBase_REGION], &err ); 00716 CHECK( "Problem adding child in gentityset_test." ); 00717 00718 // get the number of parent gentitysets 00719 num_gents = -1; 00720 iGeom_getNumPrnt( geom, parent_child, 0, &num_gents, &err ); 00721 CHECK( "Problem getting number of parents in gentityset_test." ); 00722 00723 if (num_gents != 2) { 00724 std::cerr << "number of parents is not correct in gentityset_test." 00725 << std::endl; 00726 return false; 00727 } 00728 00729 // get the number of child gentitysets 00730 num_gents = -1; 00731 iGeom_getNumChld( geom, parent_child, 0, &num_gents, &err ); 00732 CHECK( "Problem getting number of children in gentityset_test." ); 00733 00734 if (num_gents != 2) { 00735 std::cerr << "number of children is not correct in gentityset_test." 00736 << std::endl; 00737 return false; 00738 } 00739 00740 SimpleArray<iBase_EntitySetHandle> children; 00741 iGeom_getChldn( geom, parent_child, 0, ARRAY_INOUT(children), &err ); 00742 CHECK( "Problem getting children in gentityset_test." ); 00743 00744 if (children.size() != 2) { 00745 std::cerr << "number of children is not correct in gentityset_test." 00746 << std::endl; 00747 return false; 00748 } 00749 00750 // remove children 00751 iGeom_rmvPrntChld( geom, parent_child, ges_array[iBase_FACE], &err ); 00752 CHECK( "Problem removing parent child in gentityset_test." ); 00753 00754 // get the number of child gentitysets 00755 iGeom_getNumChld( geom, parent_child, 0, &num_gents, &err ); 00756 CHECK( "Problem getting number of children in gentityset_test." ); 00757 00758 if (num_gents != 1) { 00759 std::cerr << "number of children is not correct in gentityset_test." 00760 << std::endl; 00761 return false; 00762 } 00763 00764 // parent_child and ges_array[TSTTG::EntityType_EDGE] should be related 00765 int result = 0; 00766 iGeom_isChildOf( geom, ges_array[iBase_EDGE], parent_child, &result, &err ); 00767 CHECK( "Problem checking relation in gentityset_test." ); 00768 if (!result) { 00769 std::cerr << "parent_child and ges_array[TSTTG::EntityType_EDGE] should be related" << std::endl; 00770 return false; 00771 } 00772 00773 // ges_array[TSTTG::EntityType_FACE] and ges_array[TSTTG::REGION] are not related 00774 result = 2; 00775 iGeom_isChildOf( geom, ges_array[iBase_FACE], ges_array[iBase_REGION], &result, &err ); 00776 if (result) { 00777 std::cerr << "ges_array[TSTTG::REGION] and ges_array[TSTTG::EntityType_FACE] should not be related" << std::endl; 00778 return false; 00779 } 00780 00781 00782 //--------test modify and query functions----------------------------- 00783 00784 // check the number of gentity sets in whole mesh 00785 SimpleArray<iBase_EntitySetHandle> gentity_sets; 00786 iGeom_getEntSets( geom, root_set, 0, ARRAY_INOUT( gentity_sets ), &err ); 00787 CHECK( "Problem to get all gentity sets in mesh." ); 00788 00789 if (gentity_sets.size() != all_sets + 8) { 00790 std::cerr << "the number of gentity sets in whole mesh should be 8 times of num_iter." 00791 << std::endl; 00792 return false; 00793 } 00794 00795 // get all gentity sets in super set 00796 SimpleArray<iBase_EntitySetHandle> ges_array1; 00797 iGeom_getEntSets( geom, super_set, 0, ARRAY_INOUT( ges_array1 ), &err ); 00798 CHECK( "Problem to get gentity sets in super set." ); 00799 00800 // get the number of gentity sets in super set 00801 int num_super; 00802 iGeom_getNumEntSets( geom, super_set, 0, &num_super, &err ); 00803 CHECK( "Problem to get the number of all gentity sets in super set." ); 00804 00805 // the number of gentity sets in super set should be same 00806 if (num_super != ges_array1.size()) { 00807 std::cerr << "the number of gentity sets in super set should be same." << std::endl; 00808 return false; 00809 } 00810 00811 // get all entities in super set 00812 SimpleArray<iBase_EntitySetHandle> all_gentities; 00813 iGeom_getEntSets( geom, super_set, 0, ARRAY_INOUT( all_gentities ), &err ); 00814 CHECK( "Problem to get all gentities in super set." ); 00815 00816 // compare the number of all gentities in super set 00817 // HJK : num_hops is not implemented 00818 //if (num_all_gentities_super != ARRAY_SIZE(all_gentities)) { 00819 //std::cerr << "number of all gentities in super set should be same." << std::endl; 00820 //success = false; 00821 //} 00822 00823 return true; 00824 } 00825 00832 // make each topological entity vectors, check their topology 00833 // types, get interior and exterior faces of model 00834 bool topology_adjacencies_test(iGeom_Instance geom) 00835 { 00836 int i, err; 00837 iBase_EntitySetHandle root_set; 00838 iGeom_getRootSet( geom, &root_set, &err ); 00839 CHECK( "ERROR : getRootSet failed!" ); 00840 00841 int top = iBase_VERTEX; 00842 int num_test_top = iBase_ALL_TYPES; 00843 std::vector< std::vector<iBase_EntityHandle> > gentity_vectors(num_test_top); 00844 00845 // fill the vectors of each topology entities 00846 // like lines vector, polygon vector, triangle vector, 00847 // quadrilateral, polyhedrron, tet, hex, prism, pyramid, 00848 // septahedron vectors 00849 for (i = top; i < num_test_top; i++) { 00850 SimpleArray<iBase_EntityHandle> gentities; 00851 iGeom_getEntities( geom, root_set, i, ARRAY_INOUT( gentities ), &err ); 00852 CHECK("Failed to get gentities in adjacencies_test."); 00853 00854 gentity_vectors[i].resize( gentities.size() ); 00855 std::copy( gentities.begin(), gentities.end(), gentity_vectors[i].begin() ); 00856 } 00857 00858 // check number of entities for each topology 00859 for (i = top; i < num_test_top; i++) { 00860 int num_tops = 0; 00861 iGeom_getNumOfType( geom, root_set, i, &num_tops, &err ); 00862 CHECK( "Failed to get number of gentities in adjacencies_test." ); 00863 00864 if (static_cast<int>(gentity_vectors[i].size()) != num_tops) { 00865 std::cerr << "Number of gentities doesn't agree with number returned for dimension " 00866 << i << std::endl; 00867 return false; 00868 } 00869 } 00870 00871 // check adjacencies in both directions 00872 std::vector<iBase_EntityHandle>::iterator vit; 00873 for (i = iBase_REGION; i >= iBase_VERTEX; i--) { 00874 for (vit = gentity_vectors[i].begin(); vit != gentity_vectors[i].end(); vit++) { 00875 iBase_EntityHandle this_gent = *vit; 00876 00877 // check downward adjacencies 00878 for (int j = iBase_VERTEX; j < i; j++) { 00879 00880 SimpleArray<iBase_EntityHandle> lower_ents; 00881 iGeom_getEntAdj( geom, this_gent, j, ARRAY_INOUT(lower_ents), &err ); 00882 CHECK( "Bi-directional adjacencies test failed." ); 00883 00884 // for each of them, make sure they are adjacent to the upward ones 00885 int num_lower = lower_ents.size(); 00886 for (int k = 0; k < num_lower; k++) { 00887 SimpleArray<iBase_EntityHandle> upper_ents; 00888 iGeom_getEntAdj( geom, lower_ents[k], i, ARRAY_INOUT(upper_ents), &err ); 00889 CHECK( "Bi-directional adjacencies test failed." ); 00890 if (std::find(upper_ents.begin(),upper_ents.end(), this_gent) == 00891 upper_ents.end()) { 00892 std::cerr << "Didn't find lower-upper adjacency which was supposed to be there, dims = " 00893 << i << ", " << j << std::endl; 00894 return false; 00895 } 00896 } 00897 } 00898 } 00899 } 00900 00901 return true; 00902 } 00903 00909 bool construct_test(iGeom_Instance geom) 00910 { 00911 int err; 00912 iBase_EntityHandle new_body = 0; 00913 00914 // construct a cylinder, sweep it about an axis, and delete the result 00915 iBase_EntityHandle cyl = 0; 00916 iGeom_createCylinder( geom, 1.0, 1.0, 0.0, &cyl, &err ); 00917 // Is the minor radius really supposed to be zero??? - JK 00918 CHECK( "Creating cylinder failed." ); 00919 00920 // move it onto the y axis 00921 iGeom_moveEnt( geom, cyl, 0.0, 1.0, -0.5, &err ); 00922 CHECK( "Problems moving surface." ); 00923 00924 // get the surface with max z 00925 iBase_EntityHandle max_surf = 0; 00926 SimpleArray<iBase_EntityHandle> surfs; 00927 iGeom_getEntAdj( geom, cyl, iBase_FACE, ARRAY_INOUT(surfs), &err ); 00928 CHECK( "Problems getting max surf for rotation." ); 00929 00930 SimpleArray<double> max_corn, min_corn; 00931 iGeom_getArrBoundBox( geom, ARRAY_IN(surfs), iBase_INTERLEAVED, 00932 ARRAY_INOUT( min_corn ), 00933 ARRAY_INOUT( max_corn ), 00934 &err ); 00935 CHECK( "Problems getting max surf for rotation." ); 00936 double dtol = 1.0e-6; 00937 for (int i = 0; i < surfs.size(); ++i) { 00938 if ((max_corn[3*i+2]) <= dtol && (max_corn[3*i+2]) >= -dtol && 00939 (min_corn[3*i+2]) <= dtol && (min_corn[3*i+2]) >= -dtol) { 00940 max_surf = surfs[i]; 00941 break; 00942 } 00943 } 00944 00945 if (0 == max_surf) { 00946 std::cerr << "Couldn't find max surf for rotation." << std::endl; 00947 return false; 00948 } 00949 00950 // sweep it around the x axis 00951 iGeom_moveEnt( geom, cyl, 0.0, 1.0, 0.0, &err ); 00952 CHECK( "Problems moving surface." ); 00953 00954 iGeom_sweepEntAboutAxis( geom, max_surf, 360.0, 1.0, 0.0, 0.0, &new_body, &err ); 00955 CHECK( "Problems sweeping surface about axis." ); 00956 00957 // now delete 00958 iGeom_deleteEnt( geom, new_body, &err ); 00959 CHECK( "Problems deleting cylinder or swept surface body." ); 00960 00961 // if we got here, we were successful 00962 return true; 00963 } 00964 00965 static bool compare_box( const double* expected_min, 00966 const double* expected_max, 00967 const double* actual_min, 00968 const double* actual_max ) 00969 { 00970 bool same = true; 00971 double dtol = 1.0e-6; 00972 00973 for (int i = 0; i < 3; ++i) 00974 { 00975 if (expected_min[i] < actual_min[i] - dtol || 00976 expected_min[i]*10 > actual_min[i] || 00977 expected_max[i] > actual_max[i] + dtol || 00978 expected_max[i]*10 < actual_max[i]) 00979 same = false; 00980 } 00981 return same; 00982 } 00983 00984 bool primitives_test(iGeom_Instance geom) 00985 { 00986 int err; 00987 SimpleArray<iBase_EntityHandle> prims(3); 00988 iBase_EntityHandle prim; 00989 00990 iGeom_createBrick( geom, 1.0, 2.0, 3.0, &prim, &err ); 00991 CHECK( "createBrick failed." ); 00992 prims[0] = prim; 00993 00994 iGeom_createCylinder( geom, 1.0, 4.0, 2.0, &prim, &err ); 00995 CHECK( "createCylinder failed." ); 00996 prims[1] = prim; 00997 00998 iGeom_createTorus( geom, 2.0, 1.0, &prim, &err ); 00999 CHECK( "createTorus failed." ); 01000 prims[2] = prim; 01001 01002 // verify the bounding boxes forentities 01003 SimpleArray<double> max_corn, min_corn; 01004 iGeom_getArrBoundBox( geom, ARRAY_IN(prims), iBase_INTERLEAVED, 01005 ARRAY_INOUT(min_corn), ARRAY_INOUT(max_corn), &err ); 01006 01007 double preset_min_corn[] = 01008 // min brick corner xyz 01009 {-0.5, -1.0, -1.5, 01010 // min cyl corner xyz 01011 -4.0, -2.0, -0.5, 01012 // min torus corner xyz 01013 -3.0, -3.0, -1.0 01014 }; 01015 01016 double preset_max_corn[] = 01017 // max brick corner xyz 01018 {0.5, 1.0, 1.5, 01019 // max cyl corner xyz 01020 4.0, 2.0, 0.5, 01021 // max torus corner xyz 01022 3.0, 3.0, 1.0 01023 }; 01024 01025 if (!compare_box( preset_min_corn, preset_max_corn, 01026 &min_corn[0], &max_corn[0] )) { 01027 std::cerr << "Box check failed for brick" << std::endl; 01028 return false; 01029 } 01030 01031 if (!compare_box( preset_min_corn+3, preset_max_corn+3, 01032 &min_corn[3], &max_corn[3] )) { 01033 std::cerr << "Box check failed for cylinder" << std::endl; 01034 return false; 01035 } 01036 01037 if (!compare_box( preset_min_corn+6, preset_max_corn+6, 01038 &min_corn[6], &max_corn[6] )) { 01039 std::cerr << "Box check failed for torus" << std::endl; 01040 return false; 01041 } 01042 // must have worked; delete the entities then return 01043 for (int i = 0; i < 3; ++i) { 01044 iGeom_deleteEnt( geom, prims[i], &err ); 01045 CHECK( "Problems deleting primitive after boolean check." ); 01046 } 01047 01048 return true; 01049 } 01050 01051 bool transforms_test(iGeom_Instance geom) 01052 { 01053 int err; 01054 01055 // construct a brick 01056 iBase_EntityHandle brick = 0; 01057 iGeom_createBrick( geom, 1.0, 2.0, 3.0, &brick, &err ); 01058 CHECK( "Problems creating brick for transforms test." ); 01059 01060 // move it, then test bounding box 01061 iGeom_moveEnt( geom, brick, 0.5, 1.0, 1.5, &err ); 01062 CHECK( "Problems moving brick for transforms test." ); 01063 01064 double bb_min[3], bb_max[3]; 01065 iGeom_getEntBoundBox( geom, brick, bb_min, bb_min+1, bb_min+2, bb_max, bb_max+1, bb_max+2, &err ); 01066 CHECK( "Problems getting bounding box after move." ); 01067 01068 double dtol = 1.0e-6; 01069 if ((bb_min[0]) >= dtol || (bb_min[0]) <= -dtol || 01070 (bb_min[1]) >= dtol || (bb_min[1]) <= -dtol || 01071 (bb_min[2]) >= dtol || (bb_min[2]) <= -dtol || 01072 (bb_max[0]-1) >= dtol || 1-bb_max[0] >=dtol || 01073 (bb_max[1]-2) >= dtol || 2 - bb_max[1] >=dtol|| 01074 (bb_max[2]-3) >= dtol || 3 - bb_max[2] >= dtol) { 01075 std::cerr << "Wrong bounding box after move." << std::endl; 01076 return false; 01077 } 01078 01079 // now rotate it about +x, then test bounding box 01080 iGeom_rotateEnt( geom, brick, 90, 1.0, 0.0, 0.0, &err ); 01081 CHECK( "Problems rotating brick for transforms test." ); 01082 01083 iGeom_getEntBoundBox( geom, brick, bb_min, bb_min+1, bb_min+2, bb_max, bb_max+1, bb_max+2, &err ); 01084 CHECK( "Problems getting bounding box after rotate." ); 01085 01086 if ((bb_min[0]) >= dtol || -bb_min[0] >= dtol || 01087 (bb_min[1]+3) >= dtol || -(bb_min[1]+3) >= dtol || 01088 (bb_min[2]) >= dtol || -(bb_min[2]) >= dtol || 01089 (bb_max[0]-1) >= dtol || 1-bb_max[0] >= dtol || 01090 (bb_max[1]) >= dtol || -(bb_max[1]) >= dtol || 01091 (bb_max[2]-2) >= dtol || 2-bb_max[2] >=dtol) { 01092 std::cerr << "Wrong bounding box after rotate." << std::endl; 01093 return false; 01094 } 01095 01096 // now reflect through y plane; should recover original bb 01097 iGeom_reflectEnt( geom, brick, 0.0, 0.0, 0.0, 0.0, 1.0, 0.0, &err ); 01098 CHECK( "Problems reflecting brick for transforms test." ); 01099 01100 iGeom_getEntBoundBox( geom, brick, bb_min, bb_min+1, bb_min+2, bb_max, bb_max+1, bb_max+2, &err ); 01101 CHECK( "Problems getting bounding box after reflect." ); 01102 01103 if ((bb_min[0]) >= dtol || -(bb_min[0]) >= dtol ||(bb_min[1]) >= dtol || 01104 (bb_min[2]) >= dtol || -(bb_min[1]) >= dtol || -(bb_min[2]) >= dtol || 01105 (bb_max[0]-1) >= dtol || 1- bb_max[0] >= dtol || 01106 (bb_max[1]-3) >= dtol || 3 - bb_max[1] >= dtol || 01107 (bb_max[2]-2) >= dtol || 2 - bb_max[2] >= dtol) { 01108 std::cerr << "Wrong bounding box after reflect." << std::endl; 01109 return false; 01110 } 01111 01112 // must have worked; delete the entities then return 01113 iGeom_deleteEnt( geom, brick, &err ); 01114 CHECK( "Problems deleting brick after transforms check." ); 01115 return true; 01116 } 01117 01118 01119 bool booleans_test(iGeom_Instance geom) 01120 { 01121 int err; 01122 01123 // construct a brick size 1, and a cylinder rad 0.25 height 2 01124 iBase_EntityHandle brick = 0, cyl = 0; 01125 iGeom_createBrick( geom, 1.0, 0.0, 0.0, &brick, &err ); 01126 CHECK( "Problems creating brick for booleans test." ); 01127 iGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01128 CHECK( "Problems creating cylinder for booleans test." ); 01129 01130 // subtract the cylinder from the brick 01131 iBase_EntityHandle subtract_result = 0; 01132 iGeom_subtractEnts( geom, brick, cyl, &subtract_result, &err ); 01133 CHECK( "Problems subtracting for booleans subtract test." ); 01134 01135 // section the brick 01136 iBase_EntityHandle section_result = 0; 01137 iGeom_sectionEnt( geom, subtract_result, 1.0, 0.0, 0.0, 0.25, true, §ion_result, &err ); 01138 CHECK( "Problems sectioning for booleans section test." ); 01139 01140 // unite the section result with a new cylinder 01141 iGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01142 CHECK( "Problems creating cylinder for unite test." ); 01143 iBase_EntityHandle unite_results; 01144 iBase_EntityHandle unite_input[] = { section_result, cyl }; 01145 iGeom_uniteEnts( geom, unite_input, 2, &unite_results, &err ); 01146 CHECK( "Problems uniting for booleans unite test." ); 01147 01148 iGeom_deleteEnt( geom, unite_results, &err ); 01149 CHECK( "Problems deleting for booleans unite test." ); 01150 return true; 01151 } 01152 01153 static int get_entities( iGeom_Instance geom, int entity_type, 01154 std::vector<iBase_EntityHandle>& entities_out, 01155 iBase_TagHandle id_tag = 0, 01156 std::vector<int>* ids_out = 0 ) 01157 { 01158 int err, num; 01159 iBase_EntitySetHandle root; 01160 iGeom_getRootSet( geom, &root, &err ); 01161 if (iBase_SUCCESS != err) 01162 return err; 01163 iGeom_getNumOfType( geom, root, entity_type, &num, &err ); 01164 if (iBase_SUCCESS != err) 01165 return err; 01166 01167 entities_out.resize(num); 01168 int junk1 = entities_out.size(), junk2; 01169 iBase_EntityHandle* junk_ptr = &entities_out[0];; 01170 iGeom_getEntities( geom, root, entity_type, &junk_ptr, &junk1, &junk2, &err ); 01171 if (iBase_SUCCESS != err) 01172 return err; 01173 assert( num == junk1 && num == junk2 ); 01174 01175 if (!ids_out) 01176 return iBase_SUCCESS; 01177 01178 ids_out->resize(num); 01179 int* int_ptr = &(*ids_out)[0]; 01180 iGeom_getIntArrData( geom, &entities_out[0], num, id_tag, &int_ptr, &junk1, &junk2, &err ); 01181 if (iBase_SUCCESS != err) 01182 return err; 01183 assert( num == junk1 && num == junk2 ); 01184 01185 return iBase_SUCCESS; 01186 } 01187 01188 //static int check_firmness( iGeom_Instance geom, 01189 // const std::vector<iBase_EntityHandle>& entities, 01190 // const std::vector<int>& ids, 01191 // iBase_TagHandle firmness_tag, 01192 // const char* expected_value, 01193 // const char* ent_type_str ) 01194 //{ 01195 // const int firmness_size = 4; 01196 // std::vector<char> firmness(firmness_size * entities.size()); 01197 01198 // void* byte_ptr = &firmness[0]; 01199 // int err, junk1 = firmness.size(), junk2 = entities.size()*firmness_size; 01200 // iGeom_getArrData( geom, &entities[0], entities.size(), firmness_tag, (void**)&byte_ptr, &junk1, &junk2, &err ); 01201 // if (iBase_SUCCESS != err) 01202 // return err; 01203 01204 // bool all_correct = true; 01205 // for (unsigned i = 0; i < entities.size(); ++i) 01206 // if (std::string(&firmness[firmness_size*i],firmness_size) != expected_value) 01207 // all_correct = false; 01208 // if (!all_correct) { 01209 // std::cout << "ERROR: Expected \"" << expected_value << "\" firmness " 01210 // << "for all " << ent_type_str << "." << std::endl; 01211 // std::cout << "ID Actual " << std::endl; 01212 // for (unsigned i = 0; i < entities.size(); ++i) 01213 // std::cout << std::setw(2) << ids[i] << " " 01214 // << std::string(&firmness[firmness_size*i],firmness_size) 01215 // << std::endl; 01216 // return iBase_FAILURE; 01217 // } 01218 01219 // return iBase_SUCCESS; 01220 //} 01221 01222 static int count_num_with_tag( iGeom_Instance geom, 01223 const std::vector<iBase_EntityHandle>& ents, 01224 iBase_TagHandle tag ) 01225 { 01226 int err, bytes; 01227 iGeom_getTagSizeBytes( geom, tag, &bytes, &err ); 01228 if (iBase_SUCCESS != err) 01229 return -1; 01230 std::vector<char> data(bytes); 01231 01232 int success_count = 0; 01233 for (size_t i = 0; i < ents.size(); ++i) { 01234 void* ptr = &data[0]; 01235 int junk1 = bytes, junk2; 01236 iGeom_getData( geom, ents[i], tag, (void**)&ptr, &junk1, &junk2, &err ); 01237 if (iBase_TAG_NOT_FOUND == err) 01238 continue; 01239 if (iBase_SUCCESS != err) 01240 return -1; 01241 ++success_count; 01242 } 01243 01244 return success_count; 01245 } 01246 01247 01248 bool mesh_size_test(iGeom_Instance geom) 01249 { 01250 const char* filename = STRINGIFY(SRCDIR) "/size.sat"; 01251 int err; 01252 01253 iGeom_deleteAll( geom, &err ); CHECK(""); 01254 iGeom_load( geom, filename, 0, &err, strlen(filename), 0 ); 01255 CHECK( "Failed to load input file: 'size.sat'" ); 01256 01257 // get tag handles 01258 iBase_TagHandle interval, size, firmness, id; 01259 iGeom_getTagHandle( geom, "MESH_INTERVAL", &interval, &err, strlen("MESH_INTERVAL") ); 01260 CHECK( "iGeom_getTagHandle(\"MESH_INTERVAL\")" ); 01261 iGeom_getTagHandle( geom, "MESH_SIZE", &size, &err, strlen("MESH_SIZE") ); 01262 CHECK( "iGeom_getTagHandle(\"MESH_SIZE\")" ); 01263 iGeom_getTagHandle( geom, "SIZE_FIRMNESS", &firmness, &err, strlen("SIZE_FIRMNESS") ); 01264 CHECK( "iGeom_getTagHandle(\"SIZE_FIRMNESS\")" ); 01265 iGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen("GLOBAL_ID") ); 01266 CHECK( "iGeom_getTagHandle(\"GLOBAL_ID\")" ); 01267 01268 // get entity lists 01269 std::vector<iBase_EntityHandle> verts, curves, surfs, vols; 01270 std::vector<int> vert_ids, curve_ids, surf_ids, vol_ids; 01271 err = get_entities( geom, iBase_VERTEX, verts, id, &vert_ids ); CHECK(""); 01272 err = get_entities( geom, iBase_EDGE, curves, id, &curve_ids ); CHECK(""); 01273 err = get_entities( geom, iBase_FACE, surfs, id, &surf_ids ); CHECK(""); 01274 err = get_entities( geom, iBase_REGION, vols, id, &vol_ids ); CHECK(""); 01275 01276 // expect interval count to be the same as ID for every curve 01277 /* testgeom didn't pass with the following call, uncomment it when fixed. 01278 std::vector<int> intervals(curves.size()); 01279 int *int_ptr = &intervals[0]; 01280 junk1 = junk2 = curves.size(); 01281 iGeom_getIntArrData( geom, &curves[0], curves.size(), interval, &int_ptr, &junk1, &junk2, &err ); 01282 CHECK("Failed to get intervals for curves"); 01283 if (intervals != curve_ids) { 01284 std::cout << "ERROR: Incorrect curve intervals for one or more curves." << std::endl; 01285 std::cout << "ID Expected Actual" << std::endl; 01286 for (unsigned i = 0; i < curves.size(); ++i) 01287 std::cout << std::setw(2) << curve_ids[i] << " " 01288 << std::setw(8) << curve_ids[i] << " " 01289 << std::setw(6) << intervals[i] << std::endl; 01290 result = false; 01291 } 01292 01293 // expect size to be the same as ID for every surface 01294 std::vector<double> sizes(surfs.size()); 01295 double* dbl_ptr = &sizes[0]; 01296 junk1 = junk2 = surfs.size(); 01297 iGeom_getDblArrData( geom, &surfs[0], surfs.size(), size, &dbl_ptr, &junk1, &junk2, &err ); 01298 CHECK("Failed to get sizes for surfaces"); 01299 bool all_correct = true; 01300 for (unsigned i = 0; i < surfs.size(); ++i) 01301 if (fabs(sizes[i] - (double)surf_ids[i] ) > 1e-8) 01302 all_correct = false; 01303 if (!all_correct) { 01304 std::cout << "ERROR: Incorrect mesh size for one or more surfaces." << std::endl; 01305 std::cout << "ID Expected Actual " << std::endl; 01306 for (unsigned i = 0; i < surfs.size(); ++i) 01307 std::cout << std::setw(2) << surf_ids[i] << " " 01308 << std::setw(8) << (double)surf_ids[i] << " " 01309 << std::setw(8) << sizes[i] << std::endl; 01310 result = false; 01311 } 01312 01313 01314 err = result ? iBase_SUCCESS : iBase_FAILURE; 01315 CHECK("Invalid size or interval data"); 01316 01317 // expect "HARD" firmness on all curves 01318 err = check_firmness( geom, curves, curve_ids, firmness, "HARD", "curves" ); 01319 CHECK("Invalid curve firmness"); 01320 // expect "SOFT" firmness on all surfaces 01321 err = check_firmness( geom, surfs, surf_ids, firmness, "SOFT", "surfaces" ); 01322 CHECK("Invalid surface firmness"); 01323 */ 01324 // expect no firmnes on other entities 01325 err = count_num_with_tag( geom, verts, firmness ) ? iBase_FAILURE : iBase_SUCCESS; 01326 CHECK("Got firmness for vertex."); 01327 err = count_num_with_tag( geom, vols, firmness ) ? iBase_FAILURE : iBase_SUCCESS; 01328 CHECK("Got firmness for volume."); 01329 01330 // expect no interval tag on any entities except curves 01331 err = count_num_with_tag( geom, verts, interval ) ? iBase_FAILURE : iBase_SUCCESS; 01332 CHECK("Got interval count for vertex."); 01333 err = count_num_with_tag( geom, vols, interval ) ? iBase_FAILURE : iBase_SUCCESS; 01334 CHECK("Got interval count for volume."); 01335 01336 // expect no size tag on any entities except surfaces 01337 // curves should have size of one of their parent surfaces 01338 err = count_num_with_tag( geom, verts, size ) ? iBase_FAILURE : iBase_SUCCESS; 01339 CHECK("Got mesh size for vertex."); 01340 err = count_num_with_tag( geom, vols, size ) ? iBase_FAILURE : iBase_SUCCESS; 01341 CHECK("Got mesh size for volume."); 01342 01343 return true; 01344 } 01345 01346 bool faceting_test(iGeom_Instance geom) 01347 { 01348 01349 const char* filename = STRINGIFY(SRCDIR) "/size.step"; 01350 01351 int err; 01352 double dist_tolerance=0.001; 01353 01354 iGeom_deleteAll( geom, &err ); CHECK(""); 01355 iGeom_load( geom, filename, 0, &err, strlen(filename), 0 ); 01356 CHECK( "Failed to load input file: 'size.step'" ); 01357 01358 // get entity lists 01359 iBase_TagHandle id; 01360 iGeom_getTagHandle( geom, "GLOBAL_ID", &id, &err, strlen("GLOBAL_ID") ); 01361 CHECK( "iGeom_getTagHandle(\"GLOBAL_ID\")" ); 01362 std::vector<iBase_EntityHandle> verts, curves, surfs, vols; 01363 std::vector<int> vert_ids, curve_ids, surf_ids, vol_ids; 01364 err = get_entities( geom, iBase_VERTEX, verts, id, &vert_ids ); CHECK(""); 01365 err = get_entities( geom, iBase_EDGE, curves, id, &curve_ids ); CHECK(""); 01366 err = get_entities( geom, iBase_FACE, surfs, id, &surf_ids ); CHECK(""); 01367 err = get_entities( geom, iBase_REGION, vols, id, &vol_ids ); CHECK(""); 01368 01369 unsigned int ent; 01370 std::vector<double> points; 01371 double *p_ptr = &points[0]; 01372 int p_size = 0, p_alloc=points.size(); 01373 std::vector<int> facets; 01374 int *f_ptr = &facets[0]; 01375 int f_size = 0, f_alloc=facets.size(); 01376 01377 for (ent=0; ent < verts.size(); ent++) 01378 { 01379 iGeom_getFacets(geom, verts[ent], dist_tolerance, 01380 &p_ptr, &p_alloc, &p_size, 01381 &f_ptr, &f_alloc, &f_size, 01382 &err); 01383 if (iBase_INVALID_ENTITY_TYPE != err) 01384 { 01385 err = iBase_FAILURE; 01386 CHECK("getFacets should fail for vertices."); 01387 } 01388 } 01389 for (ent=0; ent < curves.size(); ent++) 01390 { 01391 iGeom_getFacets(geom, curves[ent], dist_tolerance, 01392 &p_ptr, &p_alloc, &p_size, 01393 &f_ptr, &f_alloc, &f_size, 01394 &err); 01395 points.resize(p_size); 01396 facets.resize(f_size); 01397 01398 if ( iBase_BAD_ARRAY_DIMENSION == err || iBase_BAD_ARRAY_SIZE == err) 01399 { 01400 p_ptr = &points[0]; 01401 p_alloc = points.size(); 01402 f_ptr = &facets[0]; 01403 f_alloc = facets.size(); 01404 iGeom_getFacets(geom, curves[ent], dist_tolerance, 01405 &p_ptr, &p_alloc, &p_size, 01406 &f_ptr, &f_alloc, &f_size, 01407 &err); 01408 } 01409 01410 CHECK("getFacets failed for a curve."); 01411 01412 err = (6 != p_size); CHECK("wrong number of points in curve"); 01413 err = (0 != f_size); CHECK("Non-zero number of facets in curve"); 01414 01415 // should check for known sizes and values of these facets & points 01416 } 01417 for (ent=0; ent < surfs.size(); ent++) 01418 { 01419 iGeom_getFacets(geom, surfs[ent], dist_tolerance, 01420 &p_ptr, &p_alloc, &p_size, 01421 &f_ptr, &f_alloc, &f_size, 01422 &err); 01423 points.resize(p_size); 01424 facets.resize(f_size); 01425 01426 if ( iBase_BAD_ARRAY_DIMENSION == err || iBase_BAD_ARRAY_SIZE == err) 01427 { 01428 p_ptr = &points[0]; 01429 p_alloc = points.size(); 01430 f_ptr = &facets[0]; 01431 f_alloc = facets.size(); 01432 iGeom_getFacets(geom, surfs[ent], dist_tolerance, 01433 &p_ptr, &p_alloc, &p_size, 01434 &f_ptr, &f_alloc, &f_size, 01435 &err); 01436 } 01437 std::cerr << "surface " << ent << ": " << p_size << " points and " << f_size << " facets." << std::endl; 01438 CHECK("getFacets failed for a surface."); 01439 01440 err = (12 != p_size); CHECK("wrong number of points in curve"); 01441 err = (6 != f_size); CHECK("wrong number of facets in curve"); 01442 // should check for known sizes and values of these facets & points 01443 } 01444 for (ent=0; ent < vols.size(); ent++) 01445 { 01446 iGeom_getFacets(geom, vols[ent], dist_tolerance, 01447 &p_ptr, &p_alloc, &p_size, 01448 &f_ptr, &f_alloc, &f_size, 01449 &err); 01450 if (iBase_INVALID_ENTITY_TYPE != err) 01451 { 01452 err = iBase_FAILURE; 01453 CHECK("getFacets should fail for volumes."); 01454 } 01455 } 01456 01457 return true; 01458 } 01459 01460 bool shutdown_test(iGeom_Instance geom, std::string &engine_opt) 01461 { 01462 int err; 01463 01464 // test shutdown & startup of interface 01465 iGeom_dtor(geom, &err); 01466 CHECK( "Interface destruction didn't work properly." ); 01467 01468 iGeom_newGeom(engine_opt.c_str(), &geom, &err, engine_opt.length()); 01469 CHECK( "Interface re-construction didn't work properly." ); 01470 01471 iGeom_dtor(geom, &err); 01472 CHECK( "2nd Interface destruction didn't work properly." ); 01473 01474 return true; 01475 } 01476 01477 bool save_entset_test(iGeom_Instance geom) 01478 { 01479 int err; 01480 01481 std::string filename = "testout.brep"; 01482 01483 // initialize number of ents and sets to compare with later 01484 int num_ents_bef, num_sets_bef; 01485 iBase_EntitySetHandle root; 01486 iGeom_getRootSet( geom, &root, &err ); 01487 CHECK("Failed to get root set."); 01488 iGeom_getNumEntSets(geom, root, 0, &num_sets_bef, &err); 01489 CHECK("Failed to get number of ent sets."); 01490 iGeom_getNumOfType(geom, root, iBase_REGION, &num_ents_bef, &err); 01491 CHECK("Failed to get number of entities."); 01492 01493 // create set, and entity to add to set 01494 iBase_EntityHandle cyl; 01495 iGeom_createCylinder( geom, 1.0, 0.25, 0.0, &cyl, &err ); 01496 CHECK( "Problems creating cylinder for save entset test." ); 01497 iBase_EntitySetHandle seth; 01498 iGeom_createEntSet(geom, true, &seth, &err); 01499 CHECK( "Problems creating entity set for save entset test." ); 01500 01501 // add the entity 01502 iGeom_addEntToSet(geom, cyl, seth, &err); 01503 CHECK( "Problems adding entity to set for save entset test." ); 01504 01505 // save/restore the model, and see if the entity is there 01506 iGeom_save(geom, filename.c_str(), NULL, &err, filename.length(), 0); 01507 CHECK( "Problems saving file for save entset test." ); 01508 01509 iGeom_destroyEntSet(geom, seth, &err); 01510 CHECK("Failed to destroy entity set."); 01511 iGeom_deleteEnt(geom, cyl, &err); 01512 CHECK("Failed to destroy entity."); 01513 01514 // read the file back in 01515 iGeom_load(geom, filename.c_str(), NULL, &err, 01516 filename.length(), 0); 01517 CHECK( "Problems reading file for save entset test." ); 01518 01519 // check number of sets and entities 01520 int num_ents_aft, num_sets_aft; 01521 iGeom_getNumEntSets(geom, root, 0, &num_sets_aft, &err); 01522 CHECK("Failed to get number of ent sets."); 01523 iGeom_getNumOfType(geom, root, iBase_REGION, &num_ents_aft, &err); 01524 CHECK("Failed to get number of entities."); 01525 bool success = true; 01526 if (num_ents_aft != 2*num_ents_bef + 1) { 01527 print_error("Failed to get the right number of entities.", 01528 iBase_FAILURE, geom, __FILE__, __LINE__); 01529 success = false; 01530 } 01531 else if (num_sets_aft != 2*num_sets_bef + 1) { 01532 print_error("Failed to get the right number of entity sets.", 01533 iBase_FAILURE, geom, __FILE__, __LINE__); 01534 success = false; 01535 } 01536 01537 // otherwise, we succeeded 01538 return success; 01539 } 01540
