cgma
00001 // CACompositeVG class 00002 00003 #include "CACompositeVG.hpp" 00004 #include "CADeferredAttrib.hpp" 00005 #include "CAUniqueId.hpp" 00006 #include "TDUniqueId.hpp" 00007 #include "CastTo.hpp" 00008 #include "RefFace.hpp" 00009 #include "RefEdge.hpp" 00010 #include "BasicTopologyEntity.hpp" 00011 #include "PartitionEntity.hpp" 00012 #include "TopologyBridge.hpp" 00013 #include "CubitMessage.hpp" 00014 00015 00016 #include "CompositeTool.hpp" 00017 #include "CompositeSurface.hpp" 00018 #include "CompositeCurve.hpp" 00019 00020 CubitAttrib* CACompositeVG_creator(RefEntity* entity, const CubitSimpleAttrib &p_csa) 00021 { 00022 return new CACompositeVG(entity, p_csa); 00023 } 00024 00025 CACompositeVG::CACompositeVG(RefEntity *owner, const CubitSimpleAttrib &simple_attrib) 00026 : CubitAttrib(owner) 00027 { 00028 00029 compositeId = -1; 00030 00031 if(!simple_attrib.isEmpty()) 00032 { 00033 00034 // generate a simple attribute containing the data in this CA 00035 const std::vector<int>& i_list = simple_attrib.int_data_list(); 00036 00037 // (no string) 00038 00039 // now the integers 00040 // compositeId, numSubEntities 00041 compositeId = i_list[0]; 00042 int numSubEntities = i_list[1]; 00043 int i; 00044 for (i = 0; i < numSubEntities; i++) 00045 { 00046 subEntityIds.append(i_list[i+2]); 00047 } 00048 00049 // If we are constructing from a CubitSimpleAttrib, 00050 // then this attrib is already written 00051 has_written(CUBIT_TRUE); 00052 } 00053 } 00054 00055 CubitStatus CACompositeVG::update() 00056 { 00057 hasUpdated = CUBIT_TRUE; 00058 delete_attrib(CUBIT_TRUE); 00059 return CUBIT_SUCCESS; 00060 } 00061 00062 CubitStatus CACompositeVG::reset() 00063 { 00064 00065 // reset the info on this CACVG; don't reset info on underlying 00066 // entities, since the lists on this CACVG get *assigned* to that 00067 // entity and not *appended* 00068 compositeId = -1; 00069 subEntityIds.clean_out(); 00070 return CUBIT_SUCCESS; 00071 } 00072 00073 CubitSimpleAttrib CACompositeVG::cubit_simple_attrib() 00074 { 00075 // generate a simple attribute containing the data in this CA 00076 std::vector<CubitString> cs_list; 00077 std::vector<int> i_list; 00078 00079 // first the string 00080 cs_list.push_back(att_internal_name()); 00081 00082 // now the integers 00083 // compositeId, numSubEntities 00084 i_list.push_back(compositeId); 00085 i_list.push_back(subEntityIds.size()); 00086 int i; 00087 subEntityIds.reset(); 00088 for (i = subEntityIds.size(); i > 0; i--) 00089 i_list.push_back(subEntityIds.get_and_step()); 00090 00091 00092 return CubitSimpleAttrib(&cs_list, NULL, &i_list); 00093 } 00094 00095 CubitStatus CACompositeVG::actuate() 00096 { 00097 // actuate this CA 00098 if (has_actuated() == CUBIT_TRUE) return CUBIT_SUCCESS; 00099 00100 // actuate all the unique id attribute first, since CA_COMPOSITE_VG 00101 // depends on CA_UNIQUEID 00102 CAUniqueId::actuate_all(); 00103 00104 // now, gather up all the sub entities; if they're not all around, 00105 // exit without setting the actuate flag 00106 DLIList<ToolDataUser*> tdu_list; 00107 int i; 00108 subEntityIds.reset(); 00109 CubitBoolean all_actuated = CUBIT_TRUE; 00110 00111 DLIList<CACompositeVG*> comp_attribs; 00112 00113 for (i = subEntityIds.size(); i > 0; i--) { 00114 ToolDataUser *tdu = TDUniqueId::find_td_unique_id(subEntityIds.get_and_step()); 00115 if (tdu != NULL) tdu_list.append(tdu); 00116 else { 00117 00118 // put this CA on a list for future actuation 00119 //has_actuated( CUBIT_FALSE ); 00120 bool result = CADeferredAttrib::add_unactuated_ca(this); 00121 00122 if (true == result) { 00123 PRINT_DEBUG_90("Can't actuate composite vg attrib on %s %d; adding to unactuated " 00124 "list.\n", 00125 attrib_owner()->class_name(), attrib_owner()->id()); 00126 } 00127 return CUBIT_FAILURE; 00128 } 00129 00130 //The portion of code below examines the entities that this entity will be 00131 //composited with. If the CACompositeVG attribute on these entities-to-be-composited 00132 //do not have their 'has_actuated' variable set to TRUE, then this Composite attribute 00133 //is not ready to be actuated. All entities-to-be-composited must have their 00134 //'has_actuated' flag set to TRUE to be ready to be composited 00135 00136 RefEntity *ref_entity = CAST_TO( tdu, RefEntity ); 00137 if( ref_entity == NULL ) 00138 return CUBIT_FAILURE; 00139 else 00140 { 00141 CACompositeVG *comp_vg_attrib = (CACompositeVG *) ref_entity->get_cubit_attrib(CA_COMPOSITE_VG); 00142 if( comp_vg_attrib ) 00143 { 00144 comp_attribs.append( comp_vg_attrib ); 00145 if( ref_entity == attrib_owner() ) //skip owner of this attribute..it will be actuated in a minute 00146 continue; 00147 if( !comp_vg_attrib->has_actuated() ) 00148 all_actuated = CUBIT_FALSE; 00149 continue; 00150 } 00151 else 00152 { 00153 all_actuated = CUBIT_FALSE; 00154 continue; 00155 } 00156 } 00157 } 00158 00159 has_actuated( CUBIT_TRUE ); 00160 00161 //if all sub entities CACompositeVG attribs haven't been here, 00162 //set this one and get out 00163 if( all_actuated == CUBIT_FALSE ) 00164 return CUBIT_SUCCESS; 00165 00166 // ok, we've got a list of tdu's; cast to list of ref edges or faces (currently 00167 // the only entities we know how to composite) 00168 DLIList<RefEdge*> ref_edges; 00169 CAST_LIST(tdu_list, ref_edges, RefEdge); 00170 DLIList<RefFace*> ref_faces; 00171 CAST_LIST(tdu_list, ref_faces, RefFace); 00172 00173 // do a little error checking: the entities should all be the same type, and 00174 // should be either ref edges or ref faces 00175 if ((ref_edges.size() > 0 && ref_faces.size() > 0) || 00176 (ref_edges.size() > 0 && ref_edges.size() != tdu_list.size()) || 00177 (ref_faces.size() > 0 && ref_faces.size() != tdu_list.size())) { 00178 PRINT_ERROR("Entities for composite containing %s %d not all the same.\n", 00179 attrib_owner()->class_name(), attrib_owner()->id()); 00180 return CUBIT_FAILURE; 00181 } 00182 else if (ref_edges.size() == 0 && ref_faces.size() == 0) { 00183 PRINT_ERROR("Can't find any faces or edges for composite containing %s %d.\n", 00184 attrib_owner()->class_name(), attrib_owner()->id()); 00185 return CUBIT_FAILURE; 00186 } 00187 00188 // first, check to see that we can composite these entities; if 00189 // not, return without setting actuated flag; this CA will get 00190 // re-actuated if a parent gets composited or partitioned. 00191 DLIList<BasicTopologyEntity*> bte_list; 00192 if (ref_edges.size() > 0) { 00193 CAST_LIST_TO_PARENT(ref_edges, bte_list); 00194 } 00195 else { 00196 CAST_LIST_TO_PARENT(ref_faces, bte_list); 00197 } 00198 00199 if (!CompositeTool::instance()->okayToComposite(bte_list, NULL, NULL, CUBIT_FALSE)) 00200 { 00201 for( int k = comp_attribs.size(); k--; ) 00202 comp_attribs.get_and_step()->has_actuated( CUBIT_FALSE ); 00203 has_actuated( CUBIT_FALSE ); 00204 return CUBIT_FAILURE; 00205 } 00206 00207 // ok, we can build the composite 00208 RefEntity *new_entity = NULL; 00209 if (ref_edges.size() > 0) { 00210 PRINT_DEBUG_90("Creating composite edge from %d edges\n", 00211 ref_edges.size()); 00212 00213 //need to get the RefEdge that owns this attribute 00214 RefEdge *edge_to_keep= NULL; 00215 edge_to_keep = CAST_TO( attrib_owner(), RefEdge ); 00216 00217 if( edge_to_keep == NULL ) 00218 return CUBIT_FAILURE; 00219 00220 new_entity = CompositeTool::instance()->composite(ref_edges, NULL, edge_to_keep); 00221 00222 new TDUniqueId(new_entity, compositeId); 00223 CADeferredAttrib::owner_created(new_entity, compositeId); 00224 } 00225 else if (ref_faces.size() > 0) { 00226 PRINT_DEBUG_90("Creating composite face from %d faces\n", 00227 ref_faces.size()); 00228 00229 //need to get the RefFace that owns this attribute 00230 RefFace *face_to_keep = NULL; 00231 face_to_keep = CAST_TO( attrib_owner(), RefFace ); 00232 00233 if( face_to_keep == NULL ) 00234 return CUBIT_FAILURE; 00235 00236 new_entity = CompositeTool::instance()->composite(ref_faces, face_to_keep); 00237 00238 new TDUniqueId(new_entity, compositeId); 00239 CADeferredAttrib::owner_created(new_entity, compositeId); 00240 } 00241 else { 00242 // shouldn't get here 00243 assert(CUBIT_FALSE); 00244 } 00245 /* 00246 // otherwise, we're done 00247 // set the actuated flag for all the CACVG's for this composite 00248 for (i = tdu_list.size(); i > 0; i--) { 00249 RefEntity *entity; 00250 if (ref_faces.size() > 0) entity = ref_faces.get_and_step(); 00251 else entity = ref_edges.get_and_step(); 00252 CACompositeVG *cacvg = (CACompositeVG *) entity->get_cubit_attrib(CA_COMPOSITE_VG); 00253 assert(cacvg != 0); 00254 cacvg->has_actuated(CUBIT_TRUE); 00255 } 00256 */ 00257 // ok, we've composited; now check for CACVG's on any children, and 00258 // call actuate functions on those if they exist 00259 check_child_cacvgs(new_entity); 00260 00261 return CUBIT_SUCCESS; 00262 } 00263 00264 void CACompositeVG::check_child_cacvgs(RefEntity *new_entity) 00265 { 00266 // check the new entity's children for CACVG's, and actuate those 00267 // if they exist 00268 DLIList<RefEntity*> children; 00269 new_entity->get_child_ref_entities(children); 00270 00271 DLIList<CubitAttrib*> ca_list; 00272 00273 // get the CA list first, then actuate; if we looped over entities, 00274 // actuating as we went, some entities might eventually be gone 00275 // when we got to them 00276 int i; 00277 for (i = children.size(); i > 0; i--) { 00278 RefEntity *child = children.get_and_step(); 00279 child->find_cubit_attrib_type(CA_COMPOSITE_VG, ca_list); 00280 } 00281 00282 //get unactuated deferred attribs 00283 DLIList<CubitAttrib*> unact_deferred_attribs; 00284 unact_deferred_attribs = CADeferredAttrib::get_unactuated_deferred_attribs(); 00285 00286 00287 for (i = ca_list.size(); i > 0; i--) 00288 { 00289 CubitAttrib *ca_ptr = ca_list.get(); 00290 if (ca_ptr->has_actuated() == CUBIT_TRUE) 00291 ca_list.remove(); 00292 else 00293 ca_list.step(); 00294 } 00295 00296 // for the same reason, don't delete until we've gone through the list 00297 for (i = ca_list.size(); i > 0; i--) { 00298 CubitAttrib *ca_ptr = ca_list.get(); 00299 00300 //don't try and actuate unactuated deferred attribs.....wait till later 00301 if( unact_deferred_attribs.move_to( ca_ptr ) ) 00302 { 00303 ca_list.remove(); 00304 continue; 00305 } 00306 00307 if (ca_ptr->delete_attrib() == CUBIT_FALSE && 00308 ca_ptr->has_actuated() == CUBIT_FALSE) 00309 { 00310 ca_ptr->actuate(); 00311 } 00312 00313 // remove undeletable attribs from the list so we don't delete them later 00314 if (ca_ptr->delete_attrib() == CUBIT_FALSE) 00315 ca_list.remove(); 00316 else 00317 ca_list.step(); 00318 } 00319 00320 for (i = ca_list.size(); i > 0; i--) 00321 delete ca_list.get_and_step(); 00322 } 00323 00324
