cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : CoEdge.cpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Xuechen Liu 00009 // 00010 // Creation Date : 08/02/96 00011 // 00012 // Owner : Jihong Ma 00013 //------------------------------------------------------------------------- 00014 00015 // ********** BEGIN STANDARD INCLUDES ********** 00016 // ********** END STANDARD INCLUDES ********** 00017 00018 // ********** BEGIN CUBIT INCLUDES ********** 00019 #include "CoEdge.hpp" 00020 #include "RefEdge.hpp" 00021 #include "RefFace.hpp" 00022 #include "Loop.hpp" 00023 #include "DLIList.hpp" 00024 #include "GeometryDefines.h" 00025 #include "GeometryQueryTool.hpp" 00026 #include "CastTo.hpp" 00027 #include "CoEdgeSM.hpp" 00028 #include "Curve.hpp" 00029 00030 // ********** END CUBIT INCLUDES ********** 00031 00032 // ********** BEGIN STATIC DECLARATIONS ********** 00033 // ********** END STATIC DECLARATIONS ********** 00034 00035 // ********** BEGIN PUBLIC FUNCTIONS ********** 00036 //------------------------------------------------------------------------- 00037 // Purpose : The default constructor. 00038 // 00039 // Special Notes : 00040 // 00041 // Creator : Xuechen Liu 00042 // 00043 // Creation Date : 08/02/96 00044 //------------------------------------------------------------------------- 00045 CoEdge::CoEdge() 00046 { 00047 } 00048 00049 //------------------------------------------------------------------------- 00050 // Purpose : The destructor. 00051 // 00052 // Special Notes : 00053 // 00054 // Creator : Raikanta Sahu 00055 // 00056 // Creation Date : 10/22/96 00057 //------------------------------------------------------------------------- 00058 CoEdge::~CoEdge() 00059 { 00060 remove_from_observers(); 00061 } 00062 00063 //------------------------------------------------------------------------- 00064 // Purpose : The constructor with a pointer to a edge and the 00065 // sense of this CoEdge. 00066 // 00067 // Special Notes : 00068 // 00069 // Creator : Xuechen Liu 00070 // 00071 // Creation Date : 08/02/96 00072 //------------------------------------------------------------------------- 00073 CoEdge::CoEdge(RefEdge* edgePtr, CubitSense sense) 00074 { 00075 attach_basic_topology_entity(edgePtr) ; 00076 set_sense(sense) ; 00077 } 00078 00079 //------------------------------------------------------------------------- 00080 // Purpose : 00081 // 00082 // Special Notes : 00083 // 00084 // Creator : Jason Kraftcheck 00085 // 00086 // Creation Date : 07/22/03 00087 //------------------------------------------------------------------------- 00088 CoEdge::CoEdge( CoEdgeSM* osme_ptr ) 00089 { 00090 set_co_edge_sm_ptr(osme_ptr); 00091 } 00092 00093 //------------------------------------------------------------------------- 00094 // Purpose : Get the RefEdge associated with this CoEdge. 00095 // 00096 // Special Notes : 00097 // 00098 // Creator : Malcolm J. Panthaki 00099 // 00100 // Creation Date : 08/02/96 00101 //------------------------------------------------------------------------- 00102 RefEdge* CoEdge::get_ref_edge_ptr() 00103 { 00104 // Call the generic function defined in the SenseEntity class to 00105 // do the real work 00106 BasicTopologyEntity* BTEPtr = get_basic_topology_entity_ptr(); 00107 00108 // Cast the returned pointer to RefEdge and return it 00109 return STATIC_CAST_TO( BTEPtr, RefEdge ); 00110 } 00111 00112 //------------------------------------------------------------------------- 00113 // Purpose : Get the parent Loop 00114 // 00115 // Special Notes : 00116 // 00117 // Creator : Jason Kraftcheck 00118 // 00119 // Creation Date : 09/23/99 00120 //------------------------------------------------------------------------- 00121 Loop* CoEdge::get_loop_ptr() 00122 { 00123 return STATIC_CAST_TO( get_grouping_entity_ptr(), Loop ); 00124 } 00125 00126 00127 //------------------------------------------------------------------------- 00128 // Purpose : Get the ref_face associated with this CoEdge. 00129 // 00130 // Special Notes : Will assert if more than one ref_face but will 00131 // return NULL if no RefFaces are associated with it. 00132 // 00133 // Creator : David White 00134 // 00135 // Creation Date : 3/14/97 00136 //------------------------------------------------------------------------- 00137 RefFace* CoEdge::get_ref_face() 00138 { 00139 return static_cast<RefFace*>(get_parent_basic_topology_entity_ptr()); 00140 } 00141 00142 00143 00144 //------------------------------------------------------------------------- 00145 // Purpose : This function is called after a child of a TopologyEntity 00146 // is switched. The sense of a CoEdge may change if one 00147 // of its RefEdges changes. This function takes care of 00148 // that. If the sense of the RefEdges that were switched 00149 // is same, nothing is done. If the RefEdges are of 00150 // opposite sense, the sense of this object is switched, 00151 // i.e. if it was FORWARD, it is made REVERSE, and vice 00152 // versa. 00153 // 00154 // Special Notes : 00155 // 00156 // Creator : Raikanta Sahu 00157 // 00158 // Creation Date : 02/26/97 00159 //------------------------------------------------------------------------- 00160 00161 void CoEdge::switch_child_notify(TopologyEntity const* newChild, 00162 TopologyEntity const* oldChild) 00163 { 00164 // Make sure the entities being switched are RefEdges. If not, 00165 // get out of this function. 00166 00167 TopologyEntity* tmp_new_child = const_cast<TopologyEntity*>(newChild); 00168 TopologyEntity* tmp_old_child = const_cast<TopologyEntity*>(oldChild); 00169 RefEdge * newChildRefEdge = CAST_TO(tmp_new_child, RefEdge) ; 00170 RefEdge * oldChildRefEdge = CAST_TO(tmp_old_child, RefEdge) ; 00171 00172 if ( ( newChildRefEdge == NULL ) || ( oldChildRefEdge == NULL ) ) 00173 { 00174 return ; 00175 } 00176 00177 // If the children are RefEdges, get the sense of the old RefEdge 00178 // relative to the new one. 00179 00180 CubitSense sense; 00181 CubitBoolean spatially_equal; 00182 //We really don't care at this point if the two are spatially equal. 00183 // The user could have done a force merge and in which case they are not. 00184 // So just ignore that spatial comparison. 00185 00186 //When this function is called, the merge has already taken place, so force 00187 // merge actually makes more sense to use here... 00188 CubitBoolean force_merge = CUBIT_TRUE; 00189 00190 /*CubitStatus stat = */ 00191 newChildRefEdge->relative_sense( 00192 oldChildRefEdge, GeometryQueryTool::get_geometry_factor(), &sense, 00193 spatially_equal, force_merge ); 00194 00195 // If the sense of the old RefEdge relative to the new RefEdge is 00196 // same, nothing needs to be done. However, if the relative sense 00197 // is reversed, switch the sense of the CoEdge. 00198 if ( sense == CUBIT_REVERSED ) 00199 { 00200 if ( get_sense() == CUBIT_FORWARD ) 00201 { 00202 set_sense(CUBIT_REVERSED) ; 00203 } 00204 else 00205 { 00206 set_sense(CUBIT_FORWARD) ; 00207 } 00208 } 00209 } 00210 00211 //------------------------------------------------------------------------- 00212 // Purpose : Get CoEdgeSM pointer 00213 // 00214 // Special Notes : 00215 // 00216 // Creator : Jason Kraftcheck 00217 // 00218 // Creation Date : 07/23/03 00219 //------------------------------------------------------------------------- 00220 CoEdgeSM* CoEdge::get_co_edge_sm_ptr() const 00221 { 00222 return static_cast<CoEdgeSM*>(bridge_manager()->topology_bridge()); 00223 } 00224 00225 00226 CubitStatus CoEdge::set_co_edge_sm_ptr( CoEdgeSM* ptr ) 00227 { 00228 if (!bridge_manager()->topology_bridge()) 00229 return bridge_manager()->add_bridge(ptr); 00230 else if(bridge_manager()->topology_bridge() != ptr) 00231 return CUBIT_FAILURE; 00232 else 00233 return CUBIT_SUCCESS; 00234 } 00235 00236 //------------------------------------------------------------------------- 00237 // Purpose : Check if child RefEdges are equal and have correct 00238 // relative sense. 00239 // 00240 // Special Notes : 00241 // 00242 // Creator : Jason Kraftcheck 00243 // 00244 // Creation Date : 04/01/04 00245 //------------------------------------------------------------------------- 00246 CubitBoolean CoEdge::about_spatially_equal( CoEdge* other_coedge, 00247 CubitSense relative_sense, 00248 double tolerance_factor, 00249 CubitBoolean notify_refEntity ) 00250 { 00251 RefEdge* this_ref_edge = get_ref_edge_ptr(); 00252 RefEdge* other_ref_edge = other_coedge->get_ref_edge_ptr(); 00253 CubitSense edge_sense; 00254 00255 if (!this_ref_edge->about_spatially_equal( other_ref_edge, 00256 tolerance_factor, 00257 &edge_sense, 00258 notify_refEntity )) 00259 return CUBIT_FALSE; 00260 00261 if (this_ref_edge->get_curve_ptr()->geometry_type() == POINT_CURVE_TYPE || 00262 other_ref_edge->get_curve_ptr()->geometry_type() == POINT_CURVE_TYPE) 00263 return CUBIT_TRUE; 00264 00265 if (edge_sense == CUBIT_UNKNOWN) 00266 { 00267 PRINT_WARNING("Failed to determine relative sense of curves.\n"); 00268 return CUBIT_TRUE; 00269 } 00270 00271 bool coedges_reversed = get_sense() != other_coedge->get_sense(); 00272 bool want_reversed = edge_sense != relative_sense; 00273 if (coedges_reversed == want_reversed) 00274 return CUBIT_TRUE; 00275 00276 // if (notify_refEntity) 00277 // { 00278 // this_ref_edge->remove_compare_data(); 00279 // other_ref_edge->remove_compare_data(); 00280 // } 00281 return CUBIT_FALSE; 00282 } 00283 00284 //------------------------------------------------------------------------- 00285 // Purpose : Get start/end vertex 00286 // 00287 // Special Notes : 00288 // 00289 // Creator : Jason Kraftcheck 00290 // 00291 // Creation Date : 05/11/04 00292 //------------------------------------------------------------------------- 00293 RefVertex* CoEdge::start_vertex() 00294 { 00295 return get_sense() == CUBIT_FORWARD ? 00296 get_ref_edge_ptr()->start_vertex() : 00297 get_ref_edge_ptr()->end_vertex(); 00298 } 00299 RefVertex* CoEdge::end_vertex() 00300 { 00301 return get_sense() == CUBIT_REVERSED ? 00302 get_ref_edge_ptr()->start_vertex() : 00303 get_ref_edge_ptr()->end_vertex(); 00304 } 00305 00306 // ********** END PUBLIC FUNCTIONS ********** 00307 00308 // ********** BEGIN PROTECTED FUNCTIONS ********** 00309 // ********** END PROTECTED FUNCTIONS ********** 00310 00311 // ********** BEGIN PRIVATE FUNCTIONS ********** 00312 // ********** END PRIVATE FUNCTIONS ********** 00313 00314 // ********** BEGIN HELPER CLASSES ********** 00315 // ********** END HELPER CLASSES ********** 00316 00317 // ********** BEGIN EXTERN FUNCTIONS ********** 00318 // ********** END EXTERN FUNCTIONS ********** 00319 00320 // ********** BEGIN STATIC FUNCTIONS ********** 00321 // ********** END STATIC FUNCTIONS ********** 00322
