cgma
00001 #include "CubitFacet.hpp" 00002 #include "CubitPoint.hpp" 00003 #include "CubitPointData.hpp" 00004 #include "CubitVector.hpp" 00005 #include "GeometryDefines.h" 00006 #include "CubitPlane.hpp" 00007 #include "CubitFacetEdge.hpp" 00008 #include "CubitFacetData.hpp" 00009 #include "CubitFacetEdgeData.hpp" 00010 #include "CastTo.hpp" 00011 #include "ToolData.hpp" 00012 #include "GfxDebug.hpp" 00013 #include "TDFacetBoundaryPoint.hpp" 00014 #include "CubitMessage.hpp" 00015 00016 #ifndef CUBIT_MAX 00017 #define CUBIT_MAX(a,b) (((a) > (b)) ? (a) : (b)) 00018 #endif 00019 #ifndef CUBIT_MIN 00020 #define CUBIT_MIN(a,b) (((a) < (b)) ? (a) : (b)) 00021 #endif 00022 #define min3(a,b,c) CUBIT_MIN((CUBIT_MIN((a),(b))),(c)) 00023 #define max3(a,b,c) CUBIT_MAX((CUBIT_MAX((a),(b))),(c)) 00024 static int counter_id = 0; 00025 00026 //=========================================================================== 00027 //Function Name: CubitFacetData 00028 // 00029 //Member Type: PUBLIC 00030 //Description: constructor 00031 //=========================================================================== 00032 CubitFacetData::CubitFacetData( CubitPoint *p1, CubitPoint *p2, 00033 CubitPoint *p3 ) 00034 { 00035 assert( p1 && p2 && p3 ); 00036 assert( p1 != p2 && p1 != p3 && p2 != p3 ); 00037 pointArray[0] = p1; 00038 pointArray[1] = p2; 00039 pointArray[2] = p3; 00040 p1->add_facet(this); 00041 p2->add_facet(this); 00042 p3->add_facet(this); 00043 00044 edgeArray[0] = NULL; 00045 edgeArray[1] = NULL; 00046 edgeArray[2] = NULL; 00047 edgeUse[0] = edgeUse[1] = edgeUse[2] = 0; 00048 patchCtrlPts = NULL; 00049 00050 00051 counter_id++; 00052 entityId = counter_id; 00053 00054 plane(); 00055 00056 define_bounding_box(); 00057 00058 } 00059 00060 //=========================================================================== 00061 //Function Name: CubitFacetData 00062 // 00063 //Member Type: PUBLIC 00064 //Description: constructor 00065 //=========================================================================== 00066 CubitFacetData::CubitFacetData( CubitFacetEdge *e1, CubitFacetEdge *e2, 00067 CubitFacetEdge *e3 ) 00068 { 00069 assert( e1 && e2 && e3 ); 00070 assert( e1 != e2 && e1 != e3 && e2 != e3 ); 00071 00072 edgeArray[0] = e1; 00073 edgeArray[1] = e2; 00074 edgeArray[2] = e3; 00075 00076 define_point(e2, e3, 0); 00077 define_point(e3, e1, 1); 00078 define_point(e1, e2, 2); 00079 e1->add_facet(this); 00080 e2->add_facet(this); 00081 e3->add_facet(this); 00082 00083 patchCtrlPts = NULL; 00084 00085 plane(); 00086 counter_id++; 00087 entityId = counter_id; 00088 00089 define_bounding_box(); 00090 00091 } 00092 00093 //=========================================================================== 00094 //Function Name: CubitFacetData 00095 // 00096 //Member Type: PUBLIC 00097 //Description: constructor 00098 //=========================================================================== 00099 CubitFacetData::CubitFacetData( CubitPoint *p1, CubitPoint *p2, 00100 CubitPoint *p3, int *tool_data) 00101 { 00102 assert( p1 && p2 && p3 ); 00103 assert( p1 != p2 && p1 != p3 && p2 != p3 ); 00104 pointArray[0] = p1; 00105 pointArray[1] = p2; 00106 pointArray[2] = p3; 00107 00108 edgeArray[0] = NULL; 00109 edgeArray[1] = NULL; 00110 edgeArray[2] = NULL; 00111 00112 p1->add_facet(this); 00113 p2->add_facet(this); 00114 p3->add_facet(this); 00115 00116 edgeArray[0] = 0; 00117 edgeArray[1] = 0; 00118 edgeArray[2] = 0; 00119 allocate_edge(p2,p3,0); 00120 allocate_edge(p3,p1,1); 00121 allocate_edge(p1,p2,2); 00122 00123 patchCtrlPts = NULL; 00124 00125 plane(); 00126 counter_id++; 00127 entityId = counter_id; 00128 // update toolID 00129 if(tool_data) 00130 set_tool_id(*tool_data); 00131 00132 define_bounding_box(); 00133 } 00134 00135 //=========================================================================== 00136 //Function Name: ~CubitFacetData 00137 // 00138 //Member Type: PUBLIC 00139 //Description: destructor 00140 //=========================================================================== 00141 CubitFacetData::~CubitFacetData() 00142 { 00143 destruct_facet_internals(); 00144 } 00145 00146 void CubitFacetData::destruct_facet_internals() 00147 { 00148 int ii = 3; 00149 for (ii = 2; ii>=0; ii--){ 00150 //remove this triangle-point association at the points. 00151 CubitPoint *current_point = point(ii); 00152 if (current_point) 00153 current_point->remove_facet(this); 00154 00155 pointArray[ii] = NULL; 00156 00157 //remove edge-point association at the edges 00158 00159 CubitFacetEdge *current_edge = edgeArray[ii]; 00160 00161 if (current_edge) { 00162 CubitStatus status = current_edge->remove_facet(this); 00163 if (CUBIT_SUCCESS != status) { 00164 PRINT_ERROR("Failed to remove facet at current edge.\n"); 00165 return; 00166 } 00167 } 00168 edgeArray[ii] = NULL; 00169 } 00170 } 00171 00172 00173 //=========================================================================== 00174 //Function Name: closest_point 00175 // 00176 //Member Type: PUBLIC 00177 //Description: return the closest point on plane defined by the facet 00178 //=========================================================================== 00179 CubitStatus CubitFacetData::closest_point(const CubitVector &point, 00180 CubitVector &closest_point ) 00181 { 00182 if( cachedPlane ) 00183 { 00184 closest_point = cachedPlane->project( point ); 00185 return CUBIT_SUCCESS; 00186 } 00187 00188 CubitVector normal_vec = normal(); 00189 CubitVector P0 = pointArray[0]->coordinates(); 00190 CubitVector point_to_P0 = point - P0; 00191 CubitVector P0_to_projection; 00192 //Store the normal squared the the dot product of the normal and vector to the point. 00193 double normal_length_sq = normal_vec.length_squared(); 00194 //If the normal is zero, get out! 00195 if ( normal_length_sq < CUBIT_RESABS ) 00196 return CUBIT_FAILURE; 00197 double point_to_P0_dot_norm = point_to_P0%normal_vec; 00198 //Use P0_to_projection as a temporary to store half the equation. 00199 P0_to_projection = (point_to_P0_dot_norm/normal_length_sq)*normal_vec; 00200 P0_to_projection = point_to_P0 - P0_to_projection; 00201 //Now we have the vector from P0, to the closest point. Add the vector 00202 //to P0, and you have the location! 00203 closest_point = P0 + P0_to_projection; 00204 return CUBIT_SUCCESS; 00205 } 00206 00207 //------------------------------------------------------------------------- 00208 // Purpose : Local modification functions. 00209 // 00210 // Special Notes : 00211 // 00212 // Creator : Jason Kraftcheck 00213 // 00214 // Creation Date : 03/25/00 00215 //------------------------------------------------------------------------- 00216 CubitPoint* CubitFacetData::split_edge( int edge_index, 00217 const CubitVector& position ) 00218 { 00219 CubitPoint* pt1 = point((edge_index+1)%2); 00220 CubitPoint* pt2 = point((edge_index+2)%2); 00221 return split_edge( pt1, pt2, position ); 00222 } 00223 00224 CubitPoint* CubitFacetData::split_edge( CubitPoint* edge1_pt, 00225 CubitPoint* edge2_pt, 00226 const CubitVector& position ) 00227 { 00228 CubitPointData* new_pt = new CubitPointData(position); 00229 00230 // split edge, if there is one 00231 00232 CubitFacetEdge* edge = edge1_pt->shared_edge( edge2_pt ); 00233 CubitFacetEdgeData* new_edge = 0; 00234 if ( edge ) { 00235 CubitFacetEdgeData* edge_d = dynamic_cast<CubitFacetEdgeData*>(edge); 00236 assert(!!edge_d); 00237 00238 // make sure new edge has same orientation as old edge 00239 new_edge = dynamic_cast<CubitFacetEdgeData*>(new_pt->shared_edge(edge2_pt)); 00240 if ( edge->point(0) == edge1_pt ) { 00241 edge_d->set_point(new_pt, 1); 00242 if ( !new_edge ) 00243 { 00244 new_edge = new CubitFacetEdgeData( new_pt, edge2_pt ); 00245 DLIList<ToolData*> tds; 00246 edge->get_all_TDs(&tds); 00247 for (int i=0; i<tds.size(); i++) 00248 { 00249 ToolData* new_td = tds.get_and_step()->propogate(new_edge); 00250 if (new_td) 00251 new_edge->add_TD(new_td); 00252 } 00253 } 00254 else if( new_edge->point(0) != new_pt ) 00255 new_edge->flip(); 00256 } else { 00257 edge_d->set_point(new_pt, 0); 00258 if ( !new_edge ) 00259 { 00260 new_edge = new CubitFacetEdgeData( edge2_pt, new_pt ); 00261 DLIList<ToolData*> tds; 00262 edge->get_all_TDs(&tds); 00263 for (int i=0; i<tds.size(); i++) 00264 { 00265 ToolData* new_td = tds.get_and_step()->propogate(new_edge); 00266 if (new_td) 00267 new_edge->add_TD(new_td); 00268 } 00269 } 00270 else if( new_edge->point(1) != new_pt ) 00271 new_edge->flip(); 00272 } 00273 } 00274 00275 // split triangles 00276 00277 DLIList<CubitFacet*> facets; 00278 edge1_pt->shared_facets( edge2_pt, facets ); 00279 00280 facets.reset(); 00281 for ( int i = facets.size(); i--; ) { 00282 00283 CubitFacet* facet = facets.get_and_step(); 00284 CubitFacetData* facet_d = dynamic_cast<CubitFacetData*>(facet); 00285 assert(!!facet_d); 00286 00287 00288 // fix up existing facet 00289 00290 int pt2_index = facet->point_index( edge2_pt ); 00291 bool edge_reversed = ( edge1_pt == facet->point( (pt2_index+1) % 3 ) ); 00292 int edge_index = (pt2_index + 1 + edge_reversed) % 3; 00293 00294 edge2_pt->remove_facet( facet ); 00295 facet_d->set_point( new_pt, pt2_index ); 00296 new_pt->add_facet( facet ); 00297 facet->update_plane(); 00298 00299 00300 // make new facet 00301 00302 CubitPoint* other_pt = facet->point( edge_index ); 00303 CubitFacetData* new_facet; 00304 if ( edge_reversed ) 00305 new_facet = new CubitFacetData( other_pt, edge2_pt, new_pt ); 00306 else 00307 new_facet = new CubitFacetData( other_pt, new_pt, edge2_pt ); 00308 00309 DLIList<ToolData*> td_list; 00310 facet->get_all_TDs(&td_list); 00311 for (int i=0; i< td_list.size(); i++) 00312 { 00313 ToolData* new_td = td_list.get_and_step()->propogate(new_facet); 00314 if (new_td) 00315 { 00316 new_facet->add_TD(new_td); 00317 } 00318 } 00319 00320 if ( new_edge ) { 00321 assert(!new_facet->edge(0)); 00322 new_facet->edge( new_edge, 0 ); 00323 new_edge->add_facet( new_facet ); 00324 int sense = new_facet->point( 1 ) == new_edge->point(0) ? 1 : -1; 00325 new_facet->edge_use( sense, 0 ); 00326 } 00327 00328 00329 // move other edge, if there is one 00330 00331 int pt1_index = (pt2_index + 2 - edge_reversed) % 3; 00332 CubitFacetEdge* other_edge = facet->edge(pt1_index); 00333 if ( other_edge ) { 00334 other_edge->remove_facet(facet); 00335 facet->edge( 0, pt1_index ); 00336 int e_index = 1 + edge_reversed; 00337 assert(!new_facet->edge(e_index)); 00338 new_facet->edge( other_edge, e_index ); 00339 other_edge->add_facet(new_facet); 00340 int sense = new_facet->point( (e_index+1)%3 ) == other_edge->point(0) ? 1 : -1; 00341 new_facet->edge_use( sense, e_index ); 00342 } 00343 00344 // what about a new edge for each of the adj_facets and its tool data 00345 00346 } 00347 00348 return new_pt; 00349 } 00350 00351 //------------------------------------------------------------------------- 00352 // Purpose : insert a point into the facet 00353 // 00354 // Special Notes : create two new facets and return them 00355 // 00356 // Creator : 00357 // 00358 // Creation Date : 00359 //------------------------------------------------------------------------- 00360 CubitPoint* CubitFacetData::insert_point( const CubitVector& position, 00361 CubitFacet*& new_tri1_out, 00362 CubitFacet*& new_tri2_out ) 00363 { 00364 CubitPointData* new_point = new CubitPointData( position ); 00365 CubitFacetData *new_tri1, *new_tri2; 00366 new_tri1 = new CubitFacetData( point(1), point(2), new_point ); 00367 new_tri2 = new CubitFacetData( point(2), point(0), new_point ); 00368 00369 point(2)->remove_facet( this ); 00370 set_point( new_point, 2 ); 00371 new_point->add_facet( this ); 00372 00373 if ( edge(0) ) { 00374 new_tri1->edge( edge(0), 2 ); 00375 new_tri1->edge_use( edge_use(0), 2 ); 00376 edge(0)->remove_facet(this); 00377 edge(0)->add_facet(new_tri1); 00378 edge( 0, 0 ); 00379 } 00380 00381 if ( edge(1) ) { 00382 new_tri2->edge( edge(1), 2 ); 00383 new_tri2->edge_use( edge_use(1), 2 ); 00384 edge(1)->remove_facet(this); 00385 edge(1)->add_facet(new_tri2); 00386 edge( 0, 1 ); 00387 } 00388 00389 update_plane(); 00390 00391 new_tri1_out = new_tri1; 00392 new_tri2_out = new_tri2; 00393 return new_point; 00394 } 00395 00396 00397 //------------------------------------------------------------------------- 00398 // Purpose : reorient the facet 00399 // 00400 // Special Notes : This function should only be used if it is acceptable 00401 // to change the underlying data representation of the 00402 // facets (for example the Sierra facet representation 00403 // cannot change and will not permit changing of the 00404 // node orders on a facet) 00405 // 00406 // Also note that if this function is used, the isBackwards 00407 // flag on the facet should be set appropriately. 00408 // 00409 // Creator : Steve Owen 00410 // 00411 // Creation Date : 06/28/00 00412 //------------------------------------------------------------------------- 00413 void CubitFacetData::flip() 00414 { 00415 CubitVector* ctrl_points=control_points( ); 00416 00417 CubitPoint *pt_tmp = pointArray[1]; 00418 pointArray[1] = pointArray[2]; 00419 pointArray[2] = pt_tmp; 00420 00421 CubitFacetEdge *ed_tmp = edgeArray[1]; 00422 edgeArray[1] = edgeArray[2]; 00423 edgeArray[2] = ed_tmp; 00424 00425 //make sure the edgeUses are matched with the correct edge... 00426 int ed_use_tmp = edgeUse[1]; 00427 edgeUse[1]=edgeUse[2]; 00428 edgeUse[2]=ed_use_tmp; 00429 00430 //now flip the edge uses... 00431 int ii; 00432 for (ii=0; ii<3; ii++) 00433 { 00434 if (edgeUse[ii] == -1) { 00435 edgeUse[ii] = 1; 00436 } 00437 else if(edgeUse[ii] == 1) { 00438 edgeUse[ii] = -1; 00439 } 00440 } 00441 if(ctrl_points){ 00442 CubitVector tmp_point; 00443 tmp_point = ctrl_points[0]; 00444 ctrl_points[0]=ctrl_points[1]; 00445 ctrl_points[1]=tmp_point; 00446 tmp_point = ctrl_points[2]; 00447 ctrl_points[2]=ctrl_points[5]; 00448 ctrl_points[5]=tmp_point; 00449 tmp_point = ctrl_points[3]; 00450 ctrl_points[3]=ctrl_points[4]; 00451 ctrl_points[4]=tmp_point; 00452 } 00453 update_plane(); 00454 //update the normals on the points (including boundary points) 00455 for (ii=0; ii<3; ii++) 00456 { 00457 pointArray[ii]->compute_avg_normal(); 00458 TDFacetBoundaryPoint* tdfbp = 00459 TDFacetBoundaryPoint::get_facet_boundary_point(pointArray[ii]); 00460 if(tdfbp){ 00461 if(!tdfbp->reset_normals()){ 00462 PRINT_ERROR("Could not reset all the normals for a point.\n"); 00463 } 00464 } 00465 } 00466 00467 } 00468 00469 //=========================================================================== 00470 //Function Name: allocate_edge 00471 // 00472 //Member Type: PRIVATE 00473 //Description: associate facetedge with this facet 00474 //Special Notes: 1. Assume edge(p1,p2) is in Counter-clockwise direction wrt to// this facet) 00475 // 2. Helper function to Constructor 00476 //=========================================================================== 00477 void CubitFacetData::allocate_edge(CubitPoint *p1, CubitPoint *p2, int edge_index){ 00478 00479 assert(edge_index >= 0 && edge_index < 3); 00480 assert(p1 != NULL && p2 != NULL); 00481 00482 CubitFacetEdge* shared_edge = p1->get_edge(p2); 00483 00484 if(shared_edge == NULL){ 00485 //- if edge don't exist, create it 00486 edgeArray[edge_index] = (CubitFacetEdge *) new CubitFacetEdgeData(p1,p2); 00487 edgeUse[edge_index] = 1; 00488 } else { 00489 edgeArray[edge_index] = shared_edge; 00490 shared_edge->add_facet(this); 00491 if(shared_edge->point(0) == p1) 00492 edgeUse[edge_index]= 1; 00493 else 00494 edgeUse[edge_index] = -1; 00495 00496 } 00497 00498 } 00499 00500 00501 //=========================================================================== 00502 //Function Name: define_point 00503 // 00504 //Member Type: PRIVATE 00505 //Description: define the point based on its adjacent edges. define the 00506 // edge uses too. 00507 //Special Notes: 1. Assume edge(e1,e2) is in Counter-clockwise direction wrt 00508 // this facet 00509 // 2. Helper function to Constructor 00510 //=========================================================================== 00511 void CubitFacetData::define_point(CubitFacetEdge *e1, 00512 CubitFacetEdge *e2, 00513 int point_index) 00514 { 00515 00516 assert(point_index >= 0 && point_index < 3); 00517 assert(e1 != NULL && e2 != NULL); 00518 00519 CubitPoint *pA, *pB, *pC, *pD; 00520 pA = e1->point(0); 00521 pB = e1->point(1); 00522 pC = e2->point(0); 00523 pD = e2->point(1); 00524 if(pC == pB || pC == pA) 00525 { 00526 pointArray[point_index] = pC; 00527 pC->add_facet(this); 00528 edgeUse[(point_index+2)%3] = 1; 00529 } 00530 else if(pD == pB || pD == pA) 00531 { 00532 pointArray[point_index] = pD; 00533 pD->add_facet(this); 00534 edgeUse[(point_index+2)%3] = -1; 00535 } 00536 else 00537 { 00538 assert(0); // the edges are not adjacent; 00539 } 00540 00541 } 00542 00543 //=========================================================================== 00544 //Function Name: define_bounding_box 00545 // 00546 //Member Type: PRIVATE 00547 //Description: compute and store the bounding box 00548 // Helper function to Constructor 00549 //=========================================================================== 00550 void CubitFacetData::define_bounding_box() 00551 { 00552 CubitVector bbox_min, bbox_max; 00553 CubitPoint *p1 = pointArray[0]; 00554 CubitPoint *p2 = pointArray[1]; 00555 CubitPoint *p3 = pointArray[2]; 00556 bbox_min.x(min3(p1->x(),p2->x(),p3->x())); 00557 bbox_min.y(min3(p1->y(),p2->y(),p3->y())); 00558 bbox_min.z(min3(p1->z(),p2->z(),p3->z())); 00559 bbox_max.x(max3(p1->x(),p2->x(),p3->x())); 00560 bbox_max.y(max3(p1->y(),p2->y(),p3->y())); 00561 bbox_max.z(max3(p1->z(),p2->z(),p3->z())); 00562 bBox.reset(bbox_min,bbox_max); 00563 } 00564 00565 CubitStatus CubitFacetData::flip_edge( CubitFacetEdge *edge ) 00566 { 00567 int i; 00568 for(i=0; i<3; i++) 00569 { 00570 if (edgeArray[i] == edge) 00571 return flip_edge(i); 00572 } 00573 return CUBIT_FAILURE; 00574 } 00575 00576 CubitStatus CubitFacetData::flip_edge( int this_edge_index ) 00577 { 00578 // get point indices on this facet 00579 int this_pt1_index = (this_edge_index+1)%3; 00580 int this_pt2_index = (this_edge_index+2)%3; 00581 00582 // get edge points 00583 CubitPoint* point1 = point(this_pt1_index); 00584 CubitPoint* point2 = point(this_pt2_index); 00585 00586 // can only be one adjacent facet at edge 00587 DLIList<CubitFacet*> pt_facets; 00588 point1->shared_facets(point2, pt_facets); 00589 if ( pt_facets.size() != 2 || !pt_facets.move_to(this) ) 00590 return CUBIT_FAILURE; 00591 00592 // get other facet 00593 CubitFacetData* other_facet = NULL; 00594 if( pt_facets.get() == this ) 00595 { 00596 other_facet = dynamic_cast<CubitFacetData*>(pt_facets.next()); 00597 } 00598 else 00599 if( pt_facets.next() == this ) 00600 { 00601 other_facet = dynamic_cast<CubitFacetData*>( pt_facets.get() ); 00602 } 00603 else 00604 { 00605 assert(0); 00606 return CUBIT_FAILURE; 00607 } 00608 00609 assert(other_facet); 00610 00611 // get indices on other facet 00612 int other_pt1_index = other_facet->point_index(point1); 00613 int other_pt2_index = (other_pt1_index+1)%3; 00614 int other_edge_index = (other_pt1_index+2)%3; 00615 if ( other_facet->point(other_pt2_index) != point2 ) { 00616 other_pt2_index = other_edge_index; 00617 other_edge_index = (other_pt1_index+1)%3; 00618 } 00619 assert( other_facet->point(other_pt2_index) == point2 ); 00620 00621 // check facet orientation 00622 int this_flip_use = this->edge_use(this_edge_index); 00623 int other_flip_use = other_facet->edge_use(other_edge_index); 00624 if ( this_flip_use == other_flip_use ) 00625 { 00626 // Facets don't have consistant normals!! 00627 assert(0); 00628 return CUBIT_FAILURE; 00629 } 00630 00631 // get the opposite points on facets 00632 CubitPoint* this_other_pt = this->point(this_edge_index); 00633 CubitPoint* other_other_pt = other_facet->point(other_edge_index); 00634 if(this_other_pt == other_other_pt){ 00635 PRINT_WARNING("Unable to perform flip.\n"); 00636 return CUBIT_FAILURE; 00637 } 00638 00639 00640 // get the edge that is to be moved from this to the other facet 00641 CubitFacetEdge* this_trade_edge = this->edge(this_pt2_index); 00642 // get the edge thatis to be moved from the other facet to this 00643 CubitFacetEdge* other_trade_edge = other_facet->edge(other_pt1_index); 00644 if(this_trade_edge == other_trade_edge){ 00645 PRINT_WARNING("Unable to perform flip (2).\n"); 00646 return CUBIT_FAILURE; 00647 } 00648 int this_trade_use = this->edge_use(this_pt2_index); 00649 if ( this_trade_edge ) 00650 { 00651 this_trade_edge->remove_facet(this); 00652 this_trade_edge->add_facet(other_facet); 00653 } 00654 00655 int other_trade_use = other_facet->edge_use(other_pt1_index); 00656 if ( other_trade_edge ) 00657 { 00658 other_trade_edge->remove_facet(other_facet); 00659 other_trade_edge->add_facet(this); 00660 } 00661 00662 // get the edge to flip and change its points 00663 CubitFacetEdgeData* flip_edge 00664 = dynamic_cast<CubitFacetEdgeData*>(edge(this_edge_index)); 00665 if ( flip_edge ) 00666 { 00667 // orient edge such that the edge uses stay the same 00668 int dir = (flip_edge->point(0) == point1); 00669 flip_edge->set_point( this_other_pt, 1-dir ); 00670 flip_edge->set_point( other_other_pt, dir ); 00671 } 00672 00673 00674 // change this facet 00675 this->edge( other_trade_edge, this_edge_index ); 00676 this->edge_use( other_trade_use, this_edge_index ); 00677 this->edge( flip_edge, this_pt2_index ); 00678 this->edge_use( this_flip_use, this_pt2_index ); 00679 point1->remove_facet(this); 00680 other_other_pt->add_facet(this); 00681 this->set_point( other_other_pt, this_pt1_index ); 00682 00683 00684 // change the other facet 00685 other_facet->edge( this_trade_edge, other_edge_index ); 00686 other_facet->edge_use( this_trade_use, other_edge_index ); 00687 other_facet->edge( flip_edge, other_pt1_index ); 00688 other_facet->edge_use( other_flip_use, other_pt1_index ); 00689 point2->remove_facet(other_facet); 00690 this_other_pt->add_facet(other_facet); 00691 other_facet->set_point( this_other_pt, other_pt2_index ); 00692 00693 // make sure everything is correct 00694 #ifndef NDEBUG 00695 for ( int i = 0; i < 3; i++ ) 00696 { 00697 if ( this->edge(i) ) 00698 { 00699 int start_index, end_index; 00700 if ( this->edge_use(i) == 1 ) 00701 { 00702 start_index = (i+1)%3; 00703 end_index = (i+2)%3; 00704 } 00705 else 00706 { 00707 assert(this->edge_use(i) == -1); 00708 start_index = (i+2)%3; 00709 end_index = (i+1)%3; 00710 } 00711 assert ( this->edge(i)->point(0) == this->point(start_index) ); 00712 assert ( this->edge(i)->point(1) == this->point(end_index) ); 00713 } 00714 00715 if ( other_facet->edge(i) ) 00716 { 00717 int start_index, end_index; 00718 if ( other_facet->edge_use(i) == 1 ) 00719 { 00720 start_index = (i+1)%3; 00721 end_index = (i+2)%3; 00722 } 00723 else 00724 { 00725 assert(other_facet->edge_use(i) == -1); 00726 start_index = (i+2)%3; 00727 end_index = (i+1)%3; 00728 } 00729 assert ( other_facet->edge(i)->point(0) == other_facet->point(start_index) ); 00730 assert ( other_facet->edge(i)->point(1) == other_facet->point(end_index) ); 00731 } 00732 } 00733 #endif 00734 00735 return CUBIT_SUCCESS; 00736 }
