cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetCoEdge.cpp 00003 // 00004 // Purpose : 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Steven J. Owen 00009 // 00010 // Creation Date : 07/18/00 00011 // 00012 // Owner : Steven J. Owen 00013 //------------------------------------------------------------------------- 00014 00015 // ********** BEGIN STANDARD INCLUDES ********** 00016 // ********** END STANDARD INCLUDES ********** 00017 00018 // ********** BEGIN CUBIT INCLUDES ********** 00019 #include "CubitDefines.h" 00020 #include "CastTo.hpp" 00021 #include "FacetCoEdge.hpp" 00022 #include "FacetLoop.hpp" 00023 #include "FacetQueryEngine.hpp" 00024 #include "CubitUtil.hpp" 00025 00026 #include "FacetBody.hpp" 00027 #include "FacetLump.hpp" 00028 #include "FacetShell.hpp" 00029 #include "FacetSurface.hpp" 00030 #include "FacetCurve.hpp" 00031 // ********** END CUBIT INCLUDES ********** 00032 00033 // ********** BEGIN FORWARD DECLARATIONS ********** 00034 // ********** END FORWARD DECLARATIONS ********** 00035 00036 // ********** BEGIN STATIC DECLARATIONS ********** 00037 // ********** END STATIC DECLARATIONS ********** 00038 00039 // ********** BEGIN PUBLIC FUNCTIONS ********** 00040 00041 //------------------------------------------------------------------------- 00042 // Purpose : A constructor with a pointer to a Facet CoEdge. 00043 // 00044 // Special Notes : 00045 // 00046 // Creator : Steve Owen 00047 // 00048 // Creation Date : 07/18/00 00049 //------------------------------------------------------------------------- 00050 FacetCoEdge::FacetCoEdge( Curve *curv_ptr, LoopSM *loop_ptr, CubitSense sense ) 00051 { 00052 myCurve = curv_ptr; 00053 myLoop = loop_ptr; 00054 edgeSense = sense; 00055 } 00056 00057 //------------------------------------------------------------------------- 00058 // Purpose : A constructor with a pointer to a Facet CoEdge. 00059 // 00060 // Special Notes : Constructor used for save/restore 00061 // 00062 // Creator : Corey Ernst 00063 // 00064 // Creation Date : 02/03/03 00065 //------------------------------------------------------------------------- 00066 FacetCoEdge::FacetCoEdge( Curve *curv_ptr, CubitSense sense ) 00067 { 00068 myCurve = curv_ptr; 00069 myLoop = NULL; 00070 edgeSense = sense; 00071 } 00072 00073 //------------------------------------------------------------------------- 00074 // Purpose : The destructor 00075 // 00076 // Special Notes : 00077 // 00078 // Creator : Steve Owen 00079 // 00080 // Creation Date : 07/18/00 00081 //------------------------------------------------------------------------- 00082 FacetCoEdge::~FacetCoEdge() 00083 { 00084 } 00085 00086 //------------------------------------------------------------------------- 00087 // Purpose : Get geometry modeling engine: FacetQueryEngine 00088 // 00089 // Special Notes : 00090 // 00091 // Creator : Steve Owen 00092 // 00093 // Creation Date : 07/18/00 00094 //------------------------------------------------------------------------- 00095 GeometryQueryEngine* FacetCoEdge::get_geometry_query_engine() const 00096 { 00097 return FacetQueryEngine::instance(); 00098 } 00099 00100 //------------------------------------------------------------------------- 00101 // Purpose : The purpose of this function is to append a 00102 // attribute to the OSME. The name is attached to the 00103 // underlying solid model entity this one points to. 00104 // 00105 // 00106 // Special Notes : 00107 // 00108 // Creator : Steve Owen 00109 // 00110 // Creation Date : 07/18/00 00111 //------------------------------------------------------------------------- 00112 void FacetCoEdge::append_simple_attribute_virt(const CubitSimpleAttrib& /*csattrib_ptr*/) 00113 { 00114 //PRINT_ERROR("FacetCoEdge::append_simple_attribute_virt not implemented\n"); 00115 return; 00116 } 00117 00118 00119 //------------------------------------------------------------------------- 00120 // Purpose : The purpose of this function is to remove a simple 00121 // attribute attached to this geometry entity. The name is 00122 // removed from the underlying BODY this points to. 00123 // 00124 // Special Notes : 00125 // 00126 // Creator : Steve Owen 00127 // 00128 // Creation Date : 07/18/00 00129 //------------------------------------------------------------------------- 00130 void FacetCoEdge::remove_simple_attribute_virt(const CubitSimpleAttrib& /*csattrib_ptr*/) 00131 { 00132 //PRINT_ERROR("FacetCoEdge::remove_simple_attribute_virt not implemented\n"); 00133 return; 00134 } 00135 00136 //------------------------------------------------------------------------- 00137 // Purpose : The purpose of this function is to remove all simple 00138 // attributes attached to this geometry entity. Also 00139 // removes lingering GTC attributes. 00140 // 00141 // 00142 // Special Notes : 00143 // 00144 // Creator : Steve Owen 00145 // 00146 // Creation Date : 07/18/00 00147 //------------------------------------------------------------------------- 00148 void FacetCoEdge::remove_all_simple_attribute_virt() 00149 { 00150 //PRINT_ERROR("FacetCoEdge::remove_all_simple_attribute_virt not implemented\n"); 00151 return; 00152 } 00153 00154 //------------------------------------------------------------------------- 00155 // Purpose : The purpose of this function is to get the 00156 // attributes attached to this geometry entity. The name is 00157 // attached to the underlying BODY this points to. 00158 // 00159 // Special Notes : 00160 // 00161 // Creator : Steve Owen 00162 // 00163 // Creation Date : 07/18/00 00164 //------------------------------------------------------------------------- 00165 CubitStatus FacetCoEdge::get_simple_attribute(DLIList<CubitSimpleAttrib>& 00166 /*cubit_simple_attrib_list*/) 00167 { 00168 //PRINT_ERROR("FacetCoEdge::get_simple_attribute not implemented\n"); 00169 return CUBIT_FAILURE; 00170 } 00171 CubitStatus FacetCoEdge::get_simple_attribute(const CubitString&, 00172 DLIList<CubitSimpleAttrib>&) 00173 { return CUBIT_FAILURE; } 00174 00175 00176 CubitSense FacetCoEdge::sense() 00177 { 00178 return edgeSense; 00179 } 00180 /* 00181 void FacetCoEdge::bodysms(DLIList<BodySM*> &bodies) 00182 { 00183 myLoop->bodysms(bodies); 00184 } 00185 00186 void FacetCoEdge::lumps(DLIList<Lump*> &lumps) 00187 { 00188 myLoop->lumps(lumps); 00189 } 00190 00191 void FacetCoEdge::shellsms(DLIList<ShellSM*> &shellsms) 00192 { 00193 myLoop->shellsms(shellsms); 00194 } 00195 00196 void FacetCoEdge::surfaces(DLIList<Surface*> &surfaces) 00197 { 00198 myLoop->surfaces( surfaces ); 00199 } 00200 00201 void FacetCoEdge::loopsms(DLIList<LoopSM*> &loopsms) 00202 { 00203 loopsms.append_unique( myLoop ); 00204 } 00205 00206 void FacetCoEdge::coedgesms(DLIList<CoEdgeSM*> &coedgesms) 00207 { 00208 coedgesms.append_unique( this ); 00209 } 00210 00211 void FacetCoEdge::curves(DLIList<Curve*> &curves) 00212 { 00213 curves.append_unique( myCurve ); 00214 } 00215 00216 void FacetCoEdge::points(DLIList<Point*> &points) 00217 { 00218 myCurve->points( points ); 00219 } 00220 */ 00221 00222 void FacetCoEdge::get_parents_virt( DLIList<TopologyBridge*>& parents ) 00223 { parents.append( myLoop ); } 00224 00225 void FacetCoEdge::get_children_virt( DLIList<TopologyBridge*>& children ) 00226 { children.append( myCurve ); } 00227 00228 void FacetCoEdge::reverse_sense() 00229 { 00230 edgeSense = CubitUtil::opposite_sense( edgeSense ); 00231 } 00232 00233 00234 void FacetCoEdge::get_lumps( DLIList<FacetLump*>& result_list ) 00235 { 00236 DLIList<FacetShell*> shell_list; 00237 get_shells( shell_list ); 00238 shell_list.reset(); 00239 for ( int i = shell_list.size(); i--; ) 00240 { 00241 FacetShell* shell = shell_list.get_and_step(); 00242 shell->get_lumps( result_list ); 00243 FacetLump* lump = dynamic_cast<FacetLump*>(shell->get_lump()); 00244 if (lump) 00245 result_list.append_unique(lump); 00246 } 00247 } 00248 00249 void FacetCoEdge::get_shells( DLIList<FacetShell*>& result_list ) 00250 { 00251 if ( FacetLoop* loop = dynamic_cast<FacetLoop*>(myLoop) ) 00252 if ( FacetSurface* surf = dynamic_cast<FacetSurface*>(loop->get_surface()) ) 00253 surf->get_shells( result_list ); 00254 } 00255 00256 void FacetCoEdge::get_curves( DLIList<FacetCurve*>& result_list ) 00257 { 00258 if (FacetCurve* curve = dynamic_cast<FacetCurve*>(myCurve)) 00259 result_list.append(curve); 00260 } 00261 00262 00263 // ********** END PUBLIC FUNCTIONS ********** 00264 00265 // ********** BEGIN PROTECTED FUNCTIONS ********** 00266 // ********** END PROTECTED FUNCTIONS ********** 00267 00268 // ********** BEGIN PRIVATE FUNCTIONS ********** 00269 // ********** END PRIVATE FUNCTIONS ********** 00270 00271 // ********** BEGIN HELPER CLASSES ********** 00272 // ********** END HELPER CLASSES ********** 00273 00274 // ********** BEGIN EXTERN FUNCTIONS ********** 00275 // ********** END EXTERN FUNCTIONS ********** 00276 00277 // ********** BEGIN STATIC FUNCTIONS ********** 00278 // ********** END STATIC FUNCTIONS ********** 00279
