cgma
00001 //------------------------------------------------------------------------- 00002 // Filename : FacetLoop.cpp 00003 // 00004 // Purpose : Loops for Facet-based geometry module 00005 // 00006 // Special Notes : 00007 // 00008 // Creator : Steven J. Owen 00009 // 00010 // Creation Date : 12/06/00 00011 // 00012 // Owner : Steven J. Owen 00013 //------------------------------------------------------------------------- 00014 00015 #include "CastTo.hpp" 00016 #include "FacetLoop.hpp" 00017 #include "FacetQueryEngine.hpp" 00018 #include "CoEdgeSM.hpp" 00019 00020 #include "FacetBody.hpp" 00021 #include "FacetLump.hpp" 00022 #include "FacetShell.hpp" 00023 #include "FacetSurface.hpp" 00024 #include "FacetCoEdge.hpp" 00025 #include "FacetCurve.hpp" 00026 #include "FacetPoint.hpp" 00027 // ********** END CUBIT INCLUDES ********** 00028 00029 // ********** BEGIN STATIC DECLARATIONS ********** 00030 // ********** END STATIC DECLARATIONS ********** 00031 00032 // ********** BEGIN PUBLIC FUNCTIONS ********** 00033 00034 //------------------------------------------------------------------------- 00035 // Purpose : The constructor with a pointer to the FacetEvalTool. 00036 // 00037 // Special Notes : 00038 // 00039 //------------------------------------------------------------------------- 00040 FacetLoop::FacetLoop( Surface *surf_ptr, 00041 DLIList<CoEdgeSM*> &coedge_list ) 00042 { 00043 mySurface = surf_ptr; 00044 myCoEdges += coedge_list; 00045 } 00046 00047 //------------------------------------------------------------------------- 00048 // Purpose : The constructor with coedges. 00049 // 00050 // Special Notes : 00051 // 00052 //------------------------------------------------------------------------- 00053 FacetLoop::FacetLoop( DLIList<CoEdgeSM*> &coedge_list ) 00054 { 00055 myCoEdges += coedge_list; 00056 } 00057 00058 //------------------------------------------------------------------------- 00059 // Purpose : The default destructor. 00060 // 00061 // Special Notes : 00062 // 00063 //------------------------------------------------------------------------- 00064 FacetLoop::~FacetLoop() 00065 { 00066 } 00067 00068 //------------------------------------------------------------------------- 00069 // Purpose : The purpose of this function is to see if a loop is an external 00070 // or internal loop of a surface. 00071 // 00072 // Special Notes : 00073 // 00074 // Creator : Jonathan Bugman 00075 // 00076 // Creation Date : 9/9/2008 00077 //------------------------------------------------------------------------- 00078 CubitBoolean FacetLoop::is_external() 00079 { 00080 PRINT_ERROR( "This command is not supported with this engine.\n"); 00081 return CUBIT_FAILURE; 00082 } 00083 00084 LoopType FacetLoop::loop_type() 00085 { 00086 return LOOP_TYPE_UNKNOWN; 00087 } 00088 00089 //------------------------------------------------------------------------- 00090 // Purpose : The purpose of this function is to append a 00091 // attribute to the GE. The name is attached to the 00092 // underlying solid model entity this one points to. 00093 // 00094 // 00095 // Special Notes : 00096 // 00097 //------------------------------------------------------------------------- 00098 void FacetLoop::append_simple_attribute_virt(const CubitSimpleAttrib& /*csattrib_ptr*/) 00099 { 00100 //PRINT_ERROR("FacetLoop::append_simple_attribute_virt not defined\n"); 00101 return; 00102 00103 } 00104 00105 //------------------------------------------------------------------------- 00106 // Purpose : The purpose of this function is to remove a simple 00107 // attribute attached to this geometry entity. The name is 00108 // removed from the underlying BODY this points to. 00109 // 00110 // Special Notes : 00111 // 00112 //------------------------------------------------------------------------- 00113 void FacetLoop::remove_simple_attribute_virt(const CubitSimpleAttrib& /*csattrib_ptr*/) 00114 { 00115 //PRINT_ERROR("FacetLoop::remove_simple_attribute_virt not defined\n"); 00116 return; 00117 } 00118 00119 //------------------------------------------------------------------------- 00120 // Purpose : The purpose of this function is to remove all simple 00121 // attributes attached to this geometry entity. Also 00122 // removes lingering GTC attributes. 00123 // 00124 // 00125 // Special Notes : 00126 // 00127 //------------------------------------------------------------------------- 00128 void FacetLoop::remove_all_simple_attribute_virt() 00129 { 00130 //PRINT_ERROR(" FacetLoop::remove_all_simple_attribute_virt not defined\n"); 00131 return; 00132 } 00133 00134 //------------------------------------------------------------------------- 00135 // Purpose : The purpose of this function is to get the 00136 // attributes attached to this geometry entity. The name is 00137 // attached to the underlying BODY this points to. 00138 // 00139 // Special Notes : 00140 // 00141 //------------------------------------------------------------------------- 00142 CubitStatus FacetLoop::get_simple_attribute(DLIList<CubitSimpleAttrib>& 00143 /*cubit_simple_attrib_list*/) 00144 { 00145 //PRINT_ERROR("FacetLoop::get_simple_attribute not defined\n"); 00146 return CUBIT_FAILURE; 00147 } 00148 CubitStatus FacetLoop::get_simple_attribute(const CubitString&, 00149 DLIList<CubitSimpleAttrib>&) 00150 { return CUBIT_FAILURE; } 00151 00152 //------------------------------------------------------------------------- 00153 // Purpose : compute bounding box of loop 00154 // 00155 // Special Notes : 00156 // 00157 //------------------------------------------------------------------------- 00158 CubitBox FacetLoop::bounding_box() const 00159 { 00160 CubitBox box; 00161 //PRINT_ERROR("FacetLoop::bounding_box not implemented\n"); 00162 return box; 00163 } 00164 00165 //------------------------------------------------------------------------- 00166 // Purpose : Get geometry modeling engine: FacetQueryEngine 00167 // 00168 // Special Notes : 00169 // 00170 //------------------------------------------------------------------------- 00171 GeometryQueryEngine* FacetLoop::get_geometry_query_engine() const 00172 { 00173 return FacetQueryEngine::instance(); 00174 } 00175 00176 /* 00177 void FacetLoop::bodysms(DLIList<BodySM*> &bodies) 00178 { 00179 mySurface->bodysms(bodies); 00180 } 00181 00182 void FacetLoop::lumps(DLIList<Lump*> &lumps) 00183 { 00184 mySurface->lumps(lumps); 00185 } 00186 00187 void FacetLoop::shellsms(DLIList<ShellSM*> &shellsms) 00188 { 00189 mySurface->shellsms(shellsms); 00190 } 00191 00192 void FacetLoop::surfaces(DLIList<Surface*> &surfaces) 00193 { 00194 surfaces.append_unique( mySurface ); 00195 } 00196 00197 void FacetLoop::loopsms(DLIList<LoopSM*> &loopsms) 00198 { 00199 loopsms.append_unique( this ); 00200 } 00201 void FacetLoop::coedgesms(DLIList<CoEdgeSM*> &coedgesms) 00202 { 00203 int ii; 00204 for ( ii = myCoEdges.size(); ii > 0; ii-- ) 00205 { 00206 coedgesms.append_unique(myCoEdges.get_and_step()); 00207 } 00208 } 00209 00210 void FacetLoop::curves(DLIList<Curve*> &curves) 00211 { 00212 int ii; 00213 for ( ii = myCoEdges.size(); ii > 0; ii-- ) 00214 { 00215 myCoEdges.get_and_step()->curves(curves); 00216 } 00217 } 00218 void FacetLoop::points(DLIList<Point*> &points) 00219 { 00220 int ii; 00221 for ( ii = myCoEdges.size(); ii > 0; ii-- ) 00222 { 00223 myCoEdges.get_and_step()->points(points); 00224 } 00225 } 00226 */ 00227 00228 00229 void FacetLoop::get_parents_virt( DLIList<TopologyBridge*>& parents ) 00230 { parents.append( mySurface ); } 00231 void FacetLoop::get_children_virt( DLIList<TopologyBridge*>& children ) 00232 { CAST_LIST_TO_PARENT( myCoEdges, children ); } 00233 00234 00235 void FacetLoop::get_lumps( DLIList<FacetLump*>& result_list ) 00236 { 00237 DLIList<FacetShell*> shell_list; 00238 get_shells( shell_list ); 00239 shell_list.reset(); 00240 for ( int i = shell_list.size(); i--; ) 00241 { 00242 FacetShell* shell = shell_list.get_and_step(); 00243 shell->get_lumps( result_list ); 00244 FacetLump* lump = dynamic_cast<FacetLump*>(shell->get_lump()); 00245 if (lump) 00246 result_list.append_unique(lump); 00247 } 00248 } 00249 00250 void FacetLoop::get_shells( DLIList<FacetShell*>& result_list ) 00251 { 00252 if ( FacetSurface* surf = dynamic_cast<FacetSurface*>(mySurface) ) 00253 surf->get_shells( result_list ); 00254 } 00255 00256 void FacetLoop::get_coedges( DLIList<FacetCoEdge*>& result_list ) 00257 { 00258 myCoEdges.reset(); 00259 for ( int i = 0; i < myCoEdges.size(); i++ ) 00260 if (FacetCoEdge* coedge = dynamic_cast<FacetCoEdge*>(myCoEdges.next(i))) 00261 result_list.append( coedge ); 00262 } 00263 00264 void FacetLoop::get_curves( DLIList<FacetCurve*>& result_list ) 00265 { 00266 DLIList<FacetCoEdge*> coedge_list; 00267 get_coedges( coedge_list ); 00268 coedge_list.reset(); 00269 for ( int i = coedge_list.size(); i--; ) 00270 { 00271 FacetCoEdge* coedge = coedge_list.get_and_step(); 00272 FacetCurve* curve = dynamic_cast<FacetCurve*>(coedge->curve()); 00273 if (curve) 00274 result_list.append_unique(curve); 00275 } 00276 } 00277 00278 00279 //------------------------------------------------------------------------- 00280 // Purpose : Tear down topology 00281 // 00282 // Special Notes : 00283 // 00284 // Creator : Jason Kraftcheck 00285 // 00286 // Creation Date : 09/29/03 00287 //------------------------------------------------------------------------- 00288 void FacetLoop::disconnect_all_coedges() 00289 { 00290 myCoEdges.reset(); 00291 for (int i = myCoEdges.size(); i--; ) 00292 { 00293 CoEdgeSM* sm_ptr = myCoEdges.get_and_step(); 00294 FacetCoEdge* coedge = dynamic_cast<FacetCoEdge*>(sm_ptr); 00295 if (coedge) 00296 { 00297 assert(coedge->get_loop() == this); 00298 coedge->remove_loop(); 00299 } 00300 } 00301 myCoEdges.clean_out(); 00302 } 00303 00304
