cgma
00001 //----------------------------------------------------------------------------- 00002 // Filename : GeometryHealerTool.cpp 00003 // 00004 // Purpose : Define the healer interface for all solid modeling engines. 00005 // 00006 // Special Notes : This is a singleton pattern class for the healer functions. 00007 // 00008 // Creator : Tyronne Lim (CAT) 00009 // 00010 // Creation Date : 7/21/03 00011 // 00012 // Owner : 00013 //----------------------------------------------------------------------------- 00014 00015 // *** BEGIN INCLUDES *** // 00016 00017 #include "GeometryHealerTool.hpp" 00018 00019 #include "GeometryHealerEngine.hpp" 00020 00021 #include "Body.hpp" 00022 00023 #include "RefEntityFactory.hpp" 00024 #include "TopologyEntity.hpp" 00025 00026 #include "CastTo.hpp" 00027 #include "CubitMessage.hpp" 00028 #include "RefFace.hpp" 00029 #include "AppUtil.hpp" 00030 #include "CubitOperationEvent.hpp" 00031 00032 #include "MergeTool.hpp" 00033 00034 // *** END INCLUDES *** // 00035 00036 GeometryHealerTool* GeometryHealerTool::instance_ = 0; 00037 00038 // *** BEGIN PUBLIC FUNCTIONS *** // 00039 00040 //----------------------------------------------------------------------------- 00041 // Purpose : Controls access/creation of the sole instance of this class. 00042 // 00043 // Creator : Tyronne Lim (CAT) 00044 // 00045 // Creation Date : 07/21/03 00046 //----------------------------------------------------------------------------- 00047 GeometryHealerTool* GeometryHealerTool::instance( GeometryHealerEngine *GHEPtr ) 00048 { 00049 // Check to see if we have created an instance of the class; 00050 // if not, proceed to create one. 00051 if (instance_ == 0) 00052 { 00053 // When creating the instance, we should always have a valid 00054 // ghePtr. If not, complain. 00055 instance_ = new GeometryHealerTool(GHEPtr); 00056 00057 // Check to make sure there's a ref entity factory extant: 00058 // RefEntityFactory *factory = 00059 RefEntityFactory::instance(); 00060 } 00061 // If there is an existing instance of the class, check if there 00062 // is a request to set the default engine. If so, do so. 00063 else if ( GHEPtr != NULL && !instance_->gheList.move_to(GHEPtr) ) 00064 { 00065 delete instance_->gheList.remove(); 00066 instance_->gheList.insert(GHEPtr); 00067 } 00068 00069 // Return the a pointer to the instance of the class. 00070 return instance_; 00071 } 00072 00073 //----------------------------------------------------------------------------- 00074 // Purpose : Destructor. 00075 // 00076 // Creator : Tyronne Lim (CAT) 00077 // 00078 // Creation Date : 07/21/03 00079 //----------------------------------------------------------------------------- 00080 GeometryHealerTool::~GeometryHealerTool() 00081 { 00082 for (int i = gheList.size(); i > 0; i--) 00083 delete gheList.get_and_step(); 00084 00085 gheList.clean_out(); 00086 instance_ = NULL; 00087 } 00088 00089 // *** BEGIN ENGINE OPERATIONS *** // 00090 /* 00091 //----------------------------------------------------------------------------- 00092 // Purpose : Sets the default engine. 00093 // 00094 // Creator : Tyronne Lim (CAT) 00095 // 00096 // Creation Date : 07/21/03 00097 //----------------------------------------------------------------------------- 00098 void GeometryHealerTool::set_default_engine( GeometryHealerEngine *ghe_ptr ) 00099 { 00100 default_ghe = ghe_ptr; 00101 } 00102 */ 00103 //----------------------------------------------------------------------------- 00104 // Purpose : Adds a healer engine to the list. 00105 // 00106 // Creator : Tyronne Lim (CAT) 00107 // 00108 // Creation Date : 07/21/03 00109 //----------------------------------------------------------------------------- 00110 void GeometryHealerTool::add_ghe( GeometryHealerEngine *ghe_ptr ) 00111 { 00112 assert(ghe_ptr != 0); 00113 00114 // for now, GeometryHealerTool is only set up for a single healer engine 00115 // so if more than one healer is being added all the code for this class needs 00116 // to be reviewed - Byron 08/12/2003 00117 assert(gheList.size() == 0); 00118 00119 if (!gheList.move_to(ghe_ptr)) 00120 gheList.append(ghe_ptr); 00121 } 00122 /* 00123 //----------------------------------------------------------------------------- 00124 // Purpose : Removes a healer engine from the list. 00125 // 00126 // Creator : Tyronne Lim (CAT) 00127 // 00128 // Creation Date : 07/21/03 00129 //----------------------------------------------------------------------------- 00130 CubitStatus GeometryHealerTool::remove_ghe( GeometryHealerEngine *ghe_ptr ) 00131 { 00132 assert(ghe_ptr != 0); 00133 CubitStatus status = CUBIT_FAILURE; 00134 00135 if (gheList.move_to(ghe_ptr)) 00136 { 00137 gheList.remove(); 00138 status = CUBIT_SUCCESS; 00139 } 00140 00141 return status; 00142 } 00143 00144 //----------------------------------------------------------------------------- 00145 // Purpose : Gets the list of healer engines. 00146 // 00147 // Creator : Tyronne Lim (CAT) 00148 // 00149 // Creation Date : 07/21/03 00150 //----------------------------------------------------------------------------- 00151 void GeometryHealerTool::get_ghe_list( DLIList<GeometryHealerEngine*> &ghe_list ) 00152 { 00153 ghe_list += gheList; 00154 } 00155 00156 //----------------------------------------------------------------------------- 00157 // Purpose : Gets the current healer engine (first in the list). 00158 // 00159 // Creator : Tyronne Lim (CAT) 00160 // 00161 // Creation Date : 07/21/03 00162 //----------------------------------------------------------------------------- 00163 GeometryHealerEngine *GeometryHealerTool::get_ghe() 00164 { 00165 GeometryHealerEngine *ghe = NULL; 00166 00167 if (gheList.size()) 00168 { 00169 gheList.reset(); 00170 ghe = gheList.get(); 00171 } 00172 00173 return ghe; 00174 } 00175 */ 00176 //----------------------------------------------------------------------------- 00177 // Purpose : Returns the healer engine of an entity. 00178 // 00179 // Creator : Tyronne Lim (CAT) 00180 // 00181 // Creation Date : 08/01/03 00182 //----------------------------------------------------------------------------- 00183 GeometryHealerEngine* GeometryHealerTool::get_engine( TopologyBridge *tb_ptr ) const 00184 { 00185 GeometryHealerEngine *ghe; 00186 00187 for (int i = 0; i < gheList.size(); i++) 00188 { 00189 ghe = gheList.next(i); 00190 if (ghe->is_healer_engine(tb_ptr)) 00191 return ghe; 00192 } 00193 00194 return NULL; 00195 } 00196 00197 //----------------------------------------------------------------------------- 00198 // Purpose : Returns the healer engine of an entity. 00199 // 00200 // Creator : Tyronne Lim (CAT) 00201 // 00202 // Creation Date : 08/01/03 00203 //----------------------------------------------------------------------------- 00204 GeometryHealerEngine* GeometryHealerTool::get_engine( TopologyEntity *te_ptr ) const 00205 { 00206 GeometryHealerEngine *ghe; 00207 00208 TopologyBridge *tb_ptr = te_ptr->bridge_manager()->topology_bridge(); 00209 00210 for (int i = 0; i < gheList.size(); i++) 00211 { 00212 ghe = gheList.next(i); 00213 if (ghe->is_healer_engine(tb_ptr)) 00214 return ghe; 00215 } 00216 00217 return NULL; 00218 } 00219 00220 //----------------------------------------------------------------------------- 00221 // Purpose : Determines if entities are from the same engine. 00222 // 00223 // Creator : Tyronne Lim (CAT) 00224 // 00225 // Creation Date : 08/01/03 00226 //----------------------------------------------------------------------------- 00227 CubitBoolean GeometryHealerTool::same_healer_engine( DLIList<RefEntity*> &ref_entity_list, 00228 CubitBoolean check_children ) const 00229 { 00230 DLIList<RefEntity*> complete_entity_list; 00231 00232 //Check the check_children option and check all the children if necessary 00233 if (check_children) 00234 { 00235 //Make a complete list of all the RefEntities and their children 00236 DLIList<RefEntity*> temp = ref_entity_list; 00237 RefEntity* ref_entity_ptr; 00238 00239 for (int i = 0; i < ref_entity_list.size(); i++) 00240 { 00241 ref_entity_ptr = ref_entity_list.get_and_step(); 00242 complete_entity_list.clean_out(); 00243 ref_entity_ptr->get_all_child_ref_entities(complete_entity_list); 00244 temp += complete_entity_list; 00245 } 00246 00247 complete_entity_list.clean_out(); 00248 complete_entity_list.merge_unique(temp); 00249 } 00250 00251 //Now make sure all the RefEntities are from the same geometry engine 00252 DLIList<TopologyEntity*> te_list; 00253 CAST_LIST(complete_entity_list, te_list, TopologyEntity); 00254 return same_healer_engine(te_list); 00255 } 00256 00257 //----------------------------------------------------------------------------- 00258 // Purpose : Determines if entities are from the same engine. 00259 // 00260 // Creator : Tyronne Lim (CAT) 00261 // 00262 // Creation Date : 08/01/03 00263 //----------------------------------------------------------------------------- 00264 CubitBoolean GeometryHealerTool::same_healer_engine( DLIList<TopologyEntity*> &topo_list ) const 00265 { 00266 GeometryHealerEngine *gePtr1 = get_engine(topo_list.get_and_step()); 00267 GeometryHealerEngine *gePtr2; 00268 00269 for (int i = 1; i < topo_list.size(); i++) 00270 { 00271 gePtr2 = get_engine(topo_list.get_and_step()); 00272 if (gePtr1 != gePtr2) 00273 { 00274 return CUBIT_FALSE; 00275 } 00276 } 00277 return CUBIT_TRUE; 00278 } 00279 00280 // *** END ENGINE OPERATIONS *** // 00281 00282 // *** BEGIN HEALER FUNCTIONS *** // 00283 00284 CubitStatus GeometryHealerTool::auto_heal_bodies( DLIList<Body*> &body_list, 00285 DLIList<Body*> &new_body_list, 00286 DLIList<TopologyEntity*> &bad_geometry, 00287 CubitBoolean rebuild, CubitBoolean keep_old, 00288 CubitBoolean make_tolerant, FILE* logfile_ptr ) 00289 { 00290 DLIList<RefEntity*> ref_entity_list; 00291 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00292 00293 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00294 { 00295 PRINT_ERROR("HEALING bodies from different\n" 00296 " geometry engines is not allowed.\n"); 00297 return CUBIT_FAILURE; 00298 } 00299 00300 if(rebuild && !keep_old) 00301 { 00302 MergeTool::instance()->unmerge(ref_entity_list); 00303 } 00304 00305 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00306 if (GHEPtr) 00307 { 00308 CubitStatus healer_status = GHEPtr->auto_heal_bodies(body_list, new_body_list, bad_geometry, 00309 rebuild, keep_old, make_tolerant, logfile_ptr); 00310 00311 // if( healer_status == CUBIT_SUCCESS ) 00312 AppUtil::instance()->send_event(CubitOperationEvent(CubitOperationEvent::HEALER_COMPLETED)); 00313 00314 return healer_status; 00315 } 00316 else 00317 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00318 " and cannot be healed.\n"); 00319 return CUBIT_FAILURE; 00320 } 00321 00322 CubitStatus GeometryHealerTool::heal_bodies( DLIList<Body*> &body_list, 00323 DLIList<Body*> &new_body_list, 00324 DLIList<TopologyEntity*> &bad_geometry, 00325 CubitBoolean rebuild, CubitBoolean keep_old, 00326 CubitBoolean make_tolerant, FILE* logfile_ptr ) 00327 { 00328 DLIList<RefEntity*> ref_entity_list; 00329 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00330 00331 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00332 { 00333 PRINT_ERROR("HEALING bodies from different\n" 00334 " geometry engines is not allowed.\n"); 00335 return CUBIT_FAILURE; 00336 } 00337 00338 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00339 if (GHEPtr) 00340 return GHEPtr->heal_bodies(body_list, new_body_list, bad_geometry, 00341 rebuild, keep_old, make_tolerant, logfile_ptr); 00342 else 00343 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00344 " and cannot be healed.\n"); 00345 return CUBIT_FAILURE; 00346 } 00347 00348 CubitStatus GeometryHealerTool::analyze_badgeom( DLIList<Body*> &body_list, 00349 DLIList<TopologyEntity*> &bad_geometry, 00350 FILE* logfile) 00351 { 00352 DLIList<RefEntity*> ref_entity_list; 00353 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00354 00355 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00356 { 00357 PRINT_ERROR("HEALING bodies from different\n" 00358 " geometry engines is not allowed.\n"); 00359 return CUBIT_FAILURE; 00360 } 00361 00362 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00363 if (GHEPtr) 00364 return GHEPtr->analyze_badgeom(body_list, bad_geometry, logfile); 00365 else 00366 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00367 " and cannot be healed.\n"); 00368 return CUBIT_FAILURE; 00369 } 00370 00371 CubitStatus GeometryHealerTool::get_badgeom( DLIList<Body*> &body_list, 00372 DLIList<TopologyEntity*> &bad_geometry ) 00373 { 00374 DLIList<RefEntity*> ref_entity_list; 00375 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00376 00377 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00378 { 00379 PRINT_ERROR("HEALING bodies from different\n" 00380 " geometry engines is not allowed.\n"); 00381 return CUBIT_FAILURE; 00382 } 00383 00384 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00385 if (GHEPtr) 00386 return GHEPtr->get_badgeom(body_list, bad_geometry); 00387 else 00388 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00389 " and cannot be healed.\n"); 00390 return CUBIT_FAILURE; 00391 } 00392 00393 CubitStatus GeometryHealerTool::get_tcurves( DLIList<Body*> &body_list, 00394 DLIList<RefEdge*> &t_curves ) 00395 { 00396 DLIList<RefEntity*> ref_entity_list; 00397 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00398 00399 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00400 { 00401 PRINT_ERROR("HEALING bodies from different\n" 00402 " geometry engines is not allowed.\n"); 00403 return CUBIT_FAILURE; 00404 } 00405 00406 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00407 if (GHEPtr) 00408 return GHEPtr->get_tcurves(body_list, t_curves); 00409 else 00410 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00411 " and cannot be healed.\n"); 00412 return CUBIT_FAILURE; 00413 } 00414 00415 CubitStatus GeometryHealerTool::heal_incremental( DLIList<Body*> &body_list, 00416 DLIList<Body*> &new_bodies, 00417 DLIList<TopologyEntity*> &bad_geometry, 00418 double simplify_tol, double stitch_min_tol, 00419 double stitch_max_tol, double geombuild_tol, 00420 double analytic_tol, double isospline_tol, 00421 double reblend_classify_tol, double reblend_tol, 00422 CubitBoolean keep_old, CubitBoolean make_tolerant, 00423 FILE* logfile_ptr ) 00424 { 00425 DLIList<RefEntity*> ref_entity_list; 00426 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00427 00428 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00429 { 00430 PRINT_ERROR("HEALING bodies from different\n" 00431 " geometry engines is not allowed.\n"); 00432 return CUBIT_FAILURE; 00433 } 00434 00435 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00436 if (GHEPtr) 00437 return GHEPtr->heal_incremental(body_list, new_bodies, bad_geometry, simplify_tol, 00438 stitch_min_tol, stitch_max_tol, geombuild_tol, 00439 analytic_tol, isospline_tol, reblend_classify_tol, 00440 reblend_tol, keep_old, make_tolerant, logfile_ptr); 00441 else 00442 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00443 " and cannot be healed.\n"); 00444 return CUBIT_FAILURE; 00445 } 00446 00447 void GeometryHealerTool::list_incremental() 00448 { 00449 gheList.get()->list_incremental(); 00450 } 00451 00452 void GeometryHealerTool::list_tolerances( DLIList<Body*> &body_list ) 00453 { 00454 DLIList<RefEntity*> ref_entity_list; 00455 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00456 00457 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00458 { 00459 PRINT_ERROR("HEALING bodies from different\n" 00460 " geometry engines is not allowed.\n"); 00461 } 00462 00463 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00464 if (GHEPtr) 00465 GHEPtr->list_tolerances(body_list); 00466 else 00467 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00468 " and cannot be healed.\n"); 00469 } 00470 00471 double GeometryHealerTool::get_default_simplify_tol() 00472 { 00473 return gheList.get()->get_default_simplify_tol(); 00474 } 00475 00476 void GeometryHealerTool::set_default_simplify_tol( double tol ) 00477 { 00478 gheList.get()->set_default_simplify_tol(tol); 00479 } 00480 00481 double GeometryHealerTool::get_default_stitch_min_tol() 00482 { 00483 return gheList.get()->get_default_stitch_min_tol(); 00484 } 00485 00486 void GeometryHealerTool::set_default_stitch_min_tol( double tol ) 00487 { 00488 gheList.get()->set_default_stitch_min_tol(tol); 00489 } 00490 00491 double GeometryHealerTool::get_default_stitch_max_tol() 00492 { 00493 return gheList.get()->get_default_stitch_max_tol(); 00494 } 00495 00496 void GeometryHealerTool::set_default_stitch_max_tol( double tol ) 00497 { 00498 gheList.get()->set_default_stitch_max_tol(tol); 00499 } 00500 00501 double GeometryHealerTool::get_default_geombuild_tol() 00502 { 00503 return gheList.get()->get_default_geombuild_tol(); 00504 } 00505 00506 void GeometryHealerTool::set_default_geombuild_tol( double tol ) 00507 { 00508 gheList.get()->set_default_geombuild_tol(tol); 00509 } 00510 00511 double GeometryHealerTool::get_default_analytic_tol() 00512 { 00513 return gheList.get()->get_default_analytic_tol(); 00514 } 00515 00516 void GeometryHealerTool::set_default_analytic_tol( double tol ) 00517 { 00518 gheList.get()->set_default_analytic_tol(tol); 00519 } 00520 00521 double GeometryHealerTool::get_default_isospline_tol() 00522 { 00523 return gheList.get()->get_default_isospline_tol(); 00524 } 00525 00526 void GeometryHealerTool::set_default_isospline_tol( double tol ) 00527 { 00528 gheList.get()->set_default_isospline_tol(tol); 00529 } 00530 00531 double GeometryHealerTool::get_default_reblend_classify_tol() 00532 { 00533 return gheList.get()->get_default_reblend_classify_tol(); 00534 } 00535 00536 void GeometryHealerTool::set_default_reblend_classify_tol( double tol ) 00537 { 00538 gheList.get()->set_default_reblend_classify_tol(tol); 00539 } 00540 00541 double GeometryHealerTool::get_default_reblend_tol() 00542 { 00543 return gheList.get()->get_default_reblend_tol(); 00544 } 00545 00546 void GeometryHealerTool::set_default_reblend_tol( double tol ) 00547 { 00548 gheList.get()->set_default_reblend_tol(tol); 00549 } 00550 00551 void GeometryHealerTool::reset_default_tolerances() 00552 { 00553 gheList.get()->reset_default_tolerances(); 00554 } 00555 00556 void GeometryHealerTool::list_default_tolerances() 00557 { 00558 gheList.get()->list_default_tolerances(); 00559 } 00560 00561 void GeometryHealerTool::clean_attributes( DLIList<Body*>& body_list ) 00562 { 00563 DLIList<RefEntity*> ref_entity_list; 00564 CAST_LIST_TO_PARENT(body_list, ref_entity_list); 00565 00566 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00567 { 00568 PRINT_ERROR("HEALING bodies from different\n" 00569 " geometry engines is not allowed.\n"); 00570 } 00571 00572 GeometryHealerEngine* GHEPtr = get_engine(body_list.get()); 00573 if (GHEPtr) 00574 GHEPtr->clean_attributes(body_list); 00575 else 00576 PRINT_ERROR( "Bodies are of a geometry engine without a healer\n" 00577 " and cannot be healed.\n"); 00578 } 00579 00580 CubitBoolean GeometryHealerTool::get_cleanatt_flg() 00581 { 00582 return gheList.get()->get_cleanatt_flg(); 00583 } 00584 00585 void GeometryHealerTool::set_cleanatt_flg( CubitBoolean flg ) 00586 { 00587 gheList.get()->set_cleanatt_flg(flg); 00588 } 00589 00590 int GeometryHealerTool::get_show_method() 00591 { 00592 return gheList.get()->get_show_method(); 00593 } 00594 00595 void GeometryHealerTool::set_show_method( int method ) 00596 { 00597 gheList.get()->set_show_method(method); 00598 } 00599 00600 CubitBoolean GeometryHealerTool::get_show_summary_flg() 00601 { 00602 return gheList.get()->get_show_summary_flg(); 00603 } 00604 00605 void GeometryHealerTool::set_show_summary_flg( CubitBoolean flg ) 00606 { 00607 gheList.get()->set_show_summary_flg(flg); 00608 } 00609 00610 CubitBoolean GeometryHealerTool::get_show_details_flg() 00611 { 00612 return gheList.get()->get_show_details_flg(); 00613 } 00614 00615 void GeometryHealerTool::set_show_details_flg( CubitBoolean flg ) 00616 { 00617 gheList.get()->set_show_details_flg(flg); 00618 } 00619 00620 CubitBoolean GeometryHealerTool::get_show_on_heal_flg() 00621 { 00622 return gheList.get()->get_show_on_heal_flg(); 00623 } 00624 00625 void GeometryHealerTool::set_show_on_heal_flg( CubitBoolean flg ) 00626 { 00627 gheList.get()->set_show_on_heal_flg(flg); 00628 } 00629 00630 CubitBoolean GeometryHealerTool::get_check_vol_on_heal_flg() 00631 { 00632 return gheList.get()->get_check_vol_on_heal_flg(); 00633 } 00634 00635 void GeometryHealerTool::set_check_vol_on_heal_flg( CubitBoolean flg ) 00636 { 00637 gheList.get()->set_check_vol_on_heal_flg(flg); 00638 } 00639 00640 double GeometryHealerTool::get_vol_on_heal_limit() 00641 { 00642 return gheList.get()->get_vol_on_heal_limit(); 00643 } 00644 00645 void GeometryHealerTool::set_vol_on_heal_limit( double limit ) 00646 { 00647 gheList.get()->set_vol_on_heal_limit(limit); 00648 } 00649 00650 CubitBoolean GeometryHealerTool::get_check_surf_on_heal_flg() 00651 { 00652 return gheList.get()->get_check_surf_on_heal_flg(); 00653 } 00654 00655 void GeometryHealerTool::set_check_surf_on_heal_flg( CubitBoolean flg ) 00656 { 00657 gheList.get()->set_check_surf_on_heal_flg(flg); 00658 } 00659 00660 double GeometryHealerTool::get_surf_on_heal_limit() 00661 { 00662 return gheList.get()->get_surf_on_heal_limit(); 00663 } 00664 00665 void GeometryHealerTool::set_surf_on_heal_limit( double limit ) 00666 { 00667 gheList.get()->set_surf_on_heal_limit(limit); 00668 } 00669 00670 CubitBoolean GeometryHealerTool::get_check_curve_on_heal_flg() 00671 { 00672 return gheList.get()->get_check_curve_on_heal_flg(); 00673 } 00674 00675 void GeometryHealerTool::set_check_curve_on_heal_flg( CubitBoolean flg ) 00676 { 00677 gheList.get()->set_check_curve_on_heal_flg(flg); 00678 } 00679 00680 double GeometryHealerTool::get_curve_on_heal_limit() 00681 { 00682 return gheList.get()->get_curve_on_heal_limit(); 00683 } 00684 00685 void GeometryHealerTool::set_curve_on_heal_limit( double limit ) 00686 { 00687 gheList.get()->set_curve_on_heal_limit(limit); 00688 } 00689 00690 CubitBoolean GeometryHealerTool::get_show_bad_vertices_flg() 00691 { 00692 return gheList.get()->get_show_bad_vertices_flg(); 00693 } 00694 00695 void GeometryHealerTool::set_show_bad_vertices_flg( CubitBoolean flg ) 00696 { 00697 gheList.get()->set_show_bad_vertices_flg(flg); 00698 } 00699 00700 CubitBoolean GeometryHealerTool::get_show_bad_curves_flg() 00701 { 00702 return gheList.get()->get_show_bad_curves_flg(); 00703 } 00704 00705 void GeometryHealerTool::set_show_bad_curves_flg( CubitBoolean flg ) 00706 { 00707 gheList.get()->set_show_bad_curves_flg(flg); 00708 } 00709 00710 CubitBoolean GeometryHealerTool::get_show_bad_coedges_flg() 00711 { 00712 return gheList.get()->get_show_bad_coedges_flg(); 00713 } 00714 00715 void GeometryHealerTool::set_show_bad_coedges_flg( CubitBoolean flg ) 00716 { 00717 gheList.get()->set_show_bad_coedges_flg(flg); 00718 } 00719 00720 CubitBoolean GeometryHealerTool::get_show_bad_loops_flg() 00721 { 00722 return gheList.get()->get_show_bad_loops_flg(); 00723 } 00724 00725 void GeometryHealerTool::set_show_bad_loops_flg( CubitBoolean flg ) 00726 { 00727 gheList.get()->set_show_bad_loops_flg(flg); 00728 } 00729 00730 CubitBoolean GeometryHealerTool::get_show_bad_surfaces_flg() 00731 { 00732 return gheList.get()->get_show_bad_surfaces_flg(); 00733 } 00734 00735 void GeometryHealerTool::set_show_bad_surfaces_flg( CubitBoolean flg ) 00736 { 00737 gheList.get()->set_show_bad_surfaces_flg(flg); 00738 } 00739 00740 CubitBoolean GeometryHealerTool::get_show_bad_shells_flg() 00741 { 00742 return gheList.get()->get_show_bad_shells_flg(); 00743 } 00744 00745 void GeometryHealerTool::set_show_bad_shells_flg( CubitBoolean flg ) 00746 { 00747 gheList.get()->set_show_bad_shells_flg(flg); 00748 } 00749 00750 CubitBoolean GeometryHealerTool::get_show_bad_volumes_flg() 00751 { 00752 return gheList.get()->get_show_bad_volumes_flg(); 00753 } 00754 00755 void GeometryHealerTool::set_show_bad_volumes_flg( CubitBoolean flg ) 00756 { 00757 gheList.get()->set_show_bad_volumes_flg(flg); 00758 } 00759 00760 CubitBoolean GeometryHealerTool::get_show_bad_bodies_flg() 00761 { 00762 return gheList.get()->get_show_bad_bodies_flg(); 00763 } 00764 00765 void GeometryHealerTool::set_show_bad_bodies_flg( CubitBoolean flg ) 00766 { 00767 gheList.get()->set_show_bad_bodies_flg(flg); 00768 } 00769 00770 void GeometryHealerTool::list_onshow_flgs() 00771 { 00772 gheList.get()->list_onshow_flgs(); 00773 } 00774 00775 CubitBoolean GeometryHealerTool::get_inc_preprocess_flg() 00776 { 00777 return gheList.get()->get_inc_preprocess_flg(); 00778 } 00779 00780 void GeometryHealerTool::set_inc_preprocess_flg( CubitBoolean flg ) 00781 { 00782 gheList.get()->set_inc_preprocess_flg(flg); 00783 } 00784 00785 CubitBoolean GeometryHealerTool::get_inc_simplify_flg() 00786 { 00787 return gheList.get()->get_inc_simplify_flg(); 00788 } 00789 00790 void GeometryHealerTool::set_inc_simplify_flg( CubitBoolean flg ) 00791 { 00792 gheList.get()->set_inc_simplify_flg(flg); 00793 } 00794 00795 CubitBoolean GeometryHealerTool::get_inc_stitch_flg() 00796 { 00797 return gheList.get()->get_inc_stitch_flg(); 00798 } 00799 00800 void GeometryHealerTool::set_inc_stitch_flg( CubitBoolean flg ) 00801 { 00802 gheList.get()->set_inc_stitch_flg(flg); 00803 } 00804 00805 CubitBoolean GeometryHealerTool::get_inc_geombuild_flg() 00806 { 00807 return gheList.get()->get_inc_geombuild_flg(); 00808 } 00809 00810 void GeometryHealerTool::set_inc_geombuild_flg( CubitBoolean flg ) 00811 { 00812 gheList.get()->set_inc_geombuild_flg(flg); 00813 } 00814 00815 CubitBoolean GeometryHealerTool::get_inc_analytic_flg() 00816 { 00817 return gheList.get()->get_inc_analytic_flg(); 00818 } 00819 00820 void GeometryHealerTool::set_inc_analytic_flg( CubitBoolean flg ) 00821 { 00822 gheList.get()->set_inc_analytic_flg(flg); 00823 } 00824 00825 CubitBoolean GeometryHealerTool::get_inc_isospline_flg() 00826 { 00827 return gheList.get()->get_inc_isospline_flg(); 00828 } 00829 00830 void GeometryHealerTool::set_inc_isospline_flg( CubitBoolean flg ) 00831 { 00832 gheList.get()->set_inc_isospline_flg(flg); 00833 } 00834 00835 CubitBoolean GeometryHealerTool::get_inc_reblend_flg() 00836 { 00837 return gheList.get()->get_inc_reblend_flg(); 00838 } 00839 00840 void GeometryHealerTool::set_inc_reblend_flg( CubitBoolean flg ) 00841 { 00842 gheList.get()->set_inc_reblend_flg(flg); 00843 } 00844 00845 CubitBoolean GeometryHealerTool::get_inc_sharpedge_flg() 00846 { 00847 return gheList.get()->get_inc_sharpedge_flg(); 00848 } 00849 00850 void GeometryHealerTool::set_inc_sharpedge_flg( CubitBoolean flg ) 00851 { 00852 gheList.get()->set_inc_sharpedge_flg(flg); 00853 } 00854 00855 CubitBoolean GeometryHealerTool::get_inc_genericspline_flg() 00856 { 00857 return gheList.get()->get_inc_genericspline_flg(); 00858 } 00859 00860 void GeometryHealerTool::set_inc_genericspline_flg( CubitBoolean flg ) 00861 { 00862 gheList.get()->set_inc_genericspline_flg(flg); 00863 } 00864 00865 CubitBoolean GeometryHealerTool::get_inc_wrapup_flg() 00866 { 00867 return gheList.get()->get_inc_wrapup_flg(); 00868 } 00869 00870 void GeometryHealerTool::set_inc_wrapup_flg( CubitBoolean flg ) 00871 { 00872 gheList.get()->set_inc_wrapup_flg(flg); 00873 } 00874 00875 CubitBoolean GeometryHealerTool::get_inc_postprocess_flg() 00876 { 00877 return gheList.get()->get_inc_postprocess_flg(); 00878 } 00879 00880 void GeometryHealerTool::set_inc_postprocess_flg( CubitBoolean flg ) 00881 { 00882 gheList.get()->set_inc_postprocess_flg(flg); 00883 } 00884 00885 CubitStatus GeometryHealerTool::force_simplify_to_plane( DLIList<RefFace*> &ref_face_list, 00886 DLIList<Body*>& new_body_list, 00887 CubitBoolean keep ) 00888 { 00889 ref_face_list.reset(); 00890 DLIList<RefEntity*> ref_entity_list(ref_face_list.size()); 00891 CAST_LIST_TO_PARENT( ref_face_list, ref_entity_list ); 00892 00893 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00894 { 00895 PRINT_ERROR("HEALING faces from different\n" 00896 " geometry engines is not allowed.\n"); 00897 return CUBIT_FAILURE; 00898 } 00899 00900 ref_face_list.reset(); 00901 GeometryHealerEngine* GHEPtr = get_engine((TopologyEntity*)(ref_face_list.get())); 00902 if (GHEPtr) 00903 return GHEPtr->force_simplify_to_plane(ref_face_list, new_body_list, keep); 00904 else 00905 PRINT_ERROR( "Faces are of a geometry engine without a healer\n" 00906 " and cannot be healed.\n"); 00907 return CUBIT_FAILURE; 00908 } 00909 00910 CubitStatus GeometryHealerTool::force_simplify_to_cylinder( DLIList<RefFace*> &ref_face_list, 00911 DLIList<Body*>& new_body_list, 00912 CubitBoolean keep ) 00913 { 00914 ref_face_list.reset(); 00915 DLIList<RefEntity*> ref_entity_list(ref_face_list.size()); 00916 CAST_LIST_TO_PARENT( ref_face_list, ref_entity_list ); 00917 00918 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00919 { 00920 PRINT_ERROR("HEALING faces from different\n" 00921 " geometry engines is not allowed.\n"); 00922 return CUBIT_FAILURE; 00923 } 00924 00925 ref_face_list.reset(); 00926 GeometryHealerEngine* GHEPtr = get_engine((TopologyEntity*)(ref_face_list.get())); 00927 if (GHEPtr) 00928 return GHEPtr->force_simplify_to_cylinder(ref_face_list, new_body_list, keep); 00929 else 00930 PRINT_ERROR( "Faces are of a geometry engine without a healer\n" 00931 " and cannot be healed.\n"); 00932 return CUBIT_FAILURE; 00933 } 00934 00935 CubitStatus GeometryHealerTool::force_simplify_to_cone( DLIList<RefFace*> &ref_face_list, 00936 DLIList<Body*>& new_body_list, 00937 CubitBoolean keep ) 00938 { 00939 ref_face_list.reset(); 00940 DLIList<RefEntity*> ref_entity_list(ref_face_list.size()); 00941 CAST_LIST_TO_PARENT( ref_face_list, ref_entity_list ); 00942 00943 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00944 { 00945 PRINT_ERROR("HEALING faces from different\n" 00946 " geometry engines is not allowed.\n"); 00947 return CUBIT_FAILURE; 00948 } 00949 00950 ref_face_list.reset(); 00951 GeometryHealerEngine* GHEPtr = get_engine((TopologyEntity*)(ref_face_list.get())); 00952 if (GHEPtr) 00953 return GHEPtr->force_simplify_to_cone(ref_face_list, new_body_list, keep); 00954 else 00955 PRINT_ERROR( "Faces are of a geometry engine without a healer\n" 00956 " and cannot be healed.\n"); 00957 return CUBIT_FAILURE; 00958 } 00959 00960 CubitStatus GeometryHealerTool::force_simplify_to_sphere( DLIList<RefFace*> &ref_face_list, 00961 DLIList<Body*>& new_body_list, 00962 CubitBoolean keep ) 00963 { 00964 ref_face_list.reset(); 00965 DLIList<RefEntity*> ref_entity_list(ref_face_list.size()); 00966 CAST_LIST_TO_PARENT( ref_face_list, ref_entity_list ); 00967 00968 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00969 { 00970 PRINT_ERROR("HEALING faces from different\n" 00971 " geometry engines is not allowed.\n"); 00972 return CUBIT_FAILURE; 00973 } 00974 00975 ref_face_list.reset(); 00976 GeometryHealerEngine* GHEPtr = get_engine((TopologyEntity*)(ref_face_list.get())); 00977 if (GHEPtr) 00978 return GHEPtr->force_simplify_to_sphere(ref_face_list, new_body_list, keep); 00979 else 00980 PRINT_ERROR( "Faces are of a geometry engine without a healer\n" 00981 " and cannot be healed.\n"); 00982 return CUBIT_FAILURE; 00983 } 00984 00985 CubitStatus GeometryHealerTool::force_simplify_to_torus( DLIList<RefFace*> &ref_face_list, 00986 DLIList<Body*>& new_body_list, 00987 CubitBoolean keep ) 00988 { 00989 ref_face_list.reset(); 00990 DLIList<RefEntity*> ref_entity_list(ref_face_list.size()); 00991 CAST_LIST_TO_PARENT( ref_face_list, ref_entity_list ); 00992 00993 if (!same_healer_engine(ref_entity_list, CUBIT_TRUE)) 00994 { 00995 PRINT_ERROR("HEALING faces from different\n" 00996 " geometry engines is not allowed.\n"); 00997 return CUBIT_FAILURE; 00998 } 00999 01000 ref_face_list.reset(); 01001 GeometryHealerEngine* GHEPtr = get_engine((TopologyEntity*)(ref_face_list.get())); 01002 if (GHEPtr) 01003 return GHEPtr->force_simplify_to_torus(ref_face_list, new_body_list, keep); 01004 else 01005 PRINT_ERROR( "Faces are of a geometry engine without a healer\n" 01006 " and cannot be healed.\n"); 01007 return CUBIT_FAILURE; 01008 } 01009 01010 // *** END HEALER FUNCTIONS *** // 01011 01012 // *** END PUBLIC FUNCTIONS *** // 01013 01014 // *** BEGIN PROTECTED FUNCTIONS *** // 01015 01016 //----------------------------------------------------------------------------- 01017 // Purpose : Constructor. 01018 // 01019 // Creator : Tyronne Lim (CAT) 01020 // 01021 // Creation Date : 07/21/03 01022 //----------------------------------------------------------------------------- 01023 GeometryHealerTool::GeometryHealerTool( GeometryHealerEngine* GHEPtr ) 01024 { 01025 if (GHEPtr != NULL) 01026 add_ghe(GHEPtr); 01027 } 01028 01029 // *** END PROTECTED FUNCTIONS *** // 01030 01031 // *** BEGIN PRIVATE FUNCTIONS *** // 01032 01033 // *** END PRIVATE FUNCTIONS *** //
